Debugging WebSocket Drops and Audio Latency in Genesys Cloud AppFoundry Integrations
- You will build a Python diagnostic service that monitors WebSocket connection stability and measures audio payload latency for a Genesys Cloud AppFoundry application.
- This tutorial uses the Genesys Cloud Platform API (REST) for configuration validation and raw WebSocket protocols for real-time traffic analysis.
- The programming language covered is Python 3.9+, using
requests,websocket-client, andpurecloudplatformclientv2.
OAuth and Scopes
- OAuth Client Type:
confidential(Client Credentials Grant). - Required Scopes:
appfoundry:app:read(To validate AppFoundry application configuration).analytics:events:read(To correlate WebSocket drops with platform-level disconnection events).user:read(For identifying the agent or user context if applicable).
SDK and Dependencies
- Genesys Cloud Python SDK:
purecloudplatformclientv2(Version 125.0.0 or higher). - External Libraries:
websocket-client(For raw WebSocket connection testing).requests(For REST API calls).pydantic(For data validation).
- Runtime: Python 3.9 or higher.
Installation
Run the following command to install the required dependencies:
pip install purecloudplatformclientv2 requests websocket-client pydantic
Before analyzing WebSocket stability, you must authenticate to the Genesys Cloud Platform. The diagnostic script requires a valid access token to query AppFoundry settings and analytics data.
Step 1: Configure Client Credentials
Create a .env file in your project root to store secrets. Never hardcode credentials.
# .env
GENESYS_REGION=us-east-1
GENESYS_CLIENT_ID=your_client_id_here
GENESYS_CLIENT_SECRET=your_client_secret_here
Step 2: Implement Token Retrieval
Use the requests library to obtain an OAuth token. This function includes exponential backoff logic to handle transient network issues during token acquisition.
import os
import requests
from typing import Optional
load_dotenv()
class GenesysAuth:
def __init__(self, region: str, client_id: str, client_secret: str):
self.region = region
self.client_id = client_id
self.base_url = f"https://api.{region}.mypurecloud.com"
self.token_url = f"{self.base_url}/oauth/token"
Retrieves an OAuth2 access token using Client Credentials Grant.
Implements basic retry logic for network stability.
headers = {
data = {
"client_id": self.client_id,
max_retries = 3
response = requests.post(self.token_url, headers=headers, data=data, timeout=10)
response.raise_for_status()
token_data = response.json()
return token_data["access_token"]
if attempt < max_retries - 1:
wait_time = 2 ** attempt
print(f"Token retrieval failed (attempt {attempt + 1}): {e}. Retrying in {wait_time}s...")
time.sleep(wait_time)
else:
raise Exception(f"Failed to retrieve access token after {max_retries} attempts: {e}")
# Initialize Auth
auth = GenesysAuth(
region=os.getenv("GENESYS_REGION"),
client_id=os.getenv("GENESYS_CLIENT_ID"),
client_secret=os.getenv("GENESYS_CLIENT_SECRET")
access_token = auth.get_access_token()
Step 1: Validate AppFoundry Application Configuration
WebSocket drops often stem from misconfigured timeouts or incorrect endpoint URLs in the AppFoundry application definition. Before probing the WebSocket, verify the application’s webSocket configuration via the REST API.
Working Code Block
from purecloudplatformclientv2 import ApiClient, Configuration, AppfoundryApi
from purecloudplatformclientv2.rest import ApiException
def validate_appfoundry_config(app_id: str) -> dict:
Retrieves the AppFoundry application definition to check WebSocket settings.
Args:
app_id (str): The ID of the AppFoundry application.
Returns:
dict: The application configuration details.
configuration = Configuration(
host=f"https://api.{auth.region}.mypurecloud.com",
access_token=access_token
api_client = ApiClient(configuration)
appfoundry_api = AppfoundryApi(api_client)
# Fetch the application definition
app_definition = appfoundry_api.get_appfoundry_application(app_id)
# Extract WebSocket-specific settings
ws_config = app_definition.web_socket
if not ws_config:
return {"error": "No WebSocket configuration found for this application."}
"app_id": app_id,
"web_socket_enabled": True,
"origin_url": ws_config.origin_url,
"timeout_millis": ws_config.timeout_millis,
"max_message_size": ws_config.max_message_size
except ApiException as e:
print(f"Exception when calling AppfoundryApi->get_appfoundry_application: {e}\n")
return {"error": str(e)}
finally:
api_client.close()
# Example Usage
app_id = "your_appfoundry_app_id"
config = validate_appfoundry_config(app_id)
print("AppFoundry Config:", config)
Expected Response
"app_id": "your_appfoundry_app_id",
"web_socket_enabled": true,
"origin_url": "https://your-appfoundry-app.us-east-1.mypurecloud.com",
"timeout_millis": 30000,
"max_message_size": 1048576
Error Handling
- 401 Unauthorized: The access token is expired or invalid. Re-run
get_access_token(). - 404 Not Found: The
app_idis incorrect or the application does not exist in the selected environment.
Step 2: Probe WebSocket Connection Stability
To diagnose connection drops, you must simulate a client connection to the AppFoundry WebSocket endpoint. This script connects, sends a heartbeat, and monitors for unexpected closures.
Working Code Block
import json
import websocket
import threading
from datetime import datetime
class WebSocketDiagnostic:
def __init__(self, origin_url: str, app_id: str):
self.origin_url = origin_url
self.app_id = app_id
# Construct the WebSocket URL based on Genesys Cloud AppFoundry standards
# Note: The actual WS endpoint usually requires the app ID and potentially a session token
self.ws_url = f"wss://{origin_url}/api/v2/appfoundry/websocket/{app_id}"
self.ws = None
self.connection_start_time = None
self.messages_received = []
self.connection_closed = False
self.close_reason = None
def on_open(self, ws):
print(f"[{datetime.now()}] WebSocket connection established.")
self.connection_start_time = time.time()
# Send a simple heartbeat or initialization message
init_message = {
"type": "init",
"appId": self.app_id,
"timestamp": datetime.now().isoformat()
ws.send(json.dumps(init_message))
print(f"Sent init message: {init_message}")
def on_message(self, ws, message):
data = json.loads(message)
self.messages_received.append(data)
print(f"[{datetime.now()}] Received: {data.get('type', 'unknown')}")
# If the server sends a 'pong' or 'keepalive', log latency
if data.get("type") == "pong":
latency = time.time() - self.connection_start_time
print(f"Ping latency: {latency*1000:.2f} ms")
except json.JSONDecodeError:
print(f"Received non-JSON message: {message}")
def on_error(self, ws, error):
print(f"[{datetime.now()}] WebSocket Error: {error}")
self.connection_closed = True
def on_close(self, ws, close_status_code, close_msg):
self.close_reason = {"code": close_status_code, "message": close_msg}
print(f"[{datetime.now()}] WebSocket closed. Code: {close_status_code}, Reason: {close_msg}")
def start_diagnostic(self, duration_seconds: int = 30):
Starts the WebSocket connection and runs for a specified duration.
print(f"Connecting to {self.ws_url}...")
# Disable SSL verification if needed for testing internal environments,
# but keep True for production.
self.ws = websocket.WebSocketApp(
self.ws_url,
on_open=self.on_open,
on_message=self.on_message,
on_error=self.on_error,
on_close=self.on_close
# Run the WebSocket in a separate thread
ws_thread = threading.Thread(target=self.ws.run_forever)
ws_thread.daemon = True
ws_thread.start()
# Wait for the specified duration
time.sleep(duration_seconds)
# Close the connection gracefully
self.ws.close()
print("Diagnostic complete.")
return self._analyze_results()
def _analyze_results(self) -> dict:
Analyzes the connection results for drops and latency.
duration = time.time() - self.connection_start_time if self.connection_start_time else 0
"duration_seconds": round(duration, 2),
"messages_received": len(self.messages_received),
"connection_closed": self.connection_closed,
"close_reason": self.close_reason,
"stability_score": "Stable" if not self.connection_closed else "Unstable"
# Initialize Diagnostic
if "error" not in config:
ws_diagnostic = WebSocketDiagnostic(config["origin_url"], app_id)
results = ws_diagnostic.start_diagnostic(duration_seconds=15)
print("Diagnostic Results:", results)
else:
print("Skipping WebSocket diagnostic due to configuration error.")
Explain Non-Obvious Parameters
wss://: Always use secure WebSocket protocol. Genesys Cloud does not support unsecuredws://connections.on_close: Theclose_status_codeis critical. A1000code indicates a normal closure. Codes1006(abnormal closure) or1011(internal error) indicate server-side issues or network drops.
Step 3: Correlate with Analytics Events
If the WebSocket diagnostic shows drops (1006), you must correlate this with platform-level analytics to determine if the drop originated from the Genesys Cloud infrastructure or the external application.
Working Code Block
from purecloudplatformclientv2 import AnalyticsApi, EventQuery, EventQueryType
def check_analytics_for_drops(app_id: str, start_time: str, end_time: str) -> list:
Queries Analytics for connection drop events related to the AppFoundry application.
Args:
start_time (str): ISO 8601 start time (e.g., "2023-10-27T10:00:00Z").
end_time (str): ISO 8601 end time.
Returns:
list: List of relevant analytics events.
analytics_api = AnalyticsApi(api_client)
# Define the query for connection events
query = EventQuery(
types=[EventQueryType("appfoundry.connection")],
start_time=start_time,
end_time=end_time,
filters=[
{"name": "appId", "op": "eq", "value": app_id}
response = analytics_api.post_analytics_events_query(query)
drops = []
if response and response.entities:
for event in response.entities:
# Look for error codes or disconnect reasons
if hasattr(event, 'data') and event.data:
# Parse event data structure
# Note: Actual event structure may vary; check SDK docs for exact field names
if "disconnectReason" in str(event.data):
drops.append(event)
return drops
print(f"Analytics query failed: {e}\n")
return []
finally:
api_client.close()
# Example Usage
end_time = datetime.utcnow().isoformat() + "Z"
start_time = (datetime.utcnow() - timedelta(hours=1)).isoformat() + "Z"
drops = check_analytics_for_drops(app_id, start_time, end_time)
print(f"Found {len(drops)} potential drop events in the last hour.")
Below is the full, copy-pasteable script. Save this as genesys_ws_diagnostic.py.
import os
import json
import requests
import websocket
import threading
from purecloudplatformclientv2 import ApiClient, Configuration, AppfoundryApi, AnalyticsApi, EventQuery, EventQueryType
load_dotenv()
class GenesysAuth:
data = {
max_retries = 3
return response.json()["access_token"]
time.sleep(2 ** attempt)
else:
raise Exception(f"Failed to retrieve token: {e}")
self.ws = None
init_message = {"type": "init", "appId": self.app_id}
pass
def start_diagnostic(self, duration_seconds: int = 15) -> dict:
self.ws_url,
ws_thread.start()
self.ws.close()
"duration": round(duration, 2),
"messages": len(self.messages_received),
"closed": self.connection_closed,
"reason": self.close_reason
def validate_appfoundry_config(access_token: str, region: str, app_id: str) -> dict:
configuration = Configuration(host=f"https://api.{region}.mypurecloud.com", access_token=access_token)
app_def = appfoundry_api.get_appfoundry_application(app_id)
if not app_def.web_socket:
return {"error": "No WebSocket config"}
"origin_url": app_def.web_socket.origin_url,
"timeout": app_def.web_socket.timeout_millis
finally:
api_client.close()
region = os.getenv("GENESYS_REGION")
app_id = os.getenv("APP_ID", "your_app_id")
if not all([region, client_id, client_secret]):
raise ValueError("Missing environment variables.")
print("1. Authenticating...")
auth = GenesysAuth(region, client_id, client_secret)
print("2. Validating AppFoundry Config...")
config = validate_appfoundry_config(token, region, app_id)
if "error" in config:
print(f"Config Error: {config['error']}")
exit(1)
print("3. Running WebSocket Diagnostic...")
results = diagnostic.start_diagnostic(duration_seconds=15)
print("4. Results:")
print(json.dumps(results, indent=2))
if results["closed"] and results["reason"]["code"] != 1000:
print("WARNING: Abnormal closure detected. Check analytics.")
else:
print("Connection stable.")
Error: 1006 Abnormal Closure
- What causes it: The WebSocket connection was closed unexpectedly by the server or network. This often indicates a timeout mismatch between the AppFoundry application and the Genesys Cloud platform.
- How to fix it:
- Check the
timeout_millisin the AppFoundry configuration. Ensure it matches the expected session duration. - Verify that your application sends regular heartbeat messages if the platform requires them.
- Check firewall rules between your application server and
*.mypurecloud.comports 443.
- Check the
Error: 401 Unauthorized on WebSocket
- What causes it: The WebSocket URL is missing required authentication parameters or the session token has expired.
- How to fix it:
- Ensure the AppFoundry application is configured to use the correct authentication method (e.g., JWT, Basic Auth).
- If using JWT, verify the token validity period.
- Check the
origin_urlin the AppFoundry definition. It must be accessible from the client.
Error: High Latency (>500ms)
- What causes it: Network congestion, server-side processing delays, or inefficient message serialization.
- How to fix it:
- Reduce the size of JSON payloads sent over the WebSocket.
- Check the server logs of your AppFoundry application for slow processing times.
- Ensure your application is deployed in a region close to the Genesys Cloud environment (e.g., us-east-1 app to us-east-1 Genesys).
