Debugging Undefined Outputs in Genesys Data Actions: Fixing JSON Path Mapping
- One sentence: You will build a Python script that creates a Data Action in Genesys Cloud CX, executes it against real conversation data, and validates the output to ensure fields are not undefined.
- One sentence: This uses the Genesys Cloud CX API v2 endpoints for Data Actions and Conversations.
- One sentence: The tutorial covers Python using the
requestslibrary and the officialgenesys-cloudSDK.
- OAuth client type: Private Key or Client Credentials flow.
- Required Scopes:
data:action:write,data:action:read,conversation:read,analytics:conversation:read. - SDK Version:
genesys-cloud>=2.0.0(Python). - Language/Runtime: Python 3.9+.
- External Dependencies:
pip install genesys-cloud requests httpx.
Before interacting with Data Actions, you must establish a valid OAuth token. Data Actions often require elevated permissions to access conversation analytics. Using the private key flow is recommended for server-to-server integrations.
import os
from genesyscloud import AuthenticationApi, Configuration
def get_genesys_client() -> Configuration:
Initializes and returns a Genesys Cloud Configuration object
with an active access token.
# Load credentials from environment variables
private_key = os.getenv("GENESYS_PRIVATE_KEY") # PEM format
private_key_password = os.getenv("GENESYS_PRIVATE_KEY_PASSWORD", "")
if not client_id or not private_key:
raise ValueError("GENESYS_CLIENT_ID and GENESYS_PRIVATE_KEY must be set.")
config = Configuration()
config.host = "https://api.mypurecloud.com"
auth_api = AuthenticationApi(config)
# Exchange private key for access token
token_response = auth_api.post_oauth_token(
grant_type="private_key",
client_id=client_id,
private_key=private_key,
private_key_password=private_key_password
# Set the token in the configuration for subsequent API calls
config.access_token = token_response.access_token
return config
except ApiException as e:
print(f"Authentication failed: {e.status} {e.reason}")
raise
# Initialize the client
genesys_config = get_genesys_client()
Step 1: Create a Test Data Action with Explicit Mapping
The root cause of “undefined” outputs in Data Actions is almost always a mismatch between the source data structure (the input) and the expected JSON path in the output mapping. Genesys Cloud Data Actions use a strict JSON path syntax. If the path does not exist in the input context, the output field becomes null or undefined depending on the consumer (Flow vs. API).
We will create a Data Action that takes a conversation ID, fetches the conversation details, and extracts specific fields.
from genesyscloud import DataActionsApi, DataAction, DataActionInput, DataActionOutput
import json
def create_test_data_action(config: Configuration) -> str:
Creates a Data Action that maps conversation fields.
Returns the Data Action ID.
data_actions_api = DataActionsApi(config)
# Define the input: A simple object expecting a conversation ID
input_schema = {
"type": "object",
"properties": {
"conversationId": {
"type": "string",
"description": "The ID of the conversation to analyze"
"required": ["conversationId"]
# Define the output: We expect to extract the participant ID and direction
# CRITICAL: The 'path' here must exactly match the JSON structure returned by the source
output_schema = {
"type": "object",
"properties": {
"participantId": {
"type": "string",
"description": "The ID of the customer participant"
"direction": {
"type": "string",
"description": "Inbound or Outbound"
# Create the Data Action object
data_action = DataAction(
name="Debug_Conversation_Mapper",
description="Test action to debug JSON path mapping issues",
version=1,
inputs=[
DataActionInput(
name="conversationId",
type="string",
description="Input conversation ID"
outputs=[
DataActionOutput(
name="participantId",
type="string",
description="Extracted participant ID"
DataActionOutput(
name="direction",
type="string",
description="Conversation direction"
source={
"type": "rest",
"url": "https://api.mypurecloud.com/api/v2/conversations/{conversationId}",
"method": "GET",
# This is where the mapping happens.
# We map the API response to our output fields.
"headers": {},
"mapping": {
"participantId": "$.participants[0].id",
"direction": "$.direction"
inputs_schema=input_schema,
outputs_schema=output_schema
response = data_actions_api.post_data_actions(body=data_action)
print(f"Data Action Created: {response.id}")
return response.id
print(f"Failed to create Data Action: {e.status} {e.body}")
raise
data_action_id = create_test_data_action(genesys_config)
Step 2: Execute the Data Action and Inspect Raw Output
To debug why an output is undefined, you must execute the Data Action programmatically and inspect the raw response payload. The Genesys API allows you to invoke a Data Action via the /api/v2/data/actions/{id}/invoke endpoint.
Common causes for undefined outputs:
- Index Out of Bounds: Using
$.participants[0]when the array is empty. - Typo in Path: Using
$.particpantIdinstead of$.participants[0].id. - Nested Object Misinterpretation: Treating an object as a primitive string.
import json
def execute_data_action(config: Configuration, action_id: str, conversation_id: str) -> dict:
Executes the Data Action with a specific conversation ID.
Returns the full response body as a dictionary.
# Prepare the input payload
input_payload = {
"conversationId": conversation_id
# Invoke the Data Action
# The API returns a response containing the evaluated outputs
response = data_actions_api.post_data_actions_invoke(
data_action_id=action_id,
body=input_payload
return response
print(f"Execution failed: {e.status} {e.body}")
raise
# You must provide a real Conversation ID from your Genesys environment
# Replace this with a valid ID from your org
TEST_CONVERSATION_ID = "12345678-1234-1234-1234-123456789012"
# Note: In a real scenario, fetch a recent conversation ID first
# For this tutorial, we assume you have one.
result = execute_data_action(genesys_config, data_action_id, TEST_CONVERSATION_ID)
# Print the raw result to inspect for undefined/null values
print("Raw Execution Result:")
print(json.dumps(result, indent=2))
Step 3: Validate and Handle Undefined Fields
When the output field is undefined, the Genesys API typically returns null in the JSON payload for that specific key. In JavaScript/Flow contexts, this may manifest as undefined. To fix this, you must adjust the JSON Path in the Data Action source mapping or add default values.
Here is how to programmatically detect and fix a mapping error by updating the Data Action with a fallback or corrected path.
import json
def fix_mapping_issue(config: Configuration, action_id: str) -> None:
Demonstrates how to update a Data Action to handle missing fields
by adding a default value or correcting the path.
# 1. Get the current Data Action definition
current_action = data_actions_api.get_data_action(data_action_id=action_id)
# 2. Inspect the current mapping
current_mapping = current_action.source.get("mapping", {})
print(f"Current Mapping: {json.dumps(current_mapping, indent=2)}")
# 3. Identify the issue
# If $.participants[0].id is null, it might be because the participant array is empty
# or the index is wrong.
# Let's update the mapping to use a safer path or add a default
# Note: Genesys Data Actions do not natively support "default" in the REST source mapping
# without using a Script source or Flow logic.
# However, we can correct the path if it was wrong.
# Example: Correcting a typo or wrong index
# Suppose the correct path is $.participants[1].id (agent instead of customer)
updated_source = current_action.source
updated_source["mapping"] = {
"participantId": "$.participants[0].id", # Keep original, but verify
# If the issue is that $.participants is an object instead of array in some legacy formats
# You might need to switch to a Script source for complex logic.
# For this example, let's assume we found the path was actually $.participants.customer.id
# We will update the source mapping
updated_source["mapping"]["participantId"] = "$.participants[0].id"
# 4. Update the Data Action
# We must provide the full object back
current_action.source = updated_source
updated_response = data_actions_api.put_data_action(
body=current_action
print(f"Data Action Updated: {updated_response.id}")
print(f"Failed to update Data Action: {e.status} {e.body}")
raise
fix_mapping_issue(genesys_config, data_action_id)
This script combines authentication, creation, execution, and validation into a single workflow. It uses a real conversation ID fetched from the API to ensure the input data is valid.
import os
import json
from genesyscloud import (
AuthenticationApi,
Configuration,
DataActionsApi,
ConversationsApi,
DataAction,
DataActionInput,
DataActionOutput
def main():
# 1. Authentication
print("Error: Set GENESYS_CLIENT_ID and GENESYS_PRIVATE_KEY")
return
token = auth_api.post_oauth_token(
private_key_password=os.getenv("GENESYS_PRIVATE_KEY_PASSWORD", "")
config.access_token = token.access_token
print(f"Auth Error: {e.body}")
return
# 2. Fetch a Real Conversation ID
conversations_api = ConversationsApi(config)
# Get recent conversations to find a valid ID
conv_response = conversations_api.post_conversations_search(
body={
"type": "voice",
"pageSize": 1,
"pageNumber": 1,
"filter": "status:closed"
if not conv_response.entities:
print("No recent conversations found.")
return
real_conv_id = conv_response.entities[0].id
print(f"Using Conversation ID: {real_conv_id}")
print(f"Conversation Fetch Error: {e.body}")
return
# 3. Create Data Action with Intentional "Bad" Mapping to Demonstrate Fix
# Initial Mapping: Intentionally using a non-existent path to show null output
# Then we will fix it.
bad_mapping = {
"participantId": "$.nonExistentField", # This will cause undefined/null
name="Debug_Mapping_Test",
description="Testing undefined output",
version=1,
inputs=[DataActionInput(name="convId", type="string")],
outputs=[
DataActionOutput(name="participantId", type="string"),
DataActionOutput(name="direction", type="string")
source={
"type": "rest",
"url": f"https://api.mypurecloud.com/api/v2/conversations/{{convId}}",
"method": "GET",
"mapping": bad_mapping
action_resp = data_actions_api.post_data_actions(body=data_action)
action_id = action_resp.id
print(f"Created Action: {action_id}")
# 4. Execute with Bad Mapping
print("\n--- Executing with BAD Mapping ---")
exec_resp = data_actions_api.post_data_actions_invoke(
body={"convId": real_conv_id}
print(f"Output: {json.dumps(exec_resp, indent=2)}")
# You will see participantId is null
# 5. Fix the Mapping
print("\n--- Fixing Mapping ---")
# Fetch current
current = data_actions_api.get_data_action(data_action_id=action_id)
current.source["mapping"] = {
"participantId": "$.participants[0].id", # Correct Path
# Update
data_actions_api.put_data_action(data_action_id=action_id, body=current)
# 6. Execute with Good Mapping
print("\n--- Executing with FIXED Mapping ---")
exec_resp_fixed = data_actions_api.post_data_actions_invoke(
print(f"Output: {json.dumps(exec_resp_fixed, indent=2)}")
# You will see participantId is now populated
print(f"API Error: {e.status} {e.body}")
main()
Error: 400 Bad Request - Invalid JSON Path
- What causes it: The JSON path syntax in the Data Action source mapping is malformed. For example, using
$participantsinstead of$.participants, or using square brackets without a valid index$.participants[].id. - How to fix it: Ensure all paths start with
$. Use dot notation for objects and bracket notation for arrays. Validate the path against a JSON Linter. - Code showing the fix:
# Incorrect "mapping": { "id": "$participants[0].id" } # Correct "mapping": { "id": "$.participants[0].id" }
Error: Output is Null/Undefined
- What causes it: The JSON path is syntactically correct, but the data at that path does not exist in the specific record being processed. For example,
$.participants[0]exists, but$.participants[0].idis null, or the array is empty. - How to fix it: Use the “Execute Data Action” API call with a sample input to print the raw JSON response. Verify the exact structure of the source API response. If the field is optional, consider adding logic in a Flow or Script to provide a default value, as Data Action REST sources do not support native default values for missing paths.
- Debugging Step:
# Print the raw source response to verify structure # You can simulate this by calling the REST URL directly with the token import requests resp = requests.get( f"https://api.mypurecloud.com/api/v2/conversations/{real_conv_id}", headers={"Authorization": f"Bearer {config.access_token}"} ) print(resp.json()) # Inspect the JSON to ensure $.participants[0].id exists
Error: 401 Unauthorized on Data Action Invoke
- What causes it: The OAuth token used to invoke the Data Action lacks the
data:action:readscope, or the private key used for authentication does not have permission to access the underlying data source (e.g., the conversation). - How to fix it: Ensure the OAuth client has the
data:action:readanddata:action:writescopes. Ensure the user associated with the OAuth token has permissions to read the conversations being accessed.
