Debugging Session Handover Failures Between NICE CXone Studio and Cognigy Voicebots
- You will build a diagnostic script that validates the
sessionTransferevent payload sent from a Cognigy Voicebot to a NICE CXone Studio flow. - This tutorial uses the NICE CXone REST API to inspect conversation logs and the NICE CXone Studio API to validate flow definitions.
- The programming language covered is Python, using the
requestslibrary for direct API interaction.
- OAuth Client Type: Service Account with “Offline Access” enabled.
- Required Scopes:
conversations:read(to retrieve conversation history and event logs)analytics:conversations:read(to query detailed conversation transcripts if needed)users:read(to verify agent availability during handover attempts)
- SDK/API Version: NICE CXone REST API (v2).
- Language/Runtime: Python 3.8+.
- External Dependencies:
requests(HTTP library)python-dotenv(for secure credential management)
NICE CXone uses OAuth 2.0 for authentication. For integration troubleshooting, you must use a Service Account configured with the necessary scopes. The following code demonstrates how to retrieve an access token and handle the response.
import requests
import json
import os
# Load environment variables
load_dotenv()
CLIENT_ID = os.getenv("CXONE_CLIENT_ID")
CLIENT_SECRET = os.getenv("CXONE_CLIENT_SECRET")
TENANT_ID = os.getenv("CXONE_TENANT_ID")
def get_cxone_token():
Retrieves an OAuth2 access token from NICE CXone.
url = f"https://{TENANT_ID}.api.nice.incontact.com/oauth2/token"
headers = {
data = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET
response = requests.post(url, headers=headers, data=data)
if response.status_code != 200:
raise Exception(f"Failed to acquire token: {response.status_code} - {response.text}")
token_data = response.json()
return token_data["access_token"]
# Example usage
access_token = get_cxone_token()
print("Token acquired successfully.")
print(f"Authentication Error: {e}")
Step 1: Identify the Failed Conversation
To troubleshoot a handover failure, you must first locate the specific conversation ID. In a production environment, you might correlate this with a phone number or customer ID. For this tutorial, we assume you have a list of recent conversations or are querying by a specific participant identifier.
We will query the conversations endpoint to find the conversation associated with a specific phone number.
Endpoint: GET /api/v2/analytics/conversations/details/query
Required Scope: analytics:conversations:read
def find_conversation_by_phone(phone_number: str, token: str) -> str:
Queries NICE CXone for a conversation ID based on a participant's phone number.
Returns the conversation ID or None if not found.
url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/analytics/conversations/details/query"
headers = {
# Define the query body
# We look for conversations in the last 24 hours
start_time = (datetime.utcnow() - timedelta(hours=24)).isoformat() + "Z"
end_time = datetime.utcnow().isoformat() + "Z"
query_body = {
"dateFrom": start_time,
"dateTo": end_time,
"interval": "PT1H",
"metrics": [
{"name": "conversation.count"}
"groupings": [
{"name": "conversation.id"},
{"name": "participant.id"}
# Note: The analytics API is heavy. For precise debugging,
# it is often faster to use the Conversations API if you have the ID.
# However, if you only have the phone number, Analytics is a common path.
# A more direct approach for recent active conversations:
# Let's switch to the simpler Conversations API for active/recent history
# GET /api/v2/conversations
# This requires pagination handling for production, but we simplify for the example.
conv_url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/conversations"
params = {
"pageSize": 20,
"conversationType": "voice"
response = requests.get(conv_url, headers=headers, params=params)
raise Exception(f"Failed to fetch conversations: {response.status_code} - {response.text}")
conversations = response.json().get("entities", [])
for conv in conversations:
# Check participants
for participant in conv.get("participants", []):
if participant.get("identity") == phone_number:
return conv.get("id")
return None
Step 2: Retrieve Conversation Transcript and Events
Once you have the Conversation ID, you must retrieve the detailed transcript. The transcript contains the raw events exchanged between the Cognigy bot and the NICE CXone platform. Specifically, you are looking for the sessionTransfer event.
Endpoint: GET /api/v2/conversations/{conversationId}
Required Scope: conversations:read
def get_conversation_details(conversation_id: str, token: str) -> dict:
Retrieves the full conversation object, including events and participants.
url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/conversations/{conversation_id}"
headers = {
response = requests.get(url, headers=headers)
if response.status_code == 404:
raise Exception(f"Conversation {conversation_id} not found.")
elif response.status_code != 200:
raise Exception(f"Failed to fetch conversation: {response.status_code} - {response.text}")
return response.json()
Step 3: Analyze the Session Transfer Event
The core of the troubleshooting lies in inspecting the events array within the conversation object. When a Cognigy Voicebot initiates a handover, it sends a sessionTransfer event. If this event is malformed, missing required fields, or sent by a participant that is not authorized, the handover fails.
We will parse the events to find the sessionTransfer attempt and validate its structure against the NICE CXone requirements.
def analyze_handover_events(conversation_data: dict) -> list:
Inspects the conversation events for sessionTransfer actions.
Returns a list of findings, including errors or success indicators.
events = conversation_data.get("events", [])
findings = []
# Sort events by timestamp to ensure chronological order
events.sort(key=lambda x: x.get("timestamp", ""))
for event in events:
event_type = event.get("type")
# Look for the transfer event
if event_type == "sessionTransfer":
from_participant_id = event.get("fromParticipantId")
to_participant_id = event.get("toParticipantId")
properties = event.get("properties", {})
# Validate basic structure
if not from_participant_id:
findings.append({
"status": "ERROR",
"message": "sessionTransfer event missing 'fromParticipantId'.",
"timestamp": event.get("timestamp")
if not to_participant_id:
findings.append({
"status": "ERROR",
"message": "sessionTransfer event missing 'toParticipantId'.",
# Check for specific Cognigy integration properties
# Cognigy often passes custom data in 'properties'
cognigy_session_id = properties.get("cognigySessionId")
if not cognigy_session_id:
# This is not necessarily an error, but good for debugging
findings.append({
"status": "WARNING",
"message": "No 'cognigySessionId' found in properties. Ensure Cognigy is sending context.",
# Check if the transfer was accepted
# We need to look for a subsequent event indicating acceptance or rejection
# However, the sessionTransfer event itself usually indicates the *attempt*.
# The result is often seen in the state of the participants or subsequent events.
findings.append({
"status": "INFO",
"message": f"Transfer attempted from {from_participant_id} to {to_participant_id}.",
"timestamp": event.get("timestamp"),
"properties": properties
# Look for rejection events
elif event_type == "sessionTransferRejected":
reason = event.get("reason")
findings.append({
"status": "ERROR",
"message": f"Transfer rejected. Reason: {reason}",
return findings
Step 4: Validate the Target Flow and Agent Availability
If the sessionTransfer event was sent correctly but the handover still failed, the issue may lie in the NICE CXone Studio flow configuration or the availability of the target agent.
We will check if the target participant (often an agent or a queue) exists and is active.
def check_participant_status(participant_id: str, token: str) -> dict:
Checks the status of a participant (agent or bot) in the system.
url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/users/{participant_id}"
headers = {
return {"status": "ERROR", "message": f"Participant {participant_id} does not exist."}
return {"status": "ERROR", "message": f"Failed to fetch user: {response.status_code}"}
user_data = response.json()
state = user_data.get("state", {})
"status": "OK",
"user_id": user_data.get("id"),
"name": user_data.get("name"),
"current_state": state.get("stateName"),
"is_available": state.get("stateName") == "Available" # Simplified check
The following script combines all steps into a single executable tool. It requires environment variables for authentication.
import requests
import os
import json
load_dotenv()
data = {
raise Exception(f"Token Error: {response.text}")
return response.json()["access_token"]
def find_conversation(phone_number: str, token: str) -> str:
params = {"pageSize": 10, "conversationType": "voice"}
response = requests.get(url, headers=headers, params=params)
raise Exception(f"Fetch Error: {response.text}")
for conv in response.json().get("entities", []):
for p in conv.get("participants", []):
if p.get("identity") == phone_number:
return conv["id"]
return None
def get_conversation_details(conv_id: str, token: str) -> dict:
url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/conversations/{conv_id}"
raise Exception(f"Details Error: {response.text}")
def analyze_handover(conv_data: dict) -> list:
events = conv_data.get("events", [])
findings = []
if event.get("type") == "sessionTransfer":
findings.append({
"type": "TRANSFER_ATTEMPT",
"from": event.get("fromParticipantId"),
"to": event.get("toParticipantId"),
"props": event.get("properties", {}),
elif event.get("type") == "sessionTransferRejected":
findings.append({
"type": "TRANSFER_REJECTED",
"reason": event.get("reason"),
return findings
def main():
# 1. Authenticate
print(f"Auth Failed: {e}")
return
# 2. Input Phone Number (Hardcoded for example)
target_phone = "+15550199888" # Replace with actual test number
print(f"Searching for conversation for {target_phone}...")
conv_id = find_conversation(target_phone, token)
if not conv_id:
print("No recent voice conversation found for this number.")
return
print(f"Found Conversation ID: {conv_id}")
# 3. Get Details
conv_data = get_conversation_details(conv_id, token)
print(f"Failed to get details: {e}")
return
# 4. Analyze
findings = analyze_handover(conv_data)
if not findings:
print("No sessionTransfer events found in this conversation.")
else:
print("\n--- Handover Analysis ---")
for f in findings:
print(json.dumps(f, indent=2))
# 5. Check Target Agent if transfer was attempted
last_transfer = [f for f in findings if f["type"] == "TRANSFER_ATTEMPT"]
if last_transfer:
target_id = last_transfer[-1]["to"]
print(f"\nChecking status of target participant: {target_id}")
# Note: This assumes the target is a User. If it is a Queue, you would query /api/v2/queues/{id}
url = f"https://{TENANT_ID}.api.nice.incontact.com/api/v2/users/{target_id}"
res = requests.get(url, headers=headers)
if res.status_code == 200:
user = res.json()
state = user.get("state", {})
print(f"User Name: {user.get('name')}")
print(f"Current State: {state.get('stateName')}")
if state.get("stateName") != "Available":
print("WARNING: Target agent is not Available. This may cause handover delays or failures.")
else:
print(f"Could not retrieve user details: {res.status_code}")
main()
Error: 403 Forbidden on Session Transfer
- Cause: The Cognigy bot participant does not have the necessary permissions to initiate a transfer, or the target flow requires a specific OAuth scope that the service account lacks.
- Fix: Verify that the Service Account used by the integration has
conversations:writeorconversations:readdepending on the direction. In Cognigy, ensure the “NICE CXone” connector is configured with a valid OAuth token. - Code Check: Ensure the
fromParticipantIdin thesessionTransferevent matches the participant ID assigned to the Cognigy bot in the NICE CXone conversation.
Error: 400 Bad Request - Invalid Participant ID
- Cause: The
toParticipantIdin thesessionTransferevent refers to a non-existent user, queue, or flow. - Fix: Validate that the
toParticipantIdis a valid UUID of an active agent, a queue ID, or a flow ID. - Code Check: Use the
check_participant_statusfunction above to verify the existence of the target ID.
Error: No Response After Transfer Attempt
- Cause: The transfer event was sent, but the NICE CXone Studio flow did not accept it. This often happens if the flow is not configured to handle
sessionTransferevents or if the bot is not properly linked to the flow. - Fix: In NICE CXone Studio, ensure the flow has an “Event” trigger that listens for
sessionTransfer. Ensure the “From” participant is identified correctly in the flow logic. - Debugging: Check the
findingslist in the complete example. If you seeTRANSFER_ATTEMPTbut noTRANSFER_REJECTEDand no subsequent state change, the flow may be silently ignoring the event.
