Debugging RTP Stream Desynchronization and Audio Echo in Genesys Cloud WebRTC Sessions Caused by Asymmetric NAT Traversal Paths
This guide provides the exact methodology to isolate and resolve RTP desynchronization and acoustic echo in Genesys Cloud WebRTC calls triggered by asymmetric NAT traversal. You will learn how to capture and parse ICE candidates, force symmetric media routing through Genesys WebRTC configuration, and validate RTP timestamp alignment using production network traces.
  • Genesys Cloud CX License: CX 1, CX 2, or CX 3 (WebRTC is included in all tiers)
  • User Permissions: Telephony > WebRTC > Edit, Administration > Settings > Edit, API > Read, Telephony > Trunk > Read
  • OAuth Scopes: webchat:read, routing:read, telephony:read, websockets:read, analytics:details:query
  • External Dependencies: Wireshark or tcpdump, Browser Developer Tools (Chrome/Firefox), Access to enterprise firewall logs, NTP synchronization across endpoints, TURN server credentials
1. Mapping the ICE Candidate Selection and NAT Asymmetry
WebRTC relies on ICE to negotiate media paths. When an endpoint sits behind a carrier-grade NAT or a split-tunnel VPN, the STUN server may return a reflexive candidate that differs from the actual egress IP used by the firewall. This creates an asymmetric path: signaling routes through Genesys Cloud, but outbound RTP traverses one NAT mapping while inbound RTP hits a different mapped port or IP. The result is RTP timestamp drift and echo canceller failure.
You must capture the SDP offer and answer to see exactly which candidate Genesys selected. Open the browser console during a WebRTC call and intercept the RTCPeerConnection events. Use the following JavaScript to log ICE candidate selection:
const pc = new RTCPeerConnection();
pc.onicecandidate = (event) => {
  if (event.candidate) {
    console.log('ICE Candidate:', JSON.stringify(event.candidate));
pc.oniceconnectionstatechange = () => {
  console.log('ICE State:', pc.iceConnectionState);
  console.log('Selected Transport:', pc.getSelectedCandidates ? pc.getSelectedCandidates() : 'Not available');
The Trap: Engineers frequently assume the type: host candidate will be selected for performance. When the firewall blocks UDP port ranges or enforces strict stateful inspection, ICE falls back to srflx or relay. If the fallback path differs from the initial STUN mapping, Genesys Cloud media servers receive packets from an unexpected source IP. The RTP stack drops out-of-order packets, causing jitter buffer underruns and desynchronization. Always verify that UDP ports 10000-60000 are explicitly permitted for bidirectional traffic without deep packet inspection.
Architectural Reasoning: We force explicit STUN/TURN configuration in the Genesys WebRTC settings rather than relying on browser defaults. This guarantees that the media path validation occurs against known endpoints. Asymmetric routing breaks the round-trip time calculation used by the jitter buffer. When the buffer cannot predict arrival times, it flushes old packets and reorders new ones, introducing audio gaps that the acoustic echo canceller interprets as late-arriving far-end speech. This misidentification creates the echo feedback loop. Genesys Cloud media servers expect consistent SSRC and RTP timestamp base values. Path switching mid-call invalidates the timestamp correlation, forcing the jitter buffer to reset and causing audible desynchronization.
2. Capturing and Correlating SDP/ICE Candidates with Network Traces
You need a packet capture at the enterprise edge to verify the actual egress IP against the STUN reflexive IP. Configure tcpdump or Wireshark on the gateway interface:
sudo tcpdump -i eth0 -w webrtc_nat_asymmetry.pcap 'udp and portrange 10000-60000'
Once you have the capture, filter for STUN traffic to identify the external IP reported by the STUN server:
stun && ip.addr == <stun_server_ip>
Cross-reference this with the RTP stream destination. In Wireshark, use the following display filter to isolate the RTP stream for a specific SSRC:
rtp.ssrc == <ssrc_value>
The Trap: Analyzing only the browser-side capture misses the firewall NAT translation. The browser shows the internal IP, but the media server sees the translated IP. If you compare internal capture data against Genesys Cloud server logs, the IP mismatch appears as a routing error. You must capture at the egress point where the NAT translation occurs. Failing to do this leads to chasing phantom firewall rules instead of addressing the actual mapping divergence.
Architectural Reasoning: We correlate the STUN response with the actual egress IP because Genesys Cloud validates the media path during the ICE connectivity checks. When the checks succeed on one path but actual media flows on another, the RTP synchronization markers fall out of phase. The jitter buffer relies on sequence number prediction. Asymmetric paths introduce variable latency deltas that exceed the buffer window. The buffer then discards packets to prevent overflow, causing the audio desynchronization. By capturing at the edge, you establish the ground truth for the NAT mapping and can prove whether the firewall is altering the UDP checksum or rewriting ports. You must also verify that the RTP timestamp increment matches the negotiated codec clock rate. For G.711, the clock rate is 8000 Hz. A 20ms packet should increment the timestamp by 160. If the timestamp increments irregularly, the NAT device is likely dropping or duplicating packets, which breaks the jitter buffer timing algorithm.
3. Configuring Genesys Cloud WebRTC Settings for Symmetric Routing
You must adjust the WebRTC configuration in Genesys Cloud to enforce consistent NAT traversal behavior. Navigate to Admin > Telephony > WebRTC. Configure the STUN and TURN servers explicitly:
  "iceServers": [
      "urls": [
        "stun:stun.genesyscloud.com:3478",
        "turn:turn.genesyscloud.com:3478?transport=udp",
        "turn:turn.genesyscloud.com:3478?transport=tcp"
      "username": "webrelay",
      "credential": "secure_credential_value"
Apply this configuration via the Genesys Cloud API to ensure version control and auditability:
PATCH https://api.genesyscloud.com/v2/telephony/web/settings
  "stunServers": ["stun:stun.genesyscloud.com:3478"],
  "turnServers": ["turn:turn.genesyscloud.com:3478?transport=udp"],
  "turnUsername": "webrelay",
  "turnPassword": "secure_credential_value",
  "forceTcp": false,
  "enableTurnRelay": true
The Trap: Disabling TCP fallback (forceTcp: false) while the corporate firewall blocks UDP causes ICE to fail silently. The browser falls back to WebSockets for signaling, but media fails to establish. Engineers often see this as a “no audio” issue rather than a NAT asymmetry problem. You must leave UDP as the primary transport and allow TCP only as a fallback. Forcing TCP increases latency and breaks the RTP timestamp alignment because TCP retransmissions introduce variable delays that the jitter buffer cannot compensate for.
Architectural Reasoning: We enforce a unified STUN/TURN configuration to eliminate browser-specific ICE behavior. Different browsers negotiate candidates differently. Chrome may prefer host candidates while Firefox prioritizes srflx. This inconsistency causes asymmetric routing across agents. By centralizing the configuration in Genesys Cloud, you standardize the candidate selection process. The TURN relay ensures a consistent egress IP when direct UDP fails. This consistency preserves RTP sequence integrity and allows the acoustic echo canceller to maintain phase alignment with the reference signal. You must also verify that the OAuth token used for this API call contains the telephony:edit scope. Without it, the PATCH request returns a 403 Forbidden error, and the settings remain at their default state, leaving the asymmetry unresolved.
4. Implementing Server-Side RTP Analysis and Echo Cancellation Tuning
When NAT asymmetry persists despite configuration changes, you must analyze the RTP stream directly. Genesys Cloud provides call recording metadata and RTP statistics via the API. Retrieve the call details and extract the RTP stream metrics:
GET https://api.genesyscloud.com/v2/analytics/details/query
  "viewId": "webcall",
  "dateFrom": "2024-01-01T00:00:00.000Z",
  "dateTo": "2024-01-02T00:00:00.000Z",
  "groupBy": ["conversationId"],
  "aggregations": [
    { "type": "avg", "name": "rtp.packetLossPercent" },
    { "type": "avg", "name": "rtp.jitterMs" },
    { "type": "max", "name": "rtp.roundTripTimeMs" }
High jitter and packet loss indicate path divergence. You must also verify the acoustic echo canceller settings. Genesys Cloud applies AEC at the browser level and server level. Ensure the server-side AEC is active and tuned for variable latency:
  "audioSettings": {
    "echoCancellation": true,
    "echoCancellationDelayMs": 150,
    "noiseSuppression": true,
    "autoGainControl": true
The Trap: Setting echoCancellationDelayMs too low (under 100ms) when asymmetric routing introduces 120-200ms of variable latency causes the AEC to misidentify far-end audio as near-end echo. The canceller then applies destructive filtering to the active speech path, resulting in choppy audio and perceived echo. You must match the delay parameter to the maximum observed round-trip time plus a 20ms safety margin.
Architectural Reasoning: We tune the AEC delay based on empirical RTP round-trip measurements rather than using defaults. Asymmetric NAT traversal introduces non-linear latency spikes. The AEC algorithm uses a fixed-length buffer to compare the reference signal with the microphone input. If the actual delay exceeds the buffer window, the algorithm fails to subtract the echo component. By extending the delay parameter, you accommodate the routing divergence while maintaining speech clarity. This adjustment prevents the destructive filtering that creates the echo feedback loop. You must also monitor the rtp.jitterMs metric. If jitter exceeds 50ms consistently, the jitter buffer will flush packets to prevent overflow. This flushing causes the audio desynchronization. You must address the network path before increasing the delay parameter, as increasing delay without fixing jitter will only amplify the echo issue.
Edge Case 1: TURN Relay Fallback Causing Codec Mismatch
  • The failure condition: WebRTC sessions establish successfully, but audio contains periodic clicks, desynchronization, and echo. Packet captures show the media path switches from direct UDP to TURN relay mid-call.
  • The root cause: The firewall drops UDP traffic after a timeout period. ICE renegotiates and falls back to TURN. The TURN server negotiates a different codec payload type due to transport limitations. The RTP stream switches SSRCs or payload types without proper signaling, causing the jitter buffer to flush and the AEC to lose phase alignment.
  • The solution: Configure the firewall to maintain UDP state for at least 300 seconds. If NAT timeout cannot be extended, force the browser to use TURN from the initial connection by disabling direct UDP in the WebRTC settings. Use the API to set forceTcp: true and enable turnRelayOnly: true in the browser configuration. This prevents mid-call path switching and maintains codec consistency. Cross-reference the WFM skill routing configuration to ensure that agents using affected endpoints are not routed to high-volume queues where call hold time increases the risk of UDP timeout.
Edge Case 2: Corporate Firewall ALG Interference with RTCP
  • The failure condition: RTP audio streams correctly, but RTCP reports are dropped. This causes the jitter buffer to receive no feedback on packet loss, leading to aggressive packet dropping and audio desynchronization. Echo appears because the AEC cannot receive RTCP sender reports to adjust timing.
  • The root cause: Application Layer Gateway (ALG) on the firewall inspects RTCP packets and rewrites sequence numbers or timestamps. RTCP relies on precise timestamp correlation with RTP. When the ALG alters these fields, the receiver cannot map RTCP statistics to the RTP stream. The jitter buffer defaults to conservative settings, discarding legitimate packets.
  • The solution: Disable UDP ALG on the firewall for the WebRTC media ports. Configure the firewall to treat ports 10000-60000 as generic UDP traffic without inspection. Verify using Wireshark that RTCP sender reports (rtcp.ps and rtcp.sr) arrive unmodified. If ALG cannot be disabled, implement a TURN relay that encapsulates RTCP in TCP, bypassing the firewall inspection entirely. You must also update the Genesys Cloud telephony settings to disable rtcpMux if the firewall does not support multiplexed RTCP. This forces separate RTCP ports, which some legacy firewalls handle more predictably.
Edge Case 3: NTP Drift Between Browser and Media Server
  • The failure condition: Audio plays with a consistent half-second delay and periodic echo bursts. RTP timestamps appear correct, but the audio playback lags.
  • The root cause: The endpoint browser clock drifts from the Genesys Cloud media server clock by more than 500ms. WebRTC uses system clock timestamps for jitter buffer management. When the clocks diverge, the jitter buffer miscalculates packet arrival times, delaying playback to prevent gaps. The delayed audio feeds back into the microphone, creating echo.
  • The solution: Enforce NTP synchronization on all endpoints. Configure browsers to use a corporate NTP server with sub-10ms accuracy. Implement a script to verify clock drift before initiating calls. Use the Genesys Cloud API to monitor rtp.clockDriftMs metrics. If drift exceeds 200ms, force a call renegotiation or redirect to a PSTN trunk until endpoint time synchronization is restored. You must also verify that the speech analytics engine receives correctly timestamped audio. Clock drift breaks the word-level alignment required for accurate sentiment scoring, which impacts downstream reporting and quality management workflows.
