Debugging NICE CXone Flow API Conditional Paths with Java
  • A Java utility that programmatically tests CXone Flow conditional logic by injecting breakpoint directives, evaluating branch matrices, and capturing variable state dumps.
  • This tutorial uses the NICE CXone Flow Debug API endpoints (/api/v2/flows/{flowId}/debug, /api/v2/flows/{flowId}/debug/{sessionId}).
  • The implementation covers Java 17+ with java.net.http.HttpClient, Jackson for JSON processing, and standard concurrency utilities for latency tracking.
  • OAuth 2.0 Client Credentials grant with scopes: flows:read, flows:debug, flows:write
  • CXone Flow API v2
  • Java 17 or higher
  • Maven dependencies:
    <dependency>
        <groupId>com.fasterxml.jackson.core</groupId>
        <artifactId>jackson-databind</artifactId>
        <version>2.15.2</version>
    </dependency>
    <dependency>
        <artifactId>jackson-annotations</artifactId>
    </dependency>
  • CXone Java SDK equivalent: com.nice.cxp.sdk.client.CxpClient and com.nice.cxp.sdk.api.flows.FlowsApi (referenced for SDK users; this tutorial uses native HTTP for guaranteed runtime compatibility).
CXone uses OAuth 2.0 Client Credentials for server-to-server API access. You must fetch an access token before invoking Flow Debug endpoints. The token expires after one hour and requires caching or refreshing.
import java.net.URI;
import java.time.Duration;
import java.util.Map;
public class CxoneAuthClient {
    private final String clientId;
    private final String clientSecret;
    private final String baseUrl;
    private final HttpClient httpClient;
    private final ObjectMapper mapper;
    private String cachedToken;
    private long tokenExpiryEpoch;
    public CxoneAuthClient(String clientId, String clientSecret, String baseUrl) {
        this.clientId = clientId;
        this.baseUrl = baseUrl.endsWith("/") ? baseUrl.substring(0, baseUrl.length() - 1) : baseUrl;
        this.httpClient = HttpClient.newBuilder()
                .connectTimeout(Duration.ofSeconds(10))
                .build();
        this.mapper = new ObjectMapper();
        this.tokenExpiryEpoch = 0;
    public String getAccessToken() throws Exception {
        if (System.currentTimeMillis() < tokenExpiryEpoch - 60000) {
            return cachedToken;
        var requestBody = mapper.writeValueAsString(Map.of(
                "grant_type", "client_credentials",
                "client_id", clientId,
                "client_secret", clientSecret,
                "scope", "flows:read flows:debug flows:write"
        var request = HttpRequest.newBuilder()
                .uri(URI.create(baseUrl + "/api/v2/oauth/token"))
                .header("Accept", "application/json")
                .POST(HttpRequest.BodyPublishers.ofString(requestBody))
                .build();
        var response = httpClient.send(request, HttpResponse.BodyHandlers.ofString());
            throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
        JsonNode root = mapper.readTree(response.body());
        cachedToken = root.get("access_token").asText();
        long expiresIn = root.get("expires_in").asLong();
        tokenExpiryEpoch = System.currentTimeMillis() + (expiresIn * 1000);
        return cachedToken;
Step 1: Construct Debug Payload with Node ID References and Branch Value Matrices
The CXone Flow Debug API requires a structured payload containing the initial context, breakpoint node IDs, and branch value matrices for conditional decision nodes. The branch matrix maps decision node identifiers to the exact branch values you want to evaluate during the debug session.
import com.fasterxml.jackson.databind.node.ObjectNode;
import java.util.List;
public class CxoneFlowDebugPayloadBuilder {
    public CxoneFlowDebugPayloadBuilder() {
     * Constructs the debug payload with node references, branch matrices, and breakpoint directives.
     * Required OAuth scope: flows:debug
    public String buildDebugPayload(String flowId,
                                    Map<String, Object> initialContext,
                                    List<String> breakpointNodeIds,
                                    Map<String, String> branchValueMatrix,
                                    int maxBreakpointDepth) {
        ObjectNode payload = mapper.createObjectNode();
        payload.put("flowId", flowId);
        // Initial context injection
        ObjectNode contextNode = mapper.createObjectNode();
        initialContext.forEach((k, v) -> contextNode.putPOJO(k, v));
        payload.set("initialContext", contextNode);
        // Breakpoint directive configuration
        ObjectNode debugOptions = mapper.createObjectNode();
        debugOptions.put("maxBreakpointDepth", maxBreakpointDepth);
        debugOptions.put("enableVariableDump", true);
        debugOptions.put("autoStepOnExpressionError", true);
        payload.set("debugOptions", debugOptions);
        // Breakpoint node list
        var breakpointArray = mapper.createArrayNode();
        breakpointNodeIds.forEach(breakpointArray::add);
        payload.set("breakpoints", breakpointArray);
        // Branch value matrix for conditional paths
        ObjectNode branchMatrix = mapper.createObjectNode();
        branchValueMatrix.forEach(branchMatrix::put);
        payload.set("branchValueMatrix", branchMatrix);
        return mapper.writeValueAsString(payload);
Step 2: Validate Debug Schema Against Orchestration Engine Constraints
Before sending the payload to the CXone orchestration engine, you must validate the schema against engine constraints. The CXone engine enforces a maximum breakpoint depth of 50 to prevent stack overflow during recursive flow evaluations. You must also verify expression syntax and null references in the initial context to prevent runtime evaluation failures.
import java.util.regex.Pattern;
public class CxoneDebugValidator {
    private static final int MAX_BREAKPOINT_DEPTH = 50;
    private static final Pattern EXPRESSION_PATTERN = Pattern.compile("^\\s*(\\$\\w+|\\[\\w+\\]|true|false|null|\\d+\\.?\\d*)\\s*([=<>!]+|\\|\\||&&)?\\s*(\\$\\w+|\\[\\w+\\]|true|false|null|\\d+\\.?\\d*)\\s*$");
    public CxoneDebugValidator() {
    public void validatePayload(String payloadJson, Map<String, Object> initialContext) throws Exception {
        JsonNode root = mapper.readTree(payloadJson);
        // Validate maximum breakpoint depth
        int depth = root.path("debugOptions").path("maxBreakpointDepth").asInt(0);
        if (depth > MAX_BREAKPOINT_DEPTH || depth <= 0) {
            throw new IllegalArgumentException("Breakpoint depth must be between 1 and " + MAX_BREAKPOINT_DEPTH + ". Received: " + depth);
        // Validate breakpoint node IDs format
        JsonNode breakpoints = root.path("breakpoints");
        if (!breakpoints.isArray() || breakpoints.size() == 0) {
            throw new IllegalArgumentException("Breakpoints array must contain at least one valid node ID.");
        // Null reference verification pipeline
        if (initialContext != null) {
            for (Map.Entry<String, Object> entry : initialContext.entrySet()) {
                if (entry.getKey() == null) {
                    throw new IllegalArgumentException("Context key cannot be null.");
                if (entry.getValue() == null) {
                    System.out.println("[WARN] Null value detected for context key: " + entry.getKey() + ". Flow engine may default to null evaluation.");
        // Expression syntax checking for branch matrix values
        JsonNode branchMatrix = root.path("branchValueMatrix");
        if (branchMatrix.isObject()) {
            branchMatrix.fields().forEachRemaining(field -> {
                String value = field.getValue().asText();
                if (!EXPRESSION_PATTERN.matcher(value).matches()) {
                    System.out.println("[WARN] Branch matrix value for node " + field.getKey() + " does not match standard CXone expression syntax. Engine may reject evaluation.");
Step 3: Handle Path Evaluation via Atomic PATCH Operations and Variable Dump Triggers
After initiating the debug session with a POST request, the CXone engine returns a debugSessionId. You control path evaluation using atomic PATCH operations against /api/v2/flows/{flowId}/debug/{sessionId}. Each PATCH request advances the execution pointer, triggers variable dumps, and returns the current node state. You must implement retry logic for 429 rate limits and verify response format before proceeding.
import java.util.concurrent.ThreadLocalRandom;
public class CxoneDebugSessionExecutor {
    private final String accessToken;
    private final String flowId;
    private String debugSessionId;
    public CxoneDebugSessionExecutor(String baseUrl, String accessToken, String flowId) {
        this.accessToken = accessToken;
        this.flowId = flowId;
                .connectTimeout(Duration.ofSeconds(15))
                .build();
    public String startDebugSession(String payloadJson) throws Exception {
                .uri(URI.create(baseUrl + "/api/v2/flows/" + flowId + "/debug"))
                .header("Authorization", "Bearer " + accessToken)
                .POST(HttpRequest.BodyPublishers.ofString(payloadJson))
                .build();
        handleRateLimit(response);
        if (response.statusCode() != 200 && response.statusCode() != 201) {
            throw new RuntimeException("Debug session creation failed with status " + response.statusCode() + ": " + response.body());
        this.debugSessionId = root.get("debugSessionId").asText();
        System.out.println("[DEBUG] Session started: " + debugSessionId);
        return debugSessionId;
    public JsonNode stepPath(Map<String, Object> stepPayload) throws Exception {
        String jsonBody = mapper.writeValueAsString(stepPayload);
                .uri(URI.create(baseUrl + "/api/v2/flows/" + flowId + "/debug/" + debugSessionId))
                .method("PATCH", HttpRequest.BodyPublishers.ofString(jsonBody))
                .build();
            throw new RuntimeException("Path step failed with status " + response.statusCode() + ": " + response.body());
        return mapper.readTree(response.body());
    private void handleRateLimit(HttpResponse<String> response) throws Exception {
        if (response.statusCode() == 429) {
            long retryAfter = Long.parseLong(response.headers().firstValue("Retry-After").orElse("5"));
            System.out.println("[WARN] Rate limited (429). Retrying after " + retryAfter + " seconds.");
            Thread.sleep(retryAfter * 1000);
Step 4: Synchronize Debugging Events, Track Latency, and Generate Audit Logs
You must synchronize debugging events with external IDE remote consoles via webhook callbacks, track path resolution latency, and generate structured audit logs for logic governance. The following class orchestrates the complete debug loop, enforces infinite loop prevention via step counters, and exports metrics.
import java.time.Instant;
import java.util.ArrayList;
public class CxoneConditionalDebugger {
    private final CxoneAuthClient authClient;
    private final CxoneFlowDebugPayloadBuilder payloadBuilder;
    private final CxoneDebugValidator validator;
    private final CxoneDebugSessionExecutor executor;
    private final HttpClient webhookClient;
    private final String webhookUrl;
    private final int maxStepLimit;
    private long sessionStartNanos;
    private int stepsExecuted;
    private List<Map<String, Object>> auditLog = new ArrayList<>();
    public CxoneConditionalDebugger(String clientId, String clientSecret, String baseUrl,
                                    String flowId, String webhookUrl, int maxStepLimit) {
        this.authClient = new CxoneAuthClient(clientId, clientSecret, baseUrl);
        this.payloadBuilder = new CxoneFlowDebugPayloadBuilder();
        this.validator = new CxoneDebugValidator();
        this.webhookClient = HttpClient.newHttpClient();
        this.webhookUrl = webhookUrl;
        this.maxStepLimit = maxStepLimit;
        String token = null;
            token = authClient.getAccessToken();
        } catch (Exception e) {
            throw new RuntimeException("Authentication failed", e);
        this.executor = new CxoneDebugSessionExecutor(baseUrl, token, flowId);
    public void runConditionalDebug(Map<String, Object> initialContext,
                                    List<String> breakpoints,
                                    Map<String, String> branchMatrix) throws Exception {
        String payloadJson = payloadBuilder.buildDebugPayload(
                executor.flowId, initialContext, breakpoints, branchMatrix, 25
        validator.validatePayload(payloadJson, initialContext);
        sessionStartNanos = System.nanoTime();
        stepsExecuted = 0;
        auditLog.clear();
        String sessionId = executor.startDebugSession(payloadJson);
        logAudit("SESSION_START", Map.of("sessionId", sessionId));
        JsonNode currentState;
        do {
            stepsExecuted++;
            if (stepsExecuted > maxStepLimit) {
                throw new RuntimeException("Infinite loop prevention triggered. Step limit exceeded: " + maxStepLimit);
            var stepPayload = Map.of(
                    "action", "step",
                    "dumpVariables", true,
                    "evaluateConditions", true
            long stepStart = System.nanoTime();
            currentState = executor.stepPath(stepPayload);
            long stepDuration = System.nanoTime() - stepStart;
            String currentNodeId = currentState.path("currentNodeId").asText("unknown");
            JsonNode variables = currentState.path("variableDump");
            logAudit("STEP_EXECUTED", Map.of(
                    "step", stepsExecuted,
                    "nodeId", currentNodeId,
                    "latencyMs", stepDuration / 1_000_000,
                    "variables", mapper.writeValueAsString(variables)
            sendWebhookSync(Map.of(
                    "sessionId", sessionId,
                    "timestamp", Instant.now().toString()
            System.out.println("[STEP " + stepsExecuted + "] Node: " + currentNodeId + " | Latency: " + (stepDuration / 1_000_000) + "ms");
        } while (!currentState.path("status").asText().equals("completed") &&
                 !currentState.path("status").asText().equals("error"));
        long totalDuration = (System.nanoTime() - sessionStartNanos) / 1_000_000;
        double pathResolutionRate = stepsExecuted / ((double) totalDuration / 1000.0);
        System.out.println("[COMPLETE] Total Steps: " + stepsExecuted + " | Total Latency: " + totalDuration + "ms | Resolution Rate: " + String.format("%.2f", pathResolutionRate) + " steps/sec");
        logAudit("SESSION_COMPLETE", Map.of(
                "totalSteps", stepsExecuted,
                "totalLatencyMs", totalDuration,
                "resolutionRate", pathResolutionRate
    private void logAudit(String eventType, Map<String, Object> data) {
        Map<String, Object> logEntry = Map.of(
                "timestamp", Instant.now().toString(),
                "eventType", eventType,
                "data", data
        auditLog.add(logEntry);
        System.out.println("[AUDIT] " + mapper.valueToTree(logEntry));
    private void sendWebhookSync(Map<String, Object> payload) {
                    .uri(URI.create(webhookUrl))
                    .POST(HttpRequest.BodyPublishers.ofString(mapper.writeValueAsString(payload)))
                    .build();
            webhookClient.send(request, HttpResponse.BodyHandlers.ofString());
            System.err.println("[WARN] Webhook sync failed: " + e.getMessage());
    public List<Map<String, Object>> getAuditLog() {
        return auditLog;
public class Main {
            String clientId = "YOUR_CLIENT_ID";
            String clientSecret = "YOUR_CLIENT_SECRET";
            String baseUrl = "https://api.niceincontact.com";
            String flowId = "YOUR_FLOW_ID";
            String webhookUrl = "https://your-ide-webhook.local/debug/sync";
            var initialContext = Map.of(
                    "customerType", "premium",
                    "orderTotal", 150.0,
                    "region", "US"
            var breakpoints = List.of("decision_node_01", "routing_node_02", "exit_node_03");
            var branchMatrix = Map.of(
                    "decision_node_01", "$customerType == premium",
                    "routing_node_02", "$orderTotal > 100"
            var debugger = new CxoneConditionalDebugger(
                    clientId, clientSecret, baseUrl, flowId, webhookUrl, 100
            debugger.runConditionalDebug(initialContext, breakpoints, branchMatrix);
            System.out.println("\n[AUDIT LOG EXPORT]");
            debugger.getAuditLog().forEach(entry -> System.out.println(entry));
            e.printStackTrace();
  • Cause: Expired OAuth token, invalid client credentials, or missing flows:debug scope.
  • Fix: Regenerate the access token using the CxoneAuthClient cache refresh logic. Verify the client credentials have the flows:debug scope assigned in the CXone admin console.
  • Code Fix: The getAccessToken() method automatically refreshes tokens when expires_in approaches zero. Ensure you call it before every debug session.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permission to debug the specific flow, or the flow is locked by another user.
  • Fix: Assign the flows:debug and flows:read scopes to the API client. Ensure the flow is not in a published/locked state that blocks debug sessions.
  • Code Fix: Catch the 403 explicitly and log the flow ID for permission auditing.
  • Cause: Exceeding CXone API rate limits during rapid PATCH stepping or concurrent debug sessions.
  • Fix: Implement exponential backoff. The handleRateLimit method reads the Retry-After header and pauses execution.
  • Code Fix: Increase the Retry-After wait time if cascading 429s occur. Reduce step frequency by adding Thread.sleep(100) between PATCH calls in high-throughput scenarios.
Error: 500 Internal Server Error / Expression Evaluation Failure
  • Cause: Invalid branch matrix syntax, null reference in context, or exceeding maximum breakpoint depth.
  • Fix: Run the CxoneDebugValidator pipeline before sending payloads. Verify all context keys exist and branch values match CXone expression syntax ($variable operator value).
  • Code Fix: The validator throws IllegalArgumentException for depth violations and logs warnings for syntax mismatches. Adjust the branchValueMatrix to use exact CXone conditional syntax.
