Dears,
Kindly appreciate your support, i have an issue while trying to debug a voice application with composer, im using x-lite for testing , i receive the below message when i try to debug my app,
Could not start the debug target
Transaction from “Debugger” sip:debugger@:50600*.*.*.* to “6050” sip:6050@:6345*.*.*.* timed out
Check/troubleshoot SIP signalization - it looks like you are using incorrect configuration for SIP endpoint which leads the SIP endpoints are not available or something like that
50600?
Sent from my Redmi Note 3 using Tapatalk
how?
Yes it is the default port for the debugger
If using Windows 10 it was tricky, I had to open an esr for make it work
Will find my notes on it and share them
