Debugging Genesys Cloud Flow Execution Traces via Debug API with Python SDK
This tutorial builds a Python diagnostic module that queries Genesys Cloud flow execution traces, reconstructs decision node paths through recursive step traversal, detects runtime anomalies via variable drift analysis, and exports structured debug artifacts with latency tracking and audit logging.
It uses the Genesys Cloud Flows Debug API and the official genesyscloud Python SDK.
The implementation runs in Python 3.9+ and produces production-ready JSON exports for external observability platforms.
  • OAuth client type: Confidential or Public client with flow:debug:read scope
  • SDK version: genesyscloud>=2.20.0
  • Language/runtime: Python 3.9+
  • External dependencies: pip install genesyscloud httpx pydantic click
  • Environment variables: GENESYS_REGION, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. The Python SDK handles token acquisition, caching, and automatic refresh. You must configure the client with the correct region and credentials before any API call.
import os
import logging
from genesyscloud import PlatformClient, Configuration
logger = logging.getLogger("flow_debugger")
def initialize_platform_client() -> PlatformClient:
    """Initialize the Genesys Cloud platform client with OAuth configuration."""
    config = Configuration(
        environment=os.getenv("GENESYS_REGION", "mypurecloud.com"),
        client_id=os.getenv("GENESYS_CLIENT_ID"),
        client_secret=os.getenv("GENESYS_CLIENT_SECRET"),
        scope=["flow:debug:read"]
    # SDK automatically caches tokens and refreshes before expiration
    client = PlatformClient(config)
    return client
The SDK stores the access token in memory and refreshes it when the response returns 401 Unauthorized. You must catch genesyscloud.api_exception.ApiException and verify the scope if authentication fails repeatedly.
Step 1: Construct Trace Query Payloads and Validate Constraints
The Flows Debug API accepts a structured query payload to filter traces by flow version, interaction session, and variable snapshot ranges. Genesys Cloud enforces a default retention policy of 30 days. Queries older than the retention window return empty results. You must validate the date range before submission.
from typing import Dict, Any
import httpx
from genesyscloud.flows.model import FlowsDebugTraceQuery, FlowsDebugTraceQueryVariableSnapshotRange
def build_trace_query(
    flow_version_id: str,
    session_token: str,
    start_time: datetime,
    end_time: datetime,
    snapshot_ranges: list[Dict[str, int]]
) -> FlowsDebugTraceQuery:
    """Construct a validated trace query payload."""
    # Validate retention constraint (30 days default)
    max_age = timedelta(days=30)
    if (end_time - start_time) > max_age:
        raise ValueError("Query range exceeds retention policy. Maximum span is 30 days.")
    # Build snapshot ranges model
    snapshot_models = [
        FlowsDebugTraceQueryVariableSnapshotRange(
            start_step_index=r["start_step_index"],
            end_step_index=r["end_step_index"]
        ) for r in snapshot_ranges
    query = FlowsDebugTraceQuery(
        flow_version_id=flow_version_id,
        session_token=session_token,
        start_date_time=start_time.isoformat(),
        end_date_time=end_time.isoformat(),
        variable_snapshot_ranges=snapshot_models,
        page_size=25
    return query
The raw HTTP equivalent shows the exact request structure. This helps you debug payload serialization issues.
def post_trace_query_raw(client: PlatformClient, query: FlowsDebugTraceQuery) -> Dict[str, Any]:
    """Execute trace query with explicit HTTP cycle for debugging."""
    base_url = f"https://{client.configuration.environment}"
    endpoint = "/api/v2/flows/debug/traces/query"
    headers = {
        "Authorization": f"Bearer {client.get_access_token()}",
        "Accept": "application/json"
    payload = query.to_dict()
    with httpx.Client(timeout=30.0) as http:
        response = http.post(f"{base_url}{endpoint}", headers=headers, json=payload)
            retry_after = int(response.headers.get("Retry-After", 2))
            logger.warning("Rate limited. Retrying in %d seconds.", retry_after)
            time.sleep(retry_after)
        response.raise_for_status()
        return response.json()
Required OAuth scope: flow:debug:read. Missing scope returns 403 Forbidden.
Step 2: Recursive Step Traversal and State Reconstruction
Flow traces contain a linear sequence of execution steps. Complex decision nodes branch into multiple paths. You must traverse steps recursively to reconstruct the exact execution path and maintain variable state across transitions.
from genesyscloud.flows.api import FlowsApi
from genesyscloud.api_exception import ApiException
def reconstruct_execution_path(trace_id: str, client: PlatformClient) -> Dict[str, Any]:
    """Fetch trace steps with pagination and reconstruct execution state."""
    flows_api = FlowsApi(client)
    steps = []
    next_token = None
    variable_state = {}
    execution_path = []
    while True:
            response = flows_api.get_flows_debug_trace_steps(
                trace_id=trace_id,
                page_size=100,
                next_page_token=next_token
        except ApiException as e:
            if e.status == 429:
                time.sleep(int(e.headers.get("Retry-After", 2)))
            raise
        if not response.body or not hasattr(response.body, "entities"):
            break
        steps.extend(response.body.entities)
        next_token = response.body.next_page_token
        if not next_token:
            break
    # Reconstruct state and path
    for step in steps:
        step_data = step.to_dict()
        step_type = step_data.get("type", "unknown")
        step_status = step_data.get("status", "unknown")
        variables = step_data.get("variables", {})
        # Update variable state
        variable_state.update(variables)
        # Track decision node branches
        if step_type == "decision" and step_status == "success":
            next_step_id = step_data.get("nextStepId")
            execution_path.append({
                "step_id": step_data.get("id"),
                "type": step_type,
                "branch_taken": next_step_id,
                "variables_snapshot": dict(variable_state)
        else:
                "type": step_type,
                "status": step_status,
        "trace_id": trace_id,
        "total_steps": len(steps),
        "execution_path": execution_path,
        "final_variable_state": variable_state
Pagination uses next_page_token. The SDK handles cursor-based pagination automatically. You must process entities in order because Genesys Cloud returns steps chronologically.
Step 3: Anomaly Detection and Variable Drift Analysis
Runtime failures often manifest as unexpected variable mutations or repeated error codes. This function scans the reconstructed path for error patterns and calculates variable drift between consecutive steps.
import re
from collections import Counter
def detect_anomalies(path_data: Dict[str, Any]) -> Dict[str, Any]:
    """Analyze execution path for error patterns and variable drift."""
    anomalies = {
        "error_codes": [],
        "variable_drift": [],
        "failed_decision_nodes": [],
        "summary": ""
    path = path_data.get("execution_path", [])
    error_pattern = re.compile(r"^(error|timeout|validation_error|service_unavailable)$")
    # Track previous state for drift calculation
    previous_state = {}
    for i, step in enumerate(path):
        status = step.get("status", "")
        variables = step.get("variables_snapshot", {})
        step_type = step.get("type", "")
        # Error code pattern matching
        if error_pattern.match(status):
            anomalies["error_codes"].append({
                "step_index": i,
                "step_id": step.get("step_id"),
                "status": status
        # Decision node failure tracking
        if step_type == "decision" and status != "success":
            anomalies["failed_decision_nodes"].append({
                "status": status
        # Variable drift analysis
        current_keys = set(variables.keys())
        previous_keys = set(previous_state.keys())
        new_variables = current_keys - previous_keys
        removed_variables = previous_keys - current_keys
        for key in current_keys:
            if key in previous_state:
                old_val = previous_state[key]
                new_val = variables[key]
                if old_val != new_val:
                    anomalies["variable_drift"].append({
                        "step_index": i,
                        "variable": key,
                        "old_value": old_val,
                        "new_value": new_val,
                        "drift_type": "value_change" if type(old_val) == type(new_val) else "type_change"
        if new_variables:
                "step_index": i,
                "variable": "NEW",
                "old_value": None,
                "new_value": dict({k: variables[k] for k in new_variables}),
                "drift_type": "injection"
        if removed_variables:
                "step_index": i,
                "variable": "REMOVED",
                "old_value": dict({k: previous_state[k] for k in removed_variables}),
                "new_value": None,
                "drift_type": "scope_exit"
        previous_state = variables
    # Generate summary
    error_count = len(anomalies["error_codes"])
    drift_count = len(anomalies["variable_drift"])
    anomalies["summary"] = f"Detected {error_count} errors and {drift_count} variable drift events."
    return anomalies
Variable drift flags type changes, value mutations, and scope exits. This isolates runtime failures caused by unexpected data transformations in dynamic flows.
Step 4: JSON Export, Latency Tracking and Audit Logging
External observability platforms require standardized JSON exports. You must track query latency, step resolution accuracy, and generate audit logs for security governance.
import json
def export_debug_artifacts(
    trace_id: str,
    path_data: Dict[str, Any],
    anomalies: Dict[str, Any],
    query_latency_ms: float,
    step_resolution_accuracy: float,
    operator_id: str
) -> str:
    """Export structured debug artifacts with audit metadata."""
    timestamp = datetime.utcnow().isoformat()
    audit_log = {
        "event": "flow_trace_debug",
        "timestamp": timestamp,
        "operator_id": operator_id,
        "scopes_used": ["flow:debug:read"],
        "query_latency_ms": query_latency_ms,
        "step_resolution_accuracy": step_resolution_accuracy,
        "total_steps_processed": path_data.get("total_steps", 0),
        "anomaly_summary": anomalies.get("summary", "")
    artifact = {
        "metadata": {
            "export_timestamp": timestamp,
            "genesys_trace_id": trace_id,
            "diagnostic_version": "1.0.0"
        "audit": audit_log,
        "execution_data": path_data,
        "anomaly_analysis": anomalies
    return json.dumps(artifact, indent=2, default=str)
The export includes latency tracking and step resolution accuracy. You calculate accuracy by dividing successfully resolved steps by total steps. The audit log records operator identity, scopes, and query performance for compliance review.
The following script combines all components into a runnable diagnostic workflow. Replace the environment variables with your credentials before execution.
#!/usr/bin/env python3
import os
import logging
import click
    return PlatformClient(config)
def build_trace_query(flow_version_id: str, session_token: str) -> FlowsDebugTraceQuery:
    end_time = datetime.utcnow()
    start_time = end_time - timedelta(hours=2)
    snapshot_ranges = [
        {"start_step_index": 0, "end_step_index": 50}
    snapshot_models = [
    return FlowsDebugTraceQuery(
        page_size=25
def reconstruct_execution_path(trace_id: str, client: PlatformClient) -> dict:
    steps = []
    next_token = None
    variable_state = {}
    execution_path = []
    while True:
                trace_id=trace_id,
                page_size=100,
            if e.status == 429:
            raise
            break
        if not next_token:
            break
    for step in steps:
            "type": step_type,
def detect_anomalies(path_data: dict) -> dict:
    anomalies = {"error_codes": [], "variable_drift": [], "failed_decision_nodes": [], "summary": ""}
    previous_state = {}
        if status in ("error", "timeout", "validation_error"):
            anomalies["error_codes"].append({"step_index": i, "step_id": step.get("step_id"), "status": status})
            anomalies["failed_decision_nodes"].append({"step_id": step.get("step_id"), "status": status})
            if key in previous_state and previous_state[key] != variables[key]:
                    "step_index": i, "variable": key,
                    "old_value": previous_state[key], "new_value": variables[key],
                    "drift_type": "value_change" if type(previous_state[key]) == type(variables[key]) else "type_change"
    anomalies["summary"] = f"Detected {len(anomalies['error_codes'])} errors and {len(anomalies['variable_drift'])} variable drift events."
    return anomalies
def run_diagnostic(flow_version_id: str, session_token: str, operator_id: str) -> str:
    client = initialize_platform_client()
    query = build_trace_query(flow_version_id, session_token)
        response = flows_api.post_flows_debug_traces_query(body=query)
        logger.error("Query failed: %s", e.body)
        raise
    query_latency_ms = (time.perf_counter() - start_time) * 1000
    if not response.body or not hasattr(response.body, "entities") or len(response.body.entities) == 0:
        raise ValueError("No traces found matching query constraints.")
    trace_id = response.body.entities[0].id
    path_data = reconstruct_execution_path(trace_id, client)
    anomalies = detect_anomalies(path_data)
    step_resolution_accuracy = len(path_data.get("execution_path", [])) / max(path_data.get("total_steps", 1), 1)
    artifact_json = export_debug_artifacts(
        trace_id=trace_id,
        path_data=path_data,
        anomalies=anomalies,
        query_latency_ms=query_latency_ms,
        step_resolution_accuracy=step_resolution_accuracy,
        operator_id=operator_id
    output_file = f"flow_debug_{trace_id}_{datetime.utcnow().strftime('%Y%m%d_%H%M%S')}.json"
    with open(output_file, "w") as f:
        f.write(artifact_json)
    logger.info("Diagnostic export saved to %s", output_file)
    return output_file
def export_debug_artifacts(trace_id, path_data, anomalies, query_latency_ms, step_resolution_accuracy, operator_id):
    import json
    audit_log = {
        "event": "flow_trace_debug", "timestamp": timestamp, "operator_id": operator_id,
        "trace_id": trace_id, "scopes_used": ["flow:debug:read"],
        "query_latency_ms": query_latency_ms, "step_resolution_accuracy": step_resolution_accuracy,
    artifact = {
        "metadata": {"export_timestamp": timestamp, "genesys_trace_id": trace_id, "diagnostic_version": "1.0.0"},
        "audit": audit_log, "execution_data": path_data, "anomaly_analysis": anomalies
    run_diagnostic(
        flow_version_id="your-flow-version-id",
        session_token="your-interaction-session-token",
        operator_id="svc-flow-debugger"
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the flow:debug:read scope or the operator role does not have flow debugging permissions.
  • How to fix it: Update the client configuration to include scope=["flow:debug:read"]. Verify the user role in the Genesys Cloud admin console has the “Flow Debugger” permission set.
  • Code showing the fix:
    environment="mypurecloud.com",
    scope=["flow:debug:read", "flow:read"]  # Add required scope
  • What causes it: The debug endpoints enforce strict rate limits to protect trace storage performance. Rapid pagination or concurrent queries trigger throttling.
  • How to fix it: Implement exponential backoff with jitter. Respect the Retry-After header.
import random
def retry_with_backoff(max_retries=3):
            return flows_api.get_flows_debug_trace_steps(trace_id=trace_id, page_size=100)
            if e.status != 429:
                raise
            wait_time = min(2 ** attempt + random.uniform(0, 1), 30)
            logger.warning("Rate limited. Waiting %.2f seconds.", wait_time)
            time.sleep(wait_time)
    raise RuntimeError("Max retries exceeded for 429 response.")
Error: 404 Not Found
  • What causes it: The trace ID is invalid, the flow version was archived, or the trace expired beyond the retention window.
  • How to fix it: Verify the flow version ID matches an active or recently archived version. Ensure the query date range falls within the retention policy.
# Validate trace existence before step traversal
    response = flows_api.get_flows_debug_trace(trace_id=trace_id)
    if response.status != 200:
        raise ValueError(f"Trace {trace_id} not found or expired.")
    logger.error("Trace validation failed: %s", e.body)
