Debugging Genesys Cloud CX WebRTC Connection Issues Related to ICE Candidate Conflicts and NAT Traversal Failures
This guide provides a technical framework for diagnosing and resolving WebRTC media negotiation failures in Genesys Cloud CX. You will learn how to analyze Interactive Connectivity Establishment (ICE) candidate gathering, identify Symmetric NAT blocking, and validate network pathing to ensure reliable audio streams for agents.
  • Licensing: Genesys Cloud CX 1, 2, or 3.
  • Permissions: Telephony > Station > View and User > Presence > View.
  • Administrative Access: Ability to modify corporate firewall rules or implement a Session Border Controller (SBC).
  • Tools: Chrome DevTools (chrome://webrtc-internals), Wireshark, and a network scanner (e.g., tcpdump or tshark).
  • External Dependencies: Access to the corporate network security team to validate UDP port ranges.
1. Analyzing the ICE Candidate Gathering Process
WebRTC does not use a single IP address for media. It uses the Interactive Connectivity Establishment (ICE) framework to find the most efficient path between the agent browser and the Genesys Cloud media plane. The browser gathers “candidates” (local IP, server-reflexive IP via STUN, and relayed IP via TURN).
To debug this, open chrome://webrtc-internals in the agent browser while attempting to go “On Queue.” Look for the setLocalDescription and setRemoteDescription events.
The Trap: Engineers often assume a “Connected” status in the UI means the media path is healthy. However, if the browser fails to gather “srflx” (server-reflexive) candidates and falls back to “relay” candidates, the agent may experience higher latency or one-way audio. If the browser only gathers “host” candidates (internal IPs), the connection will fail immediately for any agent not on the same subnet as the media server.
Architectural Reasoning: We prioritize srflx candidates because they allow a direct peer-to-peer-like connection between the client and the Genesys Cloud Edge/Media plane via STUN. This minimizes the load on TURN servers and reduces the hop count, which is critical for maintaining low jitter and latency in VoIP.
2. Diagnosing NAT Traversal and Symmetric NAT Failures
Most enterprise networks utilize Network Address Translation (NAT). A “Full Cone” or “Restricted Cone” NAT usually allows WebRTC to function. However, a “Symmetric NAT” (common in high-security finance or government environments) changes the external port for every destination the internal host contacts.
When a Symmetric NAT is present, the STUN server cannot predict the port the Genesys Cloud media plane should send packets back to. This results in an “ICE Connection Failed” error.
The Trap: A common mistake is opening only the TCP ports for the Genesys Cloud UI. WebRTC media is almost exclusively UDP. If the firewall is configured to drop UDP packets or perform “SIP ALG” (Application Layer Gateway) inspection, it will modify the SIP headers or block the UDP stream entirely, leading to a “Connecting…” state that eventually times out.
Architectural Reasoning: To resolve Symmetric NAT issues, we must force the traffic through a TURN (Traversal Using Relays around NAT) server. This converts the UDP stream into a relayed stream. While this adds latency, it is the only way to guarantee connectivity when the network perimeter forbids direct UDP hole-punching.
3. Validating Network Pathing via API and IP Ranges
Before escalating to a carrier or network team, you must verify that the agent’s current public IP is not being throttled or blocked by the Genesys Cloud infrastructure.
First, retrieve the official Genesys Cloud IP ranges to ensure your firewall allow-lists are current.
Request:
GET /api/v2/ipranges
Response Analysis:
The returned JSON contains the public IP ranges for the specific region (e.g., us-east-1). You must ensure that your firewall permits outbound UDP traffic to these ranges on the ports required for WebRTC (typically 3478 for STUN/TURN and the dynamic range for media).
Next, verify that the station is correctly associated with the user and that the user is in the correct presence state to initiate a WebRTC session.
Request:
GET /api/v2/users/{userId}/presences/purecloud
If the user is “Available,” but GET /api/v2/stations does not return a station with a webRtcUserId matching the agent, the browser will never even attempt the ICE gathering process because there is no logical endpoint to bind to.
Edge Case 1: The “Zombie” Station Conflict
Failure Condition: The agent can log in and go “On Queue,” but every call results in immediate “Media Failure” or a dropped call after 5 seconds.
Root Cause: A “Zombie” session exists where the previous WebRTC registration has not timed out on the Genesys Cloud side, but the browser has a new session ID. This creates a conflict in the webRtcUserId mapping.
Solution: Force the agent to log out of all sessions and clear browser cache. Use the GET /api/v2/stations endpoint to verify if multiple stations are assigned to a single user, which can cause signaling confusion in certain browser versions.
Edge Case 2: VPN MTU Fragmentation
Failure Condition: ICE candidates are gathered successfully, and the connection is “Connected,” but audio is choppy or cuts out during high-bandwidth periods (e.g., when using screen sharing alongside voice).
Root Cause: The VPN adds encapsulation overhead, reducing the Maximum Transmission Unit (MTU). WebRTC packets (especially those with large security headers) may exceed the MTU, leading to fragmentation. Many corporate firewalls drop fragmented UDP packets.
Solution: Reduce the MTU on the agent’s virtual network adapter to 1300 bytes or implement a Split-Tunnel VPN configuration that routes Genesys Cloud IP ranges (obtained via /api/v2/ipranges) outside the VPN tunnel.
Edge Case 3: Local Firewall/Antivirus SSL Inspection
Failure Condition: The agent sees “WebRTC Connection Error” immediately upon loading the page, and chrome://webrtc-internals shows no candidates being gathered.
Root Cause: Deep Packet Inspection (DPI) or SSL Inspection on the local machine is intercepting the WebSocket connection used for signaling. If the signaling channel is compromised, the browser cannot receive the remote ICE candidates.
Solution: Add the Genesys Cloud domain and the specific STUN/TURN endpoints to the “Inspection Bypass” list of the local security software.
