Debugging Genesys Cloud CX Agent Presence Issues Caused by WebSocket Connection Interruptions and Heartbeat Failures
This guide provides the technical framework for diagnosing and resolving “ghost” presence states (where an agent appears Available or On Break despite being disconnected) caused by WebSocket instability. You will learn how to correlate network-level heartbeat failures with presence API states to identify if the root cause is local client instability, corporate proxy interference, or platform-side session timeouts.
  • Licensing: Genesys Cloud CX 1, 2, or 3.
  • Permissions:
    • Presence > User > View
    • Presence > User > Edit
    • Directory > User > View
  • OAuth Scopes: presence
  • External Dependencies: Access to browser developer tools (Chrome DevTools), corporate firewall/proxy logs, and the GET /api/v2/ipranges endpoint to validate whitelist configurations.
1. Analyzing the WebSocket Heartbeat Mechanism
Genesys Cloud utilizes a WebSocket connection to maintain a real-time state between the browser (or desktop app) and the platform. Presence is not a static database entry; it is a dynamic state maintained by a heartbeat. When the WebSocket connection is active, the client sends periodic “keep-alive” packets. If the platform stops receiving these heartbeats, it does not immediately flip the user to “Offline” to avoid mass-disconnects during momentary blips. Instead, it enters a grace period before the session is terminated.
The Trap: Engineers often mistake a “Presence” issue for a “Login” issue. If an agent is logged in but their presence is stuck, the authentication token is still valid, but the state-synchronization channel (WebSocket) has collapsed. Updating the presence via the UI will often fail or “snap back” to the previous state because the client is out of sync with the server.
Architectural Reasoning: We use WebSockets instead of polling the REST API every few seconds because polling thousands of agents for presence updates would create an unsustainable load on the API gateway and introduce unacceptable latency in routing calls to “Available” agents.
2. Correlating Network Layer Failures with API State
When an agent reports that they are “stuck” in a presence state, you must verify if the platform actually believes the user is online.
Step A: Validate the Platform State
Use the following API call to see what the server thinks the presence is:
  • Method: GET
  • Endpoint: /api/v2/users/{userId}/presences/purecloud
  • Example Payload:
  "presences": [
      "presence": {
        "presence": "AVAILABLE"
If the API returns AVAILABLE but the agent’s screen shows OFFLINE (or vice versa), you have a confirmed WebSocket synchronization failure.
Step B: Inspecting the WebSocket Frames
Open Chrome DevTools $\rightarrow$ Network Tab $\rightarrow$ WS (WebSockets). Filter for notifications. Look for the ping and pong frames.
  • If you see ping frames leaving the browser but no pong returning from the server, the issue is likely an intermediate proxy or firewall dropping long-lived TCP connections.
  • If the connection status is Closed or 1006 (Abnormal Closure), the heartbeat has failed.
The Trap: Many corporate firewalls have a “TCP Idle Timeout” set to 60 or 120 seconds. If the Genesys heartbeat interval is longer than the firewall timeout, the firewall silently drops the connection. The browser thinks the socket is open, but the packets are being discarded by the network appliance.
3. Validating Network Perimeter and IP Ranges
If heartbeat failures are systemic across a specific site or VPN subnet, you must validate that the network allows bidirectional traffic to all Genesys Cloud IP ranges.
Step A: Fetch Current IP Ranges
  • Method: GET
  • Endpoint: /api/v2/ipranges
This returns a list of all public IP addresses used by the platform. You must ensure that your network team has not only whitelisted these for HTTPS (Port 443) but has specifically ensured that WebSocket (WSS) traffic is not being intercepted by a Deep Packet Inspection (DPI) engine.
Architectural Reasoning: DPI engines often attempt to buffer packets to scan for malware. Because WebSockets are a continuous stream, the buffer delay can cause the platform to miss a heartbeat, triggering a session timeout and flipping the agent to an unavailable state.
4. Remediation via Presence Patching
When an agent is stuck in a “ghost” state due to a crashed WebSocket session, the most efficient way to force a state refresh is via a PATCH request. This forces the server to update the state and attempts to trigger a push notification to any active client sessions.
  • Method: PATCH
  • Request Body:
  "presence": "OFFLINE"
(Follow this by patching them back to AVAILABLE or their intended state).
The Trap: Do not use bulk presence updates (/api/v2/users/presences/purecloud/bulk) for debugging single-user WebSocket issues. Bulk calls are optimized for reporting and may not trigger the immediate session-refresh logic required to clear a hung WebSocket state.
Edge Case 1: The “Zombie” Session (Concurrent Logins)
The failure condition: An agent logs into the Genesys Cloud desktop app and a browser simultaneously. One session loses connection, but the other remains active. The agent’s presence remains AVAILABLE, but they are not receiving interactions.
The root cause: The platform sees an active heartbeat from the second session. The first session (the one the agent is actually using) has a broken WebSocket, but the server does not mark the user as offline because the second session is still “alive.”
The solution: Implement a strict policy of single-session usage or use the PATCH API to force the user to OFFLINE to kill all active presence heartbeats, then have the agent re-log into a single device.
Edge Case 2: Proxy-Induced 1006 Errors
The failure condition: Agents experience random presence flips to “Unavailable” every 5 to 15 minutes.
The root cause: A corporate proxy is performing “TCP Reset” on connections that have been open for a specific duration, regardless of activity. This is common in environments using legacy BlueCoat or Zscaler configurations.
The solution: Configure the proxy to bypass SSL inspection for the Genesys Cloud domains and increase the TCP idle timeout to at least 300 seconds.
Edge Case 3: Local CPU Saturation
The failure condition: Presence drops only during peak call volume when the agent has multiple browser tabs open.
The root cause: Browser “tab sleeping” or CPU throttling. When the browser throttles the JavaScript execution of a background tab, the WebSocket heartbeat timer is delayed. If the delay exceeds the platform’s timeout window, the session is terminated.
The solution: Instruct agents to keep the Genesys Cloud window in a dedicated, non-minimized window or use the standalone Desktop App, which has higher priority for OS resource allocation.
