Debugging Audio Codec Mismatch Issues in NICE CXone SIP Trunks by Forcing G.711u Payload Type Negotiation and Disabling Dynamic Payload ID Allocation
This guide details how to resolve audio quality issues stemming from codec mismatches in NICE CXone SIP trunks by explicitly configuring the G.711u codec and disabling dynamic payload allocation. The end result is a stable, high-quality audio connection with predictable codec negotiation, eliminating one-way audio, garbled sound, or complete silence on calls routed through the configured trunk.
  • CXone Licensing: Requires CXone Advanced Telephony, specifically SIP Trunking functionality.
  • CXone Permissions: Requires the Telephony > SIP Trunk > Edit permission. Access to the Trunk Configuration screen is essential.
  • Carrier Support: Requires the ability to configure your carrier to accept specific G.711u payload types. You will need to engage with your carrier’s technical support team.
  • Network Knowledge: Basic understanding of SIP signaling and RTP is assumed. Familiarity with network packet capture (Wireshark, tcpdump) is highly recommended for advanced troubleshooting.
  • OAuth Scopes: Not applicable for the configuration itself, but required for any API-driven monitoring or validation scripts.
1. Identifying the Codec Mismatch
The most common symptom of a codec mismatch is one-way audio, where the agent can hear the caller, but the caller cannot hear the agent, or vice-versa. Less frequent but equally frustrating are garbled or robotic audio, or complete silence. CXone does not automatically log codec negotiation failures in a readily accessible way. Therefore, the first step is confirming the issue isn’t related to other common causes (firewall rules, incorrect routing, etc.). The definitive method is capturing SIP and RTP traffic using a tool like Wireshark. Analyze the SDP (Session Description Protocol) in the SIP INVITE and ANSWER messages to determine the codecs being offered and accepted. Look for discrepancies between what CXone offers and what the carrier ultimately selects.
The Trap: Assuming the problem lies within CXone itself. Codec negotiation is a peer-to-peer process. CXone offers codecs, but the carrier decides which one to accept. Blaming CXone’s configuration before validating the carrier’s side is a waste of time.
2. Configuring CXone to Prioritize G.711u
CXone, by default, will attempt to negotiate the highest quality codec possible. While this is generally desirable, it can lead to issues if your carrier does not fully support those codecs, or if there are inconsistencies in their implementation. Explicitly prioritizing G.711u resolves this.
  1. Navigate to Admin > Telephony > SIP Trunks.
  2. Select the problematic trunk.
  3. Click Edit.
  4. Under the Outbound Settings section, locate the Codecs field. This is a comma-separated list of codec preferences.
  5. Enter G.711u as the first codec in the list. For example: G.711u,G.729,G.722,G.711a.
  6. Ensure the RTP Payload Type for G.711u is correctly specified. CXone typically defaults to 90 for G.711u. Do not change this unless your carrier explicitly requests a different payload type.
  7. Click Save.
The Trap: Simply adding G.711u to the list does not guarantee it will be used. The order of the list determines the priority. If a higher-preference codec fails to negotiate, CXone will fall back to the next one.
3. Disabling Dynamic Payload ID Allocation
Dynamic Payload ID allocation is a feature intended for flexibility in RTP. However, it can introduce ambiguity and negotiation failures, especially with older or less compliant SIP stacks. Disabling it and forcing static allocation simplifies the process.
  3. Click Edit.
  4. Under the Advanced Settings section, locate the Dynamic Payload ID Allocation checkbox.
  5. Uncheck this box.
  6. Click Save.
The Trap: Disabling dynamic payload allocation requires that the payload IDs configured in CXone (e.g., 90 for G.711u) exactly match the payload IDs your carrier is expecting. This is why carrier coordination is critical.
4. Carrier Configuration & Payload Type Alignment
This is the most crucial step, and where the majority of troubleshooting time will be spent. You must inform your carrier of your intention to force G.711u with a specific payload ID (typically 90). Request the following:
  1. Confirmation of G.711u Support: Ensure they fully support G.711u.
  2. Payload ID Agreement: Verify that their SIP stack is configured to accept G.711u using payload ID 90 (or the ID you’ve configured in CXone).
  3. SDP Inspection: Ask them to provide a sample SDP offer that they would send to your CXone trunk. This allows you to proactively identify potential discrepancies before deploying the changes.
The Trap: Assuming your carrier “supports G.711u” is insufficient. They must support it with the specific payload type you are configuring.
Edge Case 1: One-Way Audio Persists After Configuration
Failure Condition: Audio remains one-way even after configuring CXone and coordinating with the carrier.
Root Cause: Incorrect payload ID configuration on either the CXone or carrier side. The carrier might be expecting 91 or 92 instead of 90.
Solution: Double-check the payload ID configuration in CXone and verify with the carrier. Wireshark capture of the SDP is essential to pinpoint the discrepancy.
Edge Case 2: Audio Quality Degradation After Configuration
Failure Condition: Audio quality is significantly worse (robotic, choppy, dropped packets) after the configuration.
Root Cause: Network congestion or packet loss. Forcing G.711u requires more bandwidth than some lower-bandwidth codecs.
Solution: Investigate network connectivity between CXone and the carrier. Run ping tests and traceroutes to identify potential bottlenecks. Consider Quality of Service (QoS) configuration to prioritize RTP traffic.
Edge Case 3: Carrier Refuses to Configure Specific Payload IDs
Failure Condition: The carrier is unwilling or unable to configure specific payload IDs.
Root Cause: Limited flexibility in their SIP stack, or a policy against static configuration.
Solution: Explore alternative carriers. If changing carriers isn’t an option, attempt to negotiate a compromise. You might be able to agree on a different, mutually supported codec and payload ID.
