Data Action trace missing for DogStatsD metric POST
Hi all,
Got a weird one. We’re trying to push custom metrics from a Data Action to a DogStatsD collector for some APM tracking. Most of the time it’s fine, but occasionally the action just hangs and we get zero trace data in the logs. No error code, no 400, just… nothing!!
Is it a timeout? Probably. But the timeout is set to 30 seconds and it’s dropping way before that.
I’ve tried a few ways to debug this:
Option A: Use GET /api/v2/integrations/actions/{actionId} to check if the config is actually deployed or if there’s a mismatch between the draft and the live version.
Pro: Easy to verify.
Con: Doesn’t actually explain why the execution trace disappears during the hang.
Option B: Try to pull the draft config via GET /api/v2/integrations/actions/{actionId}/draft and compare the JSON body for any hidden characters or encoding issues that might be tripping up the request.
Pro: Catches schema errors.
Con: Takes forever to manually diff the JSON when you have 50+ parameters.
The request body looks clean, but the trace is just gone. We’ve checked the log pipeline and the metrics aren’t hitting the collector, but the Data Action isn’t reporting a failure either. It’s like the request just vanishes into the void.
 "action": "metric.post",
 "metric_name": "queue.wait_time",
 "value": 45,
 "tags": ["region:tokyo", "env:prod"]
The lack of a trace is just classic. It’s a total design flaw that the system can just swallow a request without giving you a proper error code when the remote server doesn’t respond exactly how Genesys expects. If the timeout isn’t triggering, it’s usually because the connection is technically “open” but the payload is just floating in limbo.
Check your REQUEST CONFIGURATION. Specifically, look at the HTTP headers. If you’ve got a mismatch in the Content-Type or a weird character in the body, the Data Action can sometimes just choke silently.
Since you can’t see the trace, the only real way to debug this is to pull the current config into a draft and tweak the timeout down to something aggressive, like 5 seconds, just to force an error. Use the /api/v2/integrations/actions/{actionId}/draft endpoint to grab the current setup and then push a change via the PATCH method.
 "configuration": {
 "request": {
 "timeout": 5000
Once you force the failure, you’ll actually get a log entry. It’s a pain to do this manually instead of having a real debug mode, but it’s the only way to see what’s actually happening under the hood.
