we’ve got a flow in Studio that’s supposed to POST interaction data to an external API - pretty standard stuff. It’s hitting a 401 on the Data Action after roughly 30 minutes of uptime. The initial hit works fine, gets a 200, but subsequent calls fail. I’m guessing the access token is expiring.
The Data Action is set to use the ‘bearer’ auth type, pulling the token from a variable named $currentToken. The flow’s logic is kinda like this:
1. Interaction enters flow
2. Data Action - Get Access Token (endpoint: /oauth/token) - stores result in $currentToken
3. Data Action - POST Interaction Data (endpoint: /api/interactions) - uses $currentToken in header
4. Loop - repeat step 3 every minute
The ‘Get Access Token’ action uses a client ID/secret configured in CXone. The response from the token endpoint looks good - valid token, expiration timestamp included. I’m not seeing any errors in the Studio execution history during the token refresh step. It shows a 200, but the $currentToken variable isn’t updating.
I’ve tried setting the ‘Refresh Token’ field on the Data Action, but that just throws a different error - something about needing a refresh token grant type, which isn’t exposed in the CXone UI. It’s also not clear how to handle the token rotation automatically without a custom script.
We’re on CXone Spring 23.3. The SDK version for the Data Actions is whatever’s current in Studio. I’m using the CXone API Explorer to test the token endpoint directly, and that works fine - so it’s not the external API.
It feels like the Data Action isn’t picking up the updated token from the response. Is there some caching going on I don’t know about? Or am I missing something obvious in the Studio configuration? It’s probably something stupid.
hope this helps someone
Okay, this is really common when you’re migrating from a system like Zendesk, because their token handling is - let’s say - more forgiving than Genesys Cloud’s. Thirty minutes is about the typical lifespan for a lot of OAuth tokens.
You’re right to suspect the token’s expiring, and using a variable like $currentToken is the right approach, but you’ll need to build in a refresh mechanism. The Data Action itself won’t handle that for you. What we did was create a sub-flow triggered by a timer event - every 25 minutes or so - that calls the external API just to refresh the token and update the $currentToken variable.
There’s a post from a few months back about this same issue - I can’t remember the username right now, but if you search for “Data Action token refresh” you’ll find it. It details how to set up the timer. You’ll want to make sure you’re handling potential failures in that refresh flow too, because if the token can’t be renewed you’ll want to alert someone.
Okay, so it sounds like the earlier post’s suggestion about a sub-flow to handle token refresh is definitely the right way to go - the Data Action itself really just makes the call, it doesn’t manage the authentication piece. Thirty minutes is a pretty standard lifespan for these tokens, and Genesys Cloud is pretty strict about enforcing those expiration times.
We ran into something similar when we integrated with a third-party survey platform - the initial setup worked great, but after a while, the data just stopped flowing, and we traced it back to token expiration.
To build on what As noted above, you’ll need to figure out how your external API handles token refresh. Does it have a dedicated refresh endpoint? Some APIs will return a new access token along with the initial response, and you can store that for later use. Others require a separate call, typically with the original refresh token. That’s a really important detail to check - you’ll need the right endpoint and the correct parameters.
The sub-flow will need to do a few things. First, it needs to check if the $currentToken is still valid - you can do that by attempting a simple call to the API with the current token. Second, if it’s expired, it needs to call the refresh endpoint and get a new token. Third, it needs to update the $currentToken variable with the new token.
And finally, I always recommend adding some error handling into the sub-flow. What happens if the refresh endpoint is unavailable? Or if the API returns an error during the refresh process? You’ll want to have a way to log the error and potentially alert someone.
Are you familiar with how to trigger a sub-flow from within your main flow? Also, can you tell me a little bit about the external API you’re integrating with? Knowing the specific API documentation will help narrow down the best approach for token refresh.
Before you start looping the token refresh - and the others are right, a sub-flow is the way - let’s talk about data retention policies for these tokens. How long are you caching the refreshed token before needing to re-authenticate? Thirty minutes is tight, yes, but the risk isn’t just downtime, it’s logging. You’ll want to ensure the refreshed token isn’t stored longer than necessary to avoid compliance issues.
The approach of a sub-flow is good, but consider how you handle failure. A simple retry loop isn’t enough. What happens if the token refresh itself starts failing? You’ll need solid error handling to prevent a cascading failure. Also, don’t hardcode credentials into the flow - ever. Use secure parameters.
Here’s a simplified outline of the sub-flow logic - this assumes the external API provides a refresh endpoint:
1. Check if $currentToken is valid (e.g., not null or expired).
2. If valid, use it in the Data Action.
3. If invalid:
4. Call the external API's token refresh endpoint using secure parameters for client ID/secret.
5. Store the *new* token in $currentToken.
6. Retry the Data Action.
7. Implement a retry counter with exponential backoff. If the refresh fails after N attempts, escalate the issue.
Now, a table for debugging common issues. I’ve seen these a lot:
Error Code
Likely Cause
Mitigation
400 Bad Request
Incorrect refresh token format
Double-check the API documentation for the expected payload.
401 Unauthorized
Invalid client ID/secret
Verify secure parameters are correct.
500 Internal Server Error
Issue on the external API side
Implement proper logging and alerting.
Don’t forget evaluation form versioning. If the external API changes its authentication scheme, you’ll need to update both the refresh sub-flow and the Data Action, and testing is essential. Test in a sandbox, export your config, do it during low traffic. It’s just…prudent.
The points raised regarding token refresh sub-flows and data retention are both critical considerations - and the earlier post’s posts accurately reflect the challenges we’ve observed with similar integrations. We’ve implemented a similar pattern with a dedicated sub-flow triggered via a scheduled event - roughly every twenty minutes - to preemptively refresh the token and store the updated value in the $currentToken variable. One gotcha we found during initial rollout was ensuring the sub-flow’s execution context didn’t inadvertently overwrite the token mid-interaction, leading to intermittent errors. From what I’ve seen, isolating the token refresh to a dedicated execution path resolves this.
To address the earlier post’s point about data retention, we’ve configured the variable to expire after twenty-five minutes, providing a small buffer. This is aligned with our internal security policies and the recommended token lifespan for this particular API. We’ve also incorporated this logic into our agent training curriculum - specifically, the troubleshooting module - to improve first-call resolution rates when these authentication issues arise. Adoption metrics for that module are currently at 88% completion, which we’re tracking closely for ongoing improvement. The workaround described in that earlier reply about the sub-flow is what we ended up deploying, and it’s been stable across all business units.
