Data Action - Metric POST to custom endpoint
Hey everyone,
So, we’ve got a weird one happening with a Data Action - intermittent 409 Conflicts when posting metrics to our custom endpoint. It’s pulling my hair out, honestly!! The flow’s pretty simple: interaction completes, Data Action fires, POSTs a JSON payload to our API. We’re using the REST API v2 - specifically /api/v2/integrations/actions/{actionId}/execute.
The payload itself is a standard metric set - call duration, queue time, agent ID, that sort of thing. We’re expecting 201 Created on success. But about 1 in 10-15 calls is returning a 409 Conflict. The response body is… unhelpful. Just a generic “resource already exists”.
Now, why would that be? Option A - we’re accidentally sending duplicate requests. Seems unlikely - the Data Action flow is designed to fire only once per interaction. The interaction GUID is included in the payload as a unique identifier, and our API is designed to handle idempotency. Option B - there’s some race condition on the Genesys Cloud side - maybe the Data Action is being triggered multiple times internally before we can process the first request. Possible, but it feels… off.
We’re logging everything on our end - request ID, timestamp, payload hash. No duplicates are showing up in our logs, which rules out client-side issues. I checked the Data Action execution history in the GC UI, and it only shows one execution attempt per interaction. The weird thing is the successes and failures seem completely random.
The Data Action is configured with a timeout of 10 seconds, and the target endpoint typically responds within 200ms. We’re on GC SDK v5.6.0. We’ve also tried increasing the timeout to 30 seconds, but that didn’t resolve the issue. The API key and auth settings are double checked.
What’s next? I’m thinking about adding a retry mechanism with exponential backoff within the Data Action flow, but that feels like masking a problem, not fixing it. It’s a band-aid. Maybe something is going wrong with the internal queuing of Data Actions?
  • The 409 conflict usually means something already exists with the same ID. Is your custom endpoint creating new records or updating existing ones? If it’s updating, maybe the data action is firing twice for the same interaction?
  • Try adding a unique identifier in the payload - something like the interaction ID or UUID - to help pinpoint duplicates.
  • The API docs say it’s okay to retry these - have you tried adding some retry logic on your side?
  • Here’s an example of the Data Action configuration, maybe you can check if the request.headers are correct.
resource "genesyscloud_dataaction" "example" {
 name = "example-data-action"
 action_type = "http"
 http_config {
 url = "https://your-custom-endpoint.com/metrics"
 method = "POST"
 content_type = "application/json"
 request_body = "{ \"interactionId\": \"{{interaction.id}}\", \"callDuration\": \"{{interaction.duration}}\" }"
 request_headers = {
 "X-Request-ID" = "{{request.id}}"
  • What’s the response code from your endpoint when you see the 409? Is it always the same? Sometimes the 409 is a bad error on the endpoint side - maybe the ID is being checked incorrectly there.
  • Are you using any environment variables? If yes, verify they are available in the Data Action scope.
The 409 Conflict usually means the request couldn’t be completed due to a conflict with the current state of the resource. It’s not always a duplicate ID - sometimes it’s a version mismatch.
Cause: client_app_sdk doesn’t automatically handle optimistic locking when pushing data action results. The execution endpoint expects an ETag header for conditional requests. If you omit it, or if the ETag you send is stale, the server rejects the update with a 409. The API returns this header in the GET response for the data action - it’s the current version.
Solution: You need to retrieve the initial ETag value, then include it in subsequent POST requests. Here’s how. First, get the data action details.
Retrieve the data action details via the API.
The response will contain an ETag in the headers. Then, include that same ETag in your POST request:
POST /api/v2/integrations/actions/{actionId}/execute
ETag: "some-etag-value"
 "metric1": "value1",
 "metric2": "value2"
If another process updates the data action in the meantime, the POST request will fail again, and you’ll need to repeat the process - fetch the latest ETag, then retry the POST. You’ll need to build retry logic on your side.
It’s also worth checking the data action configuration - if it’s configured to run multiple times, that could explain the intermittent behavior.
That 409 is…well, it’s a classic race condition, honestly. We’ve seen it a lot with Data Actions, documented in INC-4471, and it’s almost always about idempotency - or lack of it. the earlier post’s idea about the unique identifier is good, but make sure that identifier is actually used in your endpoint’s logic to prevent the create/update confusion. At my last shop, we wrapped the POST in a transaction with a unique transactionId in the header - and the endpoint checked for that before processing, so the Data Action could fire multiple times without causing conflicts. You might also want to check the Data Action’s maxAttempts setting - if it’s too high, you could be amplifying the problem.
