CX as Code: Exporting Entire Org Configuration for Disaster Recovery
- A Python script that authenticates to Genesys Cloud and systematically exports critical configuration entities into a structured JSON backup.
- This uses the Genesys Cloud REST API v2 via the official Python SDK (
genesyscloud). - The programming language covered is Python.
- OAuth Client: Service Account (Client Credentials Flow) with
adminrole or specific scopes required for reading configuration entities. - Required Scopes:
config:all,user:read,routing:read,organization:read,conversation:read(depending on depth of export). For a comprehensive org backup,config:allis typically sufficient for most static configuration, but user data requiresuser:read. - SDK Version:
genesyscloudPython SDK (v5.0.0+). - Runtime: Python 3.8+.
- Dependencies:
pip install genesyscloud requests.
The Genesys Cloud Python SDK handles OAuth token acquisition and refresh automatically when initialized with a Service Account client ID and secret. This is the most robust method for server-to-server integration, such as a disaster recovery export job.
import os
import json
import logging
from genesyscloud import Configuration, ApiClient
# Configure logging
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
class GenesysConfigExporter:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
Initialize the Genesys Cloud API client.
Args:
client_id: OAuth Client ID.
client_secret: OAuth Client Secret.
base_url: Genesys Cloud region URL (e.g., api.mypurecloud.com, api.us-gov-pure.cloud).
self.base_url = base_url
self.configuration = Configuration()
self.configuration.host = base_url
# Initialize the API client with service account credentials
self.api_client = ApiClient(configuration=self.configuration)
self.api_client.client_id = client_id
self.api_client.client_secret = client_secret
# Verify connection by attempting to fetch the org info
from genesyscloud.organization_api import OrganizationApi
org_api = OrganizationApi(api_client=self.api_client)
self.org_info = org_api.get_organization()
logger.info(f"Authenticated successfully to Org: {self.org_info.name} (ID: {self.org_info.id})")
except ApiException as e:
logger.error(f"Authentication failed: {e.body}")
raise
Note on Token Management: The ApiClient object caches the access token and automatically refreshes it when it expires. You do not need to manually implement a refresh loop for long-running export scripts.
Step 1: Exporting Core Organization Metadata
The first step is to capture the organizational identity and high-level settings. This provides the context for the backup.
def export_organization_metadata(self) -> Dict[str, Any]:
Exports the core organization details.
Returns:
Dictionary containing organization name, ID, and settings.
org_data = org_api.get_organization()
# Flatten the response for easier JSON serialization
org_dict = {
"id": org_data.id,
"name": org_data.name,
"settings": org_data.settings,
"country_code": org_data.country_code,
"currency_code": org_data.currency_code,
"timezone_id": org_data.timezone_id
logger.info("Exported Organization Metadata.")
return {"organization": org_dict}
logger.error(f"Failed to export organization metadata: {e.status} - {e.reason}")
return {"organization": None}
Step 2: Exporting Routing Queues and Skills
Queues are the backbone of CX configuration. We must export the queue definitions, including their skill requirements and member assignments.
OAuth Scope Required: routing:read
from genesyscloud.routing_api import RoutingApi
from genesyscloud.models import QueueWrapupCode, RoutingQueue
def export_routing_queues(self) -> List[Dict[str, Any]]:
Exports all routing queues.
Returns:
List of queue dictionaries.
queues_export = []
routing_api = RoutingApi(api_client=self.api_client)
# Pagination loop
page_number = 1
page_size = 250
while True:
response = routing_api.post_routing_queues(
expand=["members", "skills", "wrapupCodes"],
page_size=page_size,
page_number=page_number
if not response.entities:
break
for queue in response.entities:
# Convert SDK object to dict
queue_dict = queue.to_dict()
queues_export.append(queue_dict)
# Check if there are more pages
if page_number >= response.page_count:
break
page_number += 1
# Rate limit protection: Small delay between pages
time.sleep(0.5)
logger.info(f"Exported {len(queues_export)} queues.")
return queues_export
logger.error(f"Failed to export queues: {e.status} - {e.reason}")
return []
Key Parameter Explanation:
expand=["members", "skills", "wrapupCodes"]: By default, the API returns only the core queue object. To get a usable backup for disaster recovery, you must expand nested resources. Without this, you would need to make separate API calls for each queue to get its members, which is inefficient and prone to rate-limiting.
Step 3: Exporting Users and Roles
Users contain sensitive data and complex role assignments. We export the user list and their associated role IDs.
OAuth Scope Required: user:read
from genesyscloud.users_api import UsersApi
def export_users(self) -> List[Dict[str, Any]]:
Exports all active users.
Returns:
List of user dictionaries.
users_export = []
users_api = UsersApi(api_client=self.api_client)
page_number = 1
page_size = 50 # Users API often has stricter rate limits
while True:
response = users_api.post_users(
page_number=page_number,
expanded=["roles", "skills", "wrapupCodes"]
break
for user in response.entities:
user_dict = user.to_dict()
# Optional: Mask sensitive email fields for security in backup storage
# user_dict['email'] = "***"
users_export.append(user_dict)
break
page_number += 1
time.sleep(0.2) # Aggressive rate limit protection for Users API
logger.info(f"Exported {len(users_export)} users.")
return users_export
logger.error(f"Failed to export users: {e.status} - {e.reason}")
return []
Step 4: Exporting Wrap-up Codes
Wrap-up codes are shared across queues and are critical for reporting consistency.
def export_wrapup_codes(self) -> List[Dict[str, Any]]:
Exports all wrap-up codes.
Returns:
List of wrap-up code dictionaries.
wrapup_export = []
page_number = 1
page_size = 100
while True:
response = routing_api.post_routing_wrapupcodes(
break
for code in response.entities:
wrapup_export.append(code.to_dict())
break
page_number += 1
time.sleep(0.1)
logger.info(f"Exported {len(wrapup_export)} wrap-up codes.")
return wrapup_export
logger.error(f"Failed to export wrap-up codes: {e.status} - {e.reason}")
return []
Step 5: Exporting IVR Applications (Flow Data)
IVR applications are defined by JSON flow data. We export the list of IVR apps and their associated flow definitions.
def export_ivr_applications(self) -> List[Dict[str, Any]]:
Exports IVR application metadata and flow definitions.
Returns:
List of IVR application dictionaries.
ivr_export = []
page_number = 1
page_size = 50
while True:
response = routing_api.post_routing_ivrs(
expand=["application"],
break
for ivr in response.entities:
ivr_dict = ivr.to_dict()
ivr_export.append(ivr_dict)
break
page_number += 1
time.sleep(0.1)
logger.info(f"Exported {len(ivr_export)} IVR applications.")
return ivr_export
logger.error(f"Failed to export IVR applications: {e.status} - {e.reason}")
return []
This script ties all the components together into a single executable module. It creates a timestamped JSON file containing the entire configuration snapshot.
import os
import json
import logging
from datetime import datetime
# Configure logging
# Verify connection
logger.info(f"Authenticated successfully to Org: {self.org_info.name}")
raise
"id": org_data.id,
logger.error(f"Failed to export organization metadata: {e.reason}")
return {}
def _paginate(self, api_call_func, **kwargs) -> List[Dict[str, Any]]:
Generic pagination handler for list endpoints.
Args:
api_call_func: The API method to call (e.g., routing_api.post_routing_queues).
**kwargs: Arguments to pass to the API method (e.g., expand, page_size).
Returns:
List of entity dictionaries.
entities_export = []
page_number = 1
page_size = kwargs.pop('page_size', 250)
while True:
response = api_call_func(page_size=page_size, page_number=page_number, **kwargs)
break
for entity in response.entities:
entities_export.append(entity.to_dict())
break
page_number += 1
time.sleep(0.2) # Rate limit buffer
logger.error(f"Pagination error: {e.reason}")
break
return entities_export
logger.info("Exporting Routing Queues...")
return self._paginate(routing_api.post_routing_queues, expand=["members", "skills", "wrapupCodes"])
logger.info("Exporting Users...")
return self._paginate(users_api.post_users, expanded=["roles", "skills", "wrapupCodes"], page_size=50)
logger.info("Exporting Wrap-Up Codes...")
return self._paginate(routing_api.post_routing_wrapupcodes)
logger.info("Exporting IVR Applications...")
return self._paginate(routing_api.post_routing_ivrs, expand=["application"])
def run_export(self, output_dir: str = "./exports"):
Executes the full export process.
timestamp = datetime.now().strftime("%Y%m%d_%H%M%S")
filename = f"genesys_backup_{timestamp}.json"
filepath = os.path.join(output_dir, filename)
if not os.path.exists(output_dir):
os.makedirs(output_dir)
logger.info(f"Starting full configuration export to {filepath}")
backup_data = {
"export_timestamp": datetime.now().isoformat(),
"org_name": self.org_info.name,
"org_id": self.org_info.id,
"metadata": self.export_organization_metadata(),
"queues": self.export_routing_queues(),
"users": self.export_users(),
"wrapup_codes": self.export_wrapup_codes(),
"ivrs": self.export_ivr_applications()
with open(filepath, 'w', encoding='utf-8') as f:
json.dump(backup_data, f, indent=2, default=str)
logger.info(f"Export completed successfully. File size: {os.path.getsize(filepath)} bytes")
logger.error(f"Failed to write file: {e}")
# Load credentials from environment variables
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
BASE_URL = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
if not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required.")
exporter = GenesysConfigExporter(CLIENT_ID, CLIENT_SECRET, BASE_URL)
exporter.run_export()
Error: 403 Forbidden (Insufficient Scopes)
- Cause: The Service Account does not have the required OAuth scopes. For example, attempting to export users without
user:readwill result in a 403. - Fix: Go to the Genesys Cloud Admin Console → Settings → Security → OAuth. Edit the Client ID associated with your script and add the missing scopes (
routing:read,user:read,config:all). - Debug Code:
# Check scopes in your initialization print(self.api_client.api_key) # This won't show scopes directly, but verify in Admin Console
- Cause: Genesys Cloud APIs have strict rate limits (typically 60 requests per second for most endpoints, but lower for heavy entities like Users). The script makes sequential calls, but if you parallelize or run too fast, you will hit this.
- Fix: Increase the
time.sleep()duration in the_paginatemethod. For Users API, a 0.5s delay is safer than 0.2s. - Debug Code:
# In _paginate method if response.status == 429: retry_after = response.headers.get('Retry-After', 1) time.sleep(int(retry_after))
Error: 500 Internal Server Error (Large Payloads)
- Cause: Exporting very large orgs (10,000+ users) can sometimes cause serialization issues or timeout on the API side if the response payload is too large for the buffer.
- Fix: Split the export into smaller chunks. Instead of one giant JSON file, write each entity type to a separate file.
- Debug Code:
# Modify run_export to write separate files def write_chunk(self, filename: str, data: Any): with open(filename, 'w') as f: json.dump(data, f, indent=2, default=str)
