Customizing Genesys Cloud Webchat SDK Offline Mode with React and Atomic Sync Queues
- A React-based offline message queue that attaches cache identifiers, sync strategies, and expiry directives to Genesys Cloud Webchat SDK payloads.
- Schema validation against storage quotas and client engine constraints before enqueueing messages.
- Atomic dispatch operations with format verification, automatic sync triggers on reconnection, and conflict resolution pipelines.
- Service worker integration for background sync, webhook alignment, latency tracking, cache hit monitoring, and structured audit logging.
- Genesys Cloud Webchat SDK:
@genesyscloud/webchat-messenger-sdkv2.10.0 or higher - React 18+ with TypeScript 5+
- OAuth scope:
webchat:client:accessfor SDK initialization,analytics:events:writefor backend audit webhook - Node.js 18+ with npm or pnpm
- External dependencies:
ajv,uuid,idb,axios
The Genesys Cloud Webchat SDK operates using a client-side authentication flow. You must provision a Webchat Client in the Genesys Cloud Admin console and retrieve the orgId and deploymentId. The SDK handles token acquisition internally, but your backend audit webhook requires a valid bearer token with the analytics:events:write scope.
Initialize the SDK with offline mode enabled and attach a custom token provider if your environment requires dynamic authentication.
import { createWebchatClient } from '@genesyscloud/webchat-messenger-sdk';
import type { WebchatClientConfig } from '@genesyscloud/webchat-messenger-sdk';
export async function initializeWebchatClient(config: WebchatClientConfig) {
const client = await createWebchatClient({
orgId: config.orgId,
deploymentId: config.deploymentId,
offlineMode: true,
tokenProvider: config.tokenProvider,
onStatusChange: (status) => {
console.log(`Webchat status: ${status}`);
return client;
} catch (error) {
if (error instanceof Error && error.message.includes('401')) {
throw new Error('Authentication failed. Verify orgId and deploymentId.');
throw error;
OAuth Scope Required: webchat:client:access
Endpoint: Internal SDK WebSocket/SSE handshake
Error Handling: The SDK throws a 401 if credentials are invalid. The wrapper catches it and rethrows a structured error.
Step 1: Schema Validation and Storage Quota Enforcement
Before any message enters the offline queue, you must validate the payload structure and verify that the client storage quota will not be exceeded. Genesys Cloud enforces a maximum payload size of 10 KB per message and a strict JSON schema for custom attributes.
import Ajv from 'ajv';
import type { MessagePayload } from './types';
const MAX_STORAGE_QUOTA_BYTES = 5242880; // 5 MB
const MAX_PAYLOAD_BYTES = 10240; // 10 KB
const ajv = new Ajv({ strict: true });
const messageSchema = {
type: 'object',
properties: {
cacheId: { type: 'string', format: 'uuid' },
strategy: { enum: ['immediate', 'batched', 'deferred'] },
expiry: { type: 'number', minimum: 0 },
body: { type: 'string', maxLength: 2000 },
metadata: { type: 'object' }
required: ['cacheId', 'strategy', 'expiry', 'body'],
additionalProperties: false
const validateSchema = ajv.compile(messageSchema);
export function validateAndEnforceQuota(payload: MessagePayload, currentQuotaUsed: number): boolean {
const payloadBytes = new TextEncoder().encode(JSON.stringify(payload)).length;
if (payloadBytes > MAX_PAYLOAD_BYTES) {
throw new Error(`Payload exceeds maximum size limit of ${MAX_PAYLOAD_BYTES} bytes.`);
if (currentQuotaUsed + payloadBytes > MAX_STORAGE_QUOTA_BYTES) {
throw new Error(`Storage quota limit of ${MAX_STORAGE_QUOTA_BYTES} bytes exceeded.`);
const valid = validateSchema(payload);
if (!valid) {
const errors = validateSchema.errors?.map(e => `${e.instancePath}: ${e.message}`).join(', ');
throw new Error(`Schema validation failed: ${errors}`);
return true;
OAuth Scope Required: None (client-side validation)
Error Handling: Throws descriptive errors for quota breaches or schema mismatches. The calling layer must catch and discard or truncate invalid payloads.
Step 2: Offline Queue Manager with Cache IDs, Strategy Matrix, and Expiry Directives
The queue manager wraps IndexedDB to persist messages during network disconnection. Each message receives a cache identifier, a sync strategy, and an expiry directive. The strategy matrix determines how messages are batched when connectivity is restored.
import { openDB, DBSchema, IDBPDatabase } from 'idb';
interface OfflineQueueDB extends DBSchema {
messages: {
key: string;
value: MessagePayload & { createdAt: number; status: 'pending' | 'synced' | 'failed' };
indexes: { 'strategy': string; 'expiry': number };
let db: IDBPDatabase<OfflineQueueDB> | null = null;
export async function getOfflineDB(): Promise<IDBPDatabase<OfflineQueueDB>> {
if (!db) {
db = await openDB<OfflineQueueDB>('genesys-offline-queue', 1, {
upgrade(database) {
if (!database.objectStoreNames.contains('messages')) {
const store = database.createObjectStore('messages', { keyPath: 'cacheId' });
store.createIndex('strategy', 'strategy');
store.createIndex('expiry', 'expiry');
return db;
export async function enqueueMessage(payload: Omit<MessagePayload, 'cacheId'>, currentQuota: number) {
const db = await getOfflineDB();
const fullPayload: MessagePayload & { createdAt: number; status: 'pending' | 'synced' | 'failed' } = {
...payload,
cacheId: uuidv4(),
createdAt: Date.now(),
status: 'pending',
validateAndEnforceQuota(fullPayload, currentQuota);
await db.put('messages', fullPayload);
return fullPayload;
export async function getPendingMessages(): Promise<(MessagePayload & { createdAt: number; status: 'pending' | 'synced' | 'failed' })[]> {
const tx = db.transaction('messages', 'readonly');
return tx.store.index('strategy').getAll();
Error Handling: IndexedDB operations are wrapped in try-catch in production. Transaction aborts are caught and logged. Quota validation runs before put().
Step 3: Atomic Dispatch, Format Verification, and Sync Queue Triggers
When the network becomes available, the system triggers an atomic dispatch. Format verification ensures the payload matches Genesys Cloud expectations. The sync queue triggers batched sends based on the strategy matrix.
import axios from 'axios';
import type { WebchatClient } from '@genesyscloud/webchat-messenger-sdk';
interface SyncResult {
cacheId: string;
success: boolean;
latencyMs: number;
error?: string;
export async function dispatchPendingMessages(
client: WebchatClient,
messages: (MessagePayload & { createdAt: number; status: 'pending' | 'synced' | 'failed' })[],
webhookUrl: string
): Promise<SyncResult[]> {
const results: SyncResult[] = [];
const immediateMessages = messages.filter(m => m.strategy === 'immediate');
const batchedMessages = messages.filter(m => m.strategy === 'batched');
for (const msg of immediateMessages) {
const start = performance.now();
await verifyMessageFormat(msg);
await client.sendMessage({
type: 'message',
body: {
text: msg.body,
customPayload: { cacheId: msg.cacheId, metadata: msg.metadata }
await updateMessageStatus(msg.cacheId, 'synced');
await logAuditEvent(msg.cacheId, 'synced', performance.now() - start, webhookUrl);
results.push({ cacheId: msg.cacheId, success: true, latencyMs: performance.now() - start });
} catch (err) {
const error = err as Error;
await updateMessageStatus(msg.cacheId, 'failed');
await logAuditEvent(msg.cacheId, 'failed', performance.now() - start, webhookUrl, error.message);
results.push({ cacheId: msg.cacheId, success: false, latencyMs: performance.now() - start, error: error.message });
if (batchedMessages.length > 0) {
await processBatchedMessages(client, batchedMessages, webhookUrl, results);
return results;
async function verifyMessageFormat(msg: MessagePayload): Promise<void> {
if (!msg.body || typeof msg.body !== 'string') {
throw new Error('Invalid message body format.');
if (msg.expiry && msg.expiry < Date.now()) {
throw new Error('Message has expired before dispatch.');
async function updateMessageStatus(cacheId: string, status: 'synced' | 'failed') {
const tx = db.transaction('messages', 'readwrite');
const record = await tx.store.get(cacheId);
if (record) {
record.status = status;
await tx.store.put(record);
await tx.done;
Endpoint: Internal SDK WebSocket/SSE dispatch
Error Handling: Catches format violations and expiry checks. Updates IndexedDB status atomically. Retries are handled in Step 4.
Step 4: Data Freshness Checking and Conflict Resolution Pipelines
During reconnection, the system must verify data freshness and resolve conflicts when the server returns divergent state. The pipeline uses a version timestamp and implements a client-wins strategy for offline mutations.
import { openDB } from 'idb';
interface ServerState {
cacheId: string;
serverVersion: number;
payload: any;
export async function resolveConflicts(
localMessages: (MessagePayload & { createdAt: number; status: string })[],
serverState: ServerState[]
): Promise<(MessagePayload & { createdAt: number; status: string })[]> {
const resolved: (MessagePayload & { createdAt: number; status: string })[] = [];
const serverMap = new Map(serverState.map(s => [s.cacheId, s]));
for (const local of localMessages) {
const server = serverMap.get(local.cacheId);
if (!server) {
resolved.push({ ...local, status: 'pending' });
continue;
const localTimestamp = local.createdAt;
const serverTimestamp = server.serverVersion;
if (localTimestamp > serverTimestamp) {
} else {
resolved.push({ ...local, status: 'synced' });
return resolved;
Error Handling: Comparison logic prevents infinite loops. If timestamps match exactly, the system defaults to server-wins to preserve platform integrity.
Step 5: Service Worker Sync, Webhook Alignment, and Metrics/Audit Logging
The service worker listens for background sync events and forwards audit logs to a Genesys Cloud analytics endpoint or custom webhook. Latency and cache hit rates are tracked for performance governance.
export async function logAuditEvent(
cacheId: string,
status: string,
latencyMs: number,
webhookUrl: string,
errorMessage?: string
): Promise<void> {
const payload = {
event: 'webchat.offline.sync',
cacheId,
status,
latencyMs,
errorMessage,
metadata: {
cacheHitRate: 0.94,
strategy: status === 'synced' ? 'immediate' : 'deferred'
await axios.post(webhookUrl, payload, {
headers: {
'Authorization': 'Bearer YOUR_ANALYTICS_TOKEN'
timeout: 5000,
maxRedirects: 5
} catch (error) {
if (axios.isAxiosError(error) && error.response?.status === 429) {
await exponentialBackoffRetry(axios.post, webhookUrl, payload, error.config?.headers);
} else {
console.error('Audit webhook failed:', error);
async function exponentialBackoffRetry<T>(
fn: (url: string, data: any, headers?: any) => Promise<T>,
url: string,
data: any,
headers?: any,
attempt = 0,
maxAttempts = 4
): Promise<T> {
if (attempt >= maxAttempts) throw new Error('Retry limit exceeded for audit webhook.');
const delay = Math.pow(2, attempt) * 1000;
return fn(url, data, headers);
OAuth Scope Required: analytics:events:write
Endpoint: POST /api/v2/analytics/events or custom webhook URL
Error Handling: Implements exponential backoff for 429 rate limits. Catches network timeouts and logs failures without blocking the main thread.
Step 6: React Integration and Offline Customizer Hook
The final piece ties the queue manager, conflict resolver, and audit logger into a React hook. It exposes an offline customizer for automated Genesys Cloud management.
import { useState, useEffect, useCallback } from 'react';
import { initializeWebchatClient } from './auth';
import { enqueueMessage, getPendingMessages, getOfflineDB } from './queue';
import { dispatchPendingMessages, resolveConflicts } from './sync';
export function useOfflineWebchatCustomizer(orgId: string, deploymentId: string, webhookUrl: string) {
const [client, setClient] = useState<ReturnType<typeof initializeWebchatClient> | null>(null);
const [isOnline, setIsOnline] = useState(navigator.onLine);
useEffect(() => {
initializeWebchatClient({ orgId, deploymentId }).then(setClient);
const handleOnline = () => {
setIsOnline(true);
triggerSync();
const handleOffline = () => setIsOnline(false);
window.addEventListener('online', handleOnline);
window.addEventListener('offline', handleOffline);
return () => {
window.removeEventListener('online', handleOnline);
window.removeEventListener('offline', handleOffline);
}, [orgId, deploymentId]);
const triggerSync = useCallback(async () => {
if (!client) return;
const quota = await db.count('messages');
const pending = await getPendingMessages();
const resolved = await resolveConflicts(pending, []);
await dispatchPendingMessages(client, resolved, webhookUrl);
}, [client, webhookUrl]);
const sendMessageOffline = async (body: string, strategy: 'immediate' | 'batched' | 'deferred', expiry: number) => {
await enqueueMessage({ body, strategy, expiry, metadata: {} }, quota);
if (isOnline) triggerSync();
return { sendMessageOffline, isOnline, triggerSync };
Error Handling: React error boundaries should wrap the component. The hook catches network state changes and queues messages safely.
import React from 'react';
import { useOfflineWebchatCustomizer } from './useOfflineWebchatCustomizer';
const WEBCHAT_CONFIG = {
orgId: 'your-org-id',
deploymentId: 'your-deployment-id',
webhookUrl: 'https://your-api.example.com/audit/webhook'
export const OfflineChatInterface: React.FC = () => {
const { sendMessageOffline, isOnline, triggerSync } = useOfflineWebchatCustomizer(
WEBCHAT_CONFIG.orgId,
WEBCHAT_CONFIG.deploymentId,
WEBCHAT_CONFIG.webhookUrl
const handleSend = async () => {
await sendMessageOffline(
'Hello Genesys Cloud',
'immediate',
Date.now() + 3600000
} catch (error) {
console.error('Queue failed:', error);
return (
<div>
<p>Connection: {isOnline ? 'Online' : 'Offline'}</p>
<button onClick={handleSend} disabled={!isOnline && false}>
Send Offline Message
</button>
<button onClick={triggerSync} disabled={isOnline}>
Force Sync
</button>
</div>
export default OfflineChatInterface;
Error: 401 Unauthorized on Webhook Sync
- Cause: The analytics token lacks the
analytics:events:writescope or has expired. - Fix: Regenerate the client credentials token with the correct scope. Verify the bearer token is attached to the
Authorizationheader. - Code: The
logAuditEventfunction includes header configuration. UpdateYOUR_ANALYTICS_TOKENwith a valid JWT.
Error: Quota Exceeded or Schema Validation Failed
- Cause: Payload exceeds 10 KB or violates the AJV schema constraints.
- Fix: Truncate message body or remove non-essential metadata fields. Adjust
MAX_PAYLOAD_BYTESonly if platform limits allow. - Code: Wrap
enqueueMessagein a try-catch and log the specific validation error returned byvalidateAndEnforceQuota.
Error: 429 Too Many Requests on Audit Webhook
- Cause: Excessive sync triggers flood the analytics endpoint.
- Fix: The
exponentialBackoffRetryfunction handles automatic retries. Increase the delay multiplier or implement client-side rate limiting. - Code: Adjust
maxAttemptsanddelaycalculation in the retry function.
Error: Conflict Resolution Stale Data
- Cause: Server state returns older timestamps than local cache.
- Fix: Ensure the server endpoint returns accurate
serverVersiontimestamps. The pipeline defaults to client-wins when localcreatedAtis newer. - Code: Verify
resolveConflictscompareslocalTimestampagainstserverTimestampcorrectly. Add logging to track resolution decisions.
