Customizing Genesys Cloud Client SDK Audio Codecs with Node.js
You will build a Node.js module that validates, optimizes, and applies audio codec configurations to the Genesys Cloud WebRTC Client SDK, including bandwidth-aware priority ordering, automatic fallback triggers, negotiation latency tracking, and structured audit logging. The implementation uses the official @genesyscloud/genesyscloud-webrtc-client SDK and standard WebRTC capability negotiation patterns. The tutorial covers JavaScript/Node.js.
  • Genesys Cloud OAuth 2.0 client credentials with scope webchat:agent
  • @genesyscloud/genesyscloud-webrtc-client v3.18.0 or higher
  • Node.js 18.0.0 or higher
  • ajv v8.12.0 for JSON schema validation
  • pino v8.17.0 for structured audit logging
  • A runtime environment with WebRTC polyfills (Node.js does not include native RTCRtpReceiver or RTCPeerConnection without wrtc or Electron)
The Genesys Cloud Client SDK requires a valid OAuth 2.0 access token. The following function retrieves the token, handles rate limiting (429), and caches the response for reuse.
import fetch from 'node-fetch';
const OAUTH_URL = 'https://api.mypurecloud.com/oauth/token';
const CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
const SCOPE = 'webchat:agent';
let cachedToken = null;
let tokenExpiry = 0;
async function getAccessToken() {
  if (cachedToken && Date.now() < tokenExpiry) {
    return cachedToken;
  const payload = new URLSearchParams({
    client_id: CLIENT_ID,
    client_secret: CLIENT_SECRET,
    scope: SCOPE
  const maxRetries = 3;
  let attempt = 0;
  while (attempt < maxRetries) {
      const response = await fetch(OAUTH_URL, {
        method: 'POST',
        body: payload
      if (response.status === 429) {
        const retryAfter = parseInt(response.headers.get('Retry-After') || '5', 10);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        attempt++;
        continue;
      if (!response.ok) {
        const errorBody = await response.text();
        throw new Error(`OAuth failed with status ${response.status}: ${errorBody}`);
      const data = await response.json();
      cachedToken = data.access_token;
      tokenExpiry = Date.now() + (data.expires_in * 1000) - 60000;
      return cachedToken;
    } catch (error) {
      if (attempt === maxRetries - 1) throw error;
      attempt++;
Step 1: Schema Validation and Constraint Enforcement
Genesys Cloud media engines enforce strict constraints on codec negotiation. The maximum number of codecs allowed in a single SDP offer is five. Supported codecs include Opus, PCMU (G.711u), PCMA (G.711a), G.722, and ISAC. The following validation pipeline rejects invalid configurations before they reach the SDK.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv();
addFormats(ajv);
const CODEC_SCHEMA = {
  type: 'object',
  required: ['codecs', 'bandwidthKbps', 'latencyToleranceMs'],
  properties: {
    codecs: {
      type: 'array',
      maxItems: 5,
      items: {
        type: 'object',
        required: ['mime', 'clockRate', 'bitrateKbps', 'priority'],
        properties: {
          mime: { enum: ['audio/opus', 'audio/PCMU', 'audio/PCMA', 'audio/G722', 'audio/ISAC'] },
          clockRate: { type: 'integer', minimum: 8000, maximum: 48000 },
          bitrateKbps: { type: 'integer', minimum: 6, maximum: 510 },
          priority: { type: 'integer', minimum: 1, maximum: 100 }
    bandwidthKbps: { type: 'integer', minimum: 20, maximum: 5000 },
    latencyToleranceMs: { type: 'integer', minimum: 10, maximum: 500 }
const validateConfig = ajv.compile(CODEC_SCHEMA);
export function validateCodecConfiguration(config) {
  const valid = validateConfig(config);
  if (!valid) {
    const errorMessages = validateConfig.errors.map(e => `${e.instancePath} ${e.message}`).join('; ');
    throw new Error(`Codec configuration validation failed: ${errorMessages}`);
  const uniqueMimes = new Set(config.codecs.map(c => c.mime));
  if (uniqueMimes.size !== config.codecs.length) {
    throw new Error('Duplicate codec MIME types detected. Each codec must be unique.');
  return true;
Step 2: Bandwidth Verification and Fallback Logic
Network conditions dictate which codecs are viable. The following function calculates a bitrate adjustment matrix based on available bandwidth, reorders codec priority, and establishes a fallback trigger when the primary codec fails negotiation.
export function applyBandwidthAndFallback(config) {
  const { codecs, bandwidthKbps, latencyToleranceMs } = config;
  const adjustedCodecs = codecs.map(codec => {
    let targetBitrate = codec.bitrateKbps;
    if (bandwidthKbps < 30) {
      targetBitrate = Math.min(codec.bitrateKbps, 12);
    } else if (bandwidthKbps < 100) {
      targetBitrate = Math.min(codec.bitrateKbps, 30);
    } else if (bandwidthKbps < 300) {
      targetBitrate = Math.min(codec.bitrateKbps, 64);
      ...codec,
      bitrateKbps: targetBitrate,
      negotiatedBitrate: targetBitrate,
      latencyDirective: latencyToleranceMs <= 50 ? 'ultra-low' : latencyToleranceMs <= 150 ? 'standard' : 'high-tolerance'
  adjustedCodecs.sort((a, b) => b.priority - a.priority);
  const primaryCodec = adjustedCodecs[0];
  const fallbackCodec = adjustedCodecs.find(c => c.mime !== primaryCodec.mime) || adjustedCodecs[0];
    ...config,
    codecs: adjustedCodecs,
    fallbackTrigger: {
      primaryMime: primaryCodec.mime,
      fallbackMime: fallbackCodec.mime,
      retryAttempts: 3,
      cooldownMs: 2000
Step 3: SDK Initialization and Atomic Configuration
The Genesys Cloud Client SDK requires all media parameters to be set before the initial connection attempt. The following code initializes the SDK, applies the validated configuration atomically, and attaches event handlers to track negotiation success and fallback execution.
import { Client } from '@genesyscloud/genesyscloud-webrtc-client';
import { validateCodecConfiguration, applyBandwidthAndFallback } from './codecValidator.js';
import { getAccessToken } from './auth.js';
export async function initializeClientWithCodecConfig(environmentUrl, region, customConfig) {
  validateCodecConfiguration(customConfig);
  const optimizedConfig = applyBandwidthAndFallback(customConfig);
  const token = await getAccessToken();
  const sdkConfig = {
    environment: environmentUrl,
    region: region,
    accessToken: token,
    mediaConfiguration: {
      audio: {
        codecs: optimizedConfig.codecs.map(c => ({
          mimeType: c.mime,
          clockRate: c.clockRate,
          maxBitrate: c.negotiatedBitrate * 1000,
          priority: c.priority
        latencyTolerance: optimizedConfig.latencyDirective,
        enableFec: true,
        enableNack: true
      fallbackPolicy: optimizedConfig.fallbackTrigger
    rtcConfiguration: {
      iceServers: [{ urls: 'stun:stun.l.google.com:19302' }],
      bundlePolicy: 'max-bundle',
      rtcpMuxPolicy: 'require'
  const client = new Client();
  const negotiationStart = Date.now();
  let negotiationSuccess = false;
  let negotiatedCodec = null;
  let fallbackExecuted = false;
  client.on('callStateChange', (state) => {
    if (state === 'connected' || state === 'active') {
      negotiationSuccess = true;
      negotiatedCodec = client.getMediaStats()?.audio?.codec;
  client.on('mediaError', (error) => {
    if (error.code === 'NEGOTIATION_FAILED' || error.code === 'CODEC_UNSUPPORTED') {
      fallbackExecuted = true;
      client.applyFallbackCodec(optimizedConfig.fallbackTrigger.fallbackMime);
  await client.configure(sdkConfig);
  const negotiationLatency = Date.now() - negotiationStart;
    client,
    metrics: {
      negotiationLatencyMs: negotiationLatency,
      success: negotiationSuccess,
      negotiatedCodec,
      fallbackExecuted,
      appliedBitrates: optimizedConfig.codecs.map(c => c.negotiatedBitrate)
Step 4: Latency Tracking and Audit Logging
Media governance requires immutable audit trails and performance telemetry. The following logger captures configuration changes, negotiation outcomes, and fallback events in a structured format compatible with SIEM ingestion.
import pino from 'pino';
const auditLogger = pino({
  level: 'info',
  formatters: {
    level: (label) => ({ level: label.toUpperCase() }),
    log: (obj) => ({ ...obj, timestamp: new Date().toISOString() })
export function logCodecAuditEvent(eventType, payload, sessionId) {
  const auditRecord = {
    event: eventType,
    session: sessionId || 'UNKNOWN',
    payload: {
      codecs: payload.codecs?.map(c => ({ mime: c.mime, bitrate: c.negotiatedBitrate })),
      bandwidth: payload.bandwidthKbps,
      latencyDirective: payload.latencyDirective,
      fallbackTriggered: payload.fallbackExecuted || false,
      negotiationLatencyMs: payload.negotiationLatencyMs
    governance: {
      schemaValidated: true,
      maxCodecLimit: 5,
      auditVersion: '1.0'
  if (eventType === 'NEGOTIATION_FAILURE') {
    auditLogger.warn(auditRecord);
  } else {
    auditLogger.info(auditRecord);
  return auditRecord;
The following script demonstrates the complete pipeline. It validates a custom codec matrix, applies bandwidth constraints, initializes the Genesys Cloud Client SDK, and records audit telemetry. Replace the environment variables with your credentials before execution.
import { initializeClientWithCodecConfig } from './clientInitializer.js';
import { logCodecAuditEvent } from './auditLogger.js';
async function runCodecCustomization() {
  const customPayload = {
    codecs: [
      { mime: 'audio/opus', clockRate: 48000, bitrateKbps: 120, priority: 100 },
      { mime: 'audio/G722', clockRate: 16000, bitrateKbps: 64, priority: 80 },
      { mime: 'audio/PCMU', clockRate: 8000, bitrateKbps: 64, priority: 60 },
      { mime: 'audio/PCMA', clockRate: 8000, bitrateKbps: 64, priority: 50 },
      { mime: 'audio/ISAC', clockRate: 16000, bitrateKbps: 32, priority: 40 }
    bandwidthKbps: 150,
    latencyToleranceMs: 100
    console.log('Validating codec configuration...');
    const { client, metrics } = await initializeClientWithCodecConfig(
      'https://api.mypurecloud.com',
      'us-east-1',
      customPayload
    console.log('Client configured. Starting connection...');
    await client.connect();
    const audit = logCodecAuditEvent('NEGOTIATION_COMPLETE', metrics, 'SESSION-001');
    console.log('Audit logged:', JSON.stringify(audit, null, 2));
    if (!metrics.success) {
      throw new Error('Codec negotiation failed despite fallback triggers.');
    console.log('Audio channel established with:', metrics.negotiatedCodec);
    console.log('Negotiation latency:', metrics.negotiationLatencyMs, 'ms');
    await client.disconnect();
  } catch (error) {
    console.error('Codec customization pipeline failed:', error.message);
    logCodecAuditEvent('NEGOTIATION_FAILURE', { error: error.message }, 'SESSION-001');
    process.exit(1);
runCodecCustomization();
  • Cause: The OAuth token expired, was revoked, or the client credentials are incorrect.
  • Fix: Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET. Ensure the webchat:agent scope is attached to the OAuth application in the Genesys Cloud admin console. Implement token refresh logic before each SDK initialization.
  • Code Fix: The getAccessToken function already caches tokens and checks expiry. Add a forced refresh by calling cachedToken = null before retrying.
Error: 403 Forbidden
  • Cause: The OAuth client lacks the webchat:agent scope, or the user/token is not associated with a valid Genesys Cloud user account.
  • Fix: Navigate to Organization Settings > Security > OAuth Applications. Attach the webchat:agent scope. Ensure the token request uses client credentials tied to an active user or service account.
  • Cause: Rate limit exceeded on /oauth/token or Genesys Cloud media signaling endpoints.
  • Fix: The authentication function implements exponential backoff using the Retry-After header. For SDK connection attempts, wrap client.connect() in a retry loop with a 2-second delay.
Error: SDK Configuration Rejection (Max Codec Count Exceeded)
  • Cause: The codecs array contains more than five entries. Genesys Cloud media engines reject SDP offers exceeding this limit.
  • Fix: The CODEC_SCHEMA enforces maxItems: 5. If you need additional codecs, remove lower-priority entries before validation. The schema throws a descriptive error indicating the exact violation.
Error: WebRTC Negotiation Failure / Codec Unsupported
  • Cause: The target media server does not support the requested codec, or network conditions prevent the negotiated bitrate.
  • Fix: The applyBandwidthAndFallback function automatically downgrades bitrates and reorders priorities. The mediaError listener triggers client.applyFallbackCodec() when the primary codec fails. Ensure your Genesys Cloud environment has Opus and G.711 enabled in Media Settings.
Error: 5xx Internal Server Error
  • Cause: Temporary Genesys Cloud platform outage or signaling service degradation.
  • Fix: Implement a circuit breaker pattern. If three consecutive 5xx responses occur, halt connection attempts for 30 seconds. Log the event with logCodecAuditEvent('PLATFORM_ERROR', ...) for incident tracking.
