custom SIP header
according to SIP server documentation, it should be possible to insert custom parameters to outgoing INVITE message.
It is mentioned on p. 137 of deployment guide (SIP_HEADERS), but not the way how and where to create them. They should be placed in AttributeExtensions section of RequestRouteCall, but i didn’t find how to create them.
I would need to insert Diversion line with the DN number, because our telecom operator is discarding redirected calls outside callcenter (they don’t know whom to bill the calls).
Peter
Hi Peter,
What version of SIP Server are you talking about?
You can find detailed description about setup of this feature in “Framework 7.6 SIP Server Deployment Guide” , chapter “Mapping SIP Headers and SDP Messages”. Just be careful as not all described features are available in previous releases of SIP Server. Please check release notes.
Hi Rene,
i’m using latest 7.6. I read the section but didn’t understand it quite. There are two ways how to achieve it - 1. edit SIPserver object in CME, 2-edit Troute parameter in URS. We would need to use this 2. way.
Do you have any example syntax of troute function with SIP_HEADERS?
Peter
Hi Peter,
I did quick test and here is brief “how to” :wink:
  1. Put a new block of type “MultiFunction” before your “Selection” block in the strategy ( — MultiFunction — Selection)
  2. Add following functions/lines to “MultiFunction” block
    ExtensionAttach[‘SIP_REQUEST_PARAMETERS’,‘req-param-1’]
    ExtensionAttach[‘req-param-1’,‘local’]
  3. Save the strategy and test it
  4. You should see in SIP Server log that RequestRouteCall has the keys “SIP_REQUEST_PARAMETERS” and “req-param-1” in the Extensions.
message RequestRouteCall
AttributeThisDN ‘601’
AttributeConnID 007801a94550a002
AttributeOtherDN ‘301’
AttributeExtensions [265] 00 0C 00 00..
‘InfoToSendInInvite’ ‘INVITE from SIP Server’
‘SIP_REQUEST_PARAMETERS’ ‘req-param-1’
‘req-param-1’ ‘local’
‘DEFAULT#’ ‘9999’
‘CUSTOMER_ID’ ‘Lab’
‘AGENT’ ‘301’
‘PLACE’ ‘Place_301’
‘DN’ ‘301’
‘ACCESS’ ‘301’
‘SWITCH’ ‘SIP’
‘NVQ’ 1
‘TARGET’ ‘vg_ServiceA@lab_rut_statsrv.GA’
AttributeRouteType 0 (RouteTypeUnknown)
AttributeReason [14] 00 01 01 00..
‘RTR’ 116
AttributeReferenceID 19
  1. INVITE issued by SIP Server contains the parameter “req-param-1” in Request URI
    INVITE sip:301@172.18.1.1:13312;req-param-1=local SIP/2.0
    From: sip:303@172.18.1.2:5060;tag=003BFA42-B380-199A-A590-020112ACAA77-8
    To: sip:601@172.18.1.2:5060
    Call-ID: 003BF9D4-B380-199A-A590-020112ACAA77-4@172.18.1.2
    CSeq: 1 INVITE
    Content-Length: 0
    Via: SIP/2.0/UDP 172.18.1.2:5060;branch=z9hG4bK003BFA56-B380-199A-A590-020112ACAA77-12
    Contact: sip:303@172.18.1.2:5060
    Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, REFER
    X-Genesys-CallUUID: 01EI265LRCCPL9CG080H5B5AES00000A
    Max-Forwards: 69
    Session-Expires: 1800;refresher=uac
    Min-SE: 90
    Supported: timer
Hi Rene,
thanks it works! :slight_smile:
Peter
