Custom data for OutBound Call with SSG on GVP 8.1
Hi all,
Is it possible to get custom data on the CreateRequest call to SSG to pass on to the VXML app? I cannot find a way.
There is a CustomData element described in the schema however I cannot find how it is supposed to work?
Or is there at least a way to get the Token from the SSG call to the VXML app?
I need a way to indicate the record in my system that initiated the outbound call so the audio tag can be customised.
Your request should look like that if you want to include userdata:
[b] [/b]
Kind Regards,
IF
Thanks IF, I did get that far however. I could not see the values coming through to the vxml app though?
I thought they would be nicely presented in the session.com.genesyslab.userdata object however I could not get them.
How do you use the values once you have passed them in?
Ok, I found it!
“session.com.genesyslab.userdata.outbounddata” has the values from in Key1=Value1&Key2=Value2 format.
:slight_smile:
