I am new to CTI. Can you please help me understand the below mentioned terms. I tried finding it on internet but there are many mismatches on the definition. Any information on the below would help me.
- CTI Switch
- CTI middleware
- CTI Server
Thanks in advance for your help.
K.V
This is going to depend on environment and configuration as these can sometimes be interchangeable. Since I don’t know the environment here are some high level definitions as I see them, and since this is a Genesys forum I will assume a Genesys solution.
- CTI Switch - A Switch or PBX in a Genesys environment that Genesys communicates with for functions and monitoring of specific objects.
- CTI middleware - Genesys Tserver for example, is CTI Middleware. Generally software that sits between a PBX/Communications system and other computer systems that translates communication between the two and can expose functions and services to each side of the connection.
- CTI Server - A server in which CTI services or applications are installed.
I hope that helps to start with.
Mike
