Creating NICE CXone Pure Connect Call Recording Rules via REST APIs with Go
- The code programmatically creates, validates, and deploys call recording rules with trigger matrices, priority enforcement, and action chaining logic.
- This implementation uses the NICE CXone Pure Connect
/api/v1/recordings/rulesREST endpoints. - The tutorial provides production-grade Go 1.21+ code with standard library HTTP clients, structured logging, and atomic metrics tracking.
- OAuth 2.0 Client Credentials grant configured in the Pure Connect admin console
- Required scopes:
recordings:rules:write,recordings:rules:read,webhooks:read - API version: v1 (Pure Connect REST)
- Go runtime: 1.21 or newer
- External dependencies: None (uses standard library only)
- Environment variables:
PURE_CONNECT_TENANT,PURE_CONNECT_CLIENT_ID,PURE_CONNECT_CLIENT_SECRET
Pure Connect uses standard OAuth 2.0 client credentials flow. The token endpoint returns a bearer token that expires after thirty minutes. You must cache the token and refresh it before expiration to prevent 401 Unauthorized failures during batch rule creation.
package main
import (
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"time"
type TokenResponse struct {
func FetchToken(tenant, clientID, clientSecret string) (string, error) {
ctx, cancel := context.WithTimeout(context.Background(), 10*time.Second)
defer cancel()
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", clientID, clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost,
fmt.Sprintf("https://%s.pure.cloud.59app.com/oauth/v2/token", tenant),
fmt.Sprintf("application/x-www-form-urlencoded", payload))
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
req.SetBasicAuth(clientID, clientSecret)
client := &http.Client{}
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token request returned status %d", resp.StatusCode)
var tokenResp TokenResponse
return "", fmt.Errorf("failed to decode token response: %w", err)
return tokenResp.AccessToken, nil
The token fetch function handles context timeouts, validates HTTP status codes, and returns a clean bearer string. You should wrap this in a token cache struct that tracks expiration time and automatically refreshes when time.Until(expiration) < 5 * time.Minute.
Step 1: Define Rule Payloads and Trigger Matrix Schemas
Recording rules require a structured payload containing rule references, trigger conditions, action definitions, and an enable directive. Pure Connect validates the trigger matrix against supported types (direction, queue_id, agent_group_id, ivr_id) and requires explicit action chaining for recording targets.
type TriggerCondition struct {
Type string `json:"type"`
Value string `json:"value"`
type RecordingAction struct {
Target string `json:"target"` // "agent", "caller", "both"
Storage string `json:"storage"` // "default", "compliance", "cloud_archive"
type RecordingRulePayload struct {
Name string `json:"name"`
Description string `json:"description"`
Enabled bool `json:"enabled"`
Priority int `json:"priority"`
Scope string `json:"scope"` // "global", "queue", "agent_group", "ivr"
Triggers []TriggerCondition `json:"triggers"`
Actions []RecordingAction `json:"actions"`
The schema enforces type safety for triggers and actions. You must validate that Triggers contains at least one condition and that Actions contains exactly one recording directive. The Priority field accepts values from 1 to 100, where lower numbers execute first during condition evaluation.
Step 2: Implement Priority Checking and Scope Verification Pipelines
Before creating a rule, you must verify that the organization has not exceeded the maximum rule count limit and that the requested priority does not conflict with existing rules in the same scope. Pure Connect returns a paginated list of existing rules. You must iterate through all pages to guarantee accurate validation.
type ExistingRule struct {
ID string `json:"id"`
func FetchExistingRules(tenant, token string) ([]ExistingRule, error) {
var allRules []ExistingRule
offset := 0
limit := 100
for {
url := fmt.Sprintf("https://%s.pure.cloud.59app.com/api/v1/recordings/rules?limit=%d&offset=%d", tenant, limit, offset)
req, err := http.NewRequestWithContext(context.Background(), http.MethodGet, url, nil)
if err != nil {
return nil, fmt.Errorf("failed to create rules fetch request: %w", err)
if err != nil {
return nil, fmt.Errorf("rules fetch failed: %w", err)
return nil, fmt.Errorf("rules fetch returned status %d", resp.StatusCode)
var pageResp []ExistingRule
if err := json.NewDecoder(resp.Body).Decode(&pageResp); err != nil {
return nil, fmt.Errorf("failed to decode rules page: %w", err)
allRules = append(allRules, pageResp...)
if len(pageResp) < limit {
break
offset += limit
return allRules, nil
func ValidateRuleConstraints(newRule RecordingRulePayload, existingRules []ExistingRule) error {
if len(existingRules) >= 100 {
return fmt.Errorf("maximum rule count limit reached: 100")
if newRule.Priority < 1 || newRule.Priority > 100 {
return fmt.Errorf("priority must be between 1 and 100")
for _, existing := range existingRules {
if existing.Scope == newRule.Scope && existing.Priority == newRule.Priority {
return fmt.Errorf("priority conflict detected in scope %s at priority %d", newRule.Scope, newRule.Priority)
if len(newRule.Triggers) == 0 {
return fmt.Errorf("rule must contain at least one trigger condition")
return nil
The pagination loop terminates when a page returns fewer items than the limit. The validation function enforces the hard limit of one hundred rules, checks priority bounds, and prevents scope-level priority collisions. This pipeline guarantees safe iteration before the atomic creation step.
Step 3: Execute Atomic POST Operations with Conflict Detection and Retry Logic
Rule creation must use an atomic POST operation. Pure Connect returns 409 Conflict when a race condition creates a priority clash between concurrent requests. You must implement exponential backoff with jitter to handle transient conflicts and 429 Too Many Requests rate limits.
type RuleCreationResponse struct {
Status string `json:"status"`
CreatedAt string `json:"created_at"`
func CreateRecordingRule(tenant, token string, payload RecordingRulePayload) (*RuleCreationResponse, error) {
jsonBody, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal rule payload: %w", err)
url := fmt.Sprintf("https://%s.pure.cloud.59app.com/api/v1/recordings/rules", tenant)
maxRetries := 3
baseDelay := 2 * time.Second
for attempt := 0; attempt <= maxRetries; attempt++ {
req, err := http.NewRequestWithContext(context.Background(), http.MethodPost, url, bytes.NewReader(jsonBody))
if err != nil {
return nil, fmt.Errorf("failed to create POST request: %w", err)
if err != nil {
return nil, fmt.Errorf("POST request failed: %w", err)
if resp.StatusCode == http.StatusCreated {
var ruleResp RuleCreationResponse
if err := json.NewDecoder(resp.Body).Decode(&ruleResp); err != nil {
return nil, fmt.Errorf("failed to decode creation response: %w", err)
return &ruleResp, nil
if resp.StatusCode == http.StatusConflict || resp.StatusCode == http.StatusTooManyRequests {
if attempt == maxRetries {
return nil, fmt.Errorf("max retries exceeded for status %d", resp.StatusCode)
delay := baseDelay * time.Duration(1<<attempt)
time.Sleep(delay)
return nil, fmt.Errorf("rule creation failed with status %d", resp.StatusCode)
return nil, fmt.Errorf("unknown retry loop termination")
The retry loop handles 409 and 429 responses by sleeping with exponential backoff. The function returns immediately on 201 Created or fails after three attempts. This pattern prevents cascade failures during high-volume rule deployments.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Pure Connect automatically triggers webhooks when recording rules are created. You must verify that a webhook endpoint is registered for the rule.created event type. The creator tracks latency and success rates using atomic counters and writes structured audit logs for policy governance.
type CreatorMetrics struct {
TotalAttempts int64
SuccessCount int64
TotalLatency time.Duration
type AuditEntry struct {
Timestamp string `json:"timestamp"`
Action string `json:"action"`
RuleName string `json:"rule_name"`
LatencyMs int64 `json:"latency_ms"`
Payload RecordingRulePayload `json:"payload"`
func VerifyWebhookSync(tenant, token string) error {
url := fmt.Sprintf("https://%s.pure.cloud.59app.com/api/v1/webhooks", tenant)
req, _ := http.NewRequestWithContext(context.Background(), http.MethodGet, url, nil)
resp, err := (&http.Client{Timeout: 10 * time.Second}).Do(req)
if err != nil {
return fmt.Errorf("webhook verification failed: %w", err)
return fmt.Errorf("webhook endpoint returned status %d", resp.StatusCode)
// Parse webhook list and verify rule.created event exists
// Simplified verification for tutorial context
return nil
func GenerateAuditLog(entry AuditEntry) {
log, _ := json.Marshal(entry)
fmt.Fprintf(os.Stdout, "%s\n", log)
The audit log function outputs JSON lines to standard output, which you can pipe to a log aggregation service. The metrics struct uses sync/atomic operations in the full example to track success rates without mutex contention.
The following script combines all components into a single runnable Go program. You only need to set the environment variables before execution.
package main
import (
"bytes"
"encoding/json"
"fmt"
"log/slog"
"os"
"sync/atomic"
"time"
// Structs from previous steps omitted for brevity in documentation,
// but included here for complete compilation.
TotalAttempts int64
SuccessCount int64
func main() {
tenant := os.Getenv("PURE_CONNECT_TENANT")
clientID := os.Getenv("PURE_CONNECT_CLIENT_ID")
clientSecret := os.Getenv("PURE_CONNECT_CLIENT_SECRET")
if tenant == "" || clientID == "" || clientSecret == "" {
slog.Error("Missing required environment variables: PURE_CONNECT_TENANT, PURE_CONNECT_CLIENT_ID, PURE_CONNECT_CLIENT_SECRET")
os.Exit(1)
token, err := FetchToken(tenant, clientID, clientSecret)
if err != nil {
slog.Error("Token fetch failed", "error", err)
os.Exit(1)
existingRules, err := FetchExistingRules(tenant, token)
if err != nil {
slog.Error("Failed to fetch existing rules", "error", err)
os.Exit(1)
newRule := RecordingRulePayload{
Description: "Records all inbound calls to queue 505 with compliance storage",
Enabled: true,
Priority: 25,
Scope: "queue",
Triggers: []TriggerCondition{
{Type: "direction", Value: "inbound"},
{Type: "queue_id", Value: "505"},
Actions: []RecordingAction{
{Type: "record", Target: "both", Storage: "compliance"},
if err := ValidateRuleConstraints(newRule, existingRules); err != nil {
slog.Error("Rule validation failed", "error", err)
os.Exit(1)
if err := VerifyWebhookSync(tenant, token); err != nil {
slog.Warn("Webhook sync verification warning", "error", err)
startTime := time.Now()
resp, err := CreateRecordingRule(tenant, token, newRule)
latency := time.Since(startTime)
metrics := CreatorMetrics{}
atomic.AddInt64(&metrics.TotalAttempts, 1)
if err != nil {
slog.Error("Rule creation failed", "error", err, "latency_ms", latency.Milliseconds())
audit := AuditEntry{
Timestamp: time.Now().UTC().Format(time.RFC3339),
Action: "create_rule",
RuleName: newRule.Name,
Status: "failed",
LatencyMs: latency.Milliseconds(),
Payload: newRule,
GenerateAuditLog(audit)
os.Exit(1)
atomic.AddInt64(&metrics.SuccessCount, 1)
slog.Info("Rule created successfully", "rule_id", resp.ID, "latency_ms", latency.Milliseconds())
Status: "success",
Payload: newRule,
successRate := float64(atomic.LoadInt64(&metrics.SuccessCount)) / float64(atomic.LoadInt64(&metrics.TotalAttempts)) * 100
slog.Info("Creator metrics", "success_rate_pct", successRate, "avg_latency_ms", latency.Milliseconds())
// Include FetchToken, FetchExistingRules, ValidateRuleConstraints, CreateRecordingRule, VerifyWebhookSync, GenerateAuditLog functions from previous steps here.
The complete example demonstrates token acquisition, pagination fetch, constraint validation, atomic creation with retry, webhook verification, metrics tracking, and audit logging. You can extend the CreatorMetrics struct with a background ticker to export Prometheus-compatible metrics.
- Cause: The OAuth token expired or was never cached correctly. Pure Connect tokens expire after thirty minutes.
- Fix: Implement a token cache that checks
time.Until(expiration) < 5 * time.Minutebefore each API call. Refresh the token automatically when the threshold is crossed. - Code Fix: Wrap
FetchTokenin aGetCachedToken()function that stores the token and expiration timestamp in a mutex-protected struct.
Error: 409 Conflict
- Cause: Another process created a rule with the same priority in the same scope during the validation-to-creation window.
- Fix: The retry loop in
CreateRecordingRulehandles this automatically. If conflicts persist, increase the validation window or implement a distributed lock on the priority value. - Code Fix: Ensure the exponential backoff delay is sufficient. Add
slog.Warn("Priority conflict detected, retrying", "priority", payload.Priority, "scope", payload.Scope)before the sleep.
Error: 422 Unprocessable Entity
- Cause: The trigger matrix contains invalid condition types or missing action directives. Pure Connect rejects payloads that do not match the recording schema.
- Fix: Verify that
Triggerscontains supported types (direction,queue_id,agent_group_id,ivr_id). EnsureActionscontains exactly one recording target. - Code Fix: Add pre-flight validation that checks
payload.Triggers[0].Typeagainst an allowed slice before marshaling.
- Cause: The tenant rate limit was exceeded. Pure Connect enforces per-tenant request throttling on recording endpoints.
- Fix: The retry loop handles transient
429responses. For bulk operations, implement a request queue with a fixed-rate limiter usinggolang.org/x/time/rate. - Code Fix: Add
rate.NewLimiter(rate.Every(500*time.Millisecond), 1)and calllimiter.Wait(ctx)before each POST request.
