:)Hi
I would like to setup a distribution group using a basic "hunting group algorithm). Meaning the first call to agent1, second to the agent2,3 to the agent3 and the fourth to the agent1 back (considering 4 agents)
I was thinking on creating a custom Value on the stat server that will use the following mask.
This variable will count the amount of time since the agent ended up his client call (call inbound) and will not be affected by internal calls, availability status change, etc). So the agent that will rank highest on that value will receive the next call. It will not be exactly a round robin hunt group but it will work very similar.
