Create multiple Objects or bulk load in CME using PSDK
Hi All,
I’m trying out creation / modification of objects in CME using configuration platform SDK in Java.
Is there any method to create/ modify multiple Objects in CME using PSDK , Please provide some sample or guide in the right direction.
Did you know that there is Genesys Configuration Import Wizard which you can use to import a big load of configuration data (DN,Skills,Agents…) from several switch export formats, xml, excel spreadsheet etc. You do not have to use SDK for that unless you are building some permanent synchronization application.
e.
