Create “duplicate” Routing points in CME for different switches:
Hello All,
Can we create “duplicate” Routing points in CME for different switches:
Example:
Number Type Switch
12345 Routing Point Chicago_Avaya
12345 Routing Point NY _Avaya
Yes, you can.
Thanks for your prompt answer.
Only the Alias have to be unique (per tenant I believe).
Correct, numbers can be the same, but the Alias must be unique.
