Correlating Quality API CSAT responses with Interaction IDs in Python SDK
Looking for the cleanest way to map Quality API CSAT survey results back to specific interaction IDs for distributed tracing.
We’re building a pipeline to trace the full lifecycle of customer interactions, including post-call surveys. The goal is to inject the traceparent header from the initial interaction into the CSAT response processing so we can see the full span in Jaeger.
The problem is that the Quality API endpoints for surveys don’t seem to return the original interactionId directly in the response payload. I’m using the Genesys Cloud Python SDK to fetch these responses. Here’s the basic call:
from genesyscloud.quality import QualityApi
quality_api = QualityApi(configuration)
 # Fetching survey responses
 result = quality_api.post_quality_surveys_responses_query(
 body=SurveyQueryRequest(
 pageSize=100,
 sortBy='dateCreated',
 sortAsc=False
 for response in result.responses:
 print(f"Survey ID: {response.id}")
 # Missing interactionId here?
 print(f"Error: {e}")
The JSON response contains surveyId and externalId, but no obvious link to the conversation or interaction ID from the /api/v2/conversations namespace. I need that ID to correlate the trace.
Is there a separate call I need to make using the surveyId to get the interaction details? Or is there a query parameter I’m missing in the post_quality_surveys_responses_query method? The docs mention externalId can be used for correlation, but we don’t set a custom external ID on the surveys, so that’s null.
Trying to avoid hitting the Analytics API just for this correlation since the latency adds up when processing high volumes. Any code examples or endpoint hints would be great.
You might try joining on the interaction_id field from the survey responses. The Quality API does return it if you request the right scope.
# Get survey details
surveys = platform_client.quality_api.get_quality_evaluations()
for survey in surveys:
 interaction_id = survey.data.interaction_id
Check if that ID exists in your interaction logs.
