Controlling NICE CXone Call Barge and Mute States with Java
This tutorial delivers a production-ready Java module that programmatically executes supervisor barge and mute actions on active CXone voice interactions. The code invokes the CXone Voice Control API, validates supervisor hierarchy and privacy constraints, handles ETag-based optimistic concurrency, and streams real-time interaction state changes to an external dashboard. The implementation runs entirely in Java 11+ using the standard java.net.http client and Jackson for JSON serialization.
  • OAuth Client Type: Server-to-Server (Client Credentials)
  • Required Scopes: voice:interactions:control, voice:interactions:read, presence:users:write, users:read
  • Runtime: Java 11 or higher
  • Dependencies:
    • com.fasterxml.jackson.core:jackson-databind:2.15.2
    • com.fasterxml.jackson.datatype:jackson-datatype-jsr310:2.15.2
  • Environment Variables: CXONE_BASE_URL, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET
CXone uses standard OAuth 2.0 client credentials flow. You must cache the access token and refresh it before expiration to avoid 401 interruptions during long-running supervision sessions.
import java.net.URI;
import com.fasterxml.jackson.databind.node.ObjectNode;
public class CxoneAuth {
    private static final ObjectMapper MAPPER = new ObjectMapper();
    private static volatile String cachedToken;
    private static volatile long tokenExpiryEpoch;
    public static String getAccessToken(String baseUrl, String clientId, String clientSecret) throws Exception {
        if (cachedToken != null && System.currentTimeMillis() < tokenExpiryEpoch) {
            return cachedToken;
        String tokenUrl = baseUrl + "/api/v2/oauth2/token";
        String body = "grant_type=client_credentials&scope=voice:interactions:control%20voice:interactions:read%20presence:users:write%20users:read";
                .uri(URI.create(tokenUrl))
                .header("Content-Type", "application/x-www-form-urlencoded")
                .POST(HttpRequest.BodyPublishers.ofString(body))
                .build();
        HttpResponse<String> response = HttpClient.newHttpClient().send(request, HttpResponse.BodyHandlers.ofString());
            throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
        ObjectNode json = MAPPER.readValue(response.body(), ObjectNode.class);
        cachedToken = json.get("access_token").asText();
        tokenExpiryEpoch = System.currentTimeMillis() + (json.get("expires_in").asInt() * 1000) - 5000; // 5s buffer
        return cachedToken;
Step 1: Validate Supervisor Permissions and Fetch Interaction ETag
Before issuing control commands, you must verify that the supervisor has authority over the target agent and that the agent has not enabled privacy restrictions. CXone returns an ETag header on interaction GET requests. You must capture this value for optimistic concurrency control during state transitions.
Required Scope: voice:interactions:read, users:read
public class InteractionValidator {
    public static String fetchInteractionETag(String baseUrl, String token, String interactionId) throws Exception {
                .uri(URI.create(baseUrl + "/api/v2/interactions/voice/" + interactionId))
                .header("Accept", "application/json")
                .GET()
                .build();
        if (response.statusCode() == 403) {
            throw new SecurityException("Supervisor lacks read access to interaction " + interactionId);
        if (response.statusCode() == 404) {
            throw new IllegalStateException("Interaction " + interactionId + " not found or already ended");
            throw new RuntimeException("Unexpected status " + response.statusCode() + ": " + response.body());
        // ETag is returned for optimistic concurrency
        String eTag = response.headers().firstValue("ETag").orElse("");
        return eTag;
    public static boolean checkPrivacyAllowed(String baseUrl, String token, String agentId) throws Exception {
                .uri(URI.create(baseUrl + "/api/v2/users/" + agentId + "/privacy"))
                .GET()
                .build();
        if (response.statusCode() != 200) return false;
        ObjectNode privacy = MAPPER.readValue(response.body(), ObjectNode.class);
        // CXone privacy object contains "enabled" field
        return !privacy.path("enabled").asBoolean(true);
Expected Response for Privacy:
  "enabled": false,
  "allowedSupervisors": ["supervisor-user-id-1", "supervisor-user-id-2"]
Step 2: Execute Barge and Mute Controls with Conflict Resolution
The control endpoint accepts a JSON payload specifying the action type and participant roles. You must attach the If-Match header with the ETag retrieved in Step 1. CXone returns 412 Precondition Failed when the interaction state changes between your fetch and control attempt. You must implement a retry loop that re-fetches the ETag and retries the control command.
Required Scope: voice:interactions:control
public class VoiceControlExecutor {
    private static final int MAX_RETRIES = 3;
    public static void executeControl(String baseUrl, String token, String interactionId,
                                      String action, boolean mute, String supervisorId) throws Exception {
        String eTag = InteractionValidator.fetchInteractionETag(baseUrl, token, interactionId);
        String payload = MAPPER.writeValueAsString(new Object() {
            public String action = action;
            public boolean mute = mute;
            public Object[] participants = new Object[]{
                new Object() {
                    public String id = supervisorId;
                    public String role = "supervisor";
        int attempts = 0;
        while (attempts < MAX_RETRIES) {
                    .uri(URI.create(baseUrl + "/api/v2/interactions/voice/" + interactionId + "/control"))
                    .header("If-Match", eTag)
                    .POST(HttpRequest.BodyPublishers.ofString(payload))
                    .build();
            if (response.statusCode() == 200 || response.statusCode() == 204) {
                System.out.println("Control action '" + action + "' executed successfully.");
                return;
            if (response.statusCode() == 412) {
                // Optimistic concurrency conflict: interaction state changed
                System.out.println("ETag conflict detected. Refreshing state and retrying...");
                attempts++;
                Thread.sleep(500 * attempts); // Linear backoff for 412
                continue;
            if (response.statusCode() == 429) {
                // Rate limit: parse Retry-After header or use exponential backoff
                long retryAfter = response.headers().firstValueAsLong("Retry-After").orElse(2);
                System.out.println("Rate limited. Waiting " + retryAfter + "s...");
                Thread.sleep(retryAfter * 1000);
                continue;
            throw new RuntimeException("Control failed with status " + response.statusCode() + ": " + response.body());
        throw new RuntimeException("Max retries exceeded for control action on interaction " + interactionId);
Control Payload Structure:
  "action": "barge",
  "mute": false,
  "participants": [
      "id": "supervisor-user-id",
      "role": "supervisor"
Step 3: Synchronize Real-Time Streams and Update Presence
Supervisor interventions must reflect immediately in external dashboards. CXone exposes Server-Sent Events (SSE) for voice interactions. You will subscribe to the stream, parse state transitions, and update the supervisor presence status to indicate active supervision.
Required Scope: voice:interactions:read, presence:users:write
import java.util.Scanner;
import java.util.concurrent.CompletableFuture;
import java.util.concurrent.atomic.AtomicBoolean;
public class StreamSyncAndPresence {
    public static void updateSupervisorPresence(String baseUrl, String token, String supervisorId, String status, String reason) throws Exception {
            public String status = status;
            public String reason = reason;
                .uri(URI.create(baseUrl + "/api/v2/presence/users/" + supervisorId + "/status"))
                .PUT(HttpRequest.BodyPublishers.ofString(payload))
                .build();
        if (response.statusCode() != 204 && response.statusCode() != 200) {
            throw new RuntimeException("Presence update failed: " + response.statusCode());
    public static CompletableFuture<Void> subscribeToVoiceStream(String baseUrl, String token, String interactionId, AtomicBoolean running) {
        return CompletableFuture.runAsync(() -> {
                        .uri(URI.create(baseUrl + "/api/v2/interactions/streams/voice?interactionId=" + interactionId))
                        .header("Accept", "text/event-stream")
                        .GET()
                        .build();
                HttpClient client = HttpClient.newBuilder().followRedirects(HttpClient.Redirect.NEVER).build();
                HttpResponse<java.io.InputStream> response = client.send(request, HttpResponse.BodyHandlers.ofInputStream());
                    System.err.println("Stream connection failed: " + response.statusCode());
                    return;
                try (Scanner scanner = new Scanner(response.body())) {
                    while (running.get() && scanner.hasNextLine()) {
                        String line = scanner.nextLine();
                        if (line.startsWith("data:")) {
                            String jsonPayload = line.substring(5).trim();
                            ObjectNode event = MAPPER.readValue(jsonPayload, ObjectNode.class);
                            String eventType = event.path("eventType").asText();
                            String newState = event.path("state").asText();
                            System.out.println("Stream Event: " + eventType + " | State: " + newState);
                            // Trigger dashboard sync logic here
            } catch (Exception e) {
                System.err.println("Stream error: " + e.getMessage());
Step 4: Audit Trail Extraction and Training Simulator
Quality assurance requires immutable logs of every supervisor intervention. CXone stores control events on the interaction resource. You will fetch these events, log them to a structured audit file, and expose a lightweight HTTP simulator endpoint for supervisor training exercises.
import com.sun.net.httpserver.HttpServer;
import com.sun.net.httpserver.HttpHandler;
import com.sun.net.httpserver.HttpExchange;
import java.net.InetSocketAddress;
import java.io.OutputStream;
import java.nio.charset.StandardCharsets;
public class AuditAndSimulator {
    public static void fetchAndLogAuditTrail(String baseUrl, String token, String interactionId) throws Exception {
                .uri(URI.create(baseUrl + "/api/v2/interactions/voice/" + interactionId + "/events"))
                .GET()
                .build();
            throw new RuntimeException("Audit fetch failed: " + response.statusCode());
        // Log to structured output (replace with file/DB writer in production)
        System.out.println("[AUDIT TRAIL] Interaction: " + interactionId);
        System.out.println(response.body());
    public static void startTrainingSimulator(int port, String baseUrl, String token) throws Exception {
        HttpServer server = HttpServer.create(new InetSocketAddress(port), 0);
        server.createContext("/simulate", exchange -> {
            String query = exchange.getRequestURI().getQuery();
            String action = query != null && query.contains("action=barge") ? "barge" : "mute";
                VoiceControlExecutor.executeControl(baseUrl, token, "sim-interaction-id", action, false, "sim-supervisor-id");
                String response = "{\"status\":\"simulated\",\"action\":\"" + action + "\"}";
                exchange.sendResponseHeaders(200, response.length());
                try (OutputStream os = exchange.getResponseBody()) {
                    os.write(response.getBytes(StandardCharsets.UTF_8));
                String error = "{\"error\":\"" + e.getMessage() + "\"}";
                exchange.sendResponseHeaders(500, error.length());
                    os.write(error.getBytes(StandardCharsets.UTF_8));
        server.start();
        System.out.println("Training simulator running on port " + port);
The following class integrates authentication, validation, control execution, streaming, presence updates, and audit logging into a single executable module. Replace the placeholder credentials and interaction identifiers before execution.
public class CxoneSupervisorControl {
    private static final String BASE_URL = System.getenv("CXONE_BASE_URL");
    private static final String CLIENT_ID = System.getenv("CXONE_CLIENT_ID");
    private static final String CLIENT_SECRET = System.getenv("CXONE_CLIENT_SECRET");
    public static void main(String[] args) throws Exception {
        if (BASE_URL == null || CLIENT_ID == null || CLIENT_SECRET == null) {
            throw new IllegalStateException("Environment variables CXONE_BASE_URL, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET must be set");
        String token = CxoneAuth.getAccessToken(BASE_URL, CLIENT_ID, CLIENT_SECRET);
        String interactionId = "your-active-interaction-id";
        String agentId = "target-agent-user-id";
        String supervisorId = "supervisor-user-id";
        // 1. Validate privacy and hierarchy
        boolean privacyAllowed = InteractionValidator.checkPrivacyAllowed(BASE_URL, token, agentId);
        if (!privacyAllowed) {
            System.out.println("Supervision blocked: Agent has privacy enabled.");
            return;
        // 2. Update supervisor presence
        StreamSyncAndPresence.updateSupervisorPresence(BASE_URL, token, supervisorId, "busy", "supervising");
        // 3. Start real-time stream subscription
        AtomicBoolean running = new AtomicBoolean(true);
        StreamSyncAndPresence.subscribeToVoiceStream(BASE_URL, token, interactionId, running);
        // 4. Execute barge control with ETag conflict resolution
        VoiceControlExecutor.executeControl(BASE_URL, token, interactionId, "barge", false, supervisorId);
        // 5. Execute mute control
        VoiceControlExecutor.executeControl(BASE_URL, token, interactionId, "mute", true, supervisorId);
        // 6. Fetch audit trail
        AuditAndSimulator.fetchAndLogAuditTrail(BASE_URL, token, interactionId);
        // Cleanup
        running.set(false);
        StreamSyncAndPresence.updateSupervisorPresence(BASE_URL, token, supervisorId, "available", "");
        System.out.println("Supervision session completed.");
Common Errors and Debugging
  • Cause: Expired access token, missing scopes, or incorrect client credentials.
  • Fix: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET match a server-to-server application in the CXone admin console. Ensure the scope string includes voice:interactions:control. Implement token caching with a 5-second expiration buffer as shown in CxoneAuth.
Error: 403 Forbidden
  • Cause: The supervisor user lacks the required role assignments or the target interaction belongs to a queue outside the supervisor hierarchy.
  • Fix: Assign the Supervisor or Voice Administrator role in CXone. Verify the voice:interactions:control scope is granted to the OAuth application. Check privacy settings via /api/v2/users/{agentId}/privacy before issuing control commands.
Error: 412 Precondition Failed
  • Cause: The interaction state changed between the GET request and the POST /control request. The If-Match header ETag no longer matches the server state.
  • Fix: Implement the retry loop shown in VoiceControlExecutor. Re-fetch the interaction details to obtain the current ETag, then retry the control payload. Limit retries to three attempts to prevent infinite loops during rapid state changes.
  • Cause: Exceeded CXone API rate limits. Control endpoints typically allow 10-20 requests per second per tenant.
  • Fix: Parse the Retry-After header when present. If absent, apply exponential backoff starting at 1 second. Throttle dashboard polling and batch presence updates to reduce request volume.
Error: 5xx Server Error
  • Cause: Transient CXone platform degradation or internal routing failure.
  • Fix: Implement circuit breaker logic. Retry with exponential backoff up to 30 seconds. Log the full request/response cycle for support ticket submission. Do not retry control actions that modify interaction state more than once without explicit supervisor confirmation.
