Controlling Genesys Cloud IVR Call Flow via Media API with Node.js
A production-ready call controller that programmatically directs IVR sessions using atomic Media API commands, validates payloads against engine constraints, tracks execution metrics, and synchronizes control events with external call detail records. This tutorial uses the Genesys Cloud Media API (/api/v2/media/call/control) and Node.js.
- OAuth Client ID and Secret with the
media:controlscope - Genesys Cloud API v2 endpoint (
https://{env}.mygenesyscloud.com) - Node.js 18+ with native
fetchoraxios - External dependencies:
axios,express,pino,uuid - A publicly accessible HTTPS endpoint to receive Genesys control callbacks
Genesys Cloud requires OAuth 2.0 client credentials authentication for programmatic access. The Media API requires the media:control scope. Token caching and automatic refresh prevents unnecessary credential exchanges during long-running IVR sessions.
import axios from 'axios';
const GENESYS_BASE_URL = process.env.GENESYS_ENV || 'https://api.mypurecloud.com';
class GenesysAuthClient {
constructor(clientId, clientSecret, scopes) {
this.clientId = clientId;
this.scopes = scopes;
this.token = null;
this.expiresAt = 0;
async getAccessToken() {
if (this.token && Date.now() < this.expiresAt) {
return this.token;
const authHeader = Buffer.from(`${this.clientId}:${this.clientSecret}`).toString('base64');
const response = await axios.post(`${GENESYS_BASE_URL}/oauth/token`, {
scope: this.scopes.join(' ')
headers: {
Authorization: `Basic ${authHeader}`,
'Content-Type': 'application/x-www-form-urlencoded',
'X-Request-ID': uuidv4()
this.token = response.data.access_token;
this.expiresAt = Date.now() + (response.data.expires_in * 1000) - 60000; // Refresh 60s early
return this.token;
getHeaders() {
Step 1: Construct Control Payloads with Call ID References and DTMF Matrices
The Media API control payload requires a valid callId, an array of actions, and optional callbacks. DTMF collection uses a constraint matrix that defines maximum digits, timeout thresholds, and terminator keys. Playback directives reference secure media URIs.
function buildControlPayload(callId, mediaUri, dtmfConfig, callbackUrl) {
callId,
actions: [
type: 'play',
mediaUri: mediaUri,
volume: 1.0,
repeat: false
type: 'collect',
dtmf: {
maxDigits: dtmfConfig.maxDigits || 4,
timeout: dtmfConfig.timeout || 5000,
terminators: dtmfConfig.terminators || ['#'],
interDigitTimeout: dtmfConfig.interDigitTimeout || 2000
audio: {
prompt: mediaUri,
playPrompt: true
callbacks: [callbackUrl]
Step 2: Validate Schemas Against Media Engine Constraints and Command Limits
Genesys media engines enforce strict payload schemas and command sequence limits. Sending excessive actions or malformed DTMF matrices causes silent failures or call drops. This validation pipeline checks carrier capability constraints, verifies media resource availability, and enforces a maximum command limit of five actions per atomic request.
async function validateControlPayload(payload, mediaResourceCheckUrl) {
// Enforce maximum command sequence limit
if (payload.actions.length > 5) {
throw new Error('Control payload exceeds maximum command sequence limit of 5 actions.');
// Verify media resource accessibility
const mediaUri = payload.actions[0].mediaUri;
const headResponse = await axios.head(mediaUri, { timeout: 3000 });
if (!headResponse.headers['content-type']?.startsWith('audio/')) {
throw new Error('Media resource does not serve a valid audio MIME type.');
} catch (error) {
throw new Error(`Media resource unavailable or invalid: ${error.message}`);
// Validate DTMF collection matrix constraints
const collectAction = payload.actions.find(a => a.type === 'collect');
if (collectAction) {
const { maxDigits, timeout } = collectAction.dtmf;
if (maxDigits < 1 || maxDigits > 32) {
throw new Error('DTMF maxDigits must be between 1 and 32.');
if (timeout < 1000 || timeout > 30000) {
throw new Error('DTMF timeout must be between 1000ms and 30000ms.');
// Carrier capability simulation check (e.g., codec compatibility, SIP INFO support)
const supportedPayloadFormats = ['play', 'collect', 'transfer', 'hangup'];
const invalidActions = payload.actions.filter(a => !supportedPayloadFormats.includes(a.type));
if (invalidActions.length > 0) {
throw new Error(`Unsupported action types detected: ${invalidActions.map(a => a.type).join(', ')}`);
return true;
Step 3: Execute Atomic POST Operations with Retry Logic and State Tracking
Each Media API control request is atomic. The platform returns a controlId and processes the sequence independently. Automatic state transition triggers require waiting for the previous control to complete before issuing the next command. This implementation uses exponential backoff for 429 rate limits and implements a state queue to prevent concurrent control collisions.
class ControlExecutor {
constructor(authClient) {
this.authClient = authClient;
this.controlQueue = [];
this.isProcessing = false;
async executeControl(payload) {
return new Promise((resolve, reject) => {
this.controlQueue.push({ payload, resolve, reject });
this.processQueue();
async processQueue() {
if (this.isProcessing || this.controlQueue.length === 0) return;
this.isProcessing = true;
const { payload, resolve, reject } = this.controlQueue.shift();
const token = await this.authClient.getAccessToken();
const headers = { ...this.authClient.getHeaders(), Authorization: `Bearer ${token}` };
const response = await this.retryRequest(() =>
axios.post(`${GENESYS_BASE_URL}/api/v2/media/call/control`, payload, { headers, timeout: 10000 })
resolve(response.data);
} catch (error) {
reject(error);
} finally {
// Process next item after a brief state synchronization delay
setTimeout(() => this.processQueue(), 500);
async retryRequest(fn) {
let attempts = 0;
const maxAttempts = 3;
while (attempts < maxAttempts) {
return await fn();
} catch (error) {
if (error.response?.status === 429 || error.response?.status === 503) {
const delay = Math.pow(2, attempts) * 1000;
await new Promise(r => setTimeout(r, delay));
attempts++;
} else {
throw error;
HTTP Request/Response Cycle
POST /api/v2/media/call/control HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIs...
X-Request-ID: 8f3a1c2d-9b4e-4f1a-a7c6-1d2e3f4a5b6c
"callId": "c4a7b2e1-9f3d-4a1b-8c5e-7d6f2a3b4c5d",
"actions": [
{ "type": "play", "mediaUri": "https://secure-media.example.com/prompts/welcome.wav", "volume": 1.0 },
{ "type": "collect", "dtmf": { "maxDigits": 4, "timeout": 5000, "terminators": ["#"] } }
"callbacks": ["https://your-server.example.com/api/v1/media/callbacks"]
HTTP/1.1 202 Accepted
"controlId": "ctrl-9a8b7c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d",
"status": "queued",
"timestamp": "2024-06-15T14:32:18.452Z"
Step 4: Implement Callback Handlers for External CDR Synchronization
Genesys triggers the configured callback URL when control actions complete, fail, or collect DTMF. This handler parses the event payload, synchronizes state with an external CDR store, and updates the control queue to allow the next atomic command.
import express from 'express';
import pino from 'pino';
const logger = pino({ level: 'info', transport: { target: 'pino-pretty' } });
function createCallbackHandler(cdrStore) {
const router = express.Router();
router.use(express.json());
router.post('/api/v1/media/callbacks', async (req, res) => {
const event = req.body;
const { callId, controlId, eventType, dtmf, status } = event;
logger.info({ callId, controlId, eventType }, 'Media control event received');
// Synchronize with external CDR
await cdrStore.updateCallState(callId, {
controlId,
eventType,
dtmfCollected: dtmf?.digits,
status: status || 'completed',
logger.info({ callId, status: 'synced' }, 'CDR updated successfully');
res.status(200).send('OK');
} catch (error) {
logger.error({ callId, error: error.message }, 'CDR synchronization failed');
res.status(500).send('Internal Server Error');
return router;
Step 5: Track Latency, Success Rates, and Generate Audit Logs
Voice efficiency requires precise measurement of control latency and command success rates. This implementation wraps the executor with metrics collection and structured audit logging for compliance and governance.
class MetricsCollector {
constructor() {
this.totalCommands = 0;
this.successfulCommands = 0;
this.latencies = [];
recordAttempt(latencyMs, success) {
this.totalCommands++;
this.latencies.push(latencyMs);
if (success) this.successfulCommands++;
getSuccessRate() {
return this.totalCommands > 0 ? (this.successfulCommands / this.totalCommands) * 100 : 0;
getAverageLatency() {
if (this.latencies.length === 0) return 0;
return this.latencies.reduce((a, b) => a + b, 0) / this.latencies.length;
The following module exposes a CallController class that integrates authentication, validation, execution, callback handling, metrics, and audit logging into a single automated management interface.
import { GenesysAuthClient } from './auth.js';
import { ControlExecutor } from './executor.js';
import { buildControlPayload, validateControlPayload } from './payload.js';
import { createCallbackHandler } from './callback.js';
import { MetricsCollector } from './metrics.js';
const logger = pino({ level: 'info' });
class CallController {
constructor(clientId, clientSecret, callbackUrl, cdrStore) {
this.authClient = new GenesysAuthClient(clientId, clientSecret, ['media:control']);
this.executor = new ControlExecutor(this.authClient);
this.metrics = new MetricsCollector();
this.callbackUrl = callbackUrl;
this.cdrStore = cdrStore;
async initiateCallControl(callId, mediaUri, dtmfConfig) {
const startTime = Date.now();
const payload = buildControlPayload(callId, mediaUri, dtmfConfig, this.callbackUrl);
await validateControlPayload(payload);
logger.info({ callId, action: 'validation_passed' }, 'Control payload validated');
const result = await this.executor.executeControl(payload);
const latency = Date.now() - startTime;
this.metrics.recordAttempt(latency, true);
logger.info({
callId,
controlId: result.controlId,
latency,
successRate: this.metrics.getSuccessRate().toFixed(2)
}, 'Control command executed successfully');
return result;
} catch (error) {
this.metrics.recordAttempt(latency, false);
logger.error({ callId, error: error.message, latency }, 'Control command failed');
throw error;
startCallbackServer(port = 3000) {
const app = express();
app.use(createCallbackHandler(this.cdrStore));
app.listen(port, () => {
logger.info({ port }, 'Callback server listening');
return app;
export { CallController };
What causes it: The OAuth token is expired, missing the media:control scope, or the client lacks media control permissions in the Genesys organization.
How to fix it: Verify the token generation includes media:control. Check the Genesys admin console under Security > OAuth 2.0 Credentials. Ensure the client is assigned to a role with media:control permissions.
Code showing the fix:
// Ensure scope is explicitly requested during token generation
const authClient = new GenesysAuthClient(process.env.CLIENT_ID, process.env.CLIENT_SECRET, ['media:control']);
Error: 400 Bad Request with Invalid control payload
What causes it: The action array exceeds the five-command limit, DTMF constraints violate engine bounds, or the media URI is unreachable.
How to fix it: Run the payload through the validateControlPayload function before execution. Verify media URI returns a valid audio MIME type. Ensure maxDigits is between 1 and 32.
} catch (validationError) {
console.error('Payload rejected:', validationError.message);
return;
What causes it: The Media API enforces rate limits per tenant. Rapid control iterations or concurrent call manipulations trigger throttling.
How to fix it: Implement exponential backoff. The ControlExecutor.retryRequest method handles 429 responses automatically. Avoid parallel control posts for the same callId.
// Handled internally in ControlExecutor.processQueue
Error: Callback Not Triggered or CDR Out of Sync
What causes it: The callback URL is not publicly accessible, uses HTTP instead of HTTPS, or fails to return a 2xx status code within 5 seconds.
How to fix it: Ensure the endpoint uses HTTPS. Return 200 OK immediately upon receipt. Process CDR updates asynchronously in the background. Verify the URL matches the exact path registered in Genesys.
res.status(200).send('OK'); // Acknowledge immediately
// Process CDR sync in background
setImmediate(() => processCallbackAsync(req.body));
