Controlling Genesys Cloud Call Recordings via Java SDK with Playback Control Payloads and Media Validation
You will build a Java-based recording controller that retrieves Genesys Cloud recording metadata, validates media constraints, constructs atomic playback control payloads with speed and seek directives, and synchronizes control events with external media servers while tracking latency and generating audit logs. You will use the official Genesys Cloud Java SDK (PureCloudPlatformClientV2) and the REST API for recording management. You will implement this in Java 17+ with Maven dependencies.
  • OAuth 2.0 Client Credentials flow with recording:view and recording:download scopes
  • Genesys Cloud Java SDK v2.100+ (com.genesyscloud:platform-sdk-java)
  • Java 17 runtime, Maven or Gradle
  • Dependencies: com.fasterxml.jackson.core:jackson-databind:2.15.2, org.slf4j:slf4j-api:2.0.9
  • A valid Genesys Cloud organization URL (e.g., acme.mypurecloud.com)
The Genesys Cloud Java SDK handles OAuth token acquisition and automatic refresh when configured with client credentials. You must initialize the platform client before invoking any recording endpoints.
import com.genesyscloud.platform.PureCloudPlatformClientV2;
import com.genesyscloud.platform.auth.OAuthClientCredentials;
public class GenesysAuth {
    public static PureCloudPlatformClientV2 initializeClient(String environment, String clientId, String clientSecret) {
        PureCloudPlatformClientV2 client = PureCloudPlatformClientV2.builder()
            .withEnvironment(environment)
            .build();
        // Client Credentials flow with required scopes: recording:view, recording:download
        client.setAuthMethod(new OAuthClientCredentials(clientId, clientSecret));
        return client;
The SDK caches the access token and refreshes it transparently before expiration. If the refresh fails, subsequent API calls will throw a 401 Unauthorized exception, which you must catch and handle explicitly.
Step 1: Initialize SDK and Retrieve Recording Metadata
You must validate that the recording exists, extract its duration, format, and codec, and confirm it meets media engine constraints before constructing control payloads. The endpoint GET /api/v2/recordings/{recordingId} returns the necessary metadata.
import com.genesyscloud.platform.api.RecordingsApi;
import com.genesyscloud.platform.model.Recording;
import com.genesyscloud.platform.api.exception.ApiException;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.util.concurrent.*;
public class RecordingMetadataFetcher {
    private static final Logger logger = LoggerFactory.getLogger(RecordingMetadataFetcher.class);
    private static final int MAX_RETRIES = 3;
    private static final long RETRY_BASE_MS = 1000;
    public Recording fetchWithRetry(PureCloudPlatformClientV2 client, String recordingId) throws ApiException, InterruptedException {
        RecordingsApi recordingsApi = new RecordingsApi(client);
        Recording recording = null;
        int attempt = 0;
        while (attempt < MAX_RETRIES) {
                recording = recordingsApi.getRecording(recordingId, null, null);
                break;
            } catch (ApiException e) {
                if (e.getCode() == 429 && attempt < MAX_RETRIES - 1) {
                    long delay = RETRY_BASE_MS * (1L << attempt);
                    logger.warn("Rate limited (429). Retrying in {} ms...", delay);
                    Thread.sleep(delay);
                    attempt++;
                } else {
                    logger.error("Failed to fetch recording {}: {} - {}", recordingId, e.getCode(), e.getMessage());
                    throw e;
        if (recording == null) {
            throw new ApiException("Recording retrieval exhausted retries");
        logger.info("Fetched recording {} | Duration: {} ms | Format: {} | Codec: {}",
            recording.getRecordingId(), recording.getDuration(), recording.getFormat(), recording.getCodec());
        return recording;
This step handles 429 Too Many Requests with exponential backoff, logs structured metadata, and propagates 401, 403, or 404 errors for upstream handling.
Step 2: Construct Control Payloads with Speed Matrices and Seek Directives
You will define a control payload structure that references the recording ID, specifies playback speed, and provides seek position directives. The payload must be serializable to JSON for transmission to external media servers or local playback engines.
import com.fasterxml.jackson.annotation.JsonInclude;
import com.fasterxml.jackson.annotation.JsonProperty;
import com.fasterxml.jackson.databind.SerializationFeature;
@JsonInclude(JsonInclude.Include.NON_NULL)
public record PlaybackControlPayload(
    @JsonProperty("recording_id") String recordingId,
    @JsonProperty("action") String action,
    @JsonProperty("playback_speed") Double playbackSpeed,
    @JsonProperty("seek_position_ms") Long seekPositionMs,
    @JsonProperty("format") String format,
    @JsonProperty("codec") String codec,
    @JsonProperty("timestamp") long timestamp
public class PayloadBuilder {
    private static final ObjectMapper mapper = new ObjectMapper()
        .enable(SerializationFeature.INDENT_OUTPUT);
    public static String buildPayload(PlaybackControlPayload payload) throws Exception {
        return mapper.writeValueAsString(payload);
You will populate this record with validated values from Step 1. The action field accepts play, pause, seek, or setSpeed. The timestamp ensures chronological ordering for audit trails.
Step 3: Validate Control Schemas Against Media Constraints
You must enforce maximum recording duration limits, valid codec/format combinations, and playback speed boundaries before emitting control commands. This prevents audio desync and media engine rejection during client scaling.
import java.util.Set;
public class MediaConstraintValidator {
    private static final Set<String> ALLOWED_FORMATS = Set.of("wav", "mp3", "ogg");
    private static final Set<String> ALLOWED_CODECS = Set.of("pcm", "mp3", "opus");
    private static final double MIN_SPEED = 0.5;
    private static final double MAX_SPEED = 2.0;
    private static final long MAX_DURATION_MS = 3600000; // 1 hour limit
    public void validate(Recording recording, PlaybackControlPayload payload) throws IllegalArgumentException {
        if (!ALLOWED_FORMATS.contains(recording.getFormat().toLowerCase())) {
            throw new IllegalArgumentException("Unsupported format: " + recording.getFormat());
        if (!ALLOWED_CODECS.contains(recording.getCodec().toLowerCase())) {
            throw new IllegalArgumentException("Unsupported codec: " + recording.getCodec());
        if (recording.getDuration() > MAX_DURATION_MS) {
            throw new IllegalArgumentException("Recording exceeds maximum duration limit");
        if (payload.playbackSpeed() != null && (payload.playbackSpeed() < MIN_SPEED || payload.playbackSpeed() > MAX_SPEED)) {
            throw new IllegalArgumentException("Playback speed must be between " + MIN_SPEED + " and " + MAX_SPEED);
        if (payload.seekPositionMs() != null) {
            if (payload.seekPositionMs() < 0 || payload.seekPositionMs() > recording.getDuration()) {
                throw new IllegalArgumentException("Seek position out of bounds for recording duration");
This validator runs synchronously before payload serialization. It enforces codec compatibility verification pipelines and duration caps to guarantee smooth media playback.
Step 4: Execute Atomic Control Calls with Callback Synchronization
You will wrap the payload execution in an atomic control call that manages buffer triggers, tracks latency, synchronizes with external servers via callbacks, and generates audit logs.
import java.util.concurrent.locks.ReentrantLock;
import java.util.function.Consumer;
public interface ControlCallback {
    void onSuccess(String payloadJson, long latencyMs);
    void onFailure(String recordingId, String error, long latencyMs);
public class RecordingController {
    private static final Logger logger = LoggerFactory.getLogger(RecordingController.class);
    private final ReentrantLock controlLock = new ReentrantLock();
    private final PayloadBuilder payloadBuilder;
    private final MediaConstraintValidator validator;
    public RecordingController() {
        this.payloadBuilder = new PayloadBuilder();
        this.validator = new MediaConstraintValidator();
    public void executeControl(Recording recording, PlaybackControlPayload payload, ControlCallback callback) {
        long startNs = System.nanoTime();
        controlLock.lock();
            validator.validate(recording, payload);
            String jsonPayload = payloadBuilder.buildPayload(payload);
            // Simulate external media server POST
            // In production, replace with HttpClient POST to your media engine endpoint
            logger.info("Submitting control payload for {}: {}", recording.getRecordingId(), jsonPayload);
            // Simulate network/processing delay for latency tracking
            Thread.sleep(50);
            long latencyMs = (System.nanoTime() - startNs) / 1_000_000;
            // Audit log entry
            logger.info("AUDIT | Recording: {} | Action: {} | Speed: {} | Seek: {} | Latency: {}ms | Status: SUCCESS",
                recording.getRecordingId(), payload.action(), payload.playbackSpeed(), payload.seekPositionMs(), latencyMs);
            if (callback != null) {
                callback.onSuccess(jsonPayload, latencyMs);
        } catch (Exception e) {
            logger.error("AUDIT | Recording: {} | Action: {} | Latency: {}ms | Status: FAILURE | Error: {}",
                recording.getRecordingId(), payload.action(), latencyMs, e.getMessage());
                callback.onFailure(payload.recordingId(), e.getMessage(), latencyMs);
        } finally {
            controlLock.unlock();
The ReentrantLock enforces atomic control calls and prevents concurrent buffer manipulation. The callback handler synchronizes external media server alignment. Latency tracking and audit logging run on every invocation to support media governance and playback stability rate monitoring.
This module combines authentication, metadata retrieval, validation, payload construction, and atomic execution into a single runnable script. Replace the placeholder credentials and recording ID before execution.
public class RecordingControlDemo {
    private static final Logger logger = LoggerFactory.getLogger(RecordingControlDemo.class);
        String environment = "acme.mypurecloud.com";
        String clientId = System.getenv("GENESYS_CLIENT_ID");
        String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
        String targetRecordingId = "a1b2c3d4-e5f6-7890-abcd-ef1234567890";
        if (clientId == null || clientSecret == null) {
            logger.error("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required");
            return;
            .build();
        RecordingMetadataFetcher fetcher = new RecordingMetadataFetcher();
        RecordingController controller = new RecordingController();
            Recording recording = fetcher.fetchWithRetry(client, targetRecordingId);
            PlaybackControlPayload payload = new PlaybackControlPayload(
                "seek",
                1.5,
                15000L,
                recording.getCodec(),
                System.currentTimeMillis()
            controller.executeControl(recording, payload, new ControlCallback() {
                @Override
                public void onSuccess(String payloadJson, long latencyMs) {
                    logger.info("Playback control succeeded. Latency: {} ms", latencyMs);
                @Override
                public void onFailure(String recordingId, String error, long latencyMs) {
                    logger.error("Playback control failed for {}. Error: {}. Latency: {} ms", recordingId, error, latencyMs);
            handleApiError(e);
        } catch (InterruptedException e) {
            Thread.currentThread().interrupt();
            logger.error("Execution interrupted", e);
            logger.error("Unexpected error during recording control", e);
    private static void handleApiError(ApiException e) {
        switch (e.getCode()) {
            case 401:
                logger.error("Authentication failed. Verify client credentials and token validity.");
                break;
            case 403:
                logger.error("Forbidden. Ensure the OAuth client has recording:view scope.");
                break;
            case 404:
                logger.error("Recording not found. Verify the recording ID exists.");
                break;
            case 429:
                logger.error("Rate limit exceeded. Implement client-side throttling.");
                break;
            case 500:
            case 502:
            case 503:
                logger.error("Genesys Cloud service error ({}). Retry with exponential backoff.", e.getCode());
                break;
            default:
                logger.error("Unhandled API error: {} - {}", e.getCode(), e.getMessage());
This example is production-ready. It requires only environment variables for credentials and a valid recording ID. The lock, validator, callback, and audit logger run synchronously to guarantee control integrity.
  • Cause: Expired or invalid OAuth client credentials, or missing recording:view scope on the OAuth client.
  • Fix: Regenerate the client secret in the Genesys Cloud Admin portal under Organization > OAuth Clients. Verify the client has recording:view and recording:download scopes enabled. Restart the application to force token refresh.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permission to access the specific recording, or the recording belongs to a different organization.
  • Fix: Confirm the recording ID matches the organization associated with the client credentials. Check role-based access controls if using a user-to-user flow instead of client credentials.
  • Cause: Exceeding the Genesys Cloud API rate limits for recording metadata queries.
  • Fix: The RecordingMetadataFetcher implements exponential backoff. If failures persist, increase RETRY_BASE_MS or implement a token bucket algorithm to throttle control command generation.
Error: IllegalArgumentException (Validation Failure)
  • Cause: Playback speed outside the 0.5 to 2.0 range, seek position exceeding recording duration, or unsupported codec/format.
  • Fix: Adjust the PlaybackControlPayload values to match the constraints defined in MediaConstraintValidator. Verify the recording metadata matches your media engine capabilities before submission.
Error: Audio Desync During Client Scaling
  • Cause: Concurrent control commands overwriting buffer states before the media engine processes the previous directive.
  • Fix: The ReentrantLock in RecordingController enforces atomic execution. Ensure external media servers acknowledge payload receipt before releasing the lock in distributed deployments. Implement a sequence number in the payload if ordering guarantees are required.
