Hi All,
I have set up a 7.5 environment to test studio IVR applications only and have these components installed - Core components, IPCS, TTS, ASR and the IVR server client on a single server. I call the application by dialing @ from a soft phone. When I call application, the connection ID is not populated or NULL(I checked the popgateway and the CFA debug logs and it’s null there). Everything else as far as the application is concerned is working fine (ANI present, SessionID present, prompts played etc). I am a newbie to installation and configuration, haven’t had installation/admin training. I read in the GVP 7.5 reference manual(pg 269) that the IVR client receives the connID from the IVR server and if IVR server doesn’t it still passes one on to the CFA. GVP 7.5 vxml 2.1 ref manual(pg 59) says connID isn’t available at setup time in network mode. But in my case is there any way of getting a connID? Work around may be… Any help or suggestion would be great.
Thanks.
