I have a trouble between Knowledge Manager and UCS!
When i try to connect the Knowlege manager, I got the following error: “Contact Server Connection Failed”
This connection is through a server using a NAT IP
But, it is wierd becouse, I did the Installation(knowledge manager) in my computer and it worked!
I saw logs of knowledge manager and there is a message: “com.genesyslab.icc.api.contactserver.PersistentException: UCS connection failed”
Look this:
at com.genesyslab.icc.api.contactserver.UCSMonitor.connect(Unknown Source)
at Genesys.iknow.manager.TM_DB.createContactServer(TM_DB.java:433)
at Genesys.iknow.manager.TM_DB.connectInit(TM_DB.java:143)
at Genesys.iknow.manager.TM_DB.(TM_DB.java:47)
at Genesys.iknow.manager.TM_Parm.initParm(TM_Parm.java:856)
at Genesys.iknow.manager.TM_start$LoginChecker.doLogin(TM_start.java:103)
at com.genesyslab.unilogin.LoginActions$OkAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicRootPaneUI$Actions.actionPerformed(BasicRootPaneUI.java:191)
at javax.swing.plaf.basic.BasicComboBoxUI$Actions.actionPerformed(BasicComboBoxUI.java:1575)
at javax.swing.plaf.basic.BasicComboBoxUI$Handler.actionPerformed(BasicComboBoxUI.java:1904)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:492)
at javax.swing.JTextField.postActionEvent(JTextField.java:705)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:820)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1633)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2851)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2886)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2814)
at java.awt.Component.processEvent(Component.java:6040)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1850)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:712)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:990)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:855)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:676)
at java.awt.Component.dispatchEventImpl(Component.java:4502)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:178)
at java.awt.Dialog$1.run(Dialog.java:1046)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: java.rmi.ConnectException: Connection refused to host: SVTT102CTO; nested exception is:
java.net.ConnectException: Connection refused: connect
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:601)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:198)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:184)
at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:322)
at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
… 50 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.(Socket.java:375)
at java.net.Socket.(Socket.java:189)
at com.genesyslab.util.rmi.CustomSocket.(Unknown Source)
at com.genesyslab.util.rmi.CustomClientSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:595)
… 54 more”
Really, it does not connect to UCS!!
Someone can help me with this trouble??
I would be VERY GRATEFUL!!!
Error message says that remote host refused the connection (see extract below). Please check there is no firewall blocking the connection including Windows Firewall running on the server.
Thank Very much René!
But, I tryed make a telnet on the server name (and number) and the port, AND IS EVERYTHING OK!
but it does not work yet whe i try to connect!!!
Perharps, is it a problem with java?
I JUST RESTART UCS BEFORE CHANGE THE DUPLEX-MODE OPTION, AND CHANGE THE HOST CONFIGURATION(VERY IMPORTANT)!
THIS TROUBLE IS BECAUSE I AM USING A NAT IP!!!
facing same problem Filippe solved way back in 2011, I decided to reply to the very same topic. Let me know if it’s better to start a whole new topic.
As I said, same problem… refused connection to UCS when logging to Knowledge Manager. ‘ucsapi-duplex-mode’ is enabled on UCS and, following what Filippe did, tried a telnet and everything seems okay. Tried a restart of UCS as well.
What am I missing?
at Genesys.iknow.manager.TM_Parm.initParm(TM_Parm.java:836)
at Genesys.iknow.manager.TM_start$LoginChecker.doLogin(TM_start.java:112)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6516)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:720)
at java.awt.EventQueue$4.run(EventQueue.java:718)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:745)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:715)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.rmi.ConnectException: Connection refused to host: T-CTI-POM-WSV06; nested exception is:
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:619)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202)
at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:341)
... 56 more
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:579)
at java.net.Socket.connect(Socket.java:528)
at java.net.Socket.(Socket.java:425)
at java.net.Socket.(Socket.java:208)
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:613)
... 60 more
Sorry for confusing with version number - remebered it wrong… BTW - Your version is not available any longer from Genesys…
The bug I mentioned is fixed in the version released yesterday:
"UCS support for RMI-based applications such as Knowledge Manager, GAD, ISDK and GIS is restored. Note that you still need to enable RMI support—option enable-rmi—in UCS options. (ESR-14549) "
