Connection with VBA (Excel)
You can create a connection to Outbound Contact Manager via Excel / VBA?
lol…no. DBServer is your software to connect to databases. Excel is not a DB
Thank you, I now have around 58 campaigns complement all and would like to generate a command to take the Excel through VBA, what and how much are the blank contacts each. It’s possible?
Is there any way to connect to genesys base at exce / vba?
Right would toolkit using desktop Genesys?
If you just want to use Excel, just connect to the OCS database directly from Excel (there are connectors). Or just use any current SQL tool, which support export to CSV.
