Configuring SDP Offer/Answer Negotiation Overrides in Genesys Cloud Agent Desktop to Force Opus Codec Fallback for Low-Bandwidth Edge Sites
This guide details how to enforce Opus codec priority during SIP/WebRTC SDP negotiation for Genesys Cloud Agent Desktop endpoints operating over constrained edge networks. You will configure tenant-level audio prioritization, apply WebRTC bandwidth constraints, enforce codec selection through Architect media flows, and validate the resulting SDP answer payload. The end result is a deterministic Opus fallback mechanism that eliminates G.711/GSM packet bloat while maintaining sub-150ms MOS scores on links with less than 5 Mbps asymmetric throughput.
- Licensing Tier: Genesys Cloud CX 1, 2, or 3 (Telephony and Routing features required). WebRTC client functionality is included in all tiers.
- IAM Roles & Permissions:
Telephony > Settings > EditTelephony > Settings > WebRTC > EditRouting > Media > EditRouting > Architect > EditAdministration > Organization > Edit
- OAuth Scopes (API/Integration):
telephony:settings:editrouting:media:editrouting:architect:edituser:read(for trace validation)
- External Dependencies:
- Genesys Cloud WebRTC Agent Desktop version 12.0.0 or higher
- Network path to Genesys Cloud edge media servers (ports 443, UDP 3478-3481, UDP 10000-20000)
- Access to browser developer tools or Wireshark for SDP payload inspection
1. Platform-Level Audio Codec Prioritization & SDP Answer Generation
Genesys Cloud does not expose SDP negotiation controls directly within the Agent Desktop UI. The platform generates SDP answers based on a centralized codec priority list stored in the tenant telephony configuration. When an edge site initiates a WebRTC or SIP session, the Genesys Cloud media server evaluates the incoming SDP offer, matches it against the tenant priority list, and returns an SDP answer containing only the highest-priority mutually supported codec.
To force Opus to the top of the negotiation stack, you must update the tenant audio settings via the Genesys Cloud REST API. The UI provides a drag-and-drop interface, but the API guarantees deterministic ordering and eliminates manual configuration drift.
API Configuration:
PATCH /api/v2/telephony/settings/audio
"codecs": [
"name": "opus",
"priority": 0,
"enabled": true
"name": "g722",
"priority": 1,
"enabled": true
"name": "pcmu",
"priority": 2,
"enabled": true
"name": "pcma",
"priority": 3,
"enabled": true
The Trap: Setting Opus to priority 0 globally without validating third-party PSTN trunk capabilities causes SDP negotiation failures on carrier gateways that do not support RFC 6716. Many legacy TDM/PSTN providers only advertise G.711 (PCMU/PCMA) and G.729 in their SDP offers. When the Genesys Cloud media server answers with Opus, the carrier rejects the answer, resulting in immediate call termination with a 488 Not Acceptable Here SIP response.
Architectural Reasoning: We prioritize Opus at the tenant level because the media server uses this list as the baseline for all SDP answer generation. WebRTC clients inherently support Opus, and the codec provides superior compression at 12-18 kbps compared to G.711’s fixed 64 kbps. By placing Opus at index 0, the media server will always select it when the endpoint advertises support, reducing bandwidth consumption by approximately 72 percent per concurrent voice stream. This reduction is critical for edge sites sharing bandwidth with ERP, POS, or video surveillance traffic.
2. WebRTC SDP Negotiation Constraints & Bandwidth Profiling
Codec priority alone does not guarantee stable audio on low-bandwidth links. WebRTC SDP negotiation includes bandwidth estimation parameters (b=AS, b=TIAS) that the Genesys Cloud media server uses to calculate packetization intervals and jitter buffer thresholds. If these values remain at default, the media server may still allocate excessive padding or disable packetization optimization, negating Opus’s compression benefits.
You must configure WebRTC bandwidth constraints to align with the edge site’s asymmetric throughput characteristics. This configuration modifies the SDP answer’s bandwidth lines and forces the media server to apply Opus-specific packetization strategies.
API Configuration:
PUT /api/v2/telephony/settings/webrtc
"enabled": true,
"defaultBandwidth": "low",
"maxBitrate": 24000,
"minBitrate": 12000,
"packetizationMode": "1",
"useStereo": false,
"dtmfType": "RFC2833"
The Trap: Setting maxBitrate below 12000 while keeping packetizationMode at 0 causes Opus to switch to SILK mode with aggressive frame loss concealment. This results in robotic audio artifacts and increased latency because the media server compensates for missing frames by expanding the jitter buffer to 120ms. The SDP answer will contain a=maxptime:60, which WebRTC clients interpret as a signal to reduce packet frequency, further degrading real-time responsiveness.
Architectural Reasoning: We enforce maxBitrate: 24000 and minBitrate: 12000 to lock Opus into CELT/HYBRID mode with 20ms frame intervals. This configuration generates SDP answers containing a=rtpmap:111 opus/48000/2 and a=fmtp:111 maxaveragebitrate=24000;stereo=0;usedtx=0. The 20ms packetization aligns with typical edge network MTU constraints and prevents UDP fragmentation. WebRTC’s built-in congestion control (GCC) will then dynamically scale between 12-24 kbps based on real-time RTCP receiver reports, ensuring the audio stream adapts to bursty link conditions without dropping below intelligible thresholds.
3. Architect Media Flow Enforcement for Edge Site Routing
Global tenant settings apply to all interactions, which introduces risk when high-bandwidth headquarters offices require G.722 wideband audio. To isolate Opus fallback behavior to specific edge sites, you must implement conditional media enforcement within Genesys Cloud Architect. This approach overrides the global codec list only for interactions originating from constrained network paths.
Create a new media flow or modify an existing one to detect edge site callers and apply explicit codec constraints before routing to Agent Desktop.
Architect Configuration Pattern:
- Add a Start block with
Interaction.Caller.PhoneNumber.AreaCodeorInteraction.Skillas the routing key. - Insert a Condition block evaluating
Interaction.Caller.NetworkBandwidth < 5000or matching edge site site codes. - Deploy a Set Media Settings block with the following configuration:
Codec Selection:Opus OnlyBandwidth Profile:LowDTMF Handling:RFC2833
- Route to the target queue or IVR path.
The Trap: Using the Set Media Settings block without verifying outbound trunk compatibility causes codec mismatch on the SDP answer when the interaction bridges to external carriers. The media flow forces Opus for the first leg, but if the second leg connects to a SIP trunk that only supports G.711, Genesys Cloud cannot transcode in real-time, resulting in one-way audio or immediate disconnection.
Architectural Reasoning: We isolate edge site routing through Architect because media flows execute before queue assignment and SIP signaling completion. The Set Media Settings block injects a X-GC-Codec-Override header into the internal SIP INVITE, instructing the media server to generate an SDP answer containing exclusively Opus parameters. This deterministic override prevents the media server from falling back to G.711 during negotiation retries. When combined with skill-based routing or site code matching, you maintain G.722 for headquarters endpoints while enforcing Opus for edge locations, optimizing total tenant bandwidth utilization without degrading primary office call quality.
4. Agent Desktop Client Verification & Trace Analysis
Agent Desktop does not negotiate codecs directly. It accepts the SDP answer from the Genesys Cloud media server and configures its WebRTC RTCPeerConnection accordingly. Verification requires inspecting the actual SDP payload exchanged during session establishment and confirming that the client’s audio processing pipeline matches the negotiated parameters.
Open the Agent Desktop browser, navigate to Developer Tools, and monitor the Network and Console tabs during a test call. Alternatively, use the Genesys Cloud Trace tool to capture the full SIP/WebRTC signaling exchange.
Trace Validation Steps:
- Initiate a call from the edge site Agent Desktop client.
- Capture the SDP answer from the media server response.
- Verify the following SDP lines:
m=audio 9 UDP/TLS/RTP/SAVPF 111 c=IN IP4 0.0.0.0 a=rtpmap:111 opus/48000/2 a=fmtp:111 maxaveragebitrate=24000;stereo=0;usedtx=0 a=ssrc:1234567890 cname:agent-desktop-edge b=AS:24 - Confirm the browser’s Media Inspector shows
codec: opus,bitrate: ~18000, andpacketLoss: <2%.
The Trap: Assuming configuration changes apply immediately without clearing the WebRTC connection pool causes stale SDP answers to persist. Genesys Cloud caches peer connections for up to 300 seconds to reduce signaling overhead. If you modify tenant settings or media flows while an Agent Desktop session remains active, the client will continue using the previous SDP answer until the connection expires, resulting in inconsistent audio quality during validation testing.
Architectural Reasoning: We validate at the client level because WebRTC implementations vary across Chrome, Firefox, and Electron-based desktop wrappers. Each browser enforces its own codec preference ordering and jitter buffer thresholds. By confirming the exact SDP answer lines and browser media inspector metrics, you verify that the platform configuration successfully propagated through the signaling chain. The b=AS:24 line confirms the media server applied the bandwidth constraint, and the a=fmtp parameters confirm Opus HYBRID mode activation. This end-to-end validation ensures the edge site receives the intended compression benefits without relying on platform defaults that may shift during Genesys Cloud patch cycles.
Edge Case 1: Opus SILK/CELT Mode Mismatch Causing Audio Artifacts
- The failure condition: Agents report robotic or clipped audio during calls exceeding 45 seconds. Network throughput remains stable, but MOS scores drop from 4.2 to 3.1.
- The root cause: The
maxBitratesetting is configured between 18000 and 24000, but the edge site experiences intermittent packet loss above 1.5 percent. Opus dynamically switches between SILK (speech-optimized) and CELT (music/general-optimized) modes based on frame content. High packet loss triggers aggressive frame loss concealment in SILK mode, causing audio discontinuities. - The solution: Adjust the WebRTC settings to
maxBitrate: 20000and adda=fmtp:111 useinbandfec=1via the media flow configuration. Enable forward error correction to allow the client to reconstruct lost frames without mode switching. Monitor RTCP XR reports to confirmpacketLossConcealmentmetrics decrease below 0.5 percent.
Edge Case 2: NAT Traversal Failure When Opus Packetization Changes ICE Timing
- The failure condition: Calls fail to establish with
ICE FAILEDorConnection Timeouterrors. Traces show successful SDP offer/answer exchange, but RTP streams never initialize. - The root cause: Opus 20ms packetization generates fewer UDP packets per second than G.711’s 20ms frames. Many edge site NAT devices and carrier CGNs interpret the reduced packet frequency as keepalive failure and drop the UDP mapping after 60 seconds. The SDP negotiation completes, but the data path expires before media flows.
- The solution: Configure the Set Media Settings block to inject
a=rtcp-muxand enable WebRTC keepalive probing. Alternatively, adjust the edge site firewall to maintain UDP mappings for ports 3478-3481 and 10000-20000 with a timeout exceeding 120 seconds. Verify usingpingandtracerouteto confirm NAT hold-time aligns with Opus packet intervals.
Edge Case 3: Third-Party PSTN Carrier Rejecting Opus in SDP Answer
- The failure condition: Outbound calls to mobile carriers or legacy VoIP providers fail with
488 Not Acceptable Hereor603 Decline. Inbound calls from these carriers drop immediately upon agent answer. - The root cause: The carrier’s SIP gateway does not support RFC 6716 and only advertises
a=rtpmap:0 PCMU/8000anda=rtpmap:8 PCMA/8000in the SDP offer. The Genesys Cloud media server answers with Opus, violating carrier codec compatibility matrices. - The solution: Implement trunk-level codec isolation. Create a dedicated outbound trunk for edge site PSTN routing and configure it with
Codec Selection: G711 Only. Use Architect to route edge site interactions through this trunk for external leg signaling, while maintaining Opus for the internal Agent Desktop leg. Genesys Cloud will perform real-time transcoding between Opus (internal) and G.711 (external), ensuring compatibility without sacrificing edge site bandwidth optimization.
