Configuring PCMU Audio Format Conversions for NICE CXone AudioHook Streams
You will configure NICE CXone AudioHook to output G.711 PCMU streams, implement the WebSocket receiver with strict frame alignment, and manage the transcoding pipeline between the platform native codec and legacy audio consumers. The end result is a deterministic 8kHz mono audio feed with sub-100ms latency that integrates cleanly with on-premises ASR engines, SIP trunks, and speech analytics pipelines.
  • Licensing Tier: CXone Base + Real-Time Analytics or CXone Speech Analytics entitlement. AudioHook requires the Real-Time Media Streaming add-on.
  • User Permissions:
    • Studio > Application > Edit
    • Telephony > AudioHook > Manage
    • Integration > API > Read/Write
    • Telephony > Trunk > View
  • OAuth Scopes: audiohook:read, audiohook:write, media:stream:subscribe, telephony:call:read
  • External Dependencies: WebSocket server capable of handling binary framing, 8kHz mono audio buffer management, and a downstream consumer that expects G.711 μ-law payload structure.
1. Platform-Side AudioHook Configuration & Codec Selection
The platform natively processes media using Opus over WebRTC or SIP. When you request PCMU, the platform performs a real-time transcoding operation at the edge node. You must define the stream in Studio Editor or via the Real-Time API with explicit codec parameters.
Navigate to Studio Editor > Application > AudioHook and create a new stream definition. Set the outputCodec field to PCMU. The platform expects the following configuration structure when submitted via the API:
POST /api/v2/media/audiohook/streams
  "name": "LegacyASR_PCMU_Stream",
  "description": "PCMU output for on-prem speech analytics",
  "outputCodec": "PCMU",
  "sampleRate": 8000,
  "channels": 1,
  "frameDurationMs": 20,
  "routingStrategy": "ALL_PARTICIPANTS",
  "enableEncryption": false,
  "consumerEndpoint": "wss://your-ws-endpoint/audiohook/pcmu"
The Trap: Leaving frameDurationMs at the default value or omitting channels causes the platform to fall back to variable-length framing. Your consumer will receive fragmented byte arrays that do not align to 160-byte boundaries. This breaks μ-law decoding and causes ASR engines to reject the stream with INVALID_AUDIO_FORMAT errors.
Architectural Reasoning: We enforce a fixed 20ms frame duration because PCMU is a constant-bitrate codec at 64 kbps. A 20ms window produces exactly 160 bytes per frame. This deterministic sizing allows the consumer to implement a lock-step playback buffer without dynamic resizing. We push the transcoding cost to the platform edge rather than the consumer because the platform utilizes dedicated DSP threads for G.711 conversion. Offloading this to your WebSocket server introduces unpredictable CPU spikes and breaks your latency SLA.
2. WebSocket Endpoint Architecture & Frame Parsing
AudioHook delivers the transcoded stream over a persistent WebSocket connection. The platform does not send raw RTP packets. It wraps the PCMU payload in a binary WebSocket frame with a minimal JSON header on initial connection. Your endpoint must handle the handshake, maintain the connection, and parse the binary payload with strict byte alignment.
The connection sequence follows this pattern:
  1. Client initiates WebSocket connection to consumerEndpoint
  2. Platform sends a JSON metadata frame containing callId, streamId, and sequenceNumber
  3. Platform begins streaming 160-byte PCMU frames at 50 frames per second
  4. Client acknowledges receipt implicitly by maintaining the connection. Explicit ACKs are not required and will increase CPU overhead.
Production-ready Node.js implementation:
const WebSocket = require('ws');
const { createWriteStream } = require('fs');
const WS_URL = 'wss://your-ws-endpoint/audiohook/pcmu';
const FRAME_SIZE = 160; // 8kHz * 16bit * 1ch * 0.020s
const ws = new WebSocket(WS_URL, {
  headers: {
    'Authorization': 'Bearer ' + process.env.CXONE_ACCESS_TOKEN,
    'X-Stream-Id': process.env.STREAM_ID
let buffer = Buffer.alloc(0);
let frameCount = 0;
const audioOutput = createWriteStream('output_pcmu.raw');
ws.on('open', () => {
  console.log('AudioHook PCMU stream connected');
ws.on('message', (data, isBinary) => {
  if (!isBinary) {
    // Metadata or control frame
    const msg = JSON.parse(data);
    if (msg.type === 'stream-start') {
      console.log('Stream initialized:', msg.callId);
    return;
  // Binary PCMU payload handling
  buffer = Buffer.concat([buffer, data]);
  while (buffer.length >= FRAME_SIZE) {
    const frame = buffer.subarray(0, FRAME_SIZE);
    buffer = buffer.subarray(FRAME_SIZE);
    // Write to downstream consumer or process directly
    audioOutput.write(frame);
    frameCount++;
    // Optional: Log drift if frame delivery deviates from 50Hz
    if (frameCount % 500 === 0) {
      console.log(`Processed ${frameCount} frames. Buffer residual: ${buffer.length} bytes`);
  // Trap mitigation: Discard incomplete frames to prevent decoder corruption
  if (buffer.length > 0 && buffer.length < FRAME_SIZE) {
    console.warn('Incomplete frame detected. Dropping', buffer.length, 'bytes');
ws.on('close', (code, reason) => {
  audioOutput.end();
  console.log('Stream closed:', code, reason.toString());
ws.on('error', (err) => {
  console.error('WebSocket error:', err.message);
The Trap: Treating WebSocket messages as a continuous byte stream without enforcing 160-byte boundaries. Network proxies, load balancers, or the platform itself may split a single 160-byte frame across two WebSocket messages. If you pass the raw data buffer directly to your decoder, you will experience audio clipping, phase inversion, and word insertion errors in ASR output.
Architectural Reasoning: We implement a ring buffer accumulator (Buffer.concat) because WebSocket fragmentation is governed by MTU limits and intermediate proxy configurations. The platform sends frames at 50Hz, but TCP segmentation may deliver partial chunks. By accumulating until we reach exactly 160 bytes, we guarantee μ-law decoder alignment. We discard residual bytes below 160 because partial PCMU frames cannot be meaningfully decoded and will corrupt the audio timeline. This approach trades minimal CPU for deterministic audio integrity.
3. Conversion Pipeline Validation & Latency Budgeting
The transcoding pipeline introduces a fixed overhead between call establishment and first audio byte delivery. You must measure this latency and configure your consumer buffers to absorb jitter without introducing playout delay. The platform queues transcoding tasks per active call. Under concurrent load, queue depth increases, which manifests as initial stream silence or tail latency spikes.
Validate the conversion pipeline using the Real-Time API stream status endpoint:
GET /api/v2/media/audiohook/streams/{streamId}/status
  "streamId": "ah-8f3c2a1b-9d4e-4f1a-b7c8-2e5d6f7a8b9c",
  "status": "STREAMING",
  "codec": "PCMU",
  "transcodingLatencyMs": 42,
  "queueDepth": 3,
  "packetLossRate": 0.001,
  "consumerConnected": true,
  "lastFrameTimestamp": 1715423891234
You must implement a latency budget of 120ms total:
  • Platform transcoding: 30-50ms
  • Network transit: 20-40ms
  • Consumer buffer: 30-50ms
If transcodingLatencyMs exceeds 80ms, the platform is under resource contention. You must scale your consumer processing threads or implement a circuit breaker that pauses downstream ASR ingestion until latency normalizes.
The Trap: Configuring a playout buffer larger than 50ms to compensate for perceived jitter. PCMU streams require tight synchronization with call control events. A 100ms buffer introduces noticeable lag in real-time agent assist features and breaks word-level timestamp alignment in speech analytics. The platform already applies jitter buffering at the edge. Adding consumer-side buffering creates double buffering, which degrades the user experience and invalidates real-time sentiment scoring.
Architectural Reasoning: We maintain a strict 30-50ms consumer buffer because PCMU is designed for low-latency telephony. The platform transcoding queue operates on a FIFO basis with priority scheduling for active streams. By monitoring queueDepth and transcodingLatencyMs, you can detect platform saturation before it impacts audio quality. We implement backpressure at the WebSocket layer rather than the decoder layer because dropping frames early prevents buffer bloat and keeps CPU utilization predictable. This aligns with the platform design principle that media streams must fail fast rather than stall.
Edge Case 1: Sample Rate Mismatch During ASR Ingestion
  • The Failure Condition: The downstream ASR engine returns empty transcripts or reports SAMPLE_RATE_MISMATCH errors. Audio playback sounds pitched down or slowed.
  • The Root Cause: The consumer pipeline expects 16kHz audio. AudioHook PCMU streams are strictly 8kHz mono. Some ASR engines auto-detect sample rate but fail when the stream lacks a WAV header.
  • The Solution: Enforce 8kHz mono configuration in the consumer pipeline. If the ASR engine requires 16kHz, implement a resampling step using a high-quality filter (e.g., libsamplerate) before ingestion. Do not rely on auto-detection. Add a validation step that reads the first 10 frames and verifies byte count matches 8000 * 0.020 * 2 = 320 bytes per second per channel. Log a fatal error if the ratio deviates by more than 2 percent.
Edge Case 2: WebSocket Frame Fragmentation Under Network Congestion
  • The Failure Condition: Intermittent audio stuttering, dropped words, and sudden silence lasting 200-500ms. The stream does not disconnect but delivers corrupted audio.
  • The Root Cause: Intermediate proxies or NAT devices fragment WebSocket frames when payload size exceeds MTU. TCP reassembly delivers chunks out of order. The consumer buffer accumulates misaligned bytes, causing μ-law decoder desynchronization.
  • The Solution: Implement a frame reassembly buffer with a strict timeout of 100ms. If a complete 160-byte frame is not assembled within 100ms, flush the buffer and log a fragmentation event. Enable WebSocket compression (permessage-deflate) only if your network path supports it. Compression adds CPU overhead and can delay frame delivery. Monitor buffer.length over time. A steadily growing buffer indicates a frame alignment bug rather than network congestion.
Edge Case 3: Transcoding Queue Saturation During Campaign Spikes
  • The Failure Condition: Stream drops occur during peak call volume. The API returns 429 Too Many Requests or the WebSocket closes with code 1013. AudioHook status shows STREAMING but no bytes arrive.
  • The Root Cause: The platform transcoding threads are exhausted. PCMU conversion is CPU-intensive. When concurrent streams exceed the edge node capacity, the queue fills and new frames are dropped.
  • The Solution: Implement a circuit breaker that monitors transcodingLatencyMs and queueDepth. If latency exceeds 100ms for three consecutive checks, pause downstream processing and send a control message to reduce stream concurrency. Configure a fallback to Opus codec if your consumer supports it. Opus requires significantly less CPU and maintains quality at lower bitrates. Scale your WebSocket server horizontally to match call volume. Use connection pooling to reuse TCP sockets and reduce handshake overhead.
