Configuring NICE CXone Pure Connect IVR Menu Trees via Pure Connect APIs with Python
- A Python module that programmatically constructs, validates, and deploys IVR menu trees to NICE CXone Pure Connect using atomic PUT operations and automatic build triggers.
- It leverages the Pure Connect Configuration API v2 to manage menu references, option matrices, DTMF mapping, and timeout prompt assignment.
- The tutorial covers Python 3.9+ using
httpxfor async HTTP operations andpydanticfor strict payload validation.
- OAuth 2.0 Client Credentials flow with
configuration:ivr:writeandconfiguration:ivr:readscopes - NICE CXone Pure Connect Configuration API v2
- Python 3.9+ runtime with
asynciosupport - External dependencies:
httpx,pydantic,uuid,datetime,json
NICE CXone uses standard OAuth 2.0 client credentials flow. The token endpoint requires your site-specific base URL. The following class handles token retrieval, caching, and automatic refresh before expiry.
import httpx
from typing import Optional
class CXoneAuthManager:
def __init__(self, base_url: str, client_id: str, client_secret: str):
self.client_id = client_id
self.token_expiry: Optional[float] = None
if self.token and self.token_expiry and time.time() < self.token_expiry - 60:
return self.token
response = await client.post(
f"{self.base_url}/api/v2/oauth/token",
data={"grant_type": "client_credentials"},
auth=(self.client_id, self.client_secret)
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.token_expiry = time.time() + payload["expires_in"]
return self.token
The token is cached in memory and refreshed sixty seconds before expiration to prevent mid-operation authentication failures. All subsequent API calls attach the bearer token in the Authorization header.
Step 1: Initialize HTTP Client and OAuth Handler
The configurator requires a persistent HTTP client to manage connection pooling and retry logic. We initialize httpx.AsyncClient with exponential backoff for rate limiting.
import httpx
from typing import Dict, Any
import asyncio
class IVRMenuConfigurator:
def __init__(self, base_url: str, auth: CXoneAuthManager):
self.auth = auth
self.client = httpx.AsyncClient(
base_url=self.base_url,
timeout=30.0,
limits=httpx.Limits(max_connections=20, max_keepalive_connections=10)
self.request_headers: Dict[str, str] = {}
async def initialize(self) -> None:
token = await self.auth.get_token()
self.request_headers = {
"Accept": "application/json"
async def close(self) -> None:
await self.client.aclose()
The client is initialized once per deployment session. The headers are cached to avoid redundant token fetches during bulk menu updates.
Step 2: Construct IVR Menu Payload with DTMF and Timeout Logic
Pure Connect IVR menus require a structured option matrix. Each option maps a DTMF sequence to a target node and an associated prompt. Timeout logic must define a fallback prompt and a destination node.
from pydantic import BaseModel, Field, validator
import uuid
class IVROption(BaseModel):
dtmf_sequence: str = Field(..., description="DTMF digits pressed by caller")
next_menu_id: str = Field(..., description="Target menu or action ID")
prompt_id: str = Field(..., description="Audio prompt UUID for this option")
class IVRMenuNode(BaseModel):
menu_id: str = Field(default_factory=lambda: str(uuid.uuid4()))
options: List[IVROption]
timeout_prompt_id: str
timeout_next_menu_id: str
max_depth: int = Field(default=0)
@validator("dtmf_sequence")
def validate_dtmf(cls, v: str) -> str:
allowed = set("0123456789*#")
if not v or len(v) > 4:
raise ValueError("DTMF sequence must be 1 to 4 digits")
if not all(c in allowed for c in v):
raise ValueError("DTMF sequence contains invalid characters")
return v
def construct_menu_payload(
options: List[Dict[str, str]],
timeout_prompt_id: str,
) -> IVRMenuNode:
parsed_options = [IVROption(**opt) for opt in options]
return IVRMenuNode(
name=name,
options=parsed_options,
timeout_prompt_id=timeout_prompt_id,
timeout_next_menu_id=timeout_next_menu_id
The payload construction uses pydantic validators to enforce DTMF constraints at the Python layer before network transmission. This prevents 400 Bad Request errors from malformed telephony inputs.
Step 3: Validate Telephony Constraints and Maximum Depth Limits
Pure Connect enforces strict depth limits to prevent stack overflow during runtime compilation. The following validator traverses the menu tree and enforces a maximum depth of twelve levels.
def validate_telephony_constraints(menu_tree: Dict[str, IVRMenuNode], max_depth: int = 12) -> None:
def _check_depth(node_id: str, current_depth: int, visited: set) -> None:
if current_depth > max_depth:
raise ValueError(f"Menu tree exceeds maximum depth of {max_depth}")
if node_id in visited:
return
visited.add(node_id)
node = menu_tree.get(node_id)
if not node:
return
for option in node.options:
_check_depth(option.next_menu_id, current_depth + 1, visited.copy())
_check_depth(node.timeout_next_menu_id, current_depth + 1, visited.copy())
root_id = next(iter(menu_tree.keys()))
_check_depth(root_id, 0, set())
The recursive validator tracks visited nodes to avoid redundant checks. It raises a ValueError immediately when the depth threshold is breached, halting deployment before API submission.
Step 4: Execute Loop Detection and Node Connectivity Pipeline
IVR routing loops cause infinite caller traps and trigger platform-level circuit breakers. We implement a directed graph cycle detection algorithm using depth-first search with color marking.
def detect_loops(menu_tree: Dict[str, IVRMenuNode]) -> bool:
WHITE, GRAY, BLACK = 0, 1, 2
color: Dict[str, int] = {node_id: WHITE for node_id in menu_tree}
def _dfs(node_id: str) -> bool:
color[node_id] = GRAY
node = menu_tree[node_id]
targets = [opt.next_menu_id for opt in node.options] + [node.timeout_next_menu_id]
for target in targets:
if target not in menu_tree:
if color[target] == GRAY:
return True
if color[target] == WHITE and _dfs(target):
return True
color[node_id] = BLACK
return False
for node_id in menu_tree:
if color[node_id] == WHITE:
if _dfs(node_id):
return True
return False
The pipeline returns True if a cycle exists. Deployment proceeds only when the function returns False. This guarantees navigable caller flow before atomic configuration.
Step 5: Perform Atomic PUT and Trigger IVR Compilation
Configuration updates must be atomic to prevent partial deployments. We use a single PUT request to replace the menu tree, then trigger the compilation endpoint. The code includes explicit 429 retry logic.
import asyncio
async def deploy_menu(
self,
menu_id: str,
payload: IVRMenuNode,
max_retries: int = 3
) -> Dict[str, Any]:
url = f"/api/v2/configuration/ivr/menus/{menu_id}"
json_body = payload.dict()
response = await self.client.put(url, headers=self.request_headers, json=json_body)
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
return response.json()
raise httpx.HTTPStatusError("Rate limit exceeded after retries", request=response.request, response=response)
async def trigger_ivr_build(self, build_id: str) -> Dict[str, Any]:
url = "/api/v2/configuration/ivr/build"
payload = {"build_id": build_id, "trigger": "api_config_update"}
response = await self.client.post(url, headers=self.request_headers, json=payload)
HTTP Request/Response Cycle (PUT Menu):
PUT /api/v2/configuration/ivr/menus/{menu_id} HTTP/1.1
Host: {your-site}.cxone.com
Authorization: Bearer {access_token}
"menu_id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"name": "Main_Customer_Services",
"options": [
{"dtmf_sequence": "1", "next_menu_id": "sales_menu_id", "prompt_id": "prompt_sales_id"},
{"dtmf_sequence": "2", "next_menu_id": "support_menu_id", "prompt_id": "prompt_support_id"}
"timeout_prompt_id": "prompt_timeout_id",
"timeout_next_menu_id": "operator_transfer_id",
"max_depth": 3
HTTP Response:
"status": "success",
"version": 4,
"updated_at": "2024-06-15T14:32:10Z"
The build trigger compiles the IVR runtime bytecode. The platform returns a build status endpoint that you can poll until state equals COMPILED.
Step 6: Webhook Synchronization, Latency Tracking and Audit Logging
External IVR designers require real-time synchronization. We dispatch configuration events to a webhook endpoint, track deployment latency, and generate immutable audit logs.
import json
import logging
logger = logging.getLogger("cxone_ivr_config")
async def sync_and_log(
self,
menu_id: str,
start_time: float,
build_result: Dict[str, Any],
webhook_url: str
) -> None:
audit_entry = {
"menu_id": menu_id,
"action": "IVR_MENU_DEPLOYED",
"build_status": build_result.get("state"),
"build_id": build_result.get("build_id")
logger.info(json.dumps(audit_entry))
webhook_url,
json=audit_entry,
headers={"Content-Type": "application/json"},
timeout=5.0
except httpx.HTTPError as e:
logger.warning(f"Webhook sync failed: {e}")
The audit log captures governance metadata required for telephony compliance reviews. Latency tracking identifies deployment bottlenecks during high-scale configuration iterations.
import asyncio
import httpx
import json
import logging
from typing import Dict, List, Optional
# Import classes defined in previous steps
# CXoneAuthManager, IVRMenuConfigurator, construct_menu_payload, validate_telephony_constraints, detect_loops
async def main() -> None:
base_url = "https://acme-site.cxone.com"
auth = CXoneAuthManager(
base_url=base_url,
client_id="your_client_id",
client_secret="your_client_secret"
configurator = IVRMenuConfigurator(base_url=base_url, auth=auth)
await configurator.initialize()
menu_tree: Dict[str, Any] = {}
options_payload = [
{"dtmf_sequence": "1", "next_menu_id": "menu_sales", "prompt_id": "prompt_opt1"},
{"dtmf_sequence": "2", "next_menu_id": "menu_support", "prompt_id": "prompt_opt2"},
{"dtmf_sequence": "0", "next_menu_id": "menu_operator", "prompt_id": "prompt_opt0"}
root_menu = construct_menu_payload(
name="Root_Menu",
options=options_payload,
timeout_prompt_id="prompt_timeout",
timeout_next_menu_id="menu_operator"
menu_tree[root_menu.menu_id] = root_menu
# Validation Pipeline
validate_telephony_constraints(menu_tree, max_depth=12)
except ValueError as e:
logger.error(f"Constraint validation failed: {e}")
return
if detect_loops(menu_tree):
logger.error("Loop detected in IVR routing. Deployment aborted.")
return
# Deployment
start_time = time.time()
deploy_result = await configurator.deploy_menu(root_menu.menu_id, root_menu)
logger.info(f"Menu deployed: {deploy_result}")
build_result = await configurator.trigger_ivr_build("build_" + root_menu.menu_id)
logger.info(f"Build triggered: {build_result}")
await configurator.sync_and_log(
root_menu.menu_id,
start_time,
build_result,
webhook_url="https://designer-sync.acme.com/webhooks/cxone-ivr"
logger.error(f"API deployment failed: {e.response.status_code} - {e.response.text}")
finally:
await configurator.close()
asyncio.run(main())
The script runs synchronously from initialization to cleanup. Replace the placeholder credentials and webhook URL with your environment values. The module handles token caching, constraint validation, loop detection, atomic deployment, and audit logging in a single execution flow.
Common Errors and Debugging
Error: 400 Bad Request
- What causes it: Invalid DTMF sequences, missing required fields, or malformed JSON structure.
- How to fix it: Verify the payload against the
IVRMenuNodeschema. Ensure DTMF sequences contain only0-9,*, or#and do not exceed four characters. Check that allprompt_idandnext_menu_idreferences exist in your CXone media and routing repository. - Code showing the fix: The
pydanticvalidator in Step 2 catches DTMF violations before network transmission. Addprint(payload.dict())before the PUT call to inspect the exact JSON sent.
Error: 409 Conflict
- What causes it: Concurrent modification of the same menu resource. Pure Connect uses optimistic locking via version numbers.
- How to fix it: Implement version checking. Fetch the current menu version with a GET request, increment it, and include it in the PUT header or payload if your site version supports it. Alternatively, serialize deployments to avoid parallel writes to the same resource.
- What causes it: Exceeding CXone API rate limits during bulk configuration or rapid iteration.
- How to fix it: The
deploy_menumethod includes exponential backoff retry logic. Monitor theRetry-Afterheader. Space out concurrent PUT requests usingasyncio.Semaphoreif deploying multiple menus simultaneously.
- What causes it: Platform-side compilation failure, usually triggered by invalid prompt references or unsupported telephony actions.
- How to fix it: Review the build response payload for error details. Verify that all referenced prompts are published and accessible to the IVR runtime. Check platform status dashboards for maintenance windows.
