Configuring NICE Cognigy Entity Extraction Throttling with Python
  • A Python pipeline that constructs throttling payloads for NICE Cognigy entity extraction, validates them against compute constraints, and submits them via atomic HTTP POST operations.
  • The pipeline uses the NICE Cognigy REST API surface (/api/v2/nlu/extraction/throttle) with direct httpx client control for precise retry, defer, and queue management.
  • The implementation is written in Python 3.10+ using httpx, asyncio, and structured logging.
  • OAuth 2.0 client credentials with scopes: nlu:manage, nlu:read, platform:admin
  • Cognigy API version: v2
  • Python runtime: 3.10 or higher
  • External dependencies: httpx>=0.25.0, pydantic>=2.0.0, asyncio (standard library)
Cognigy uses standard OAuth 2.0 client credentials flow. The following code retrieves an access token, caches it, and handles refresh logic.
import asyncio
import httpx
from typing import Optional
import logging
logger = logging.getLogger("cognigy_throttle")
@dataclass
class OAuthConfig:
    tenant: str
    client_id: str
    client_secret: str
    token_url: str = "https://auth.cognigy.com/oauth/token"
@dataclass
class TokenCache:
    access_token: Optional[str] = None
    expires_at: float = 0.0
    refresh_in: int = 30  # seconds before expiry to refresh
async def fetch_oauth_token(cfg: OAuthConfig) -> str:
        resp = await client.post(
            cfg.token_url,
            data={
                "client_id": cfg.client_id,
                "client_secret": cfg.client_secret,
                "scope": "nlu:manage nlu:read platform:admin"
            headers={"Content-Type": "application/x-www-form-urlencoded"}
        resp.raise_for_status()
        payload = resp.json()
        return payload["access_token"]
async def get_cached_token(cfg: OAuthConfig, cache: TokenCache) -> str:
    if cache.access_token and time.time() < (cache.expires_at - cache.refresh_in):
        return cache.access_token
    token = await fetch_oauth_token(cfg)
    cache.access_token = token
    cache.expires_at = time.time() + 3500  # Cognigy tokens typically last 3600s
    logger.info("OAuth token refreshed successfully.")
    return token
Step 1: Construct Throttling Payloads and Validate Against Compute Constraints
The Cognigy NLU extraction throttle endpoint expects a structured JSON payload containing extractRef, limitMatrix, and queueDirective. You must validate these fields against your deployment compute constraints before submission.
from typing import Dict, List
import json
@dataclass
class LimitMatrix:
    max_concurrent_extractions: int
    memory_allocation_mb: int
    model_load_threshold: float
@dataclass
class QueueDirective:
    strategy: str  # "FIFO", "PRIORITY", "WEIGHTED"
    max_queue_depth: int
    defer_on_exhaustion: bool
@dataclass
class ThrottlePayload:
    extractRef: str
    limitMatrix: LimitMatrix
    queueDirective: QueueDirective
def validate_throttle_schema(payload: ThrottlePayload) -> None:
    if payload.limitMatrix.max_concurrent_extractions < 1:
        raise ValueError("max_concurrent_extractions must be >= 1")
    if payload.limitMatrix.memory_allocation_mb > 8192:
        raise ValueError("memory_allocation_mb exceeds platform compute constraint")
    if not (0.0 < payload.limitMatrix.model_load_threshold <= 1.0):
        raise ValueError("model_load_threshold must be between 0.0 and 1.0")
    if payload.queueDirective.strategy not in ("FIFO", "PRIORITY", "WEIGHTED"):
        raise ValueError("Invalid queue strategy")
def serialize_payload(payload: ThrottlePayload) -> str:
    return json.dumps({
        "extractRef": payload.extractRef,
        "limitMatrix": {
            "maxConcurrentExtractions": payload.limitMatrix.max_concurrent_extractions,
            "memoryAllocationMB": payload.limitMatrix.memory_allocation_mb,
            "modelLoadThreshold": payload.limitMatrix.model_load_threshold
        "queueDirective": {
            "strategy": payload.queueDirective.strategy,
            "maxQueueDepth": payload.queueDirective.max_queue_depth,
            "deferOnExhaustion": payload.queueDirective.defer_on_exhaustion
    }, indent=2)
Step 2: Execute Atomic HTTP POST Operations with Defer Triggers
Atomic submission requires strict timeout control and automatic defer handling when Cognigy returns 429 Too Many Requests or 202 Accepted. The following function implements exponential backoff and defer trigger parsing.
import math
async def submit_throttle_configuration(
    client: httpx.AsyncClient,
    tenant: str,
    payload: ThrottlePayload,
    max_retries: int = 5
) -> dict:
    endpoint = f"https://{tenant}.cognigy.com/api/v2/nlu/extraction/throttle"
    headers = {
        "Authorization": f"Bearer {client.headers.get('Authorization', '').replace('Bearer ', '')}",
        "Accept": "application/json"
    body = serialize_payload(payload)
            resp = await client.post(endpoint, headers=headers, content=body, timeout=15.0)
            if resp.status_code == 200:
                logger.info("Throttle configuration applied successfully.")
                return resp.json()
            if resp.status_code == 202:
                logger.info("Configuration deferred. Awaiting platform processing.")
                return {"status": "deferred", "message": "Processing queued"}
            if resp.status_code == 429:
                retry_after = int(resp.headers.get("Retry-After", 2 ** attempt))
                logger.warning(f"Rate limited. Deferring for {retry_after}s.")
            if attempt == max_retries - 1:
                raise RuntimeError(f"Failed to submit throttle config after {max_retries} attempts: {e}") from e
            await asyncio.sleep(2 ** attempt)
            logger.error(f"Network error during submission: {e}")
            raise
    raise RuntimeError("Submission exhausted all retry attempts without resolution.")
Step 3: Implement Queue Validation and Resource Exhaustion Pipelines
Before and after submission, you must verify queue health. This step checks resource exhaustion flags and timeout breach conditions to prevent dialog latency spikes during CXone scaling events.
@dataclass
class QueueHealthStatus:
    resource_exhausted: bool
    timeout_breach_detected: bool
    active_queue_depth: int
    estimated_latency_ms: float
async def validate_queue_health(client: httpx.AsyncClient, tenant: str) -> QueueHealthStatus:
    endpoint = f"https://{tenant}.cognigy.com/api/v2/nlu/queues/status"
    headers = {"Authorization": client.headers.get("Authorization", "")}
        resp = await client.get(endpoint, headers=headers, timeout=5.0)
        data = resp.json()
        return QueueHealthStatus(
            resource_exhausted=data.get("resourceExhausted", False),
            timeout_breach_detected=data.get("timeoutBreachDetected", False),
            active_queue_depth=data.get("activeQueueDepth", 0),
            estimated_latency_ms=data.get("estimatedLatencyMs", 0.0)
    except httpx.HTTPError as e:
        logger.error(f"Queue health check failed: {e}")
        raise RuntimeError("Queue validation pipeline interrupted") from e
async def enforce_queue_safety(health: QueueHealthStatus) -> bool:
    if health.resource_exhausted:
        logger.warning("Resource exhaustion detected. Throttling pipeline paused.")
        return False
    if health.timeout_breach_detected:
        logger.warning("Timeout breach detected. Deferring extraction requests.")
        return False
    if health.active_queue_depth > 1000:
        logger.warning("Queue depth exceeds safe threshold. Reducing ingestion rate.")
        return False
    return True
Step 4: Synchronize Throttling Events via Extract Deferred Webhooks
When Cognigy defers extraction processing, you must notify an external ML orchestrator. The following function posts structured defer events to a configurable webhook endpoint.
@dataclass
class DeferredEvent:
    extractRef: str
    deferred_at: float
    reason: str
    queue_depth: int
    retry_scheduled_at: float
async def sync_deferred_event(client: httpx.AsyncClient, webhook_url: str, event: DeferredEvent) -> None:
    payload = {
        "eventType": "EXTRACT_DEFERRED",
        "timestamp": event.deferred_at,
        "extractRef": event.extractRef,
        "reason": event.reason,
        "queueDepth": event.queue_depth,
        "retryScheduledAt": event.retry_scheduled_at
            webhook_url,
            json=payload,
            headers={"Content-Type": "application/json", "X-Source": "cognigy-throttle-pipeline"},
            timeout=5.0
        if resp.status_code >= 400:
            logger.error(f"Webhook sync failed with status {resp.status_code}: {resp.text}")
        else:
            logger.info("Deferred event synchronized with external ML orchestrator.")
        logger.error(f"Webhook delivery failed: {e}")
Step 5: Track Latency, Success Rates, and Generate Audit Logs
Governance requires persistent tracking of throttle efficiency. This module maintains rolling metrics and writes structured audit records.
from collections import deque
import json
import os
@dataclass
class ThrottleMetrics:
    latencies: deque = field(default_factory=lambda: deque(maxlen=100))
    successes: int = 0
    failures: int = 0
    deferred: int = 0
def record_attempt(metrics: ThrottleMetrics, latency: float, status: str) -> None:
    metrics.latencies.append(latency)
    if status == "success":
        metrics.successes += 1
    elif status == "deferred":
        metrics.deferred += 1
    else:
        metrics.failures += 1
def calculate_efficiency(metrics: ThrottleMetrics) -> dict:
    total = metrics.successes + metrics.failures + metrics.deferred
    if total == 0:
        return {"success_rate": 0.0, "defer_rate": 0.0, "avg_latency_ms": 0.0}
    avg_lat = sum(metrics.latencies) / len(metrics.latencies) if metrics.latencies else 0.0
        "success_rate": metrics.successes / total,
        "defer_rate": metrics.deferred / total,
        "avg_latency_ms": avg_lat,
        "total_processed": total
def write_audit_log(log_dir: str, entry: dict) -> None:
    os.makedirs(log_dir, exist_ok=True)
    timestamp = int(time.time() * 1000)
    log_file = os.path.join(log_dir, f"nlu_throttle_audit_{timestamp}.json")
    with open(log_file, "w") as f:
        json.dump({
            "auditTimestamp": timestamp,
            "event": entry,
            "schema": "v1"
        }, f, indent=2)
    logger.info(f"Audit log written: {log_file}")
The following script integrates all components into a production-ready throttle manager. Replace the placeholder credentials before execution.
import asyncio
import httpx
import logging
import sys
async def main():
    # Configuration
    cfg = OAuthConfig(
        tenant="your-tenant-name",
        client_id="your_client_id",
        client_secret="your_client_secret"
    cache = TokenCache()
    metrics = ThrottleMetrics()
    webhook_url = "https://your-ml-orchestrator.internal/webhooks/cognigy-defer"
    log_dir = "./audit_logs"
    # Construct throttling payload
    payload = ThrottlePayload(
        extractRef="entity-extraction-v2-prod",
        limitMatrix=LimitMatrix(
            max_concurrent_extractions=25,
            memory_allocation_mb=4096,
            model_load_threshold=0.75
        queueDirective=QueueDirective(
            strategy="WEIGHTED",
            max_queue_depth=500,
            defer_on_exhaustion=True
    # Validate schema
        validate_throttle_schema(payload)
        logger.info("Payload schema validated against compute constraints.")
    except ValueError as e:
        logger.error(f"Schema validation failed: {e}")
        sys.exit(1)
    # Initialize HTTP client with OAuth token
    token = await get_cached_token(cfg, cache)
        headers={"Authorization": f"Bearer {token}"},
        timeout=httpx.Timeout(30.0)
    ) as client:
        # Step 1: Queue validation
        logger.info("Executing queue validation pipeline...")
        health = await validate_queue_health(client, cfg.tenant)
        if not await enforce_queue_safety(health):
            logger.error("Queue safety check failed. Aborting throttle submission.")
            sys.exit(1)
        # Step 2: Atomic submission with defer handling
        start_time = time.time()
            result = await submit_throttle_configuration(client, cfg.tenant, payload)
            latency = (time.time() - start_time) * 1000
            status = "success" if result.get("status") == "applied" else "deferred"
            record_attempt(metrics, latency, status)
            # Step 3: Webhook sync on defer
                event = DeferredEvent(
                    extractRef=payload.extractRef,
                    deferred_at=time.time(),
                    reason="Platform queue saturation",
                    queue_depth=health.active_queue_depth,
                    retry_scheduled_at=time.time() + 60
                await sync_deferred_event(client, webhook_url, event)
                logger.info("Deferred event synchronized.")
            # Step 4: Audit logging
            efficiency = calculate_efficiency(metrics)
            audit_entry = {
                "action": "throttle_configuration_submitted",
                "payload_ref": payload.extractRef,
                "latency_ms": latency,
                "status": status,
                "metrics": efficiency
            write_audit_log(log_dir, audit_entry)
            logger.info(f"Pipeline complete. Latency: {latency:.2f}ms | Status: {status}")
            logger.info(f"Efficiency metrics: {efficiency}")
            logger.error(f"Pipeline execution failed: {e}")
            record_attempt(metrics, (time.time() - start_time) * 1000, "failed")
            raise
    asyncio.run(main())
  • What causes it: Expired or missing OAuth token, incorrect client credentials, or missing nlu:manage scope.
  • How to fix it: Verify the client_id and client_secret match your Cognigy tenant. Ensure the token request includes nlu:manage in the scope parameter. Implement the TokenCache refresh logic to automatically rotate tokens before expiry.
  • Code showing the fix: The get_cached_token function checks expires_at - refresh_in and triggers fetch_oauth_token when the window approaches.
  • What causes it: Cognigy rate limiting due to concurrent extraction spikes or exceeding platform throttle caps.
  • How to fix it: The submit_throttle_configuration function parses the Retry-After header and implements exponential backoff. Adjust max_concurrent_extractions in your limitMatrix to align with your subscription tier.
  • Code showing the fix: The retry loop checks resp.status_code == 429, extracts Retry-After, and sleeps before the next attempt.
Error: 400 Bad Request (Schema Validation Failure)
  • What causes it: Payload fields violate Cognigy compute constraints or JSON structure mismatches.
  • How to fix it: Run validate_throttle_schema before submission. Ensure memory_allocation_mb does not exceed 8192 and model_load_threshold stays within (0.0, 1.0].
  • Code showing the fix: The validate_throttle_schema function raises ValueError with explicit constraint boundaries before the HTTP request is formed.
Error: Queue Resource Exhaustion Detected
  • What causes it: The NLU processing pipeline is saturated, and new extraction requests would cause dialog latency spikes.
  • How to fix it: The enforce_queue_safety function returns False when resource_exhausted or timeout_breach_detected is true. Halt submission until the queue depth drops below max_queue_depth.
  • Code showing the fix: The pipeline checks health.resource_exhausted and exits gracefully, preventing cascade failures during CXone scaling events.
