Configuring mTLS Authentication for Secure Genesys Cloud API Communication from On-Premise Java Applications Using PKCS12 Keystore Management
A Java application that authenticates to Genesys Cloud using mutual TLS with a PKCS12 keystore, obtains an OAuth 2.0 access token, and retrieves the authenticated user profile. This tutorial uses the Genesys Cloud Java SDK and Apache HttpClient. The implementation covers Java 17.
- Genesys Cloud OAuth client configured for Client Credentials Grant with client certificate authentication enabled in Admin > Security > OAuth Clients
- Required OAuth scope:
view:users - Genesys Cloud Java SDK version 12.0.0 or later
- Java Development Kit 17 or later
- Maven dependencies:
<dependency> <groupId>com.genesiscloud</groupId> <artifactId>genesyscloud-java-sdk</artifactId> <version>12.0.0</version> </dependency> <dependency> <groupId>org.apache.httpcomponents</groupId> <artifactId>httpclient</artifactId> <version>4.5.14</version> </dependency>
Genesys Cloud validates the client certificate during the TLS handshake before processing any OAuth or API request. You must upload the public certificate to the Genesys Cloud platform and associate it with an OAuth client. The Java application loads the corresponding PKCS12 file, which contains the private key and certificate chain. The application constructs an SSLContext and attaches it to the underlying HTTP client. When the application requests a token from https://api.mypurecloud.com/oauth/token, the TLS handshake presents the client certificate. Genesys Cloud verifies the certificate against the registered OAuth client and issues an access token if the handshake succeeds and the client credentials are valid.
Step 1: Load PKCS12 Keystore and Initialize SSLContext
The PKCS12 format stores the private key and certificate chain in a single encrypted file. Java requires explicit loading of the keystore and initialization of the KeyManagerFactory to expose the credentials to the TLS stack.
import java.io.FileInputStream;
import java.io.InputStream;
import java.security.KeyStore;
import java.security.SecureRandom;
import javax.net.ssl.KeyManagerFactory;
import javax.net.ssl.SSLContext;
import javax.net.ssl.TrustManagerFactory;
public class MtlsConfig {
private static final String PKCS12_TYPE = "PKCS12";
private static final String KEY_MANAGER_ALGORITHM = KeyManagerFactory.getDefaultAlgorithm();
private static final String TRUST_MANAGER_ALGORITHM = TrustManagerFactory.getDefaultAlgorithm();
public static SSLContext buildSslContext(String keystorePath, char[] keystorePassword) throws Exception {
KeyStore keyStore = KeyStore.getInstance(PKCS12_TYPE);
try (InputStream keystoreStream = new FileInputStream(keystorePath)) {
keyStore.load(keystoreStream, keystorePassword);
KeyManagerFactory kmf = KeyManagerFactory.getInstance(KEY_MANAGER_ALGORITHM);
kmf.init(keyStore, keystorePassword);
// Use the system default trust manager to validate Genesys Cloud server certificates
TrustManagerFactory tmf = TrustManagerFactory.getInstance(TRUST_MANAGER_ALGORITHM);
tmf.init((KeyStore) null);
SSLContext sslContext = SSLContext.getInstance("TLSv1.3");
sslContext.init(kmf.getKeyManagers(), tmf.getTrustManagers(), new SecureRandom());
return sslContext;
Error Handling: If the keystore password is incorrect, kmf.init() throws UnrecoverableKeyException. If the file is corrupted, keyStore.load() throws java.io.IOException or java.security.cert.CertificateException. Always wrap these in a custom runtime exception or handle them explicitly before proceeding to HTTP client configuration.
Step 2: Configure Apache HttpClient with Mutual TLS
The Genesys Cloud Java SDK delegates HTTP transport to Apache HttpClient. You must inject a custom SSLConnectionSocketFactory that uses the SSLContext from Step 1. This ensures every outbound request presents the client certificate during the handshake.
import org.apache.http.conn.ssl.SSLConnectionSocketFactory;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
import org.apache.http.client.config.RequestConfig;
public class MtlsHttpClient {
public static CloseableHttpClient buildClient(SSLContext sslContext) {
SSLConnectionSocketFactory socketFactory = new SSLConnectionSocketFactory(
sslContext,
new String[]{"TLSv1.3", "TLSv1.2"},
null,
SSLConnectionSocketFactory.getDefaultHostnameVerifier()
RequestConfig requestConfig = RequestConfig.custom()
.setConnectTimeout(5000)
.setSocketTimeout(10000)
.setValidateAfterInactivity(3000)
.build();
return HttpClients.custom()
.setSSLSocketFactory(socketFactory)
.setDefaultRequestConfig(requestConfig)
.disableAutomaticRetries() // We handle 429 retries manually
.build();
Raw HTTP Cycle Reference:
When the SDK requests a token, the underlying HTTP request looks like this:
POST /oauth/token HTTP/1.1
Host: api.mypurecloud.com
Authorization: Basic <base64(client_id:client_secret)>
User-Agent: GenesysCloud-Java-SDK/12.0.0
grant_type=client_credentials&scope=view:users
The TLS handshake occurs before this payload is transmitted. If mTLS succeeds, Genesys Cloud responds:
HTTP/1.1 200 OK
Cache-Control: no-store
"token_type": "Bearer",
"expires_in": 1800,
"scope": "view:users"
Step 3: Attach mTLS Client to Genesys Cloud SDK and Fetch Token
The ApiClient class accepts the custom HTTP client. You configure the ClientCredentialsProvider to handle token acquisition and refresh. The provider automatically attaches the Authorization header and retries token requests if the access token expires.
import com.genesiscloud.sdk.ApiClient;
import com.genesiscloud.sdk.auth.ClientCredentialsProvider;
public class GenesysMtlsClient {
private static final String BASE_URL = "https://api.mypurecloud.com";
public static ApiClient initializeApiClient(CloseableHttpClient httpClient,
String clientId,
String clientSecret) {
ApiClient apiClient = new ApiClient(BASE_URL);
apiClient.setHttpClient(httpClient);
ClientCredentialsProvider authProvider = new ClientCredentialsProvider(
clientId, clientSecret, BASE_URL);
authProvider.setScopes(new String[]{"view:users"});
apiClient.setAuthenticator(authProvider);
return apiClient;
Non-Obvious Parameter Note: The setScopes() call is mandatory. Even though the OAuth client has default scopes in the Genesys Cloud console, the SDK requires explicit scope declaration to prevent silent permission escalation. If you omit this, the SDK falls back to an empty scope string, which triggers a 403 Forbidden on protected endpoints.
Step 4: Execute API Call with 429 Retry Logic
Genesys Cloud enforces strict rate limits. On-premise applications must implement exponential backoff for 429 Too Many Requests responses. The SDK throws ApiException for all HTTP errors. You must inspect the status code and implement retry logic before failing the operation.
import com.genesiscloud.sdk.ApiException;
import com.genesiscloud.sdk.api.UsersApi;
import com.genesiscloud.sdk.model.UserResponse;
public class UserFetcher {
private static final int MAX_RETRIES = 3;
private static final long INITIAL_BACKOFF_MS = 1000;
public static UserResponse fetchAuthenticatedUser(ApiClient apiClient) throws Exception {
UsersApi usersApi = new UsersApi(apiClient);
UserResponse user = null;
long backoff = INITIAL_BACKOFF_MS;
for (int attempt = 0; attempt <= MAX_RETRIES; attempt++) {
user = usersApi.getUsersMe();
return user;
} catch (ApiException e) {
if (e.getCode() == 429 && attempt < MAX_RETRIES) {
System.out.println("Rate limited. Retrying in " + backoff + "ms...");
Thread.sleep(backoff);
backoff *= 2; // Exponential backoff
} else {
throw e; // Re-throw non-retryable or max-retry errors
return user;
GET /api/v2/users/me HTTP/1.1
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
Realistic Response:
HTTP/1.1 200 OK
"name": "On-Prem Service Account",
"email": "svc.onprem@company.com",
"division": {
"id": "global",
"name": "Default"
"routing_email": {
"address": "svc.onprem@company.com"
"presence_id": "available",
"self_uri": "https://api.mypurecloud.com/api/v2/users/a1b2c3d4-e5f6-7890-abcd-ef1234567890"
The following class combines all components into a single executable application. Replace the placeholder credentials and keystore path with your environment values.
public class MtlsGenesysClient {
String keystorePath = "/opt/secrets/genesys-client.p12";
char[] keystorePassword = "your-keystore-password".toCharArray();
String clientId = "your-oauth-client-id";
String clientSecret = "your-oauth-client-secret";
SSLContext sslContext = buildSslContext(keystorePath, keystorePassword);
CloseableHttpClient httpClient = buildMtlsHttpClient(sslContext);
ApiClient apiClient = initializeApiClient(httpClient, clientId, clientSecret);
UserResponse user = fetchAuthenticatedUser(apiClient);
System.out.println("Authenticated User: " + user.getName());
System.out.println("User ID: " + user.getId());
System.out.println("Division: " + user.getDivision().getName());
} catch (Exception e) {
System.err.println("mTLS Genesys Cloud integration failed: " + e.getMessage());
e.printStackTrace();
private static SSLContext buildSslContext(String keystorePath, char[] keystorePassword) throws Exception {
try (InputStream is = new FileInputStream(keystorePath)) {
keyStore.load(is, keystorePassword);
KeyManagerFactory kmf = KeyManagerFactory.getInstance(KeyManagerFactory.getDefaultAlgorithm());
TrustManagerFactory tmf = TrustManagerFactory.getInstance(TrustManagerFactory.getDefaultAlgorithm());
return sslContext;
private static CloseableHttpClient buildMtlsHttpClient(SSLContext sslContext) {
sslContext,
null,
.build();
.build();
private static ApiClient initializeApiClient(CloseableHttpClient httpClient,
String clientId,
return apiClient;
private static UserResponse fetchAuthenticatedUser(ApiClient apiClient) throws Exception {
return user;
backoff *= 2;
} else {
throw e;
return user;
Error: javax.net.ssl.SSLHandshakeException: PKIX path building failed
Cause: The Java runtime does not trust the Genesys Cloud server certificate, or the PKCS12 keystore contains an incomplete certificate chain.
Fix: Verify that the .p12 file includes the intermediate CA certificates. Use OpenSSL to inspect the chain: openssl pkcs12 -in genesys-client.p12 -nokeys -info. If the chain is truncated, export the full chain from your certificate authority and import it into the PKCS12 file before deployment.
Error: 401 Unauthorized: invalid_client
Cause: The client certificate presented during the TLS handshake does not match the certificate registered in the Genesys Cloud OAuth client configuration, or the client_id/client_secret pair is incorrect.
Fix: Navigate to Admin > Security > OAuth Clients in Genesys Cloud. Verify that the certificate fingerprint matches the one in your keystore. Confirm that the OAuth client is active and that certificate authentication is enabled. Ensure the clientId and clientSecret passed to ClientCredentialsProvider exactly match the console values.
Error: 403 Forbidden: insufficient_scope
Cause: The OAuth token was issued without the required view:users scope, or the scope was not explicitly set on the ClientCredentialsProvider.
Fix: Ensure authProvider.setScopes(new String[]{"view:users"}) is called before apiClient.setAuthenticator(). The SDK does not inherit default scopes from the console. You must declare scopes at runtime.
Cause: The application exceeded the Genesys Cloud API rate limit for the tenant or OAuth client.
Fix: Implement exponential backoff as shown in Step 4. Genesys Cloud returns a Retry-After header in the response. You can parse it from e.getResponseHeaders() for precise wait times. Increase the INITIAL_BACKOFF_MS value if your on-premise application batches requests.
Error: java.security.UnrecoverableKeyException: Password verification failed
Cause: The keystore password provided to keyStore.load() or kmf.init() is incorrect.
Fix: Verify the password against the certificate authority documentation. Ensure that environment variables or secret managers are not stripping special characters or adding trailing whitespace before passing the password to the keystore loader.
