Configuring High-Availability SIP Trunk Failover in Genesys Cloud With Multi-Homed Gateways and DNS Health Monitoring
This guide details the exact configuration steps to architect a fault-tolerant SIP trunk topology in Genesys Cloud using multiple carrier gateways, DNS SRV-based endpoint resolution, and SIP OPTIONS health monitoring. The end result is a production-grade telephony edge that automatically routes inbound and outbound voice traffic around carrier outages, DNS shifts, or edge node failures without call dropping, signaling storms, or manual intervention.
  • Licensing: Genesys Cloud CX 2 or CX 3 license (SIP Trunk configuration requires at least CX 2 for full telephony edge capabilities)
  • Permissions: Telephony > Trunks > Edit, Telephony > Trunk Groups > Edit, Telephony > SIP Proxy > Edit, Telephony > Dial Rules > Edit
  • OAuth Scopes: telephony:trunk:write, telephony:trunkgroup:write, telephony:dialrule:write
  • External Dependencies:
    • Carrier gateways compliant with RFC 3261 (SIP) and RFC 2782 (DNS SRV)
    • DNS provider supporting SRV records with programmable TTL values
    • NTP synchronization across all carrier edge nodes and Genesys Cloud SIP proxies
    • Network path allowing UDP/TCP 5060/5061 and RTP port ranges 10000-20000
1. DNS SRV Architecture and Genesys Cloud SIP Proxy Integration
Genesys Cloud resolves carrier endpoints through its SIP Proxy layer before establishing signaling paths. Static IP configuration creates rigid dependencies that break when carriers perform maintenance, upgrade edge hardware, or shift traffic between points of presence. DNS SRV records decouple logical trunk identity from physical IP addresses, allowing the carrier to rotate endpoints without Genesys Cloud configuration changes.
Configure your carrier to publish SRV records following the standard _sip._udp.<domain> or _sip._tcp.<domain> format. Genesys Cloud performs DNS resolution at trunk initialization and caches results based on the TTL value. You must set TTL values between 60 and 300 seconds. Lower values accelerate failover but increase DNS query volume against your authoritative nameservers. Higher values reduce resolver load but delay traffic redirection during actual outages.
In Genesys Cloud, navigate to Admin > Telephony > Trunks and create a new SIP trunk. Under the Endpoints section, enter the FQDN matching your carrier SRV record rather than raw IP addresses. Enable Use DNS for endpoint resolution and set the DNS Refresh Interval to 120 seconds. This interval dictates how frequently Genesys Cloud re-resolves the FQDN independent of health check states.
The Trap: Configuring DNS refresh intervals that do not align with carrier TTL values creates resolution desynchronization. If your DNS provider publishes a 60-second TTL but Genesys Cloud refreshes every 300 seconds, the platform will continue routing to a decommissioned IP for up to four minutes after the carrier removes it. This causes 408 Request Timeout errors during peak volume. Align the DNS Refresh Interval to exactly 1.5 times the published TTL to guarantee fresh resolution before cache expiration.
Architectural Reasoning: We use FQDN resolution instead of static IP lists because carrier networks operate in active-active or active-standby topologies that change without notice. DNS provides the control plane abstraction that Genesys Cloud consumes. The SIP Proxy layer validates SRV priority and weight values, automatically distributing traffic according to RFC 2782 specifications before health checks even engage. This eliminates manual trunk reconfiguration during carrier maintenance windows.
2. Multi-Home Trunk Group Configuration and Routing Policy
Single trunks represent single points of failure regardless of how many endpoints you attach to them. Genesys Cloud evaluates health at the trunk level, not the individual endpoint level. To achieve true high availability, you must distribute traffic across multiple trunks aggregated into a Trunk Group with explicit failover or load distribution policies.
Create separate SIP trunks for each carrier point of presence or logical gateway cluster. Assign each trunk a distinct name following the pattern TRK-{Carrier}-{POP}-{Role}. Configure identical dial rules and codec preferences across all trunks to prevent routing asymmetry. Navigate to Admin > Telephony > Trunk Groups and create a new group. Add your trunks in priority order if using failover, or equal weight if using round-robin distribution.
For production environments requiring automatic failover with capacity-aware routing, select Failover as the distribution method. Set Minimum Concurrent Calls to 0 and Maximum Concurrent Calls to your carrier contract limit. Enable Allow Overflow to Next Trunk to permit traffic spillage when the primary trunk reaches capacity or fails health checks.
POST /api/v2/telephony/sip/trunkgroups
  "name": "TRKG-CARRIER-A-HA-PRIMARY",
  "description": "Multi-homed carrier trunk group with DNS health monitoring",
  "trunks": [
      "id": "trunk-id-primary-pop1",
      "priority": 1,
      "minimumConcurrentCalls": 0,
      "maximumConcurrentCalls": 2500,
      "allowOverflow": true
      "id": "trunk-id-secondary-pop2",
      "priority": 2,
      "id": "trunk-id-tertiary-pop3",
      "priority": 3,
      "maximumConcurrentCalls": 1500,
      "allowOverflow": false
  "distributionMethod": "failover",
  "failoverThreshold": 3
The Trap: Configuring overflow without aligning maximum concurrent call limits to actual carrier circuit capacity creates overcommitment scenarios. When the primary trunk fails and Genesys Cloud shifts 100 percent of traffic to the secondary trunk, the secondary carrier may lack sufficient bandwidth, causing packet loss, jitter spikes, and degraded MOS scores. This is not a Genesys Cloud limitation. This is a capacity planning failure. Always provision secondary and tertiary trunks with equal or greater capacity than the primary, or implement WFM-driven call volume throttling during failover events. Reference the WFM Capacity Scaling during Telephony Failover guide for integration patterns.
Architectural Reasoning: We use explicit trunk groups with failover distribution because Genesys Cloud evaluates trunk health holistically. The routing engine checks the group state, queries individual trunk health metrics, and applies priority ordering before selecting a signaling path. Round-robin distribution spreads load but does not provide deterministic failover behavior. Failover distribution with overflow guarantees that traffic remains on the highest priority trunk until health checks mandate a shift, preventing unnecessary flapping during transient network blips.
3. SIP OPTIONS Health Check Tuning and Threshold Configuration
DNS resolution provides address discovery. SIP OPTIONS health checks provide operational state validation. Genesys Cloud sends periodic OPTIONS requests to each trunk endpoint to verify signaling responsiveness. You must tune frequency, timeout, and failure thresholds to balance detection speed against network stability.
Navigate to Admin > Telephony > Trunks > Health Check for each trunk in your group. Configure the following baseline values:
  • Health Check Method: SIP OPTIONS
  • Interval: 15 seconds
  • Timeout: 5 seconds
  • Failure Threshold: 3 consecutive failures
  • Recovery Threshold: 2 consecutive successes
  • Enable UDP Health Checks: true
  • Enable TCP Health Checks: false (unless carrier mandates TLS signaling)
These values create a 45-second detection window for complete trunk failure. The recovery threshold requires two successful pings before traffic returns to the previously failed trunk, preventing rapid oscillation when carrier edges experience intermittent packet loss.
PATCH /api/v2/telephony/sip/trunks/{trunkId}
  "healthCheck": {
    "enabled": true,
    "method": "SIP_OPTIONS",
    "intervalSeconds": 15,
    "timeoutSeconds": 5,
    "failureThreshold": 3,
    "recoveryThreshold": 2,
    "useUdp": true,
    "useTcp": false,
    "useTls": false
The Trap: Aggressive health check intervals combined with low failure thresholds trigger SIP signaling storms. When multiple Genesys Cloud SIP proxies independently ping carrier gateways at 5-second intervals with a 1-failure threshold, transient network congestion causes immediate failover, then immediate recovery, creating routing flapping that degrades both Genesys Cloud edge performance and carrier gateway CPU utilization. Carriers implement rate limiting that blocks OPTIONS requests exceeding 10 per second per source IP. You will receive 429 Too Many Requests responses that Genesys Cloud interprets as health failures, causing cascading false outages.
Architectural Reasoning: We use 15-second intervals with a 3-failure threshold because carrier networks experience sub-second packet loss that does not indicate trunk failure. SIP OPTIONS validation must distinguish between transient jitter and actual gateway unreachability. The recovery threshold of 2 successes ensures the carrier edge has stabilized before traffic returns. This configuration aligns with Genesys Cloud’s internal health evaluation window, which aggregates results across multiple SIP proxy instances before marking a trunk as unhealthy at the platform level.
4. Dial Rule Integration and Failover Validation
Trunk groups require explicit dial rule references to participate in call routing. Create or modify your outbound dial rules to reference the trunk group rather than individual trunks. Set the Trunk Group field in the dial rule configuration to your newly created group. Enable Allow Trunk Failover to permit the routing engine to shift traffic when health checks trigger state changes.
For inbound traffic, configure your carrier to route SIP INVITEs to the Genesys Cloud SIP Proxy FQDNs. Genesys Cloud distributes inbound signaling across available proxy instances. When a trunk fails health checks, inbound calls destined for that trunk receive 503 Service Unavailable responses. The carrier must implement SIP routing logic to retry INVITEs against secondary Genesys Cloud proxy endpoints or alternate trunk identities.
Validate the configuration using Genesys Cloud’s Telephony Monitoring dashboard. Navigate to Admin > Telephony > Trunks and select your trunk group. The health status column displays aggregate state. Individual trunk health indicators show OPTIONS ping success rates, latency percentiles, and failure timestamps. Trigger a controlled test by disabling DNS resolution for one carrier endpoint using a local hosts file override on a test workstation, then place test calls through the affected dial rule. Verify that calls route to the secondary trunk without manual intervention.
The Trap: Testing failover by physically disconnecting carrier circuits during production hours guarantees service disruption. You will drop live calls, trigger carrier-side alarm thresholds, and generate incident tickets that obscure the validation exercise. Always test using DNS override on isolated test endpoints, carrier-provided test numbers, or Genesys Cloud’s built-in test dial rules with restricted destination patterns. Coordinate with carrier network operations to schedule maintenance windows that simulate real failure conditions without impacting production call streams.
Architectural Reasoning: We integrate trunk groups into dial rules rather than hardcoding trunk references because dial rules serve as the routing policy layer. Hardcoding individual trunks bypasses the failover engine entirely. The dial rule engine evaluates trunk group state, applies distribution algorithms, and selects the optimal signaling path. This abstraction allows you to modify trunk composition, adjust priorities, or swap carriers without rewriting routing logic.
Edge Case 1: DNS Caching Delays During Carrier Failover
The Failure Condition: Carrier removes an IP from their SRV record, but Genesys Cloud continues routing to the decommissioned address for 3 to 5 minutes, generating 408 Request Timeout errors.
The Root Cause: Authoritative DNS servers or intermediate resolvers cache the old SRV record beyond the published TTL. Genesys Cloud’s DNS refresh interval aligns with the TTL, but upstream recursive resolvers (ISPs, public DNS providers, carrier edge caches) ignore TTL values or implement minimum TTL floors.
The Solution: Configure your DNS provider to publish a TTL of 60 seconds and enable DNSSEC to prevent cache poisoning. Contact intermediate resolver operators to request TTL compliance. In Genesys Cloud, reduce the DNS Refresh Interval to 90 seconds. This forces earlier re-resolution before upstream caches expire. Monitor DNS query logs to verify that Genesys Cloud SIP proxies are fetching fresh records.
Edge Case 2: SIP OPTIONS Response Mismatch During High Load
The Failure Condition: Health checks report trunk failure despite successful call completion. OPTIONS requests receive 408 Timeout or 503 Service Unavailable responses while INVITEs process normally.
The Root Cause: Carrier gateways prioritize media and signaling over health check requests during peak load. OPTIONS pings share the same processing thread as call setup. When CPU utilization exceeds 80 percent, the gateway delays OPTIONS responses beyond the 5-second timeout threshold. Genesys Cloud interprets the timeout as trunk failure and triggers failover.
The Solution: Increase the Health Check Timeout to 8 seconds and adjust the Failure Threshold to 5. Configure the carrier to process OPTIONS requests on a dedicated lightweight thread or separate virtual interface. Verify that carrier QoS policies mark OPTIONS traffic with DSCP CS3 to ensure timely processing. Monitor Genesys Cloud trunk health metrics alongside carrier CPU dashboards to correlate failures with load spikes.
Edge Case 3: Asymmetric NAT and Health Check Source IP Mismatch
The Failure Condition: Health checks fail consistently on one trunk while calls route successfully. Packet capture shows OPTIONS requests originating from a Genesys Cloud SIP proxy IP that differs from the IP used for call signaling.
The Root Cause: Genesys Cloud distributes health check requests across multiple SIP proxy instances. Each proxy has a distinct source IP. Carrier gateways implement stateful firewalls that only allow SIP traffic from registered proxy IPs. When a health check originates from an unregistered proxy IP, the carrier drops the request, causing timeout failures.
The Solution: Configure the carrier firewall to allow OPTIONS traffic from the full Genesys Cloud SIP Proxy IP range, or restrict health check source IPs using Genesys Cloud’s Preferred SIP Proxy setting on the trunk configuration. Verify that the carrier accepts OPTIONS from all documented Genesys Cloud edge ranges. Enable Force Health Check from Primary Proxy if available in your tenant configuration to ensure consistent source addressing.
