Configuring Genesys Cloud Routing Wrap-Up Codes via Python SDK with Validation and Audit Tracking
- You will build a Python module that programmatically creates, validates, and sequences Genesys Cloud routing wrap-up codes while preventing duplicates and schema violations.
- The code uses the Genesys Cloud Routing API endpoint
/api/v2/routing/wrappupcodesand the officialgenesys-cloud-pythonSDK. - The tutorial covers Python 3.9+ with type hints,
httpxfor external webhook synchronization, andpydanticfor payload validation.
- OAuth client type: Confidential Client (Client Credentials flow)
- Required scopes:
routing:wrappupcode:read,routing:wrappupcode:write - SDK version:
genesys-cloud-python >= 2.0.0 - Runtime requirements: Python 3.9 or higher
- External dependencies:
pip install genesys-cloud-python httpx pydantic python-dotenv
Genesys Cloud requires OAuth 2.0 Client Credentials authentication. The Python SDK handles token acquisition, caching, and automatic refresh. You must initialize the platform client with your environment, client identifier, and client secret.
import os
from genesyscloud.platform.client import PureCloudPlatformClientV2
def initialize_genesys_client(environment: str = "mypurecloud.com") -> PureCloudPlatformClientV2:
client = PureCloudPlatformClientV2()
client.set_credentials(
client_id=os.environ.get("GENESYS_CLIENT_ID"),
client_secret=os.environ.get("GENESYS_CLIENT_SECRET"),
environment=environment
return client
The SDK stores the access token in memory and automatically appends the Authorization: Bearer <token> header to subsequent requests. You do not need to manually manage token expiration. The SDK raises an authentication exception if the credentials are invalid or if the token cannot be refreshed.
Step 1: Fetch Existing Codes and Validate Routing Constraints
Before creating wrap-up codes, you must retrieve existing codes for the target routing queue to prevent duplicate conflicts. The endpoint supports pagination via pageSize and nextPageToken. You must also enforce the maximum description length constraint, which Genesys Cloud caps at 255 characters.
import logging
from genesyscloud.models import WrapupCode
def fetch_existing_wrappup_codes(
client: PureCloudPlatformClientV2,
routing_queue_id: str,
page_size: int = 100
) -> List[WrapupCode]:
existing_codes: List[WrapupCode] = []
pagination_token: Optional[str] = None
while True:
response = client.routing.get_routing_wrappupcodes(
routing_queue_id=routing_queue_id,
page_size=page_size,
page_token=pagination_token
if response.entities:
existing_codes.extend(response.entities)
if response.next_page_token:
pagination_token = response.next_page_token
else:
break
logger.error("Failed to fetch wrap-up codes: %s", str(e))
raise
return existing_codes
def validate_description_length(description: str, max_length: int = 255) -> bool:
if len(description) > max_length:
raise ValueError(
f"Description exceeds maximum routing constraint limit of {max_length} characters. "
f"Current length: {len(description)}"
return True
The pagination loop continues until next_page_token returns None. You must handle network interruptions and API errors gracefully. The validation function enforces the schema constraint before payload construction.
Step 2: Construct Payloads with Sequence Calculation and Disposition Mapping
Wrap-up codes require a codeSequence value to determine their display order in the agent interface. You must calculate the next available sequence number dynamically. The payload also requires a codeGroup identifier and a dispositionMapping evaluation to align with routing matrix definitions.
from dataclasses import dataclass
from genesyscloud.models import WrapupCodeBody
import httpx
@dataclass
class WrapupCodeConfig:
code: str
description: str
code_group_id: str
disposition_mapping: str
def calculate_next_sequence(existing_codes: List[WrapupCode]) -> int:
if not existing_codes:
return 1
max_sequence = max(code.code_sequence for code in existing_codes if code.code_sequence is not None)
return max_sequence + 1
def check_duplicate_code(existing_codes: List[WrapupCode], new_code: str) -> bool:
return any(code.code == new_code for code in existing_codes)
def construct_wrappup_payload(
config: WrapupCodeConfig,
) -> WrapupCodeBody:
validate_description_length(config.description)
if check_duplicate_code(existing_codes, config.code):
raise ValueError(f"Duplicate code detected: {config.code}. Routing matrix requires unique codes per queue.")
next_sequence = calculate_next_sequence(existing_codes)
return WrapupCodeBody(
code=config.code,
description=config.description,
code_group_id=config.code_group_id,
routing_queue_id=config.routing_queue_id,
code_sequence=next_sequence,
disposition_mapping=config.disposition_mapping,
is_default=False,
is_system=False
The calculate_next_sequence function scans existing codes and increments the highest value. The check_duplicate_code function prevents 409 Conflict responses by validating uniqueness before submission. The WrapupCodeBody object matches the Genesys Cloud schema exactly.
Step 3: Atomic HTTP POST Operations with Retry Logic and Format Verification
Genesys Cloud enforces strict rate limits. You must implement exponential backoff for 429 responses. The SDK handles JSON serialization, but you must verify the HTTP request format and handle schema validation errors.
from functools import wraps
def retry_on_rate_limit(max_retries: int = 3, base_delay: float = 1.0):
def decorator(func):
@wraps(func)
def wrapper(*args, **kwargs):
retries = 0
while True:
return func(*args, **kwargs)
error_msg = str(e)
if "429" in error_msg or "Too Many Requests" in error_msg:
if retries >= max_retries:
raise RuntimeError("Max retries exceeded for rate limit 429")
delay = base_delay * (2 ** retries)
logger.warning("Rate limit 429 encountered. Retrying in %.2f seconds...", delay)
time.sleep(delay)
retries += 1
else:
raise
return wrapper
return decorator
@retry_on_rate_limit(max_retries=3, base_delay=1.5)
def create_wrappup_code(
payload: WrapupCodeBody
) -> WrapupCode:
response = client.routing.post_routing_wrappupcode(body=payload)
logger.info("Successfully created wrap-up code: %s (ID: %s)", response.code, response.id)
return response
error_body = str(e)
if "400" in error_body:
raise ValueError(f"Schema validation failed: {error_body}")
if "409" in error_body:
raise ConflictError(f"Resource conflict: {error_body}")
raise
The decorator intercepts 429 responses and applies exponential backoff. The SDK call maps to the following HTTP request cycle:
POST /api/v2/routing/wrappupcodes HTTP/1.1
Host: mycompany.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIs...
"code": "TRANSFER_COMPLETED",
"description": "Agent successfully transferred the conversation to a specialized queue",
"codeGroupId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"routingQueueId": "q9r8s7t6-u5v4-3210-wxyz-9876543210ab",
"codeSequence": 42,
"dispositionMapping": "transfer.completed",
"isDefault": false,
"isSystem": false
Expected successful response:
"id": "wrappup-12345-67890-abcde",
"codeSequence": 42,
"isDefault": false,
"isSystem": false,
"version": 1,
"selfUri": "https://mycompany.mypurecloud.com/api/v2/routing/wrappupcodes/wrappup-12345-67890-abcde"
Step 4: External WFM Synchronization, Latency Tracking, and Audit Logging
You must synchronize configuration events with external Workforce Management systems via outbound webhooks. You must also track configuration latency and success rates for governance auditing.
import json
from typing import Dict, Any
import httpx
class CodeConfigAuditLogger:
def __init__(self, webhook_url: str):
self.http_client = httpx.Client(timeout=10.0)
self.metrics: Dict[str, Any] = {"total": 0, "success": 0, "failure": 0}
def log_configuration_event(self, code_id: str, code_name: str, status: str, latency_ms: float) -> None:
self.metrics["total"] += 1
if status == "success":
self.metrics["success"] += 1
else:
self.metrics["failure"] += 1
audit_record = {
"event_type": "wrappup_code_configured",
"code_id": code_id,
"code_name": code_name,
"status": status,
"latency_ms": latency_ms,
"success_rate": round(self.metrics["success"] / max(1, self.metrics["total"]), 4)
self._generate_audit_log(audit_record)
self._sync_external_wfm(audit_record)
def _generate_audit_log(self, record: Dict[str, Any]) -> None:
log_entry = json.dumps(record, indent=2)
logger.info("AUDIT | %s", log_entry)
def _sync_external_wfm(self, record: Dict[str, Any]) -> None:
response = self.http_client.post(
self.webhook_url,
json={"event": record},
headers={"Content-Type": "application/json", "X-Source": "genesys-configurer"}
response.raise_for_status()
logger.debug("External WFM webhook synchronized successfully")
logger.error("WFM webhook sync failed: %s", e.response.text)
logger.error("WFM webhook network error: %s", str(e))
The audit logger captures latency, calculates success rates, writes structured logs, and pushes events to an external WFM endpoint. The httpx client handles the outbound POST with explicit timeout configuration.
The following module combines authentication, validation, atomic creation, and audit tracking into a single executable script. Replace the environment variables with your Genesys Cloud credentials.
import os
import sys
import logging
from genesyscloud.models import WrapupCode, WrapupCodeBody
# Import helper functions from previous steps
# In production, organize these into separate modules
def run_wrappup_configurer():
client_id = os.environ.get("GENESYS_CLIENT_ID")
client_secret = os.environ.get("GENESYS_CLIENT_SECRET")
queue_id = os.environ.get("TARGET_QUEUE_ID")
code_group_id = os.environ.get("CODE_GROUP_ID")
wfm_webhook = os.environ.get("WFM_WEBHOOK_URL", "https://example.com/wfm/sync")
if not all([client_id, client_secret, queue_id, code_group_id]):
raise EnvironmentError("Missing required environment variables")
client.set_credentials(client_id=client_id, client_secret=client_secret)
existing_codes = fetch_existing_wrappup_codes(client, queue_id)
audit_logger = CodeConfigAuditLogger(wfm_webhook)
new_config = WrapupCodeConfig(
code="CUSTOMER_ESCALATED",
description="Customer requires supervisor intervention due to billing discrepancy",
code_group_id=code_group_id,
routing_queue_id=queue_id,
disposition_mapping="escalation.billing"
start_time = time.time()
payload = construct_wrappup_payload(new_config, existing_codes)
created_code = create_wrappup_code(client, payload)
audit_logger.log_configuration_event(
code_id=created_code.id,
code_name=created_code.code,
status="success",
latency_ms=latency_ms
print(f"Configuration complete. Code ID: {created_code.id}")
except ValueError as ve:
code_id="pending",
code_name=new_config.code,
status="validation_failure",
print(f"Validation failed: {ve}")
sys.exit(1)
code_id="pending",
status="api_failure",
print(f"API operation failed: {e}")
sys.exit(1)
Error: 400 Bad Request (Schema Validation Failure)
- What causes it: The payload violates Genesys Cloud schema constraints. Common triggers include
descriptionexceeding 255 characters, missing required fields likeroutingQueueId, or invalid UUID format incodeGroupId. - How to fix it: Verify the
WrapupCodeBodystructure matches the API specification. Run thevalidate_description_lengthfunction before submission. Check the response body for the exact field path. - Code showing the fix:
payload = construct_wrappup_payload(config, existing_codes)
except ValueError as e:
logger.error("Payload rejected by schema validator: %s", str(e))
# Correct the field before retrying
Error: 409 Conflict (Duplicate Code)
- What causes it: You attempted to create a wrap-up code with a
codevalue that already exists in the specified routing queue. Genesys Cloud enforces uniqueness per queue scope. - How to fix it: Fetch existing codes first. Use the
check_duplicate_codefunction to abort creation or update the existing resource viaput_routing_wrappupcode. - Code showing the fix:
if check_duplicate_code(existing_codes, new_code):
logger.warning("Code %s already exists. Skipping creation or triggering update flow.", new_code)
# Route to PUT endpoint instead of POST
Error: 429 Too Many Requests (Rate Limit Cascade)
- What causes it: You exceeded the Genesys Cloud API rate limit for your organization or tenant. The routing endpoint typically allows 100 requests per minute per client.
- How to fix it: Implement exponential backoff. The
retry_on_rate_limitdecorator handles this automatically. Reduce batch sizes if processing multiple queues. - Code showing the fix:
@retry_on_rate_limit(max_retries=4, base_delay=2.0)
def batch_create_codes(client: PureCloudPlatformClientV2, payloads: List[WrapupCodeBody]) -> List[WrapupCode]:
return [create_wrappup_code(client, p) for p in payloads]
Error: 403 Forbidden (Missing OAuth Scope)
- What causes it: The OAuth token lacks
routing:wrappupcode:write. The SDK will throw a credentials exception or return a 403. - How to fix it: Regenerate the OAuth token with the correct scope. Verify your Genesys Cloud application configuration includes the required routing scopes.
client_id=os.environ["GENESYS_CLIENT_ID"],
client_secret=os.environ["GENESYS_CLIENT_SECRET"],
environment="mypurecloud.com"
# Ensure your Genesys Cloud app has routing:wrappupcode:write enabled
