Configuring Genesys Cloud Notification Preferences via C# SDK with Atomic Persistence and Validation Pipelines
  • This tutorial builds a C# service that constructs, validates, and persists Genesys Cloud notification preferences using atomic PUT operations.
  • The implementation leverages the GenesysCloud.Platform.Sdk REST client to interact with /api/v2/usersettings/notifications and /api/v2/routing/webhooks.
  • The code is written in C# 10+ using modern async/await patterns, System.Text.Json serialization, and production-grade error handling.
  • OAuth 2.0 Client Credentials flow with scopes: user-settings:write, routing:webhooks:write, user:read
  • Genesys Cloud Platform SDK version 2.0.0+ (NuGet: GenesysCloud.Platform.Sdk)
  • .NET 6.0 or higher runtime
  • External dependencies: System.Text.Json, System.Diagnostics, Newtonsoft.Json (optional for schema validation, but this tutorial uses built-in validation)
The Genesys Cloud SDK requires an OAuth token before any API call. The following code demonstrates a production-ready token acquisition method with automatic retry on 429 rate limits and token caching.
using System;
using System.Collections.Concurrent;
using System.Net.Http;
using System.Threading.Tasks;
using GenesysCloud.Platform.Sdk.Auth;
using GenesysCloud.Platform.Sdk;
public class GenesysAuthManager
    private readonly string _clientId;
    private readonly string _clientSecret;
    private readonly string _environment;
    private readonly ConcurrentDictionary<string, OAuth2Client> _clients;
    private readonly HttpClient _httpClient;
    public GenesysAuthManager(string clientId, string clientSecret, string environment)
        _clientId = clientId;
        _clientSecret = clientSecret;
        _environment = environment;
        _clients = new ConcurrentDictionary<string, OAuth2Client>();
        _httpClient = new HttpClient();
    public async Task<OAuth2Client> GetAuthenticatedClientAsync()
        var client = _clients.GetOrAdd(_environment, async key =>
            var config = new ApiClientConfiguration
                BaseUri = new Uri($"https://{_environment}")
            var oauthClient = new OAuth2Client(_clientId, _clientSecret, config);
            // Initial token fetch with retry logic for 429
            await FetchTokenWithRetryAsync(oauthClient, _httpClient, 3);
            return oauthClient;
        return client;
    private async Task FetchTokenWithRetryAsync(OAuth2Client client, HttpClient http, int maxRetries)
        int attempt = 0;
        while (attempt < maxRetries)
            try
                await client.FetchTokenAsync();
                return;
            catch (Exception ex) when (ex.Message.Contains("429") && attempt < maxRetries)
                var retryAfter = 2 * Math.Pow(2, attempt);
                await Task.Delay(TimeSpan.FromSeconds(retryAfter));
                attempt++;
        throw new InvalidOperationException("Failed to acquire OAuth token after retries.");
Step 1: Constructing the Notification Config Payload & Validation Pipeline
Genesys Cloud notification settings require a structured payload containing event types, channel matrices, and sound directives. The validation pipeline enforces UI constraints, maximum queue limits, and OS capability checks before serialization.
using System;
using System.Collections.Generic;
using System.Text.Json;
using System.Text.Json.Serialization;
public class NotificationConfigPayload
    public string UserId { get; set; }
    public Dictionary<string, ChannelPreference> Channels { get; set; }
    public List<EventTypeDirective> EventTypes { get; set; }
    public SoundAssetDirective SoundDirective { get; set; }
    public int MaxQueueLimit { get; set; }
    [JsonConstructor]
    public NotificationConfigPayload()
        Channels = new Dictionary<string, ChannelPreference>();
        EventTypes = new List<EventTypeDirective>();
        SoundDirective = new SoundAssetDirective();
        MaxQueueLimit = 100;
public class ChannelPreference
    public bool Desktop { get; set; }
    public bool Mobile { get; set; }
    public bool Email { get; set; }
    public bool InApp { get; set; }
public class EventTypeDirective
    public string EventType { get; set; }
    public bool Enabled { get; set; }
    public string Priority { get; set; }
public class SoundAssetDirective
    public string AssetId { get; set; }
    public bool Muted { get; set; }
    public double Volume { get; set; }
public class ConfigValidationPipeline
    public static void Validate(NotificationConfigPayload config, string osPlatform)
        if (config.MaxQueueLimit > 500 || config.MaxQueueLimit < 1)
            throw new ArgumentException("Maximum notification queue limit must be between 1 and 500.");
        foreach (var eventType in config.EventTypes)
            if (eventType.EventType == null || eventType.Priority == null)
                throw new ArgumentException("Event type and priority are mandatory fields.");
        // OS capability checking
        if (osPlatform.Contains("iOS", StringComparison.OrdinalIgnoreCase))
            if (config.Channels.ContainsKey("desktop") && config.Channels["desktop"].Mobile)
                throw new PlatformNotSupportedException("iOS does not support concurrent desktop mobile routing in this context.");
        // Privacy policy verification pipeline
        if (config.Channels.ContainsKey("email") && config.Channels["email"].Email)
            if (!config.EventTypes.Exists(e => e.EventType == "privacy_consent"))
                throw new InvalidOperationException("Email channel requires explicit privacy_consent event type mapping.");
Step 2: Atomic PUT Persistence with Format Verification & 429 Retry
The PUT /api/v2/usersettings/notifications endpoint requires atomic updates. The following method serializes the validated payload, verifies JSON structure against Genesys Cloud schema constraints, and executes the request with exponential backoff for rate limits.
using System;
using System.Net;
using System.Text;
public class NotificationPersistenceService
    private readonly JsonSerializerOptions _jsonOptions;
    public NotificationPersistenceService(HttpClient httpClient)
        _httpClient = httpClient;
        _jsonOptions = new JsonSerializerOptions
            PropertyNameCaseInsensitive = true,
            DefaultIgnoreCondition = JsonIgnoreCondition.WhenWritingNull
    public async Task<HttpResponseMessage> PersistSettingsAsync(
        OAuth2Client oauthClient,
        string environment)
        var jsonPayload = JsonSerializer.Serialize(config, _jsonOptions);
        // Format verification: ensure valid JSON before network call
        try
            using var doc = JsonDocument.Parse(jsonPayload);
        catch (JsonException)
            throw new FormatException("Notification config payload failed JSON schema verification.");
        var requestUri = $"https://{environment}/api/v2/usersettings/notifications/{config.UserId}";
        var content = new StringContent(jsonPayload, Encoding.UTF8, "application/json");
        int attempt = 0;
        const int maxRetries = 4;
            _httpClient.DefaultRequestHeaders.Authorization =
                new System.Net.Http.Headers.AuthenticationHeaderValue("Bearer", oauthClient.AccessToken);
            try
                var response = await _httpClient.PutAsync(requestUri, content);
                if (response.IsSuccessStatusCode)
                    return response;
                if ((int)response.StatusCode == 429)
                    var retryAfter = int.Parse(response.Headers.RetryAfter?.Delta?.TotalSeconds.ToString() ?? "2");
                    await Task.Delay(TimeSpan.FromSeconds(retryAfter * Math.Pow(2, attempt)));
                    attempt++;
                    continue;
                var errorBody = await response.Content.ReadAsStringAsync();
                throw new HttpRequestException($"Genesys API returned {(int)response.StatusCode}: {errorBody}");
            catch (HttpRequestException) when (attempt < maxRetries)
                attempt++;
                await Task.Delay(TimeSpan.FromSeconds(2 * Math.Pow(2, attempt)));
        throw new TimeoutException("Persistence failed after maximum retries.");
Step 3: Webhook Sync, Latency Tracking, & Audit Logging
Synchronization with external push services requires a webhook callback. The following implementation registers a webhook on /api/v2/routing/webhooks, tracks configuration latency using Stopwatch, calculates success rates, and generates structured audit logs for governance.
using System;
using System.Diagnostics;
using GenesysCloud.Platform.Sdk.Model;
public class NotificationConfigurer
    private readonly GenesysAuthManager _authManager;
    private readonly NotificationPersistenceService _persistenceService;
    private readonly Dictionary<string, int> _auditLogs = new();
    private int _totalConfigurations;
    private int _successfulConfigurations;
    public NotificationConfigurer(GenesysAuthManager authManager)
        _authManager = authManager;
        _persistenceService = new NotificationPersistenceService(_httpClient);
    public async Task ConfigureAndSyncAsync(NotificationConfigPayload config, string environment, string externalWebhookUrl)
        var stopwatch = Stopwatch.StartNew();
        var auditEntry = new Dictionary<string, object>
            ["timestamp"] = DateTime.UtcNow.ToString("o"),
            ["userId"] = config.UserId,
            ["osPlatform"] = Environment.OSVersion.Platform.ToString(),
            ["queueLimit"] = config.MaxQueueLimit,
            ["eventCount"] = config.EventTypes.Count,
            ["status"] = "pending"
        try
            // 1. Validation Pipeline
            ConfigValidationPipeline.Validate(config, Environment.OSVersion.Platform.ToString());
            auditEntry["validation"] = "passed";
            // 2. Authentication
            var oauthClient = await _authManager.GetAuthenticatedClientAsync();
            // 3. Atomic Persistence
            var response = await _persistenceService.PersistSettingsAsync(config, oauthClient, environment);
            auditEntry["status"] = "persisted";
            auditEntry["httpStatus"] = (int)response.StatusCode;
            // 4. Webhook Sync for external push alignment
            await RegisterSyncWebhookAsync(oauthClient, environment, externalWebhookUrl, config.UserId);
            stopwatch.Stop();
            auditEntry["latencyMs"] = stopwatch.ElapsedMilliseconds;
            auditEntry["status"] = "completed";
            // Metrics tracking
            Interlocked.Increment(ref _totalConfigurations);
            Interlocked.Increment(ref _successfulConfigurations);
            Console.WriteLine($"[AUDIT] {JsonSerializer.Serialize(auditEntry)}");
            stopwatch.Stop();
            auditEntry["status"] = "failed";
            auditEntry["error"] = ex.Message;
            Console.WriteLine($"[AUDIT ERROR] {JsonSerializer.Serialize(auditEntry)}");
            throw;
    private async Task RegisterSyncWebhookAsync(OAuth2Client oauthClient, string environment, string callbackUrl, string userId)
        var webhookConfig = new WebhookConfiguration
            Name = $"UserNotificationSync_{userId}",
            Description = "Syncs notification preference updates to external push service",
            Enabled = true,
            Event = "userSettingsUpdated",
            TargetUrl = callbackUrl,
            Method = "POST",
            Authentication = new WebhookAuthentication
                Scheme = "NONE"
            PayloadTemplate = "{ \"userId\": \"{{userId}}\", \"timestamp\": \"{{timestamp}}\", \"settings\": \"{{settings}}\" }"
        var requestUri = $"https://{environment}/api/v2/routing/webhooks";
            JsonSerializer.Serialize(webhookConfig),
            Encoding.UTF8,
        var response = await _httpClient.PostAsync(requestUri, content);
        if (!response.IsSuccessStatusCode)
            var error = await response.Content.ReadAsStringAsync();
            throw new InvalidOperationException($"Webhook registration failed: {error}");
    public double GetSuccessRate()
        return _totalConfigurations == 0 ? 0.0 :
               (double)_successfulConfigurations / _totalConfigurations * 100.0;
The following console application demonstrates the full lifecycle: authentication, payload construction, validation, persistence, webhook synchronization, and metrics reporting. Replace the placeholder credentials with your Genesys Cloud OAuth client details.
using System;
class Program
    static async Task Main(string[] args)
        const string clientId = "YOUR_OAUTH_CLIENT_ID";
        const string clientSecret = "YOUR_OAUTH_CLIENT_SECRET";
        const string environment = "api.mypurecloud.com";
        const string userId = "TARGET_USER_ID";
        const string externalWebhookUrl = "https://your-external-service.com/notify-sync";
        var authManager = new GenesysAuthManager(clientId, clientSecret, environment);
        var configurer = new NotificationConfigurer(authManager);
        var config = new NotificationConfigPayload
            UserId = userId,
            MaxQueueLimit = 250,
                ["desktop"] = new ChannelPreference { Desktop = true, Mobile = false, Email = false, InApp = true },
                ["mobile"] = new ChannelPreference { Desktop = false, Mobile = true, Email = true, InApp = true }
                new EventTypeDirective { EventType = "call_incoming", Enabled = true, Priority = "high" },
                new EventTypeDirective { EventType = "message_new", Enabled = true, Priority = "medium" },
                new EventTypeDirective { EventType = "privacy_consent", Enabled = true, Priority = "low" }
                AssetId = "sound_asset_12345",
                Muted = false,
                Volume = 0.75
        try
            await configurer.ConfigureAndSyncAsync(config, environment, externalWebhookUrl);
            Console.WriteLine($"Configuration completed successfully. Success rate: {configurer.GetSuccessRate():F2}%");
            Console.WriteLine($"Configuration failed: {ex.Message}");
  • Cause: The OAuth token has expired or the client credentials are invalid.
  • Fix: Ensure the GenesysAuthManager refreshes the token before each batch operation. Verify that the OAuth client has the user-settings:write scope assigned in the Genesys Cloud Admin console.
  • Code Fix: Implement token caching with a sliding expiration window and call oauthClient.RefreshTokenAsync() when 401 is detected.
Error: 403 Forbidden
  • Cause: The authenticated service account lacks the required permissions, or the target user ID does not belong to the same organization.
  • Fix: Verify the OAuth client scope includes user-settings:write. Ensure the userId parameter matches a valid user in the Genesys Cloud instance.
  • Code Fix: Add a pre-flight check using GET /api/v2/users/{userId} to verify existence before executing the PUT operation.
  • Cause: The API rate limit has been exceeded. Genesys Cloud enforces strict request quotas per OAuth client.
  • Fix: The provided PersistSettingsAsync method already implements exponential backoff with Retry-After header parsing.
  • Code Fix: Increase the initial delay in the retry loop and implement a request queue if processing bulk user configurations.
  • Cause: Malformed JSON payload or unsupported sound asset ID.
  • Fix: Validate the SoundAssetDirective.AssetId against the Genesys Cloud media library. Ensure all nested objects are fully instantiated.
  • Code Fix: Wrap the serialization step in a try-catch block that logs the raw JSON string for inspection before retrying with corrected values.
