Configuring Genesys Cloud LLM Gateway Model Registry Entries via Python SDK
A production-grade model registrar that constructs LLM Gateway payloads with endpoint URLs, authentication credential references, and parameter matrices, validates schemas against architecture constraints, submits registrations asynchronously, runs synthetic prompt latency tests, tracks metrics, and synchronizes status via webhook callbacks. This tutorial uses the Genesys Cloud Python SDK and httpx for external validation. The implementation is written in Python 3.9+.
  • OAuth service account client with scopes: ai:llm-gateway:write, ai:llm-gateway:read, ai:jobs:read
  • Genesys Cloud Python SDK: genesyscloud>=2.20.0
  • Runtime: Python 3.9 or higher
  • External dependencies: httpx>=0.25.0, pydantic>=2.0.0, tenacity>=8.2.0
  • Access to a Genesys Cloud organization with LLM Gateway enabled
The Genesys Cloud Python SDK handles OAuth token acquisition and automatic refresh when configured with a service account. You must initialize the configuration with your client ID, client secret, and base URL. The SDK caches the access token and refreshes it transparently before expiration.
import os
from genesyscloud import Configuration
from genesyscloud.ai_largelanguage import ApiClient as LlmGatewayApiClient
from genesyscloud.ai_jobs import ApiClient as JobsApiClient
def init_genesys_clients() -> tuple[LlmGatewayApiClient, JobsApiClient]:
    config = Configuration()
    config.host = os.getenv("GENESYS_CLOUD_HOST", "https://api.mypurecloud.com")
    config.oauth_client_id = os.getenv("GENESYS_OAUTH_CLIENT_ID")
    config.oauth_client_secret = os.getenv("GENESYS_OAUTH_CLIENT_SECRET")
    # SDK automatically handles token caching and refresh
    llm_client = LlmGatewayApiClient(config)
    jobs_client = JobsApiClient(config)
    return llm_client, jobs_client
Step 1: Schema Validation and Payload Construction
Genesys Cloud LLM Gateway enforces strict schema constraints for model registration. You must validate the endpoint URL, authentication credential reference, and parameter configuration matrix before submission. The payload must conform to the CreateLargeLanguageModel schema. Rate limit matrices require you to declare max_requests_per_minute and max_tokens_per_minute to prevent gateway throttling.
import logging
from pydantic import BaseModel, HttpUrl, Field, validator
from typing import Optional
class ModelRegistrationPayload(BaseModel):
    name: str = Field(..., min_length=3, max_length=64)
    endpoint_url: HttpUrl
    auth_credential_id: str
    model_architecture: str = Field(..., pattern="^(openai|anthropic|azure|cohere|custom)$")
    max_requests_per_minute: int = Field(..., ge=1, le=10000)
    max_tokens_per_minute: int = Field(..., ge=1, le=5000000)
    parameters: dict[str, float | int | str] = Field(default_factory=dict)
    webhook_callback_url: Optional[HttpUrl] = None
    @validator("parameters")
    def validate_parameter_matrix(cls, v: dict) -> dict:
        allowed_keys = {"temperature", "top_p", "max_tokens", "stop_sequences", "frequency_penalty"}
        invalid_keys = set(v.keys()) - allowed_keys
        if invalid_keys:
            raise ValueError(f"Unsupported parameter keys: {invalid_keys}. Must be subset of {allowed_keys}")
        return v
def build_registration_payload(config: dict) -> dict:
    schema = ModelRegistrationPayload(**config)
    payload = {
        "name": schema.name,
        "endpointUrl": str(schema.endpoint_url),
        "authCredentialId": schema.auth_credential_id,
        "modelArchitecture": schema.model_architecture,
        "rateLimits": {
            "maxRequestsPerMinute": schema.max_requests_per_minute,
            "maxTokensPerMinute": schema.max_tokens_per_minute
        "parameters": schema.parameters,
        "webhookCallbackUrl": str(schema.webhook_callback_url) if schema.webhook_callback_url else None
    logger.info("Constructed registration payload: %s", payload)
    return payload
Step 2: Asynchronous Job Processing and Health Check Triggers
Model registration in Genesys Cloud is processed asynchronously. The API returns a job identifier immediately. You must poll the job status until completion. The SDK provides create_largelanguage_model and get_job methods. You must implement retry logic for 429 rate limit responses and handle 5xx server errors gracefully.
import requests
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
@retry(
    stop=stop_after_attempt(5),
    wait=wait_exponential(multiplier=1, min=2, max=30),
    retry=retry_if_exception_type(ApiException),
    reraise=True
def submit_model_registration(llm_client: LlmGatewayApiClient, payload: dict) -> str:
        # HTTP Cycle: POST /api/v2/ai/llm-gateway/models
        # Headers: Authorization: Bearer <token>, Content-Type: application/json
        # Body: payload
        response = llm_client.create_largelanguage_model(body=payload)
        job_id = response["jobId"]
        logger.info("Registration job submitted. Job ID: %s", job_id)
        return job_id
    except ApiException as e:
        if e.status == 429:
            logger.warning("Rate limit exceeded. Retrying...")
            raise
        elif e.status == 400:
            logger.error("Schema validation failed: %s", e.body)
            raise
        else:
            logger.error("API error %s: %s", e.status, e.body)
            raise
def poll_registration_status(jobs_client: JobsApiClient, job_id: str, timeout_seconds: int = 120) -> dict:
    start_time = time.time()
    while time.time() - start_time < timeout_seconds:
            # HTTP Cycle: GET /api/v2/ai/jobs/{jobId}
            status_resp = jobs_client.get_job(job_id)
            logger.debug("Job status: %s", status_resp["status"])
            if status_resp["status"] in ("COMPLETED", "FAILED"):
                return status_resp
            time.sleep(3)
            if e.status == 429:
                time.sleep(5)
            raise
    raise TimeoutError(f"Job {job_id} did not complete within {timeout_seconds} seconds")
Step 3: Synthetic Prompt Testing and Latency Measurement
Before activating the model in production routing logic, you must verify endpoint responsiveness. This step sends a synthetic prompt to the registered endpoint, measures latency, and triggers an automatic health check in Genesys Cloud. You must use httpx for non-blocking HTTP requests and capture timing metrics.
import httpx
import json
def run_synthetic_validation(endpoint_url: str, auth_header: str, timeout_seconds: int = 15) -> dict:
    synthetic_prompt = {
        "model": "test-architecture",
        "messages": [{"role": "user", "content": "Respond with exactly: VALIDATION_SUCCESS"}],
        "temperature": 0.0,
        "max_tokens": 10
    start_time = datetime.now(timezone.utc)
        # HTTP Cycle: POST {endpoint_url}/v1/chat/completions
        # Headers: Authorization: Bearer <external_token>, Content-Type: application/json
        with httpx.Client(timeout=timeout_seconds) as client:
            response = client.post(
                str(endpoint_url) + "/v1/chat/completions",
                json=synthetic_prompt,
                headers={"Authorization": auth_header}
        latency_ms = (datetime.now(timezone.utc) - start_time).total_seconds() * 1000
        response.raise_for_status()
            "status": "PASS" if response.status_code == 200 else "FAIL",
            "latency_ms": latency_ms,
            "response_code": response.status_code,
            "payload_size_bytes": len(response.content)
    except httpx.HTTPError as e:
        logger.error("Synthetic validation failed: %s", e)
        return {"status": "FAIL", "latency_ms": latency_ms, "error": str(e)}
def trigger_health_check(llm_client: LlmGatewayApiClient, model_id: str) -> dict:
        # HTTP Cycle: POST /api/v2/ai/llm-gateway/models/{modelId}/health-checks
        health_resp = llm_client.create_largelanguage_model_health_check(model_id)
        logger.info("Health check triggered for model %s", model_id)
        return health_resp
        logger.error("Health check failed: %s", e.body)
        raise
Step 4: Webhook Synchronization and Audit Logging
You must synchronize registration status with external AI orchestration platforms. The payload includes a webhookCallbackUrl field that Genesys Cloud calls upon job completion. You must also generate audit logs containing registration latency, validation success rates, and configuration hashes for governance compliance.
def send_webhook_sync(webhook_url: str, model_id: str, status: str, metrics: dict) -> bool:
    payload = {
        "event": "llm_model_registration_updated",
        "modelId": model_id,
        "status": status,
        "metrics": metrics
        with httpx.Client(timeout=10) as client:
            resp = client.post(webhook_url, json=payload, headers={"Content-Type": "application/json"})
            resp.raise_for_status()
            return True
        logger.error("Webhook sync failed: %s", e)
        return False
def write_audit_log(model_id: str, payload_hash: str, job_duration_ms: float, validation_result: dict) -> None:
    log_entry = {
        "payloadHash": payload_hash,
        "jobDurationMs": job_duration_ms,
        "validationStatus": validation_result["status"],
        "latencyMs": validation_result.get("latency_ms"),
        "compliance": "RECORD_STORED"
    with open("llm_model_audit.log", "a") as f:
        f.write(json.dumps(log_entry) + "\n")
    logger.info("Audit log written for model %s", model_id)
The following script combines all components into a production-ready GenesysLlmModelRegistrar class. It handles authentication, validation, async job polling, synthetic testing, webhook synchronization, and audit logging in a single execution flow.
import os
import hashlib
import json
import logging
import httpx
class GenesysLlmModelRegistrar:
    def __init__(self, host: str, client_id: str, client_secret: str):
        config.host = host
        config.oauth_client_id = client_id
        config.oauth_client_secret = client_secret
        self.llm_client = LlmGatewayApiClient(config)
        self.jobs_client = JobsApiClient(config)
    def register_model(self, config: dict, external_auth_token: str) -> dict:
        payload = build_registration_payload(config)
        payload_hash = hashlib.sha256(json.dumps(payload, sort_keys=True).encode()).hexdigest()
        job_id = submit_model_registration(self.llm_client, payload)
        status_resp = poll_registration_status(self.jobs_client, job_id)
        job_duration_ms = (time.time() - start_time) * 1000
        model_id = status_resp.get("result", {}).get("id")
        if status_resp["status"] != "COMPLETED" or not model_id:
            raise RuntimeError(f"Registration failed: {status_resp}")
        validation_result = run_synthetic_validation(
            endpoint_url=payload["endpointUrl"],
            auth_header=f"Bearer {external_auth_token}"
        trigger_health_check(self.llm_client, model_id)
        webhook_url = config.get("webhook_callback_url")
        if webhook_url:
            send_webhook_sync(webhook_url, model_id, status_resp["status"], {
                "validationLatencyMs": validation_result.get("latency_ms")
        write_audit_log(model_id, payload_hash, job_duration_ms, validation_result)
            "status": status_resp["status"],
            "validation": validation_result,
    registrar = GenesysLlmModelRegistrar(
        host=os.getenv("GENESYS_CLOUD_HOST"),
        client_id=os.getenv("GENESYS_OAUTH_CLIENT_ID"),
        client_secret=os.getenv("GENESYS_OAUTH_CLIENT_SECRET")
    model_config = {
        "name": "production-llm-v2",
        "endpoint_url": "https://api.external-ai-provider.com",
        "auth_credential_id": "cred_abc123xyz",
        "model_architecture": "openai",
        "max_requests_per_minute": 500,
        "max_tokens_per_minute": 100000,
        "parameters": {"temperature": 0.7, "max_tokens": 4096},
        "webhook_callback_url": "https://my-orchestrator.internal/webhooks/genesys-llm"
    result = registrar.register_model(model_config, os.getenv("EXTERNAL_AI_TOKEN"))
    print(json.dumps(result, indent=2))
  • Cause: Missing OAuth scopes or expired service account token. The SDK requires ai:llm-gateway:write and ai:jobs:read.
  • Fix: Verify the service account role includes the ai:llm-gateway:write scope. Regenerate credentials if rotated. The SDK refreshes tokens automatically, but initial acquisition requires valid secrets.
  • Code Fix: Ensure Configuration is initialized before client instantiation. Catch ApiException with status 401 or 403 and log the exact scope mismatch.
  • Cause: Exceeding Genesys Cloud API rate limits or model-specific rate matrices during polling or submission.
  • Fix: The tenacity retry decorator in submit_model_registration handles exponential backoff. Increase wait_exponential multipliers if cascading. Implement request throttling for bulk registrations.
  • Code Fix: Monitor RetryError exceptions. Log Retry-After headers if returned by the API.
Error: 400 Bad Request (Schema Validation)
  • Cause: Invalid parameter keys, unsupported model architecture, or malformed webhook URL.
  • Fix: The Pydantic validator rejects unsupported parameter keys before API submission. Verify model_architecture matches the allowed enum. Ensure endpointUrl and webhookCallbackUrl are absolute HTTPS URLs.
  • Code Fix: Parse e.body from ApiException to identify the exact field violation. Update payload construction logic.
Error: 503 Service Unavailable or Timeout
  • Cause: External AI endpoint unreachable during synthetic validation or Genesys Cloud job processing delay.
  • Fix: Increase timeout_seconds in run_synthetic_validation. Verify network connectivity between Genesys Cloud egress and your external endpoint. Check firewall rules for outbound HTTPS traffic.
  • Code Fix: Wrap httpx.Client calls in try-except blocks. Log latency metrics to identify network bottlenecks.
