Configuring Genesys Cloud EventBridge Filtering and SNS Fan-Out with Python
  • A Python script that subscribes to specific Genesys Cloud event types via the REST API and creates AWS EventBridge rules that filter those events and route them to dedicated SNS topics.
  • Uses the Genesys Cloud REST API and AWS boto3 SDK for infrastructure provisioning.
  • Python 3.9+ with requests and boto3.
  • Genesys Cloud OAuth 2.0 client credentials with eventbridge:manage and eventbridge:read scopes.
  • AWS IAM principal with events:CreateRule, events:PutTargets, sns:CreateTopic, and sns:Subscribe permissions.
  • Python 3.9 or later.
  • External dependencies: pip install requests boto3
Genesys Cloud requires OAuth 2.0 Client Credentials flow for API access. The script below implements a token manager that handles initial authentication, caches the access token, and implements a retry mechanism for 429 rate limit responses. AWS authentication relies on the standard boto3 credential chain (environment variables, IAM roles, or shared credentials file).
import os
import requests
from typing import Optional, Dict
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, environment: str = "mypurecloud.com"):
        self.client_id = client_id
        self.environment = environment
        self.base_url = f"https://{environment}"
        self.token_expiry: float = 0
        if self.access_token and time.time() < self.token_expiry:
            return self.access_token
        token_url = f"{self.base_url}/oauth/token"
        payload = {
            "client_id": self.client_id,
            "scope": "eventbridge:manage eventbridge:read"
        response = requests.post(token_url, data=payload)
        response.raise_for_status()
        token_data = response.json()
        self.token_expiry = time.time() + (token_data["expires_in"] - 60)
    def make_request(self, method: str, path: str, json_body: Optional[Dict] = None, max_retries: int = 3) -> requests.Response:
        url = f"{self.base_url}{path}"
        headers = {"Authorization": f"Bearer {self.get_access_token()}", "Content-Type": "application/json"}
            response = requests.request(method, url, headers=headers, json=json_body)
                self.access_token = None
                headers["Authorization"] = f"Bearer {self.get_access_token()}"
                retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                time.sleep(retry_after)
            return response
        raise RuntimeError(f"Max retries exceeded for {method} {path}")
Step 1: Subscribe to Genesys Cloud Event Types
Genesys Cloud pushes events to a single AWS EventBridge bus. You must explicitly subscribe to each event type you want to receive. The API uses PUT /api/v2/platform/eventbridge/events/{eventType}. The required scope is eventbridge:manage.
def subscribe_to_events(auth: GenesysAuthManager, event_types: list[str]) -> list[Dict]:
    subscribed = []
    for event_type in event_types:
        path = f"/api/v2/platform/eventbridge/events/{event_type}"
        body = {"enabled": True}
        response = auth.make_request("PUT", path, json_body=body)
        if response.status_code in (200, 201, 204):
            subscribed.append({"type": event_type, "status": "enabled"})
        else:
            raise ValueError(f"Failed to subscribe to {event_type}: {response.status_code} {response.text}")
    return subscribed
Expected response status: 204 No Content. The API does not return a body on success. A 403 Forbidden indicates missing eventbridge:manage scope. A 404 Not Found indicates the event type is not available in your Genesys Cloud region or tier.
Step 2: Provision SNS Topics for Fan-Out Routing
Each filtered event stream requires a dedicated SNS topic. The script creates topics named after the event type. AWS SDK handles idempotency automatically; calling create_topic with an existing name returns the existing ARN without error.
import boto3
def create_sns_topics(sns_client: boto3.client, event_types: list[str]) -> dict[str, str]:
    topic_arns = {}
        topic_name = f"genesys-cloud-{event_type.replace(' ', '-').lower()}"
        response = sns_client.create_topic(Name=topic_name)
        topic_arns[event_type] = response["TopicArn"]
        print(f"Provisioned SNS topic: {topic_name} -> {response['TopicArn']}")
    return topic_arns
Step 3: Create EventBridge Rules with Source Filtering
EventBridge rules filter incoming events using a JSON pattern. Genesys Cloud events always contain "source": "genesyscloud" and "detail-type": "<eventType>". The rule must match these fields to route traffic correctly.
def create_eventbridge_rules(events_client: boto3.client, event_types: list[str], role_arn: str) -> dict[str, str]:
    rule_arns = {}
        rule_name = f"genesys-filter-{event_type.replace(' ', '-').lower()}"
        event_pattern = {
            "source": ["genesyscloud"],
            "detail-type": [event_type]
        response = events_client.create_rule(
            Name=rule_name,
            EventPattern=str(event_pattern).replace("'", '"'),
            State="ENABLED",
            RoleArn=role_arn
        rule_arns[event_type] = response["RuleArn"]
        print(f"Created EventBridge rule: {rule_name} -> {response['RuleArn']}")
    return rule_arns
The RoleArn parameter must point to an IAM role with sns:Publish permission. The EventPattern must be a stringified JSON object. AWS rejects rules with invalid JSON syntax.
Step 4: Attach SNS Targets to EventBridge Rules
Rules do not route events until you attach targets. The put_targets API links the rule ARN to the SNS topic ARN. This completes the fan-out pipeline.
def attach_sns_targets(events_client: boto3.client, rule_arns: dict[str, str], topic_arns: dict[str, str]) -> list[Dict]:
    attached = []
    for event_type, rule_arn in rule_arns.items():
        target_id = f"sns-target-{event_type.replace(' ', '-').lower()}"
        response = events_client.put_targets(
            Rule=rule_arn,
            Targets=[
                    "Id": target_id,
                    "Arn": topic_arns[event_type],
                    "DeadLetterConfig": {
                        "Arn": topic_arns.get("genesys-cloud-dead-letter", None)
        if response["FailedEntryCount"] == 0:
            attached.append({"rule": rule_arn, "target": target_id, "status": "attached"})
        else:
            print(f"Failed to attach target for {event_type}: {response['FailedEntries']}")
    return attached
import os
import requests
import boto3
        payload = {
            return response
    subscribed = []
        else:
    return subscribed
    topic_arns = {}
    return topic_arns
    rule_arns = {}
        event_pattern = {"source": ["genesyscloud"], "detail-type": [event_type]}
            Name=rule_name,
            State="ENABLED",
            RoleArn=role_arn
    return rule_arns
    attached = []
            Rule=rule_arn,
            Targets=[{"Id": target_id, "Arn": topic_arns[event_type]}]
    return attached
    GENESYS_CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
    GENESYS_CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
    AWS_ROLE_ARN = os.getenv("AWS_EVENTBRIDGE_ROLE_ARN")
    if not all([GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, AWS_ROLE_ARN]):
        raise EnvironmentError("Missing required environment variables")
    auth = GenesysAuthManager(GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET)
    event_types = ["conversationCreated", "conversationUpdated", "conversationEnded"]
    print("Subscribing to Genesys Cloud events...")
    subscribe_to_events(auth, event_types)
    sns = boto3.client("sns", region_name="us-east-1")
    events = boto3.client("events", region_name="us-east-1")
    print("Creating SNS topics...")
    topics = create_sns_topics(sns, event_types)
    print("Creating EventBridge rules...")
    rules = create_eventbridge_rules(events, event_types, AWS_ROLE_ARN)
    print("Attaching SNS targets...")
    attach_sns_targets(events, rules, topics)
    print("Fan-out architecture configured successfully.")
  • Cause: Expired OAuth token or invalid client credentials. The Genesys Cloud API rejects tokens older than the expires_in window.
  • Fix: The GenesysAuthManager automatically refreshes tokens on 401 responses. Ensure your OAuth client has the eventbridge:manage scope assigned in the Genesys Cloud admin console.
  • Code Fix: Verify the get_access_token() method is called before every request. The retry loop in make_request handles token refresh automatically.
Error: 403 Forbidden
  • Cause: The OAuth client lacks the required scope, or the Genesys Cloud org does not have EventBridge integration enabled.
  • Fix: Navigate to Genesys Cloud Admin > Security > OAuth Clients. Edit the client and add eventbridge:manage and eventbridge:read. Confirm the EventBridge integration is active in Admin > Integrations > EventBridge.
  • Debugging: Run GET /api/v2/platform/eventbridge manually. A 403 confirms scope or integration status issues.
  • Cause: Genesys Cloud enforces rate limits per OAuth client. Bulk event subscriptions or rapid retries trigger throttling.
  • Fix: The make_request method implements exponential backoff with Retry-After header parsing. For high-volume deployments, space out API calls or implement a queue-based dispatcher.
  • Code Fix: The retry loop already handles this. Increase max_retries if your deployment requires higher tolerance.
Error: AWS ValidationException: Rule already exists
  • Cause: EventBridge rule names must be unique per AWS account and region. Re-running the script without cleanup triggers this error.
  • Fix: Use events.describe_rule(Name=rule_name) before creation, or implement idempotent rule creation by catching ClientError and checking error code.
  • Code Fix: Wrap create_rule in a try-except block that checks for ValidationException and skips creation if the rule exists.
