Configuring Dynamic Time-Zone Offset Adjustments in Genesys Cloud WFM Shift Scheduling for Multi-Regional Agent Pools
This guide details the architectural configuration required to manage shift scheduling for agent pools distributed across multiple time zones within Genesys Cloud WFM. You will configure the organization hierarchy, user-level time zone overrides, and shift template anchors to ensure the scheduling solver correctly interprets availability windows, handles Daylight Saving Time (DST) transitions, and aligns adherence calculations with local business hours.
By the end of this implementation, agents will see shifts rendered in their local time, the solver will optimize schedules against region-specific demand forecasts, and external schedule imports will maintain offset integrity without manual correction.
Licensing Requirements
- Genesys Cloud CX License: Standard or higher.
- Workforce Management (WFM) License: Mandatory. Specifically, the WFM Scheduling capability must be provisioned. The WFM Forecasting add-on is required if you intend to drive shift generation from demand forecasts rather than static templates.
Required Roles & Permissions
Access to the WFM configuration requires granular permissions. Assign the following permission strings to the implementation account:
Workforce Management > Schedule > EditWorkforce Management > Schedule > ViewWorkforce Management > Forecast > ViewAdministration > Organization > EditUsers > Edit(to configure user-level time zone overrides)
OAuth Scopes (API-Driven Implementation)
If you are pushing configurations via the Genesys Cloud Platform API or using an external scheduling middleware, your service account requires:
wfm:schedule:writewfm:schedule:readwfm:forecast:readusers:writeusers:view
External Dependencies
- Telephony/IVR Alignment: Your IVR schedules and call routing schedules must be time-zone aware. If the WFM shift is in
America/New_Yorkbut the IVR availability schedule defaults toUTC, you will experience adherence gaps during DST transitions. - Carrier/Trunk Time Zones: Ensure SIP trunk configurations respect local time for call recording retention policies and regulatory reporting.
1. Establishing the Baseline Time Zone Hierarchy
Genesys Cloud stores all temporal data in UTC at the database layer. The presentation layer and the scheduling solver apply offsets based on a hierarchy: Organization Default > Schedule Group Time Zone > User Personal Time Zone.
We must establish the Organization time zone as the “anchor” time zone for the scheduling engine. This is not the time zone of the agents; it is the time zone of the schedule object. For multi-regional deployments, we typically set the Organization time zone to the primary business unit or UTC to avoid solver bias toward a single region during optimization.
Configuration via API
We use the PATCH method to update the organization’s primary time zone. This ensures that any newly created schedule groups inherit the correct baseline.
HTTP Method: PATCH
Endpoint: /api/v2/organization
Payload:
"name": "Global Operations Org",
"description": "Primary WFM Organization",
"primaryTimeZoneId": "UTC",
"defaultCalendarTimeZoneId": "UTC"
Architectural Reasoning:
Setting the organization to UTC forces the scheduling solver to evaluate all constraints in a neutral time zone. When the solver optimizes a schedule, it converts agent availability and demand forecasts into UTC for comparison, then converts the resulting shifts back to the user’s local time for rendering. If you set the organization time zone to a specific region (e.g., America/Los_Angeles), the solver may inadvertently bias shift assignments toward that region during edge cases involving cross-day boundary shifts.
The Trap: The “Default User” Misconfiguration
The most common failure mode occurs when administrators create users via bulk import and neglect to specify the timeZoneId field. Genesys Cloud defaults new users to the Organization’s primary time zone.
Catastrophic Downstream Effect:
If the Organization is UTC and a user is left at UTC, but the user physically works in Europe/London, their shifts will render at UTC time. During British Summer Time, this creates a permanent one-hour drift. Adherence will show the agent as “Off Shift” during their actual working hours, and they will be penalized for unexcused absence while they are actively handling calls.
Mitigation:
Always enforce the timeZoneId during user creation. Use the PATCH /api/v2/users/{userId} endpoint to correct existing users:
"timeZoneId": "Europe/London"
2. Configuring Shift Templates with Explicit Time Zone Anchors
Shift templates define the structure of a work block (start time, end time, breaks). In a multi-regional pool, you cannot use a single “Standard Shift” template across all regions. You must anchor shift templates to specific time zones or configure the schedule to allow dynamic local time interpretation.
Strategy: Local Time Interpretation
When creating shifts via the WFM API, you must distinguish between startTime (absolute ISO 8601 UTC) and localStartTime (local time relative to the user or schedule time zone).
For dynamic scheduling, we recommend using localStartTime tied to the scheduleTimeZoneId. This allows the same shift template logic to apply to multiple regions without hardcoding UTC offsets, which break during DST.
HTTP Method: POST
Endpoint: /api/v2/wfm/schedules/shifts
Payload:
"scheduleId": "schedule-uuid-here",
"userId": "agent-uuid-here",
"scheduleTimeZoneId": "America/New_York",
"localStartTime": "2023-11-01T09:00:00.000",
"localEndTime": "2023-11-01T17:00:00.000",
"shiftType": "WORK",
"name": "Standard Day Shift - Local",
"notes": "Shift anchored to local New York time"
By specifying scheduleTimeZoneId and localStartTime, you instruct the WFM engine to calculate the UTC equivalent dynamically. On 2023-11-05 (DST transition in the US), the solver will automatically adjust the UTC start time for shifts scheduled after the transition. If you used absolute startTime in UTC, you would need to manually recalculate every shift payload for every agent during the DST transition week, which is operationally unsustainable at scale.
The Trap: Mixing Time Zones in a Single Schedule Group
A schedule group is a logical container for a cohort of agents. Genesys Cloud allows agents with different personal time zones to reside in the same schedule group. However, the schedule object itself has a master scheduleTimeZoneId.
The Failure Mode:
If you set the schedule group time zone to America/Chicago but assign an agent with a user time zone of America/Los_Angeles to that group, the solver will generate shifts relative to Chicago time unless you explicitly override the time zone per shift.
When the schedule is published, the agent in Los Angeles will see their shift times rendered in Chicago time (3 hours ahead). This creates confusion, reduces agent satisfaction, and causes adherence reporting errors because the WFM engine calculates adherence against the shift’s defined time, not the agent’s perception.
Mitigation:
Segment schedule groups by time zone. Create distinct schedule groups for each major time zone region (e.g., “US-East”, “US-West”, “EMEA”). Assign the schedule group’s scheduleTimeZoneId to match the dominant time zone of that region. If you must mix time zones in a single group, you must use the API to push shifts with explicit scheduleTimeZoneId overrides per shift, which significantly increases payload complexity and solver processing time.
3. Solving the DST Transition Edge Case in the Scheduler
Daylight Saving Time introduces two critical failure points: the “missing hour” (spring forward) and the “repeated hour” (fall back). The Genesys WFM solver must handle these transitions without generating invalid shift times or double-booking agents.
Spring Forward: The Missing Hour
When clocks spring forward, 2:00 AM becomes 3:00 AM. A shift scheduled for 2:30 AM local time does not exist.
Configuration:
The WFM solver is configured to “snap” invalid times to the next valid hour. However, this behavior can be disrupted if you use rigid external scheduling tools that push absolute UTC times without DST awareness.
API Payload for DST-Aware Shifts:
When pushing schedules programmatically, ensure you are not using a fixed offset (e.g., Z or +05:00). Use the scheduleTimeZoneId with a named time zone identifier.
"scheduleTimeZoneId": "Europe/Berlin",
"localStartTime": "2024-03-31T02:30:00.000",
"localEndTime": "2024-03-31T10:30:00.000"
When the solver processes this payload on 2024-03-31, it recognizes that 02:30 local time is invalid in Europe/Berlin. The engine will automatically adjust the shift to start at 03:30 local time (02:30 UTC). This preserves the intended shift duration relative to the business day, rather than preserving the absolute UTC start time, which would result in a shifted start relative to the agent’s local routine.
Fall Back: The Repeated Hour
When clocks fall back, 1:00 AM to 2:00 AM occurs twice. This creates ambiguity for 1:30 AM.
Configuration:
Genesys Cloud WFM defaults to interpreting repeated hours as the “first occurrence” (standard time). If you have a “Follow the Sun” operation with agents in multiple regions experiencing DST at different times, you must ensure your schedule imports specify whether the time is DST or Standard.
Mitigation via CSV Import:
If you are using CSV import for bulk scheduling, ensure the time format includes the offset or uses a DST-aware parser. The recommended format is ISO 8601 with offset: 2023-11-05T01:30:00.000-05:00. This removes ambiguity by explicitly stating the UTC offset at the moment of the shift.
The Trap: Forecasting Misalignment During DST
WFM Forecasting drives demand-based scheduling. If your historical call volume data is tagged with local time but your forecast is generated in UTC without proper offset mapping, the demand curve will shift by one hour during DST weeks.
The solver will assign shifts based on the misaligned forecast. You will have overstaffing during the first hour of the DST transition and understaffing during the second hour, leading to Service Level Agreement (SLA) breaches.
Mitigation:
Validate your historical data ingestion pipeline. Ensure that the wfm:forecast:read API returns demand segments aligned with the scheduleTimeZoneId. Use the WFM Data Quality reports to check for time zone anomalies in your historical wrap-up codes and call detail records (CDR).
4. Multi-Regional Schedule Groups and Availability Windows
Availability windows define when an agent is eligible to work. In a multi-regional pool, availability windows must be defined in the agent’s local time, not the schedule group’s time.
Configuration
When configuring user availability via the API, you must tie the availability window to the user’s personal time zone.
HTTP Method: POST
Endpoint: /api/v2/wfm/users/{userId}/availability
Payload:
"timeZoneId": "Asia/Tokyo",
"availability": [
"startTime": "2023-10-01T09:00:00.000",
"endTime": "2023-10-01T18:00:00.000",
"recurrence": "WEEKLY",
"recurrenceType": "MONDAY",
"localTime": true
The localTime: true flag ensures that the availability window repeats relative to the agent’s local clock. If you omit this or set it to false, the window repeats in UTC. For an agent in Tokyo, a 9 AM local availability window would drift by 9 hours if interpreted in UTC, eventually resulting in the solver offering shifts at 3 AM local time.
The Trap: Cross-Day Boundary Shifts in Follow-the-Sun Models
In global operations, a 12-hour shift starting at 10 PM local time crosses midnight. When the schedule is exported to an external system or imported into Genesys, the date boundary can cause the shift to be split into two separate days or lose the end time.
Failure Mode:
The import parser sees a shift starting on 2023-10-01 and ending on 2023-10-02. If the import template expects single-day shifts, the end time is truncated, resulting in an infinite shift or a shift that ends at midnight.
Mitigation:
Enforce ISO 8601 duration formats or explicit start/end timestamps in your import payloads. When using the WFM API to create shifts, always provide both localStartTime and localEndTime. Do not rely on duration fields for cross-day shifts.
"localStartTime": "2023-10-01T22:00:00.000",
"localEndTime": "2023-10-02T10:00:00.000"
This explicitly tells the solver that the shift spans two calendar days in the local time zone.
Edge Case 1: The “Ghost Shift” During DST Spring Forward
The Failure Condition:
Agents report that their scheduled shift disappears from the Agent Desktop calendar one hour before start time during the spring DST transition.
The Root Cause:
The shift was created with a rigid UTC start time that fell into the “missing hour.” The WFM engine marks the shift as invalid and removes it from the active schedule to prevent adherence errors.
The Solution:
Audit the shift creation logic. Ensure that shifts are generated using localStartTime with a named time zone identifier rather than absolute UTC. If you must use UTC, implement a pre-validation check that snaps times falling in the missing hour to the next valid hour (e.g., 2:30 AM → 3:30 AM) before pushing to the WFM API.
Edge Case 2: Cross-Day Boundary Shifts in Follow-the-Sun Models
A night shift starting at 10 PM and ending at 6 AM appears as two separate shifts in the WFM dashboard, or the end time is missing entirely.
The Root Cause:
The schedule import CSV or JSON payload uses a date-only field for the shift, causing the parser to assume the shift ends on the same day. The parser truncates the end time because 6 AM is interpreted as the previous day relative to the start date.
The Solution:
Update the import template to include full ISO 8601 timestamps for both start and end times. Verify that the localTime flag is set to true in the availability windows to ensure the solver respects the local midnight boundary.
Edge Case 3: Telephony Routing Misalignment
Adherence reports show agents as “On Shift” and “Available,” but inbound calls are routed to voicemail or an unavailable queue.
The Root Cause:
The IVR schedule and the call routing schedule are configured in the Organization’s default time zone (e.g., UTC), while the agent shifts are in a local time zone (e.g., America/New_York). During DST, the offset between the IVR schedule and the agent shift changes, causing the IVR to close before the agents are actually off shift.
The Solution:
Align all telephony schedules to the primary routing pool’s time zone. If you have multiple routing pools in different time zones, create separate IVR schedules for each pool and assign them based on the caller’s geographic location or the agent group’s time zone. Use the scheduleTimeZoneId in the IVR configuration to match the WFM schedule group’s time zone.
