Configuring Dead Letter Queue Routing for Failed Genesys Cloud Platform API Webhook Payloads using AWS SQS and Lambda Retry Policies
This guide details the architectural pattern for routing failed Genesys Cloud Platform API webhook payloads into an AWS SQS dead letter queue, with configurable Lambda retry policies and redrive mechanisms. When complete, your integration will automatically capture undeliverable or malformed events, prevent silent data loss, and provide a deterministic path for manual or automated reprocessing.
  • Genesys Cloud Licensing: CX 2 or CX 3 tier (Platform API access is included across all tiers, but production event subscription volume limits and advanced filtering require CX 2+).
  • Genesys Cloud Permissions: Application > Event Subscriptions > Edit, Application > Event Subscriptions > View, Application > Integrations > Edit.
  • OAuth Scopes: webhook:write, integration:write, analytics:read (if subscribing to analytics events), user:read (for user-centric event filters).
  • AWS Permissions: IAM execution role with SQS:CreateQueue, SQS:SendMessage, SQS:GetQueueAttributes, Lambda:InvokeFunction, Lambda:UpdateFunctionConfiguration, Lambda:GetFunctionConfiguration, CloudWatch:PutMetricData, DynamoDB:PutItem (for idempotency tracking).
  • External Dependencies: TLS 1.2 compliant HTTPS endpoint, AWS account with Lambda execution permissions, optional AWS API Gateway for payload normalization and rate limiting.
1. Provision the AWS SQS Dead Letter Queue and Redrive Policy
The dead letter queue serves as the immutable sink for payloads that exhaust all retry attempts. You must provision this queue before configuring the primary Lambda processor, as the Lambda configuration requires a valid target ARN.
Create a FIFO queue to preserve event ordering. Genesys Cloud events follow a causal timeline. Losing sequence order during replay introduces state corruption in downstream systems like CRM record updates or WEM session logging.
  "QueueName": "genesys-webhook-dlq.fifo",
  "FifoQueue": true,
  "ContentBasedDeduplication": true,
  "VisibilityTimeout": 300,
  "MessageRetentionPeriod": 1209600
Configure the redrive policy on your primary processing queue. The maxReceiveCount parameter dictates how many times a message is reprocessed before routing to the DLQ. Set this value based on your downstream system recovery window. A value of five is standard for transient database locks or rate limit throttling.
aws sqs set-queue-attributes \
  --queue-url https://sqs.us-east-1.amazonaws.com/123456789012/genesys-webhook-primary.fifo \
  --attributes '{"RedrivePolicy":"{\"deadLetterTargetArn\":\"arn:aws:sqs:us-east-1:123456789012:genesys-webhook-dlq.fifo\",\"maxReceiveCount\":\"5\"}"}'
The Trap: Configuring maxReceiveCount to match Lambda’s internal retry limit. AWS Lambda automatically retries failed invocations up to three times before routing to the DLQ. If you set SQS maxReceiveCount to three, messages experience six total attempts before dying. This masks true failure rates and inflates CloudWatch Throttles and Errors metrics, making root cause analysis impossible during incident response.
Architectural Reasoning: Separate compute failures from queue processing failures. Lambda internal retries handle transient function execution errors (memory spikes, cold start timeouts, runtime exceptions). SQS redrive retries handle downstream integration failures (database deadlocks, third-party API rate limits). Align maxReceiveCount with your downstream system’s expected recovery SLA, not with Lambda’s default retry behavior.
2. Configure the Primary Lambda Processor with Dead Letter Target and Retry Boundaries
The Lambda function receives the webhook payload, validates the schema, executes business logic, and handles errors. You must explicitly configure the DeadLetterConfig to point to your SQS DLQ ARN. Without this configuration, failed invocations silently drop after three retries.
Update the Lambda function configuration via the AWS CLI. The TargetArn must match your SQS DLQ exactly. Lambda will route any invocation that throws an unhandled exception or returns a non-zero exit code to this target.
aws lambda update-function-configuration \
  --function-name genesys-webhook-processor \
  --dead-letter-config '{"TargetArn":"arn:aws:sqs:us-east-1:123456789012:genesys-webhook-dlq.fifo"}' \
  --timeout 30 \
  --memory-size 256
Implement explicit error categorization in your Lambda handler. Distinguish between recoverable errors and fatal schema violations. Fatal errors should bypass retry logic entirely and route directly to the DLQ with a custom metadata tag.
import json
import boto3
import logging
sqs = boto3.client('sqs')
DLQ_URL = 'https://sqs.us-east-1.amazonaws.com/123456789012/genesys-webhook-dlq.fifo'
def lambda_handler(event, context):
        payload = event.get('body', event)
        if isinstance(payload, str):
            payload = json.loads(payload)
        validate_schema(payload)
        process_event(payload)
        return {'statusCode': 204, 'body': None}
    except ValidationError:
        # Fatal: malformed Genesys payload or missing required fields
        route_to_dlq(payload, error_type='SCHEMA_INVALID', bypass_retry=True)
        return {'statusCode': 400, 'body': 'Invalid event schema'}
    except TransientError:
        # Recoverable: downstream API 503, database lock, rate limit
        raise # Lambda will retry internally up to 3x, then route to DLQ
def route_to_dlq(payload, error_type, bypass_retry=False):
    message_group = payload.get('eventid', 'default')
    sqs.send_message(
        QueueUrl=DLQ_URL,
        MessageBody=json.dumps({
            'original_payload': payload,
            'error_type': error_type,
            'bypass_retry': bypass_retry,
            'timestamp': context.aws_request_id
        MessageGroupId=message_group,
        MessageDeduplicationId=context.aws_request_id
The Trap: Returning HTTP 200 from Lambda when downstream processing fails. Genesys Cloud interprets any 2xx response as successful delivery. If your Lambda returns 200 but your database write fails, Genesys Cloud stops retrying. The payload vanishes from the event stream. You lose the ability to replay the event because the producer considers it acknowledged.
Architectural Reasoning: Your Lambda must act as a strict gatekeeper. Return 204 No Content only when the entire processing pipeline completes successfully. Throw unhandled exceptions for transient failures. Explicitly catch and log schema violations, then route them to the DLQ with a SCHEMA_INVALID flag. This separation ensures Genesys Cloud’s retry mechanism triggers for transient network blips, while malformed payloads skip retry logic and enter the DLQ immediately for manual inspection.
3. Establish the Genesys Cloud Event Subscription and HTTPS Endpoint
Genesys Cloud delivers webhooks through Event Subscriptions. You must configure an Application Integration with a valid HTTPS endpoint, then create an Event Subscription definition that routes specific event types to that endpoint.
Create the Application Integration via the Platform API. The endpoint must support TLS 1.2 and return 204 within two seconds. AWS API Gateway or Lambda Function URLs are recommended to handle certificate management and payload validation.
POST /api/v2/integrations/applicationintegrations HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer <oauth_token>
  "name": "Webhook DLQ Integration",
  "description": "HTTPS endpoint for event subscription with DLQ routing",
  "endpointUrl": "https://api.gateway.example.com/genesys-webhook",
  "type": "HTTPS",
  "enabled": true
Create the Event Subscription definition. Subscribe only to the event types your system requires. Broad subscriptions (*) increase payload volume, trigger rate limits, and inflate DLQ routing costs.
POST /api/v2/analytics/eventsub/definitions HTTP/1.1
  "name": "Call and Interaction Events",
  "description": "Routes call and interaction events to AWS Lambda DLQ pattern",
  "eventTypes": ["call", "interaction", "conversation"],
  "filter": "eventtype in ['call', 'interaction', 'conversation']",
  "enabled": true,
  "retryPolicy": {
    "maxRetries": 50,
    "retryIntervalSeconds": 30
The Trap: Ignoring Genesys Cloud’s built-in retry policy and endpoint timeout thresholds. Genesys Cloud retries failed deliveries using exponential backoff up to 50 attempts over approximately one hour. If your endpoint takes longer than two seconds to respond, Genesys Cloud drops the connection and marks the delivery as failed. Your Lambda will never receive the payload, and the retry cycle begins immediately.
Architectural Reasoning: Genesys Cloud acts as an eventually consistent producer. Its retry policy is generous but finite. Your endpoint must acknowledge receipt instantly. Implement an async fan-out pattern: Lambda returns 204 immediately upon payload validation, then pushes the payload to an SQS processing queue. The downstream consumer reads from that queue at its own pace. This decouples Genesys Cloud’s strict timeout requirement from your business logic execution time. Cross-reference the WEM Real-Time Data Ingestion guide for similar async acknowledgment patterns.
4. Implement Payload Validation, Idempotency, and Replay Logic
DLQ payloads are immutable. Replay logic must handle duplicate deliveries, schema drift, and downstream state changes. You must implement strict idempotency checks before reprocessing any DLQ message.
Genesys Cloud includes a unique eventid in every payload. Use this field as your idempotency key. Store processed event IDs in DynamoDB with a TTL that exceeds your maximum replay window.
  "TableName": "genesys-event-idempotency",
  "KeySchema": [
    {"AttributeName": "eventid", "KeyType": "HASH"}
  "AttributeDefinitions": [
    {"AttributeName": "eventid", "AttributeType": "S"}
  "TimeToLiveSpecification": {
    "AttributeName": "expiry",
    "Enabled": true
Implement the DLQ consumer with idempotency validation. The consumer reads from the DLQ, checks DynamoDB, processes the event, and updates the idempotency table. If the event was already processed, the consumer deletes the DLQ message and skips execution.
import boto3
dynamodb = boto3.resource('dynamodb')
idempotency_table = dynamodb.Table('genesys-event-idempotency')
sqs_client = boto3.client('sqs')
def dlq_consumer():
    while True:
        response = sqs_client.receive_message(
            QueueUrl=DLQ_URL,
            MaxNumberOfMessages=10,
            WaitTimeSeconds=5
        messages = response.get('Messages', [])
        if not messages:
        for msg in messages:
            payload = json.loads(msg['Body'])
            event_id = payload.get('original_payload', {}).get('eventid')
            if not event_id:
                # Missing idempotency key, skip and delete
                sqs_client.delete_message(QueueUrl=DLQ_URL, ReceiptHandle=msg['ReceiptHandle'])
            # Check idempotency
            existing = idempotency_table.get_item(Key={'eventid': event_id})
            if 'Item' in existing:
                # Already processed, safe to delete
            # Process event
            process_event(payload['original_payload'])
            # Mark as processed with 30-day TTL
            idempotency_table.put_item(Item={
                'eventid': event_id,
                'processed_at': time.time(),
                'expiry': time.time() + 2592000
The Trap: Replaying DLQ messages without validating downstream system state. Genesys Cloud events often trigger state changes in CRMs, ticketing systems, or WEM session logs. If you replay a call.completed event after the CRM record has already been closed, you may reopen the record or trigger duplicate SLA timers. Blind replay corrupts business state.
Architectural Reasoning: DLQ replay must be conditional. Implement a state reconciliation layer before reprocessing. Query the downstream system for the current record state. If the record is already in the expected terminal state, log a reconciliation alert and delete the DLQ message. If the record is missing or in an intermediate state, proceed with replay. This pattern prevents cascade failures during bulk DLQ processing and aligns with PCI-DSS audit requirements for deterministic data reconciliation.
Edge Case 1: Payload Size Exceeds SQS and Lambda Execution Limits
AWS SQS enforces a 256 KB message size limit. AWS Lambda enforces a 6 MB payload limit for synchronous invocations. Genesys Cloud event subscriptions can attach large transcription payloads, interaction transcripts, or WEM session metadata that exceed these thresholds.
When a payload exceeds 256 KB, SQS rejects the message with an InvalidMessageContents error. The Lambda invocation fails, routes to the DLQ, and the DLQ itself rejects the message. The payload is permanently lost.
Solution: Implement a payload sharding pattern at the API Gateway or Lambda entry point. Hash large payloads and store them in S3 with a presigned URL. Replace the large payload in the SQS message with a lightweight reference object containing the S3 URI, event ID, and hash. The downstream consumer retrieves the full payload from S3 during processing. Configure S3 lifecycle policies to archive processed payloads after 90 days for audit compliance.
Edge Case 2: Genesys Cloud Certificate Rotation Breaking TLS Handshakes
Genesys Cloud rotates its root and intermediate certificates periodically. If your AWS endpoint relies on a pinned certificate bundle or an outdated OS trust store, TLS handshakes fail. Genesys Cloud receives a connection refused error, triggers its retry policy, and eventually abandons delivery. No payload reaches your Lambda.
Solution: Use AWS-managed endpoints (API Gateway, Lambda Function URLs) that automatically sync with Mozilla’s CA bundle. Disable certificate pinning in your custom infrastructure. Monitor CloudWatch TLS_Handshake_Failure metrics. Implement a synthetic health check that pings api.mypurecloud.com using the same TLS stack as your production endpoint. Alert when certificate expiration falls within 30 days. Cross-reference the Platform API Certificate Validation guide for automated trust store synchronization procedures.
Edge Case 3: Lambda Timeout Masking Downstream 503 Errors
Your Lambda function times out at 30 seconds. The downstream CRM API returns a 503 Service Unavailable after 25 seconds. Lambda throws a Task timed out error. AWS routes the payload to the DLQ. The DLQ consumer reprocesses the message. The CRM API remains down. The cycle repeats until maxReceiveCount exhausts.
Solution: Implement circuit breaker logic in your Lambda handler. Use a library like pybreaker or resilience4j to track downstream API health. When the error rate exceeds a threshold, open the circuit. Route payloads directly to the DLQ with a CIRCUIT_OPEN flag instead of retrying. Close the circuit after a configurable cooldown period. This prevents DLQ inflation during prolonged downstream outages and preserves retry capacity for transient errors.
