Configuring Cross-Cluster Data Replication for Genesys Cloud Analytics Reporting with Regional Data Residency Constraints
This guide configures the Analytics Data Replication feature to synchronize interaction metadata and selected media to a target Genesys Cloud cluster. The end result is a hardened replication pipeline that feeds a centralized reporting hub while strictly enforcing regional data residency boundaries by excluding restricted media types and sanitizing custom attributes before egress.
  • Licensing Tier: CX 1, CX 2, or CX 3 (Analytics is core, but cross-cluster replication may incur additional egress charges depending on the volume of replicated media).
  • Org Roles:
    • admin:analytics:view
    • admin:analytics:edit
    • admin:org:edit (Required to view cluster topology and verify target cluster linkage).
  • OAuth Scopes (for API configuration):
    • analytics:settings:write
    • analytics:settings:view
  • External Dependencies:
    • The target cluster must be provisioned and linked to the source organization by Genesys Professional Services or Customer Success. Cross-cluster replication is not a self-service topology change.
    • A documented Data Residency Policy defining which data types are permitted to traverse cluster boundaries.
1. Architectural Topology and Data Classification Audit
Before touching the configuration, we must establish the data gravity rules. Genesys Cloud clusters (US-1, US-2, EU-1, AU-1, AP-1) are physically isolated data centers. Replication creates a logical bridge that moves data across this isolation boundary.
We classify data into three tiers for replication eligibility:
  1. Tier 1: Interaction Metadata. Includes timestamps, queue IDs, agent IDs, wrap-up codes, and custom attributes. Low risk, high value for global reporting.
  2. Tier 2: Text-Based Media. Chat transcripts, social conversations, and email bodies. Medium risk due to potential PII in free-text fields.
  3. Tier 3: Binary Media. Voice recordings, screen recordings, and video. High risk, high bandwidth cost.
The Trap: Enabling “All Data Types” by default. The UI presents a convenient checkbox to replicate everything. If you enable voice recording replication from an EU-1 cluster to a US-1 reporting hub, you violate GDPR data transfer mechanisms unless you have an explicit Standard Contractual Clause in place and have performed a Transfer Impact Assessment. Furthermore, voice replication consumes massive egress bandwidth. A single hour of Opus-encoded audio is approximately 50MB. Multiply that by 1,000 concurrent interactions, and you will see your monthly network egress costs spike by an order of magnitude.
Architectural Decision: We explicitly disable binary media replication for any cross-region flow. We replicate only interactions and text-based media, relying on text redaction policies to sanitize PII before the data leaves the source cluster.
2. Configuring Replication Scope via Admin Console
We configure the replication scope to define what leaves the source cluster.
  1. Navigate to Admin > Analytics > Settings.
  2. Select the Data Replication tab.
  3. Locate the Target Cluster dropdown. Select the pre-provisioned target cluster (e.g., US-1-Reporting-Hub).
  4. Under Replication Settings, toggle Enable Data Replication to ON.
  5. In the Data Types section, configure the following:
    • Interactions: ON
    • Chat Transcripts: ON
    • Social Conversations: ON
    • Voice Recordings: OFF
    • Screen Recordings: OFF
    • Email Attachments: OFF (Attachments are binary and often contain sensitive documents).
  6. Set Retention Days to match the target cluster’s compliance window (e.g., 730 days for 2-year retention).
  7. Click Save.
The Trap: Misaligning Retention Policies. If the source cluster retains data for 730 days, but the target cluster is configured for 365 days, the replication stream will function, but the target cluster will silently purge data after one year. This creates a reporting discrepancy where global dashboards show missing historical data compared to regional dashboards. We always enforce the longer retention period on the target cluster to ensure the reporting hub is the authoritative archive.
3. Implementing Custom Attribute Sanitization via Architect
Interaction metadata includes Custom Attributes set by the Architect flow. These attributes often contain PII (e.g., customer_ssn, transaction_id, email_address). Replicating interactions replicates these attributes. We must sanitize this data before it reaches the analytics engine.
We use the Modify Interaction block in Architect to redact or remove sensitive attributes before the interaction is closed and queued for analytics replication.
  1. Open Architect and locate the main interaction handling flow.
  2. Before the End Interaction block, insert a Modify Interaction block.
  3. Configure the Attributes section:
    • Locate sensitive attributes (e.g., cust_email).
    • Set the value to a static redaction string (e.g., "REDACTED") or delete the attribute entirely if it is not required for analytics.
    • Example Configuration:
      • Attribute Name: cust_email
      • Action: Set
      • Value: "ANONYMIZED"
  4. Save the flow as a new version and activate.
The Trap: Relying solely on Analytics Redaction Policies for real-time reporting. Genesys provides an Analytics Redaction feature that can mask PII in transcripts. However, this redaction is asynchronous. The raw interaction metadata is replicated first, and redaction is applied in the background. If the target cluster queries the data immediately after replication, the PII may be visible in transit or temporarily stored in the target before the redaction job completes. By sanitizing at the Architect level, we ensure the data never leaves the source cluster in its sensitive form.
4. Automating Configuration Compliance via API
Manual configuration drift is a critical failure mode. Over time, engineers may enable voice replication for troubleshooting and forget to disable it. We enforce compliance by using the Genesys Cloud API to audit and correct the analytics settings.
We execute a PUT request to /api/v2/analytics/settings to enforce the desired state.
API Endpoint: PUT /api/v2/analytics/settings
OAuth Scope: analytics:settings:write
Payload Construction:
  "dataReplication": {
    "targetClusterId": "cluster-us-1-hub",
    "enabled": true,
    "replicatedDataTypes": [
      "interactions",
      "chatTranscripts",
      "socialConversations"
    "retentionDays": 730,
    "excludeVoiceRecordings": true,
    "excludeScreenRecordings": true,
    "excludeEmailAttachments": true
Implementation Script (Curl Example):
curl -X PUT "https://{your-org-domain}.mygen.com/api/v2/analytics/settings" \
  -H "Content-Type: application/json" \
  -H "Authorization: Bearer {your-access-token}" \
  -d '{
      "enabled": true,
        "interactions",
        "chatTranscripts",
The Trap: Overwriting Unrelated Analytics Settings. The PUT /api/v2/analytics/settings endpoint updates the entire analytics settings object. If you only send the dataReplication block in the payload, you may inadvertently reset other analytics configurations, such as queue-specific retention overrides or custom metric definitions. The payload must include all current analytics settings, with only the dataReplication block modified, or you must use a PATCH operation if the API supports partial updates. Genesys Cloud PUT operations are generally full-replace. We always fetch the current settings via GET /api/v2/analytics/settings, modify the replication object in memory, and then push the full object back.
Edge Case 1: Replication Latency Impacting WFM Forecasting
Failure Condition: Workforce Management (WFM) reports on the target cluster show interaction volumes that are lower than the source cluster for the current day.
Root Cause: Cross-cluster replication is asynchronous and eventually consistent. Replication jobs run on a scheduled interval (typically every 15-30 minutes, depending on load and cluster capacity). Data queried on the target cluster is always stale by at least one replication cycle.
Solution: Do not use the target cluster for real-time intraday WFM forecasting. WFM must pull historical and intraday data directly from the source cluster API. The target cluster is strictly for historical trend analysis, global capacity planning, and post-shift reporting. If WFM must use the target cluster, implement a 24-hour data buffer in all forecasting algorithms to ensure the replication lag is absorbed.
Edge Case 2: PII Leakage via Custom Attributes in Screen Pops
Failure Condition: A screen pop integration pushes a CRM record to the agent desktop. The Architect flow captures the screen pop data as an interaction attribute. This attribute is replicated to the target cluster, bypassing the manual sanitization blocks because it is set dynamically by an external system.
Root Cause: External integrations can inject arbitrary data into interaction attributes. If the integration sets crm_customer_id or medical_record_number, this data flows into analytics and replicates.
Solution: Implement a global Data Redaction Policy in Admin > Security > Data Redaction. Configure a policy that applies to all interactions and targets common PII patterns (emails, SSNs, credit cards). Additionally, audit the Architect flows that consume screen pops to ensure they map only non-sensitive identifiers to interaction attributes. Use a hash function for external IDs if traceability is required without exposing the raw value.
Edge Case 3: Storage Quota Exhaustion on Target Cluster
Failure Condition: Replication jobs fail with 403 Forbidden or Quota Exceeded errors. Analytics data stops flowing to the target cluster.
Root Cause: The target cluster has a finite storage allocation for analytics data. If the source cluster generates a massive spike in interactions (e.g., a marketing campaign or outage driving call volume), the replication volume can rapidly consume the target cluster’s storage quota.
Solution: Monitor the analytics_storage_usage metric in Genesys Cloud Analytics. Configure an alert to trigger when storage utilization exceeds 80%. Implement a dynamic retention policy on the target cluster that reduces retention for older data when quotas are approached. Alternatively, request a storage quota increase from Genesys Support before launching high-volume replication.
