Configuring AWS S3 Dual-Storage Integrations for Call Recordings
This guide details the architectural configuration of AWS S3 dual-storage for Genesys Cloud CX call recordings. You will provision an IAM execution role, enforce bucket policies aligned with Genesys Cloud CIDR ranges, deploy the external storage connection via REST API, and align retention lifecycles across both environments. The end result is a fault-tolerant recording pipeline that maintains native Genesys Cloud analytics compatibility while preserving a compliant, encrypted copy in your AWS tenant.
  • Licensing: Genesys Cloud CX 1, CX 2, or CX 3 base license. Dual Storage requires the Recordings feature enabled and the External Storage add-on. WEM (Workforce Engagement Management) licenses are recommended if you plan to run speech analytics on the Genesys native copy.
  • Permissions:
    • Genesys Cloud: Integration > External Storage > Edit, Recording > Recording > Read, Architect > Flow > Edit
    • AWS: IAM role creation, S3 bucket management, KMS key management, CloudWatch Logs access
  • OAuth Scopes: integration:write, integration:read, recording:read, organization:read
  • External Dependencies: AWS account with cross-account or same-account IAM permissions, AWS KMS CMK (Customer Managed Key), Genesys Cloud organization ID, and a documented CIDR allowlist for your region.
1. AWS IAM Role & S3 Bucket Architecture
Dual storage operates on a push model. Genesys Cloud processes the raw call media, applies metadata, and initiates an authenticated PUT request to your designated S3 bucket. The architecture requires an IAM role that Genesys Cloud can assume, or an IAM user with access keys that you inject into the connection profile. Role assumption is the enterprise standard because it eliminates long-lived credential rotation and enables CloudTrail audit trails.
Create an IAM role with a trust policy that allows the sts:AssumeRole action. Genesys Cloud uses a service principal for authentication. The trust policy must reference the Genesys Cloud AWS account ID and role path. You will find the exact account ID in the Genesys Cloud External Storage configuration wizard, but the structure remains consistent.
  "Version": "2012-10-17",
  "Statement": [
      "Effect": "Allow",
      "Principal": {
        "AWS": "arn:aws:iam::GENESYS_CLOUD_ACCOUNT_ID:role/external-storage-service-role"
      "Action": "sts:AssumeRole",
      "Condition": {
        "StringEquals": {
          "sts:ExternalId": "YOUR_GENESYS_ORGANIZATION_ID"
Attach an IAM policy to this role that grants minimal S3 and KMS permissions. Over-provisioning triggers compliance failures and increases blast radius during credential compromise.
  "Statement": [
      "Effect": "Allow",
      "Action": [
        "s3:PutObject",
        "s3:PutObjectAcl",
        "s3:ListBucket",
        "s3:GetBucketLocation",
        "s3:GetObject",
        "s3:DeleteObject"
      "Resource": [
        "arn:aws:s3:::your-recording-bucket",
        "arn:aws:s3:::your-recording-bucket/*"
      "Effect": "Allow",
      "Action": [
        "kms:GenerateDataKey",
        "kms:Decrypt",
        "kms:DescribeKey"
      "Resource": "arn:aws:kms:REGION:ACCOUNT_ID:key/CMK_ID"
Configure the S3 bucket policy to enforce encryption in transit and at rest, and to restrict access to Genesys Cloud IP ranges. Genesys Cloud publishes region-specific CIDR blocks. You must update the bucket policy quarterly or implement an automated script that pulls from the Genesys Cloud IP ranges JSON feed.
  "Statement": [
      "Sid": "EnforceSSLOnly",
      "Effect": "Deny",
      "Principal": "*",
      "Action": "s3:*",
      "Resource": [
      "Condition": {
        "Bool": {
          "aws:SecureTransport": "false"
      "Sid": "AllowGenesysCloudPush",
      "Effect": "Allow",
      "Principal": {
      "Action": "s3:PutObject",
      "Resource": "arn:aws:s3:::your-recording-bucket/recordings/*",
      "Condition": {
        "IpAddress": {
          "aws:SourceIp": ["GENESYS_CIDR_BLOCK_1", "GENESYS_CIDR_BLOCK_2"]
The Trap: Configuring bucket versioning without aligning object lifecycle rules to the Genesys Cloud retention window. S3 versioning preserves deleted objects indefinitely if you do not set a Noncurrent Version Expiration rule. This causes storage costs to compound exponentially and breaks compliance audits that require deterministic deletion after the retention period expires.
Architectural Reasoning: We enforce bucket versioning because call recordings are legal artifacts. If an agent or supervisor accidentally deletes a recording in Genesys Cloud, the dual-storage copy must remain immutable until the retention policy triggers. We pair versioning with a lifecycle rule that transitions noncurrent versions to Glacier Deep Archive after 90 days and expires them after the maximum compliance window. This balances legal hold requirements with cost optimization.
2. Genesys Cloud External Storage Connection Configuration
Once the AWS side is provisioned, you register the connection in Genesys Cloud. You can use the Admin UI, but the REST API provides deterministic deployment and version control for infrastructure-as-code pipelines. The endpoint requires a JSON payload that defines the connection type, authentication method, bucket path, and encryption parameters.
POST https://api.mypurecloud.com/api/v2/externalstorage/connections
Authorization: Bearer <OAUTH_TOKEN>
  "name": "AWS S3 Dual Storage - Prod Recordings",
  "description": "Primary dual-storage target for Genesys Cloud CX call recordings",
  "type": "S3",
  "status": "ACTIVE",
  "settings": {
    "accessKeyId": "IAM_USER_ACCESS_KEY_OR_ROLE_CREDENTIALS",
    "secretAccessKey": "IAM_USER_SECRET_KEY",
    "bucketName": "your-recording-bucket",
    "region": "us-east-1",
    "pathPrefix": "recordings/",
    "encryption": {
      "type": "AWS_KMS",
      "keyArn": "arn:aws:kms:us-east-1:ACCOUNT_ID:key/CMK_ID"
    "storageMode": "DUAL"
The storageMode field is critical. Setting it to DUAL instructs Genesys Cloud to retain the native recording blob while pushing a synchronized copy to S3. Setting it to PRIMARY moves the recording out of Genesys Cloud storage entirely after successful upload.
After creating the connection, run the validation endpoint to verify authentication, bucket accessibility, and encryption key permissions.
POST https://api.mypurecloud.com/api/v2/externalstorage/connections/{connectionId}/validate
  "testType": "FULL"
The Trap: Selecting PRIMARY storage mode during initial configuration. Primary storage deletes the Genesys Cloud native copy immediately after the S3 upload succeeds. This breaks native transcription pipelines, WEM quality monitoring, and Architect recording playback nodes. The platform cannot run speech analytics on an external blob without additional middleware.
Architectural Reasoning: We mandate DUAL storage for all production deployments. Native recordings remain accessible to Genesys Cloud services, which guarantees low-latency playback for supervisors, uninterrupted WEM transcription jobs, and seamless integration with Speech Analytics. The S3 copy serves as a compliance archive, disaster recovery target, and long-term retention repository. This separation of duties aligns with the principle of least privilege and prevents analytics pipeline failures during storage provider outages.
3. Recording Routing & Metadata Tagging in Architect
Dual storage does not automatically apply business logic to recording creation. You must configure Architect flows to determine which interactions generate recordings, how they are named, and what metadata tags accompany them. The recording rule node accepts dynamic tokens that map to S3 key prefixes.
Configure the Recording Rule node in your IVR or Agent flow. Set the recording type to Call or Screen depending on your channel. Enable the External Storage toggle and select your connection profile. Define the file path pattern using Genesys Cloud expression tokens.
recordings/{yyyy}/{mm}/{dd}/{conversation_uuid}.{format}
The platform replaces these tokens at runtime. The conversation_uuid guarantees uniqueness. The date partitioning enables S3 lifecycle policies to operate efficiently without scanning the entire bucket.
You must also configure metadata tagging if your compliance framework requires it. Genesys Cloud pushes recording metadata to S3 via a sidecar JSON file when you enable the Include Metadata option in the connection settings. The metadata payload contains agent ID, supervisor ID, queue name, start/end timestamps, and recording duration.
  "conversationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
  "recordingId": "rec-9876543210",
  "startTime": "2024-01-15T14:32:00Z",
  "endTime": "2024-01-15T14:35:42Z",
  "durationSeconds": 222,
  "agentId": "agent-jdoe-001",
  "queueId": "queue-support-us",
  "channel": "voice",
  "format": "wav",
  "externalStoragePath": "recordings/2024/01/15/a1b2c3d4-e5f6-7890-abcd-ef1234567890.wav"
The Trap: Hardcoding static directory paths or omitting date partitioning tokens. Static paths cause file collisions when multiple agents record simultaneously. S3 does not support true directories, only key prefixes. Without date partitioning, lifecycle rules must evaluate every object in the bucket during each execution cycle, which increases API costs and introduces evaluation delays.
Architectural Reasoning: We enforce date-partitioned key prefixes because S3 lifecycle rules evaluate objects based on last modified timestamps and key patterns. Partitioning by year, month, and day allows lifecycle rules to target specific prefixes with granular precision. This reduces API call volume, accelerates transition to Glacier, and simplifies forensic searches during compliance audits. The platform expression engine evaluates these tokens at recording initialization, so there is zero runtime penalty.
4. Lifecycle Alignment & Compliance Guardrails
Dual storage introduces two independent retention engines. Genesys Cloud manages native recording retention through Admin > Recordings > Retention Policies. AWS S3 manages external copy retention through Lifecycle Rules. Misalignment between these two systems creates orphaned metadata, compliance gaps, and storage bloat.
Configure the Genesys Cloud retention policy to match your regulatory requirement. For PCI-DSS environments, the standard is 24 months. For HIPAA, the standard is 6 years. Set the policy to Delete after the retention window expires. Enable the Notify on Deletion webhook to trigger downstream cleanup jobs.
Configure the S3 Lifecycle rule to mirror the Genesys Cloud policy. Use the Transition action to move objects to Standard-IA after 30 days, Glacier after 90 days, and Glacier Deep Archive after 180 days. Set the Expiration action to match the Genesys Cloud retention window exactly.
  "Rules": [
      "ID": "RecordingRetentionPolicy",
      "Status": "Enabled",
      "Filter": {
        "Prefix": "recordings/"
      "Transitions": [
          "Days": 30,
          "StorageClass": "STANDARD_IA"
          "Days": 90,
          "StorageClass": "GLACIER"
          "Days": 180,
          "StorageClass": "DEEP_ARCHIVE"
      "Expiration": {
        "Days": 730
      "NoncurrentVersionExpiration": {
        "NoncurrentDays": 30
Enable S3 Object Lock in compliance mode if your audit framework requires write-once-read-many (WORM) protection. Object Lock prevents deletion or overwriting until the retention period expires. This satisfies SEC Rule 17a-4 and CFTC requirements for immutable records.
The Trap: Setting the S3 expiration window shorter than the Genesys Cloud retention policy. The external copy deletes before the native copy, leaving Genesys Cloud metadata pointing to a non-existent S3 object. This breaks cross-reference audits and triggers false positive compliance alerts.
Architectural Reasoning: We enforce identical retention windows across both platforms to maintain referential integrity. The Genesys Cloud recording metadata object contains a pointer to the S3 path. If the S3 object expires first, the metadata becomes stale. We align expiration down to the day and implement a CloudWatch EventBridge rule that triggers a Lambda function to validate pointer integrity weekly. This validation job scans Genesys Cloud recording metadata, checks S3 object existence via HEAD requests, and logs discrepancies to CloudWatch Logs for audit review.
Edge Case 1: Cross-Region S3 Propagation Delay
The failure condition occurs when Genesys Cloud reports a successful dual-storage sync, but the S3 object is not immediately visible in the target region. This happens when you configure the S3 bucket in a different AWS region than the Genesys Cloud tenant region. The platform pushes to the bucket endpoint, but S3 cross-region replication or DNS resolution introduces latency.
The root cause is DNS caching and S3 eventual consistency during initial object propagation. Genesys Cloud validates the upload via an S3 HEAD request immediately after PUT. If the object has not yet propagated to the endpoint the platform queries, the validation fails and retries.
The solution is to deploy the S3 bucket in the same AWS region as your Genesys Cloud tenant. If cross-region deployment is mandatory for data sovereignty, configure S3 Cross-Region Replication (CRR) with a replica bucket in the Genesys Cloud region. Point the dual-storage connection to the replica bucket. This ensures low-latency validation while maintaining the primary copy in your compliance region.
Edge Case 2: KMS Key Alias Resolution Failure
The failure condition manifests as AccessDenied errors during the S3 PUT operation, even when IAM policies grant kms:GenerateDataKey and kms:Decrypt. The error log shows KeyId mismatch or Alias not found.
The root cause is using a KMS key alias in the Genesys Cloud connection payload instead of the full key ARN. Genesys Cloud resolves aliases at configuration time, not at runtime. If the alias points to a disabled key or a key in a different account, the push fails. Additionally, cross-account KMS usage requires the key policy to explicitly grant kms:Decrypt and kms:GenerateDataKey to the Genesys Cloud IAM role.
The solution is to replace the alias with the full KMS key ARN in the encryption.keyArn field. Verify the key policy contains a statement granting the necessary permissions to the Genesys Cloud service principal. Enable KMS key rotation and configure the connection to reference the ARN, which remains stable across rotations.
Edge Case 3: Metadata Mismatch During Transcription Sync
The failure condition appears when WEM transcription jobs succeed for the native recording but fail to locate the corresponding metadata JSON file in S3. The transcription engine reports MetadataNotFound or PathMismatch.
The root cause is a discrepancy between the file path pattern defined in the Architect recording rule and the path pattern expected by the WEM metadata parser. If you modify the path prefix in the external storage connection after recordings have already been generated, the metadata files are written to a new prefix while existing recordings retain the old prefix. The parser cannot reconcile the mismatch.
The solution is to lock the path prefix pattern at deployment and never modify it retroactively. If a path change is required, create a new external storage connection, update the Architect recording rule to reference the new connection, and implement a migration job that copies existing S3 objects to the new prefix using AWS DataSync or a custom Lambda function. Update the WEM configuration to monitor both prefixes during the transition window.
