# Configuring Advanced Alerting in Genesys Cloud CX Using Custom Event Filters and PagerDuty Integration for Critical Queue Overflow Scenarios
## What This Guide Covers
This guide details the configuration of advanced alerting in Genesys Cloud CX, specifically leveraging custom event filters to trigger PagerDuty incidents when queues experience critical overflow conditions. The end result is a proactive alerting system that notifies on-call personnel only when queues are genuinely overloaded, minimizing alert fatigue and ensuring timely intervention to maintain service levels.
## Prerequisites, Roles & Licensing
- **Licensing Tier:** Genesys Cloud CX 2.0 or higher (required for Custom Event Filters). WEM (Workforce Engagement Management) add-on is not required for this configuration but beneficial for correlating with agent availability.
- **Permissions:**
- `Administration > System Settings > Custom Event Filters > View & Edit`
- `Administration > Integrations > PagerDuty > View & Edit`
- `Reporting & Analytics > Historical Reporting > View` (for validating filter behavior)
- `Telephony > Queues > View & Edit` (to understand queue metrics)
- **OAuth Scopes:** N/A - PagerDuty integration utilizes API keys.
- **External Dependencies:** Active PagerDuty account with an integration key. A pre-defined escalation policy and on-call schedule in PagerDuty are essential.
## The Implementation Deep-Dive
### 1. Defining the Custom Event Filter
The core of this solution is the Custom Event Filter. Genesys Cloud CX's native alerting only provides basic queue metrics. We need a filter to detect *sustained* overflow, not just a momentary spike. We will create a filter that triggers when the average queue length over a 5-minute window exceeds a defined threshold, and the percentage of abandoned calls exceeds a second threshold.
Navigate to **Administration > System Settings > Custom Event Filters**. Click **Add Event Filter**.
- **Name:** `Critical Queue Overflow - PagerDuty`
- **Description:** `Triggers PagerDuty incident on sustained queue overflow and high abandon rate.`
- **Event Type:** `Queue`
- **Event Subtype:** `QueueMetrics`
- **Filter Expression:** (This is the crucial part)
```json
"type": "AND",
"rules": [
"field": "averageQueueLength",
"operator": ">",
"value": 10 // Adjust threshold based on queue capacity
"field": "abandonedCallPercentage",
"operator": ">",
"value": 0.15 // 15% abandon rate - adjust based on SLA
"type": "TIME_WINDOW",
"duration": 300 // 5 minutes in seconds
The Trap: A common mistake is setting the TIME_WINDOW too short. A 60-second window will trigger alerts for momentary spikes, causing alert fatigue. 300 seconds (5 minutes) provides a reasonable buffer to identify sustained issues. Also, failing to adjust the value fields based on queue capacity and SLA will result in either too many false positives or a delayed response to genuine overflows.
2. Configuring the PagerDuty Integration
Next, we configure the integration to send events from the Custom Event Filter to PagerDuty.
Navigate to Administration > Integrations > PagerDuty. Click Add PagerDuty Integration.
- Integration Name:
Genesys Cloud - Queue Overflow - Integration Key: Enter your PagerDuty integration key.
- Service ID: Select the PagerDuty service you want to associate these alerts with.
- Event Type Mapping: This is where we link the Custom Event Filter to PagerDuty.
- Event Filter Name: Select
Critical Queue Overflow - PagerDuty. - PagerDuty Event Type:
trigger. This tells PagerDuty to create a new incident. - Severity:
critical. - Details to include: We will leverage custom details to provide contextual information in PagerDuty. Add the following:
- Key:
queueName - Value:
{{queue.name}}(This uses the Genesys Cloud expression language) - Key:
averageQueueLength - Value:
{{queue.averageQueueLength}} - Key:
abandonedCallPercentage - Value:
{{queue.abandonedCallPercentage}}
- Key:
The Trap: Incorrectly mapping the Event Filter will result in PagerDuty not receiving any alerts. Double-check that the names match exactly. Also, forgetting to set the Severity can lead to alerts being buried in noise.
3. Testing and Validation
After configuration, thorough testing is critical.
- Simulate Queue Overflow: Generate sufficient call volume to exceed the defined thresholds in the Custom Event Filter. Use a call volume testing tool or manually initiate calls.
- Verify PagerDuty Incident Creation: Confirm that a new incident is created in PagerDuty with the correct Severity and custom details.
- Validate Filter Behavior with Historical Reporting: Run a Historical Report in Genesys Cloud CX, filtering by QueueMetrics and the relevant queues. Examine the data to confirm that the Custom Event Filter is triggering as expected based on queue length and abandon rate.
Edge Case 1: Intermittent Network Issues
- Failure Condition: Genesys Cloud CX loses connectivity to PagerDuty, causing alerts to not be delivered.
- Root Cause: Network outages, DNS resolution problems, or PagerDuty service disruptions.
- Solution: Implement a monitoring solution to track the health of the Genesys Cloud CX - PagerDuty integration. Consider using a health check endpoint within PagerDuty to confirm connectivity. Configure Genesys Cloud CX to retry sending events if a connection error occurs.
Edge Case 2: Incorrect Queue Assignment
- Failure Condition: Alerts are triggered for the wrong queues or contain incorrect queue names.
- Root Cause: The
queue.nameexpression is not resolving correctly, likely due to a configuration error or incorrect queue IDs. - Solution: Double-check the queue ID mapping in the PagerDuty integration. Verify that the queue names are consistent between Genesys Cloud CX and PagerDuty. Test the expression language using the Genesys Cloud CX Developer Tools to confirm it resolves to the expected value.
Edge Case 3: Alert Storming During Short Outages
- Failure Condition: A brief, intermittent outage causes a flurry of alerts as the queue rapidly fluctuates above and below the defined thresholds.
- Root Cause: The
TIME_WINDOWis not sufficiently long to filter out transient issues. - Solution: Increase the duration of the
TIME_WINDOWto smooth out short-term fluctuations. Consider adding hysteresis to the filter – a different threshold for triggering an alert versus clearing an alert. For example, the alert triggers when the average queue length exceeds 10, but only clears when it drops below 5.
