Configuration Conversion Wizard issue ???????
i am trying to fetch the configuration server database from POSTGRESql engine in the Business Edition Premise solution using Configuration Conversion Wizard but i can’t access it succefully.
the required info by POSTGRESql are :
host = db-host
port =
dbengine = postgres
dbserver =
dbname = genesys
username = postgres
password = Postgre$0
i don’t know the name of the dbserver and it’s port no because the cong=figuration server is 8.5 and it doesn’t have explicit dbserver…so how can i find these info???
thanks in advance guys.
Use Postgre GUI?
Without DBServer CCW can’t connect to DB. You will need to setup new instance of DBServer even if you will not use this instance in production environment (CS-DB connection).
dear all thanks for reply
cav: i can’t find any postgresql GUI in the business edition, shall i download one and use it,if i shall do so, can you please guide me to the download link of the proper version.
borkokrz: how can i use a dbserver with ccw with a configuration server 8.5 that doesn’t need any dbserver to access database.?
kindly note the following:
all the dbservers version is 8.1.301.11 the configuration server is 8.5.100.17
the configuration conversion wizard version 8.5.000.0
Best regards
Sorry but that info is too basic, google it, there are tons of info around
thanks Cav for reply
but believe me i am asking basic and many questions to avoid any error in the future.
and i still wait for your answer to the versions conflict questions.
best regards
Regarding Postgre GUI installation, Google is your friend.
You need to install a DBServer that supports Postgre, install the latest version just in case.
Thanks so much Cav
