config db-direct-connection
Is there a way to configure DAP for statserver to access a database directly using the section db-direct-connection?
Genesys documentation doesn’t provide details, other jdbc config are related either to infomart, GRS…
Any help is appreciated
Best regards
That section should be configured on StatServer application object to be able to use SS without a Genesys DBserver.
So, add the section on SS, configure the DAP that is connected to SS as a normal DAP for DBServer use (not jdbc) and install correct db drivers on the server as described on:
https://docs.genesys.com/Documentation/Options/Current/RTME/Stat_Server-db-direct-connection
