Conference call issue
We are facing one issue which is quite strange somehow as it hasnt been recurring for every call.
Issue Description:
I made a call to help line and i got the IVR , transfered the call from IVR to agent.
Call routed to agent station 1007.
Agent take me on conference with IVR and when the conference completed IVR should hang up and i had to connect with the agent.
But my call was transfered to other station when the conference ended.
This issue has been happening very frequently and callcenter operations has been quite disturbed due to this issue as a single customer has been verified 5 times during his single call as every time his call was transfered to other agent once conference completed…
16:46:31.640 Trc 04541 RequestInitiateConference received from [456] (00000008 AgentDesktop 10.154.65.41:3253)
message RequestInitiateConference
AttributeThisDN ‘1007’
AttributeConnID 007001b3b995c471
AttributeOtherDN ‘2060’
AttributeUserData [156] 00 06 00 00..
‘Customer_NIC’ ‘5440005144695’
‘FindCustomer’ ‘True’
‘StateDefinition’ ‘[U]Enter%20TPIN’
‘Conn_ID’ ‘007001b3b995c471’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeReferenceID 77
16:46:31.640 Int 04543 Interaction message “RequestInitiateConference” received from 456 (“AgentDesktop”)
@16:46:31.6400 [gctmi] Distributing request RequestInitiateConference
16:46:32.500 Trc 04541 RequestCompleteTransfer received from [456] (00000008 AgentDesktop 10.154.65.41:3253)
message RequestCompleteTransfer
AttributeTransferConnID 007001b3b995c48c
AttributeReferenceID 81 …
And what should we get out of this message and a half? :slight_smile:
Bob,
I would check code of IVR application. It seems to me that IVR doesn’t recognize conference call and treats it as standard inbound call that has to be routed to an agent.
check the IVR code its work fine …actually this event happend frequently but not all calls..we use ADT application
So are you sure that IVR is really hanging up the call? Did you check all logfiles (IVR serve/IVR driver/TServer)?
E.
Yesterday i was again tested ,which analyze that ..when agent transfer the call to IVR for tpin verification its work fine for 3 to 4 calls,after that when agent transfer ,the customer hear the hold music instaed of IVR menu for enter tpin ,at the sme time agent listen the ivr menu of tpin…can any one advice this happen frquently after 3 to 4 calls
And what do you see in TServer/IVR logfiles? Do all three or four calls have the same event flow there or does they differ? The best would be you post the log here.
We had somewhat similar kind of issue. When checked we found Cache was not getting clear from the IVR. Just try, it might help in your case also.
Also, if you are using Stream Manager for playing the hold music, check whether there is space in the tream manager server.
Mohit
thanks mohit..i will do let you know..
ecki and mohit and all
plz send me your email add i will send logs in your email id..problem to upload the logs
@16:40:57.3430 [0] 7.5.009.00 distribute_event: message EventPartyAdded
AttributeEventSequenceNumber 00000000001f1c65
AttributeTimeinuSecs 343000
AttributeTimeinSecs 1246444857 (16:40:57)
AttributeExtensions [91] 00 05 02 00..
‘UCID’ bin: FF FF FF FF.. (len=8)
‘OrigDN-1’ ‘2095’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘NumOfOrigDNs’ 3
AttributeThirdPartyDNRole 5
AttributeThirdPartyDN ‘1006’
AttributeOtherDNRole 4
AttributeOtherDN ‘2109’
AttributeThisDNRole 3
AttributeThisDN ‘1006’
AttributeANI ‘2001’
AttributeDNIS ‘1006’
‘StateDefinition’ ‘[E]Enter%20TPIN’
‘Conn_ID’ ‘007001b3b99746d4’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallUUID ‘QIOVJ2IBC14VH1P1O48QU7K4BO00C8BP’
AttributeConnID 007001b3b99746d4
AttributeCallID 229
AttributeCallType 2
AttributeNetworkCallID 4294967295
AttributeCallState 2
AttributeAgentID ‘5475’
AttributeEventSequenceNumber 00000000001f1c66
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘NumOfOrigDNs’ 3
AttributeThisDN ‘2095’
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeThisQueue ‘2060’
AttributeEventSequenceNumber 00000000001f1c67
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘NumOfOrigDNs’ 3
AttributeThisDN ‘2061’
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1c68
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘NumOfOrigDNs’ 3
AttributeThisDN ‘2084’
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
@16:40:57.3430 [0] 7.5.009.00 distribute_event: message EventReleased
AttributeEventSequenceNumber 00000000001f1c69
AttributeRefConnID 007001b3b99746d4
AttributeDNIS ‘2060’
AttributeUserData [178] 00 07 00 00..
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeTransferConnID 007001b3b99746d4
AttributeCallUUID ‘QIOVJ2IBC14VH1P1O48QU7K4BO00C8GT’
AttributeConnID 007001b3b9974700
AttributeCallID 229
AttributeCallType 4
AttributeThisDN ‘SwitchG3::’
message RequestUpdateUserData
AttributeThisDN ‘2109’
AttributeUserData [224] 00 09 00 00..
‘StateDefinition’ ‘[E]Enter NID:’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Current_Call_Duration’ ‘000008true’
‘Last_Menu_Option’ ‘BA0000’
‘Status_Flag’ ‘1’
‘FindCustomer’ ‘true’
AttributeReferenceID 567
@16:41:09.3120 [0] 7.5.009.00 distribute_event: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1c9c
AttributeTimeinuSecs 312000
AttributeTimeinSecs 1246444869 (16:41:09)
AttributeThirdPartyDN ‘2109’
AttributeANI ‘2001’
AttributeUserData [242] 00 0A 00 00..
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1c9d
AttributeANI ‘2001’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1c9e
AttributeANI ‘2001’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1c9f
AttributeANI ‘2001’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
@16:41:09.3120 [0] 7.5.009.00 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1ca0
AttributeANI ‘2001’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
message RequestInitiateTransfer
AttributeOtherDN ‘2901’
AttributeReferenceID 568
@16:41:09.3590 [0] 7.5.009.00 distribute_event: message EventHeld
AttributeEventSequenceNumber 00000000001f1ca1
AttributeTimeinuSecs 359000
AttributeExtensions [19] 00 01 02 00..
AttributeANI ‘2001’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 229
AttributeCallType 2
AttributeCallState 0
@16:41:09.3750 [0] 7.5.009.00 distribute_response: message EventDialing
AttributeEventSequenceNumber 00000000001f1ca2
AttributeTimeinuSecs 375000
AttributeOtherDNRole 2
AttributeThisDNRole 1
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallUUID ‘QIOVJ2IBC14VH1P1O48QU7K4BO00C8HA’
AttributeConnID 007001b3b9974703
AttributeCallID 232
AttributeCallType 4
logs continue
AttributeTransferConnID 007001b3b9974703
AttributeReferenceID 569
@16:41:09.3900 [0] 7.5.009.00 distribute_event: message EventQueued
AttributeEventSequenceNumber 00000000001f1ca3
AttributeTimeinuSecs 390000
AttributeOtherDNRole 1
AttributeThisDNRole 2
AttributeThisDN ‘2901’
AttributeDNIS ‘2901’
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 232
AttributeCallType 4
AttributeThisQueue ‘2901’
@16:41:09.4210 [0] 7.5.009.00 send_to_client: message EventError
(Reorder/denial)
AttributeEventSequenceNumber 00000000001f1ca4
AttributeTimeinuSecs 421000
AttributeErrorCode 629
AttributeCallID 229
@16:41:11.1400 [0] 7.5.009.00 distribute_event: message EventReleased
AttributeEventSequenceNumber 00000000001f1ca5
AttributeTimeinuSecs 140000
AttributeTimeinSecs 1246444871 (16:41:11)
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 232
AttributeCallType 4
@16:41:11.6400 [0] 7.5.009.00 distribute_event: message EventAbandoned
AttributeEventSequenceNumber 00000000001f1ca6
AttributeTimeinuSecs 640000
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 232
AttributeCallType 4
AttributeReliability 0
16:41:11.6400 [0] 7.5.009.00 distribute_event: message EventReleased
AttributeEventSequenceNumber 00000000001f1ca7
‘Menu_Option’ ‘2’
‘Customer_Name’ ‘’
‘ANI’ ‘2001’
‘Status_Flag’ ‘1’
AttributeCallID 232
AttributeCallType 4
message RequestDeleteUserData
AttributeReferenceID 144
16:41:16.1400 [0] 7.5.009.00 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1cc8
AttributeTimeinSecs 1246444876 (16:41:16)
AttributeANI ‘2001’
AttributeCallID 229
AttributeCallType 2
@16:41:16.1400 [0] 7.5.009.00 distribute_event: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1cc9
AttributeANI ‘2001’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cca
AttributeANI ‘2001’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ccb
AttributeANI ‘2001’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ccc
AttributeANI ‘2001’
AttributeCallID 229
AttributeCallType 2
message RequestAttachUserData
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeReferenceID 145
@16:41:16.1400 [0] 7.5.009.00 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1ccd
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cce
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ccf
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd0
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd1
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeReferenceID 146
AttributeEventSequenceNumber 00000000001f1cd2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd3
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd4
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd5
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cd6
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeReferenceID 147
@16:41:16.1870 [0] 7.5.009.00 distribute_event: message EventHeld
AttributeEventSequenceNumber 00000000001f1cd7
AttributeTimeinuSecs 187000
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
@16:41:16.2180 [0] 7.5.009.00 distribute_response: message EventDialing
AttributeEventSequenceNumber 00000000001f1cd8
AttributeTimeinuSecs 218000
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallUUID ‘QIOVJ2IBC14VH1P1O48QU7K4BO00C8HO’
AttributeConnID 007001b3b9974707
AttributeCallID 236
AttributeCallType 4
@16:41:16.2650 [0] 7.5.009.00 distribute_event: message EventQueued
AttributeEventSequenceNumber 00000000001f1cdb
AttributeTimeinuSecs 265000
AttributeOtherDN ‘1006’
AttributeThisDN ‘2060’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
@16:41:16.2650 [0] 7.5.009.00 distribute_event: message EventDiverted
AttributeEventSequenceNumber 00000000001f1cdc
AttributeThirdPartyDNRole 2
AttributeThirdPartyDN ‘2118’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
@16:41:16.2650 [0] 7.5.009.00 distribute_event: message EventRinging
AttributeEventSequenceNumber 00000000001f1cdd
AttributeThisDN ‘2118’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
@16:41:16.3900 [0] 7.5.009.00 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1cde
AttributeReferenceID 148
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
@16:41:16.3900 [0] 7.5.009.00 distribute_event: message EventAttachedDataChanged
AttributeEventSequenceNumber 00000000001f1cdf
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
AttributeEventSequenceNumber 00000000001f1ce0
AttributeReferenceID 149
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
AttributeEventSequenceNumber 00000000001f1ce1
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 236
AttributeCallType 4
@16:41:16.6870 [0] 7.5.009.00 distribute_event: message EventPartyAdded
AttributeEventSequenceNumber 00000000001f1ce2
AttributeTimeinuSecs 687000
AttributeExtensions [172] 00 09 02 00..
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘ConsultDN-1’ ‘1006’
‘ConsultDN-2’ ‘2118’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ce3
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ce4
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ce7
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ce9
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2084’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cea
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ceb
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cec
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1ced
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2084’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
@16:41:16.7030 [0] 7.5.009.00 distribute_event: message EventPartyAdded
AttributeEventSequenceNumber 00000000001f1cee
AttributeTimeinuSecs 703000
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cef
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf0
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf1
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2084’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf2
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2061’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf3
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2084’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf4
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2109’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1cf5
‘OrigDN-1’ ‘1006’
‘OrigDN-2’ ‘2095’
‘OrigDN-3’ ‘2061’
‘OrigDN-4’ ‘2084’
‘NumOfOrigDNs’ 4
‘NumOfConsultDNs’ 2
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
@16:41:46.2650 [0] 7.5.009.00 distribute_event: message EventReleased
AttributeEventSequenceNumber 00000000001f1db4
AttributeTimeinSecs 1246444906 (16:41:46)
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1db5
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1db7
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1db9
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1dbb
AttributeOtherDN ‘2084’
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
AttributeEventSequenceNumber 00000000001f1dbd
AttributeANI ‘2001’
‘Status_Flag’ ‘0’
‘Menu_Option’ ‘2’
AttributeCallID 229
AttributeCallType 2
any update…
You do undestand that this is a forum, we are not paid at all to give support, we all who contribute here do it on some free time we may find. If your issue is so urgent you should open a ticket with Genesys. We do our best to help but sometimes projects and other responsabilities left us without time to interact with the forum as we may wish.
i can understand because we all are professional ,and i didnt mean that as you undesrtand any ways …
Mohit
i have done your suggestion (delete ivr cache but still issue not resolve_
still not resolve this issue could any budy help me put
Hey mate,
I send you email, but you did not send me back your logfiles. Did you get my email?
e.
yes i have got ur email and i have already reply u ..have u got reply
Hi Bob,
Yes I got your email.
So, I looked at them and I think that you have some serious issues with your IVR. There are many IVR ports (2119, 2118, 2117… for example) which from time to time just do not answer calls and therefore calls are abandoned by customer after while, or sometimes calls are answered, but then there is no evidence that calls are handled by IVR and eventually calls are released with hardware error. (connids 007001b3b9974c56 , 007001b3b9974cbc,007001b3b9974c50)
I also found that some ports from time to time are experiencing problem to transfer calls back and from this moment the event flow is quite weird (007001b3b9974c18,007001b3b9974bcb). These are issues which you probably are not aware of and are not probably causing directly your issues, but it could be that there is some ACD switch configuration in place, which take calls back experiencing issues in IVRs and rerouted again as new call on entry routepointcalls. This means that calls send to IVR for final treatment and then supposed to be released by IVR are routed back to agents as new calls.
So I really recommend you to have pretty serious look at your IVR configuration from software as well as hardware perspective by your VAR who sold you this solution .
By the way, what is the IVR you have there?
Cheers.
e.
TDM base IVR…
