Composer Help
I m trying get it going with composer, and i see most of the learning for composer is based on the multimedia routing, is there any pointer where i can see an example of voice application development. Also is there a good guide that would let us go over the process of learning the composer based routing.
Any directions regarding this is highly appreciated.
Thanks.
Nope, just training or testing.
While you develop check the block help file. Will help a lot.
Also on composer there are some templates with samples on it, maybe you can try to check those as well.
