Composer Debugger NOT Working.
My Composer Debugger suddenly stop Working, used to work.
error msg is unable to fetch content, but I can access to this vxml link from host where MCP installed.
fetch_end Fail (Unable to fetch content):http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
any thoughts?
following is the related log:
2012-08-01T14:21:24.327 Std 20004 EROR 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:667 Request failed: uri=http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml?session.connection.callidref=74d8fe80e7c3d3890d6f6d81866f01a3%4010.8.142.147&session.connection.local.uri=sip%3Adialog%4010.36.141.193%3A5070%3Bvoicexml%3Dhttp%3A%2F%2F10.8.142.147%3A8080%2FHelloWorld%252Fsrc-gen%252FMain.vxml%3Bgvp.debug%3Dtrue&session.connection.originator=remote&session.connection.remote.uri=sip%3A4001%4010.8.142.147%3A50601, result=7
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:769 HTTP request completed
2012-08-01 14:21:24.327 DBUG 00000000-00000000 3444 01F00000 FMResponseData.cxx:405 Received fetch completed, response code=0
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:1416 Response is not cacheable
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMUserRequest.cxx:468 Request completed, sending RequestCompleteNotify.
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMThreadQueue.cxx:1179 Processing ReleaseRequest
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99-00000000 3444 01F00000 FMUserRequest.cxx:127 Deleting Request
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1888 ProcessEvents() Started
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1905 ProcessEvents() Event type [1], session id: [00E90101-10003A99]
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1319 HandleFetchEvent(): Process state: 6, response code: 0, error: Unable to fetch content, uri: http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
2012-08-01T14:21:24.327 Int 50043 00E90101-10003A99 4460 fetch_end Fail (Unable to fetch content):http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml
2012-08-01T14:21:24.327 Std 40027 EROR 00E90101-10003A99 4460 0C0003F9 Fetch error on url http://10.8.142.147:8080/HelloWorld/src-gen/Main.vxml, reason Unable to fetch content, callid 00E90101-10003A99
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4460 0C000000 VXMLSession.cxx:1894 ProcessEvents() Event queue was empty
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4340 0C000000 AppEventBase.h:61 app.VXML-NG AMEVENT_VXML_DIALOG_PREPARED - failed fetch document
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4340 0C000000 AppCallLeg.h:125 Call Leg CallInReject
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4992 01C00000 CMMsgBase.h:183 cmapi.msg: CM_MSG_CALLLEG_INB_REJECT - CallObjID == 00E90101-10003A99; Binding State == 1
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4992 01C00000 CMCallLeg.C:2317 CMCallLeg::DisconnectLine - pszDiscContentType=, pszDiscContent=
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIP.C:1429 In CallDisconnect
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIP.C:1471 LMCallSIP::CallDisconnect - strContentType=, strContent=
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIPStack.C:203 LMCallSIP::SendResponse for ID Headers
2012-08-01 14:21:24.327 DBUG 00E90101-10003A99 4880 02800000 LMCallSIPStack.C:225 LMCallSIP::SendResponse - X-Genesys-GVP-Session-ID: FF06AD46-33A8-40FC-3F90-F7CF6E7AB1F0
2012-08-01 14:21:24.327 DBUG 00000000-00000000 4880 08500000 VGSIPTransportMgr.cxx:3443 VGSIPTransportMgr::ResolveDNS for 10.8.142.147:50601
2012-08-01T14:21:24.327 Trc 33009 INFO 00000000-00000000 4880 02800FA1 Response sent: SIP/2.0 500 Server Internal Error
Via: SIP/2.0/TCP 10.8.142.147:50601;branch=z9hG4bK-353730-808ef3c9be399b53315fd88cf86c15a4
From: “Debugger” sip:4001@10.8.142.147:50601;tag=JLG1yz3nZnV1
To: “dialog” sip:dialog@10.36.141.193:5070;voicexml=http://10.8.142.147:8080/HelloWorld%2Fsrc-gen%2FMain.vxml;gvp.debug=true;tag=8C7EF499-FCAD-4035-9ABE-6B410CA97910
CSeq: 1 INVITE
Develop Tomcat is started? Composer has integrated Tomcat which have provided debug calls of VXML files on app srv.
Yes, as I said I can access to this vxml link from host where MCP installed.
Tomcat is the one installed by default when Composer was installed.
What version of MCP do you use?
Release 8.1.4 and lower contained a “bug”,which causes failure of fetching
8.1.504.86, latest one.
And can you open/access VXML URI from other host? I mean that is a network trouble maybe
Yes, it looks like it’s network issue. but I did try to access to vxml link from other hosts.
But My understanding is it’s enough that VXML can be accessed from MCP host, for MCP is vxml intepreter.
